发表于 2011-8-5 09:20:27
在楼主位的文件里有汇编的解码程序,可惜不懂PIC,更不懂汇编
; FUNCTION : DECRYPT ()
; DESCRIPTION : DECRYPTS 32 BIT [HOP1:HOP4] USING [CSR0:CSR7]
DECRYPT
BANKSEL CNT1
MOVLW (.11+1) ; OUTER LOOP 11+1 TIMES
MOVWF CNT1 ; OUTER LOOP 11+1 TIMES
DECRYPT_OUTER
MOVLW .48 ; INNER LOOP 48 TIMES
MOVWF CNT0 ; INNER LOOP 48 TIMES
DECRYPT_INNER
CLRWDT ; RESET WATCHDOG TIMER
MOVFW CNT1 ; LAST 48 LOOPS RESTORE THE KEY
XORLW .1 ; LAST 48 LOOPS RESTORE THE KEY
btfsc STATUS,Z ; LAST 48 LOOPS RESTORE THE KEY
GOTO ROTATE_KEY ; LAST 48 LOOPS RESTORE THE KEY
; THE LOOKUP TABLE IS COMPRESSED INTO IN 4 BYTES TO SAVE SPACE
; USE THE 3 LOW INDEX BITS TO MAKE UP AN 8-BIT BIT MASK
; USE THE 2 HIGH INDEX BITS TO LOOK UP THE VALUE IN THE TABLE
; USE THE BIT MASK TO ISOLATE THE CORRECT BIT IN THE BYTE
; PART OF THE REASON FOR THIS SCHEME IS BECAUSE NORMAL TABLE
; LOOKUP REQUIRES AN ADDITIONAL STACK LEVEL
bcf STATUS,C ; CLEAR CARRY (FOR THE LEFT SHIFT)
MOVLW .1 ; INITIALISE MASK = 1
BTFSC HOP3,3 ; SHIFT MASK 4X IF BIT 2 SET
MOVLW B'00010000' ; SHIFT MASK 4X IF BIT 2 SET
MOVWF MASK ; INITIALISE MASK = 1
BTFSS HOP2,0 ; SHIFT MASK ANOTHER 2X IF BIT 1 SET
GOTO $+3
RLF MASK,F
RLF MASK,F
BTFSC HOP1,0 ; SHIFT MASK ANOTHER 1X IF BIT 0 SET
RLF MASK,F
; MASK HAS NOW BEEN SHIFTED 0-7 TIMES ACCORDING TO BITS 2:1:0
movlw HIGH TABLE
movwf PCLATH
movlw LOW TABLE
movwf KEELOQ_Temp
MOVLW 0 ; TABLE INDEX = 0
BTFSC HOP4,1
IORLW .2 ; IF BIT 3 SET ADD 2 TO THE TABLE INDEX
BTFSC HOP4,6
IORLW .4 ; IF BIT 4 SET ADD 4 TO THE TABLE INDEX
addwf KEELOQ_Temp,W
btfsc STATUS,C
incf PCLATH,F
movwf PCL ; ADD THE INDEX TO THE PROGRAM COUNTER
; [ MUST BE IN LOWER HALF OF PAGE ]
TABLE
MOVLW 0x2E ; BITS 4:3 WERE 00
GOTO TABLE_END ; END OF LOOKUP
MOVLW 0x74 ; BITS 4:3 WERE 01
MOVLW 0x5C ; BITS 4:3 WERE 10
MOVLW 0x3A ; BITS 4:3 WERE 11
TABLE_END
ANDWF MASK,1 ; ISOLATE THE CORRECT BIT
MOVLW 0 ; COPY THE BIT TO BIT 7
btfss STATUS,Z ; COPY THE BIT TO BIT 7
MOVLW B'10000000' ; COPY THE BIT TO BIT 7
XORWF HOP2,W ; ONLY INTERESTED IN BIT HOP2,7
XORWF HOP4,W ; ONLY INTERESTED IN BIT HOP4,7
XORWF KEY1,W ; ONLY INTERESTED IN BIT KEYREG1,7
MOVWF MASK ; STORE W TEMPORARILY (WE NEED BIT 7)
RLF MASK,F ; LEFT ROTATE MASK TO GET BIT 7 INTO CARRY
RLF HOP1,F ; SHIFT IN THE NEW BIT
RLF HOP2,F
RLF HOP3,F
RLF HOP4,F
ROTATE_KEY
BTFSC KEY7,7 ; SET CARRY IF LEFTMOST BIT SET
bsf STATUS,C ; SET CARRY IF LEFTMOST BIT SET
RLF KEY0,F ; LEFT-ROTATE THE 64-BIT KEY
RLF KEY1,F
RLF KEY2,F
RLF KEY3,F
RLF KEY4,F
RLF KEY5,F
RLF KEY6,F
RLF KEY7,F
DECFSZ CNT0,F ; INNER LOOP 48 TIMES
GOTO DECRYPT_INNER ; INNER LOOP 48 TIMES
DECFSZ CNT1,F ; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
GOTO DECRYPT_OUTER ; OUTER LOOP 12 TIMES (11+1 TO RESTORE KEY)
RETLW 0 ; RETURN |
