发表于 2008-1-14 10:26:19
char *ftoa(float f, int *status)
converts a floating point number to the ASCII representation. It returns a static buffer of approximately 15 chars. If the input is out of range, *status is set to the constant _FTOA_TOO_LARGE, or _FTOA_TOO_SMALL, defined in stdlib.h, and 0 is returned. Otherwise, *status is set to 0 and the char buffer is returned. This version of the ftoa is fast but cannot handle values outside of the range listed. Please contact us if you need a (much) larger version that handles greater ranges. |
