马老师讲得很精彩,以前也做过时钟,但比起马老师的这个,差远了。忍不住发贴,让初学的朋友借鉴。
以下是原理图及程序:
1![](http://cache.amobbs.com/bbs_upload782111/files_9/ourdev_226435.JPG)
File name : time
Chip type : AT89C51
Program type : Application
Clock frequency : 12.00000MHZ
Memory model : Small
External SRAM size : 0
DataStack size : I don't know
#include <reg51.h>
#define uint unsigned int
#define key_state_0 0 //按键状态
#define key_state_1 1
#define key_state_2 2
sbit key_input = P1^0; // 按键输入
const uchar led[] = {0x3F,0x06,0x5b,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F}; //0—9数字码
const uchar position[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf}; //动态扫描位置码
uchar time[3]={59,58,23}; //时间
uchar dis_buff[6]; //显示缓存数据
uchar posit; //扫描位置
uchar key_stime_counter,time_counter;//时间计数单元
bit posit_on,key_stime_ok,time_1s_ok;//秒闪烁标志,按键扫描标志,1秒标志
void display(void);
uchar key_read(void);
void time_to_buffer(void);
void _time(void);
/*==============display=============*/
void display(void)
P2 = 0xff;
P0 = led[dis_buff[posit]]; //显示数值
if(posit_on&&(posit==2||posit==4))//秒闪烁
P0 |= 0x80;
P2 = position[posit]; //动态扫描
if(++posit>=6)
posit = 0;
/*=============key read============*/
static uchar key_state = 0;
uchar key_press,key_return=0;
key_press = key_input; //输入按键值
switch(key_state)
case key_state_0:
if(!key_press)
key_state = key_state_1; //进入key状态1
case key_state_1:
if(!key_press)
key_state = key_state_2; //进入key状态2
key_return = 1;
key_state = key_state_0;
case key_state_2:
if(key_press)
return key_return; //返回key值
/*=============time0 2ms interrupt================*/
void time0() interrupt 1
TH0 = 0xF8;
TL0 = 0x2F;
display();
if(++key_stime_counter>=5)//如果满10MS则将标志位置1
key_stime_counter = 0;
key_stime_ok = 1;
if(++time_counter>=100)
time_counter = 0;
time_1s_ok = 1;
/*===============give to buffer================*/
uchar i,j=0;
for(i=0;i<3;i++)
dis_buff[j++] = time%10;
dis_buff[j++] = time/10;
/*===============main=============*/
P0 = 0xFF;
P2 = 0xFF;
TMOD = 0x01;
EA = 1;
ET0 = 1;
TH0 = 0xF8;
TL0 = 0x2F;
posit = 0;
time_to_buffer();
TR0 = 1;
if(time_1s_ok)
_time();
time_1s_ok = 0;
posit_on = ~posit_on;//秒标志
if(key_stime_ok)
key_stime_ok = 0;
if(key_read())
_time();
/*===============the time=============*/
void _time(void)
if(++time[0]>=60) //如果到60s清零秒位,进位分位。
time[0] = 0;
if(++time[1]>=60)
time[1]=0;
if(++time[2]>=24)
time[2]=0;
time_to_buffer(); //送至显示缓存区
