发表于 2008-4-8 22:56:58
void *memcpy(void *dest,void *src, unsigned char n)
for the TINY memory model.
void *memcpy(void *dest,void *src, unsigned int n)
for the SMALL memory model.
Copies n bytes from src to dest. dest must not overlap src, else use memmove.
Returns a pointer to dest.
void *memcpyf(void *dest,void flash *src, unsigned char n)
void *memcpyf(void *dest,void flash *src, unsigned int n)
Copies n bytes from src, located in FLASH, to dest. Returns a pointer to dest.
void *memccpy(void *dest,void *src, char c, unsigned char n)
void *memccpy(void *dest,void *src, char c, unsigned int n)
Copies at most n bytes from src to dest, until the character c is copied.
dest must not overlap src.
Returns a NULL pointer if the last copied character was c or a pointer to dest+n+1.
void *memmove(void *dest,void *src, unsigned char n)
void *memmove(void *dest,void *src, unsigned int n)
Copies n bytes from src to dest. dest may overlap src.
void *memchr(void *buf, unsigned char c, unsigned char n)
void *memchr(void *buf, unsigned char c, unsigned int n)
Scans n bytes from buf for byte c.
Returns a pointer to c if found or a NULL pointer if not found.
signed char memcmp(void *buf1,void *buf2, unsigned char n)
signed char memcmp(void *buf1,void *buf2, unsigned int n)
Compares at most n bytes of buf1 with buf2.
Returns <0, 0, >0 according to buf1<buf2, buf1=buf2, buf1>buf2.
signed char memcmpf(void *buf1,void flash *buf2, unsigned char n)
signed char memcmpf(void *buf1,void flash *buf2, unsigned int n)
Compares at most n bytes of buf1, located in SRAM, with buf2, located in FLASH.
void *memset(void *buf, unsigned char c, unsigned char n)
void *memset(void *buf, unsigned char c, unsigned int n)
Sets n bytes from buf with byte c. Returns a pointer to buf.
以上是CVAVR的HELP中提供的函数,在里面找一下. |
