发表于 2009-5-1 14:16:31
实验用0一20V数控电源,程序升级,具体看源程序注释.
注意下载时把EEPROM存储器文件DC04.EEP也下载到单片机.
点击此处下载 ourdev_441307.rar(文件大小:4K) (原文件名:程序04.rar)
'/ 这是一个M8控制LM317的直流稳压电源 /
'/ 输出电压 0-20V 连续调节 /
'/ 最大输出电流 1.5A /
'/ 截止型过电流保护 0-1.5A 连续调节 /
'/ 这次更新作出以下改进: /
'/ 1.修正了电源启动/停止按键容易翻转的问题,增加了按键音 /
'/ 2.增加了EEPROM存储器数据保存功能,上电后直接到保存的电压、电流值。 /
'/ junsheng427@126.com 200712-20090501 /
'/ 吕军省 天津大港 /
'//当前电源用这个20090501///
$regfile = "m8def.dat"
$crystal = 8000000
Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = Portb.5 , E = Portb.0 , Rs = Portd.2
Config Lcd = 16 * 2
Config Adc = Single , Prescaler = Auto , Reference = Internal
'定义ADC为单次运行模式,转换时钟-自动,内部参考电压
Config Timer1 = Pwm , Pwm = 10 , Compare A Pwm = Clear Down , Prescale = 1
'PWM1A配置,用于数模转换,
Ddrb.1 = 1 'PWM1A输出端子
'/////定义所需要变量 ///////////////////////////////////////////////////////////
Dim V_dc As Long , A_dc As Long , W As Long
Dim V1_dc As Word , A1_dc As Word , A As Word , C As Word , A1 As Word
Dim V1 As String * 5
Dim V2 As String * 5
Dim C1 As String * 5
Dim Vdeep As String * 5
Dim Veep As Word
Dim Aeep As Word
Dim N As Byte , B2 As Byte , B3 As Byte , B4 As Byte , B5 As Byte , K As Byte
'/////初始化设置////////////////////////////////////////////////////////////////
Ddrd.3 = 0 '定义PD.3~PD.7为输入,上拉电阻有效 .按键初始化
Ddrd.4 = 0
Ddrd.5 = 0
Ddrd.6 = 0
Ddrd.7 = 0
Portd.3 = 1
Portd.4 = 1
Portd.5 = 1
Portd.6 = 1
Portd.7 = 1
Start Timer1
Start Adc
Readeeprom Veep , 2 '上电时读取存贮的电压值
Readeeprom Aeep , 5 '上电时读取存贮的电流值
A1 = Veep
C = Aeep
Veep = Veep * 2
Vdeep = Str(veep)
Vdeep = Format(vdeep , " 0.00")
A = 0
W = 0
Ddrc.4 = 1 '初始化风扇控制
Portc.4 = 0
Ddrc.3 = 1 '初始化继电器控制
Portc.3 = 0
Ddrc.2 = 1
Portc.2 = 0
Cls
Cursor Off
Locate 1 , 10
Lcd "[" ; Vdeep ; "V"
'/////主程序////////////////////////////////////////////////////////////////////
Do
Pwm1a = A
N = 1
V1_dc = 0
A1_dc = 0
V_dc = 0
A_dc = 0
For N = 1 To 30 'ADC采样30次
V1_dc = Getadc(0)
V_dc = V_dc + V1_dc 'ADC的原始值累加
A1_dc = Getadc(1)
A_dc = A_dc + A1_dc
Next
V_dc = V_dc / 30
A_dc = A_dc / 30
V_dc = 2600 * V_dc
V_dc = V_dc / 1023
A_dc = 2600 * A_dc
A_dc = A_dc / 1430
If A >= 451 Then Portc.3 = 1 Else Portc.3 = 0 '继电器控制
If A < 451 Then W = 1400 Else W = 2800 '风扇控制
W = W - V_dc
W = W * A_dc
If W > 400000 Then Portc.4 = 1 Else Portc.4 = 0
Gosub Lp_lcd
Gosub Lp_key
If A_dc >= C Then '截止型电流保护
Waitms 500
If A_dc >= C Then
A1 = A
A = 0
Locate 1 , 10
Lcd " OC "
Gosub Mu
End If
End If
Loop
End
'/////显示处理//////////////////////////////////////////////////////////////////
Lp_lcd:
V1 = Str(v_dc)
V1 = Format(v1 , " 0.00") '数字转换为字符串,确定小数点
V2 = Str(a_dc)
V2 = Format(v2 , "0.000")
C1 = Str(c)
C1 = Format(c1 , "0.000")
Locate 1 , 1
Lcd "U=" ; V1 ; "V"
Lowerline
Lcd "I=" ; V2 ; "A <"
Locate 2 , 11
Lcd C1 ; "A"
Return
'/////按键处理//////////////////////////////////////////////////////////////////
Lp_key:
If Pind.3 = 0 And A = 0 Then '启动
Waitms 50
A = A1
Locate 1 , 10
Lcd " ON "
Sound Portc.5 , 100 , 1000
K = 1 '加入这个变量是为了是为了在电源关闭时禁止电压调节
Bitwait Pind.3 , Set '等待直到位设置为 set(1)
End If
End If
If Pind.3 = 0 And A > 1 Then '停止
Waitms 50
A1 = A
A = 0
Locate 1 , 10
Lcd " OFF "
Waitms 20
K = 0
End If
End If
'/////保存掉电数据///////////////////////////////////////////////////////////
'当电源停止时,按下“电压+”按键,存贮当前电压、电流设置。
If Pind.4 = 0 And K = 0 Then
Waitms 50
Writeeeprom A1 , 2 '存电压
Writeeeprom C , 5 '存电流
End If
End If
If Pind.4 = 1 Then B2 = 0 '电压+
If Pind.4 = 0 And K = 1 Then
Waitms 50
If A < 1023 Then
A = A + 1
B2 = B2 + 1
If B2 > 20 And A < 1013 Then
A = A + 10
End If
End If
End If
End If
If Pind.5 = 1 Then B3 = 0 '电压-
If Pind.5 = 0 And K = 1 Then
Waitms 50
If A > 1 Then
A = A - 1
B3 = B3 + 1
If B3 > 20 And A > 10 Then
A = A - 10
End If
End If
End If
End If
If Pind.6 = 1 Then B4 = 0 '电流+
If Pind.6 = 0 Then
Waitms 50
If Pind.6 = 0 Then
If C < 1500 Then
C = C + 1
B4 = B4 + 1
If B4 > 20 And C < 1480 Then
C = C + 20
End If
End If
End If
End If
If Pind.7 = 1 Then B5 = 0 '电流-
If Pind.7 = 0 Then
Waitms 50
If Pind.7 = 0 Then
If C > 1 Then
C = C - 1
B5 = B5 + 1
If B5 > 20 And C > 20 Then
C = C - 20
End If
End If
End If
End If
Return
'报警声音///////////////////////////////////////////////////////////////////////
Mu:
Waitms 20
Waitms 20
Return
$eeprom
$eepromhex
Shuzu:
Data 0 , 0 , 0 , 0 , 0 , 232 , 3 |
