终于用PWM做成了DA
a_bb 发表于 2008-3-31 16:40 ST MCU ←返回版面 举报该贴
首先谢谢各位的建议与支持,感谢ing,当然也离不开自己的探索!
之前不能得到正确的波形,主要是混淆了PWM频率和信号的采样频率,错误地使用了用DAC做输出时的8K频率,导致滤波电路无法正常工作.
以下的程序我使用TIMER4 channel3作为PWM输出,并使用TIMER2做8K定时去更新PWM占空比,输出了1KHz的正弦波。
TIM4 Configuration: Output Compare Inactive Mode:
TIM4CLK = 72 MHz, Prescaler = 0, TIM2 counter clock = 72 KHz
TIM4 frequency = TIM4CLK/(TIM1_Period + 1) = 70 KHz
void TIMER4_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
/* Time base configuration */
TIM_TimeBaseStructure.TIM_Period = 1023;
TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_Channel = TIM_Channel_3;
TIM_OCInitStructure.TIM_Pulse = 512;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInit(TIM4, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM4, ENABLE);
/* TIM4 enable counter */
TIM_Cmd(TIM4, ENABLE);
void TIMER2_Configuration(void)
TIM2 Configuration: Output Compare Inactive Mode:
TIM2CLK = 72 MHz, Prescaler = 1000, TIM2 counter clock = 72 KHz
TIM2 frequency = TIM2CLK/(TIM2_Period + 1) = 8KHz
TIM_TimeBaseStructure.TIM_Period = 8;
TIM_TimeBaseStructure.TIM_Prescaler = 1000-1;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
/* Prescaler configuration */
// TIM_PrescalerConfig(TIM2, 1000-1, TIM_PSCReloadMode_Immediate);
/* Output Compare Active Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Inactive;
TIM_OCInitStructure.TIM_Channel = TIM_Channel_1;
TIM_OCInitStructure.TIM_Pulse = 8;
TIM_OCInit(TIM2, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM2, ENABLE);
/* TIM IT enable */
TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE);
/* Set PC.06, PC.07, PC.08 and PC.09 pins */
GPIO_SetBits(GPIOC, GPIO_Pin_6);
/* TIM2 enable counter */
TIM_Cmd(TIM2, ENABLE);
u16 SINDATA[8]=
512,874,1024,874,
512,149,0,149
* Function Name : TIM2_IRQHandler
* Description : This function handles TIM2 global interrupt request.
* Input : None
* Output : None
* Return : None
void TIM2_IRQHandler(void)
static u16 i=0;
static u8 j=0;
if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
/* Clear TIM2 Capture Compare1 interrupt pending bit*/
TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
if(i==0)
i = 1;
GPIO_ResetBits(GPIOC, GPIO_Pin_6);
i = 0;
// /* Set the Pulse value */
TIM4->CCR3 = SINDATA[j++];
if(j == 8)j = 0;
