12FG
12-Channel 2048 2.4GHz Computer System
Taking twelve-channel control to the next level!
When you improve upon all of the best that Futaba 2048 technology has to offer, you have the 12FG – one serious system for discerning R/C pilots. From the state-of-the-art receiver to the capacity to store memory for a whopping 1,882 models, the 12FG has the features and functions to position itself far above the competition. And because it's from Futaba, you can fly with confidence, knowing that the industry's finest research and development is behind you.
![](http://cache.amobbs.com/bbs_upload782111/files_9/ourdev_250622.jpg)
(原文件名:futk9275-04a.jpg)
12FG Specifics:
G3 2048 resolution
30 model memory — up to 1,882 models with a 1GB SD card
Combines airplane, glider, and helicopter programming
Supports 13 wing types, 3 tail types, and
8 heli swash types
8 total flight conditions (7 plus the default)
Variable Dual Rates (VDR)
Servo grouping for servo synchronization
Digital trims on all 4 main channels
7.2V 1700mAh NiMH transmitter battery
Battery charging jack
Ergonomic rubber grips
12FG System Overview:
Quad-bearing gimbals
27 preset model types, with built-in shortcuts
Newly designed “joystick” button and Dial-N-Key editing for easier menu navigating
Ultra-precise tuning in .5% increments
Front-mounted slider switches for easier access
255 x 196 LCD Screen with Adjustable Contrast
You get all this with the 12FG:
R6014FS 2048 Receiver
Heavy-Duty Switch Harness
7.2V 1700mAh NiMH Transmitter Battery
1500mAh Receiver NiCd Battery
Futaba Orange Transmitter Neck Strap
![](http://cache.amobbs.com/bbs_upload782111/files_9/ourdev_250623.jpg)
(原文件名:futl7644.jpg)
Futaba advanced technology allows the R6014FS to be the first 2.4GHz receiver able to utilize all 14 channels. It retains G3 2048 resolution and Futaba Real Time ResponseTM from the 72 MHz version.
![](http://cache.amobbs.com/bbs_upload782111/files_9/ourdev_250624.jpg)
(原文件名:futk9200-sdcard.jpg)
Not only does SD Card Data Storage & Transfer give you incredible memory*, it works with an included Futaba Utility File that further upgrades programs and functions.
*A 1GB card is required for maximum memory capacity. SD Card sold separately. |
