https://lists.berlios.de/pipermail/openocd-development/
https://lists.berlios.de/pipermail/openocd-development/attachments/20070728/5ca117c7/attachment.ksh
Index: doc/configs/at91sam7_jlink.cfg
--- doc/configs/at91sam7_jlink.cfg (revision 0)
+++ doc/configs/at91sam7_jlink.cfg (revision 0)
@@ -0,0 +1,23 @@
+#daemon configuration
+telnet_port 4444
+gdb_port 3333
+#interface
+interface jlink
+jtag_speed 8000
+reset_config trst_and_srst
+#jtag scan chain
+#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
+jtag_device 4 0x1 0xf 0xe
+#target configuration
+daemon_startup reset
+#target <type> <startup mode>
+#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
+target arm7tdmi little reset_halt 0 arm7tdmi
+working_area 0 0x00208000 0x4000 backup
+#flash configuration
+flash bank at91sam7 0 0 0 0 0
Index: configure.in
--- configure.in (revision 184)
+++ configure.in (working copy)
@@ -67,6 +67,10 @@
AS_HELP_STRING([--enable-usbprog], [Enable building support for the usbprog JTAG Programmer]),
[build_usbprog=$enableval], [build_usbprog=no])
+AC_ARG_ENABLE(jlink,
+ AS_HELP_STRING([--enable-jlink], [Enable building support for the Segger J-Link JTAG Programmer]),
+ [build_jlink=$enableval], [build_jlink=no])
AC_ARG_WITH(ftd2xx,
[AS_HELP_STRING(--with-ftd2xx,
[Where libftd2xx can be found <default=search>])],
@@ -191,6 +195,12 @@
AC_DEFINE(BUILD_USBPROG, 0, [0 if you don't want the usbprog JTAG driver.])
fi
+if test $build_jlink = yes; then
+ AC_DEFINE(BUILD_JLINK, 1, [1 if you want the J-Link JTAG driver.])
+else
+ AC_DEFINE(BUILD_JLINK, 0, [0 if you don't want the J-Link JTAG driver.])
+fi
AM_CONFIG_HEADER(config.h)
AM_INIT_AUTOMAKE(openocd, 0.1)
@@ -205,6 +215,7 @@
AM_CONDITIONAL(GW16012, test $build_gw16012 = yes)
AM_CONDITIONAL(PRESTO, test $build_presto = yes)
AM_CONDITIONAL(USBPROG, test $build_usbprog = yes)
+AM_CONDITIONAL(JLINK, test $build_jlink = yes)
AM_CONDITIONAL(IS_CYGWIN, test $is_cygwin = yes)
AM_CONDITIONAL(IS_MINGW, test $is_mingw = yes)
AM_CONDITIONAL(IS_WIN32, test $is_win32 = yes)
Index: src/jtag/jlink.c
--- src/jtag/jlink.c (revision 0)
+++ src/jtag/jlink.c (revision 0)
@@ -0,0 +1,825 @@
+ * Copyright (C) 2007 by Juergen Stuber <juergen@jstuber.net> *
+ * based on Dominic Rath's and Benedikt Sauter's usbprog.c *
+ * This program is free software; you can redistribute it and/or modify *
+ * it under the terms of the GNU General Public License as published by *
+ * the Free Software Foundation; either version 2 of the License, or *
+ * (at your option) any later version. *
+ * This program is distributed in the hope that it will be useful, *
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of *
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the *
+ * GNU General Public License for more details. *
+ * You should have received a copy of the GNU General Public License *
+ * along with this program; if not, write to the *
+ * Free Software Foundation, Inc., *
+ * 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. *
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "replacements.h"
+#include "jtag.h"
+#include <usb.h>
+#include <string.h>
+#include "log.h"
+#ifdef _DEBUG_JTAG_IO_
+#define DEBUG_JTAG_IO(expr ...) DEBUG(expr)
+#else
+#endif
+#define VID 0x1366
+#define PID 0x0101
+#define JLINK_WRITE_ENDPOINT 0x02
+#define JLINK_READ_ENDPOINT 0x81
+#define JLINK_USB_TIMEOUT 100
+#define JLINK_IN_BUFFER_SIZE 2064
+#define JLINK_OUT_BUFFER_SIZE 2064
+/* Global USB buffers */
+static u8 usb_in_buffer[JLINK_IN_BUFFER_SIZE];
+static u8 usb_out_buffer[JLINK_OUT_BUFFER_SIZE];
+/* Constants for JLink command */
+#define JLINK_SPEED_COMMAND 0x05
+#define JLINK_TAP_SEQUENCE_COMMAND 0xcd
+#define JLINK_SET_SRST_LOW_COMMAND 0xdc
+#define JLINK_SET_SRST_HIGH_COMMAND 0xdd
+#define JLINK_SET_TRST_LOW_COMMAND 0xde
+#define JLINK_SET_TRST_HIGH_COMMAND 0xdf
+#define JLINK_MAX_SPEED 12000
+/* External interface functions */
+static int jlink_execute_queue(void);
+static int jlink_speed(int speed);
+static int jlink_register_commands(struct command_context_s *cmd_ctx);
+static int jlink_init(void);
+static int jlink_quit(void);
+/* CLI command handler functions */
+static int jlink_handle_jlink_version_command(
+ struct command_context_s *cmd_ctx,
+ char *cmd,
+ char **args,
+ int argc);
+/* Queue command functions */
+static void jlink_end_state(enum tap_state state);
+static void jlink_state_move(void);
+static void jlink_path_move(int num_states, enum tap_state *path);
+static void jlink_runtest(int num_cycles);
+static void jlink_scan(
+ int ir_scan,
+ enum scan_type type,
+ u8 *buffer,
+ int scan_size,
+ scan_command_t *command);
+static void jlink_reset(int trst, int srst);
+static void jlink_simple_command(u8 command);
+/* J-Link tap buffer functions */
+static void jlink_tap_init();
+static int jlink_tap_execute();
+static void jlink_tap_ensure_space(int scans, int bits);
+static void jlink_tap_append_step(int tms, int tdi);
+static void jlink_tap_append_scan(
+ int length,
+ u8 *buffer,
+/* Jlink lowlevel functions */
+typedef struct jlink_jtag
+ struct usb_dev_handle* usb_handle;
+} jlink_jtag_t;
+static jlink_jtag_t *jlink_usb_open(void);
+static void jlink_usb_close(jlink_jtag_t *jlink_jtag);
+static int jlink_usb_message(
+ jlink_jtag_t *jlink_jtag,
+ int out_length,
+ int in_length);
+static int jlink_usb_write(jlink_jtag_t *jlink_jtag, int out_length);
+static int jlink_usb_read(jlink_jtag_t *jlink_jtag);
+static jlink_debug_buffer(u8 *buffer, int length);
+jlink_jtag_t* jlink_jtag_handle;
+/* External interface implementation */
+jtag_interface_t jlink_interface =
+ .name = "jlink",
+ .execute_queue = jlink_execute_queue,
+ .support_pathmove = 0,
+ .speed = jlink_speed,
+ .register_commands = jlink_register_commands,
+ .init = jlink_init,
+ .quit = jlink_quit
+ jtag_command_t *cmd = jtag_command_queue;
+ int scan_size;
+ enum scan_type type;
+ u8 *buffer;
+ while (cmd != NULL)
+ switch (cmd->type)
+ case JTAG_END_STATE:
+ DEBUG_JTAG_IO("end_state: %i", cmd->cmd.end_state->end_state);
+ if (cmd->cmd.end_state->end_state != -1)
+ jlink_end_state(cmd->cmd.end_state->end_state);
+ break;
+ case JTAG_RUNTEST:
+ DEBUG_JTAG_IO(
+ "runtest %i cycles, end in %i",
+ cmd->cmd.runtest->num_cycles, cmd->cmd.runtest->end_state);
+ if (cmd->cmd.runtest->end_state != -1)
+ jlink_end_state(cmd->cmd.runtest->end_state);
+ jlink_runtest(cmd->cmd.runtest->num_cycles);
+ break;
+ case JTAG_STATEMOVE:
+ DEBUG_JTAG_IO(
+ "statemove end in %i",
+ cmd->cmd.statemove->end_state);
+ if (cmd->cmd.statemove->end_state != -1)
+ jlink_end_state(cmd->cmd.statemove->end_state);
+ jlink_state_move();
+ break;
+ case JTAG_PATHMOVE:
+ DEBUG_JTAG_IO("pathmove: %i states, end in %i",
+ cmd->cmd.pathmove->num_states,
+ cmd->cmd.pathmove->path[cmd->cmd.pathmove->num_states - 1]);
+ jlink_path_move(
+ cmd->cmd.pathmove->path);
+ break;
+ case JTAG_SCAN:
+ DEBUG_JTAG_IO("scan end in %i", cmd->cmd.scan->end_state);
+ if (cmd->cmd.scan->end_state != -1)
+ jlink_end_state(cmd->cmd.scan->end_state);
+ scan_size = jtag_build_buffer(cmd->cmd.scan, &buffer);
+ // DEBUG("scan input, length = %d", scan_size);
+ // jlink_debug_buffer(buffer, (scan_size + 7) / 8);
+ type = jtag_scan_type(cmd->cmd.scan);
+ jlink_scan(
+ cmd->cmd.scan->ir_scan,
+ type,
+ buffer,
+ scan_size,
+ cmd->cmd.scan);
+ break;
+ case JTAG_RESET:
+ DEBUG_JTAG_IO(
+ "reset trst: %i srst %i",
+ cmd->cmd.reset->trst,
+ cmd->cmd.reset->srst);
+ jlink_tap_execute();
+ if (cmd->cmd.reset->trst == 1)
+ cur_state = TAP_TLR;
+ jlink_reset(cmd->cmd.reset->trst, cmd->cmd.reset->srst);
+ break;
+ case JTAG_SLEEP:
+ DEBUG_JTAG_IO("sleep %i", cmd->cmd.sleep->us);
+ jtag_sleep(cmd->cmd.sleep->us);
+ break;
+ default:
+ ERROR("BUG: unknown JTAG command type encountered");
+ exit(-1);
+ cmd = cmd->next;
+ return ERROR_OK;
+/** Sets speed in kHz. */
+ int result;
+ if (1 <= speed && speed <= JLINK_MAX_SPEED)
+ usb_out_buffer[0] = JLINK_SPEED_COMMAND;
+ usb_out_buffer[1] = (speed >> 0) & 0xff;
+ usb_out_buffer[2] = (speed >> 8) & 0xff;
+ result = jlink_usb_write(jlink_jtag_handle, 3);
+ if (result == 3)
+ return ERROR_OK;
+ else
+ ERROR("J-Link setting speed failed (%d)", result);
+ return ERROR_JTAG_DEVICE_ERROR;
+ else
+ INFO("Requested speed %dkHz exceeds maximum of %dkHz, ignored",
+ speed,
+ JLINK_MAX_SPEED);
+ return ERROR_OK;
+ int result;
+ jlink_jtag_handle = jlink_usb_open();
+ if (jlink_jtag_handle == 0)
+ ERROR("Can't find USB JTAG Interface! Please check connection and permissions.");
+ return ERROR_JTAG_INIT_FAILED;
+ result = jlink_usb_read(jlink_jtag_handle);
+ if (result != 2 || usb_in_buffer[0] != 0x07 || usb_in_buffer[1] != 0x00)
+ INFO("J-Link initial read failed, don't worry");
+ INFO("J-Link JTAG Interface ready");
+ jlink_reset(0, 0);
+ jlink_tap_init();
+ return ERROR_OK;
+ jlink_usb_close(jlink_jtag_handle);
+ return ERROR_OK;
+/* Queue command implementations */
+ if (tap_move_map[state] != -1)
+ end_state = state;
+ else
+ ERROR("BUG: %i is not a valid end state", state);
+ exit(-1);
+/** Goes to the end state. */
+ int i;
+ int tms = 0;
+ u8 tms_scan = TAP_MOVE(cur_state, end_state);
+ for (i = 0; i < 7; i++)
+ tms = (tms_scan >> i) & 1;
+ jlink_tap_append_step(tms, 0);
+ cur_state = end_state;
+ int i;
+ for (i = 0; i < num_states; i++)
+ if (path = tap_transitions[cur_state].low)
+ jlink_tap_append_step(0, 0);
+ else if (path == tap_transitions[cur_state].high)
+ jlink_tap_append_step(1, 0);
+ else
+ ERROR(
+ "BUG: %s -> %s isn't a valid TAP transition",
+ tap_state_strings[cur_state],
+ tap_state_strings[path]);
+ exit(-1);
+ cur_state = path;
+ end_state = cur_state;
+ int i;
+ enum tap_state saved_end_state = end_state;
+ /* only do a state_move when we're not already in RTI */
+ if (cur_state != TAP_RTI)
+ jlink_end_state(TAP_RTI);
+ /* execute num_cycles */
+ for (i = 0; i < num_cycles; i++)
+ /* finish in end_state */
+ jlink_end_state(saved_end_state);
+ if (cur_state != end_state)
+ int ir_scan,
+ u8 *buffer,
+ int scan_size,
+ enum tap_state saved_end_state;
+ int bit_cnt;
+ jlink_tap_ensure_space(1, scan_size + 8);
+ saved_end_state = end_state;
+ /* Move to appropriate scan state */
+ jlink_end_state(ir_scan ? TAP_SI : TAP_SD);
+ /* Scan */
+ jlink_tap_append_scan(scan_size, buffer, command);
+ /* We are in Exit1, go to Pause */
+ cur_state = ir_scan ? TAP_PI : TAP_PD;
+void jlink_reset(int trst, int srst)
+ DEBUG("trst: %i, srst: %i", trst, srst);
+ /* Signals are active low */
+ if (trst == 0)
+ jlink_simple_command(JLINK_SET_TRST_HIGH_COMMAND);
+ else if (trst == 1)
+ jlink_simple_command(JLINK_SET_TRST_LOW_COMMAND);
+ if (srst == 0)
+ jlink_simple_command(JLINK_SET_SRST_HIGH_COMMAND);
+ else if (srst == 1)
+ jlink_simple_command(JLINK_SET_SRST_LOW_COMMAND);
+ int result;
+ DEBUG("0x%02x", command);
+ usb_out_buffer[0] = command;
+ result = jlink_usb_write(jlink_jtag_handle, 1);
+ if (result != 1)
+ ERROR("J-Link command 0x%02x failed (%d)", command, result);
+/* J-Link tap functions */
+/* We use the maximal value observed */
+#define JLINK_TAP_BUFFER_SIZE 390
+static int tap_length;
+static u8 tms_buffer[JLINK_TAP_BUFFER_SIZE];
+static u8 tdi_buffer[JLINK_TAP_BUFFER_SIZE];
+static u8 tdo_buffer[JLINK_TAP_BUFFER_SIZE];
+typedef struct
+ int first; /* First bit position in tdo_buffer to read */
+ int length; /* Number of bits to read */
+ scan_command_t *command; /* Corresponding scan command */
+ u8 *buffer;
+} pending_scan_result_t;
+#define MAX_PENDING_SCAN_RESULTS 16
+static int pending_scan_results_length;
+static pending_scan_result_t
+ pending_scan_results_buffer[MAX_PENDING_SCAN_RESULTS];
+static int last_tms;
+ tap_length = 0;
+ pending_scan_results_length = 0;
+ int available_scans = MAX_PENDING_SCAN_RESULTS - pending_scan_results_length;
+ int available_bits = JLINK_TAP_BUFFER_SIZE * 8 - tap_length;
+ if (scans > available_scans || bits > available_bits)
+ last_tms = tms;
+ int index = tap_length / 8;
+ if (index < JLINK_TAP_BUFFER_SIZE)
+ int bit_index = tap_length % 8;
+ u8 bit = 1 << bit_index;
+ if (tms)
+ tms_buffer[index] |= bit;
+ else
+ tms_buffer[index] &= ~bit;
+ if (tdi)
+ tdi_buffer[index] |= bit;
+ else
+ tdi_buffer[index] &= ~bit;
+ tap_length++;
+ else
+ ERROR("jlink_tap_append_step, overflow");
+ int length,
+ u8 *buffer,
+ pending_scan_result_t *pending_scan_result =
+ &pending_scan_results_buffer[pending_scan_results_length];
+ int i;
+ pending_scan_result->first = tap_length;
+ pending_scan_result->length = length;
+ pending_scan_result->command = command;
+ pending_scan_result->buffer = buffer;
+ for (i = 0; i < length; i++)
+ (i < length-1 ? 0 : 1),
+ (buffer[i/8] >> (i%8)) & 1);
+ pending_scan_results_length++;
+/* Pad and send a tap sequence to the device, and receive the answer.
+ * For the purpose of padding we assume that we are in idle or pause state. */
+ int byte_length;
+ int tms_offset;
+ int tdi_offset;
+ int i;
+ int result;
+ if (tap_length > 0)
+ // Pad last byte so that tap_length is divisible by 8
+ while (tap_length % 8 != 0)
+ /* More of the last TMS value keeps us in the same state,
+ * analogous to free-running JTAG interfaces. */
+ jlink_tap_append_step(last_tms, 0);
+ byte_length = tap_length / 8;
+ usb_out_buffer[0] = JLINK_TAP_SEQUENCE_COMMAND;
+ usb_out_buffer[1] = (tap_length >> 0) & 0xff;
+ usb_out_buffer[2] = (tap_length >> 8) & 0xff;
+ tms_offset = 3;
+ for (i = 0; i < byte_length; i++)
+ usb_out_buffer[tms_offset + i] = tms_buffer;
+ tdi_offset = tms_offset + byte_length;
+ usb_out_buffer[tdi_offset + i] = tdi_buffer;
+ result = jlink_usb_message(
+ jlink_jtag_handle,
+ 3 + 2 * byte_length,
+ byte_length);
+ if (result == byte_length)
+ tdo_buffer = usb_in_buffer;
+ for (i = 0; i < pending_scan_results_length; i++)
+ &pending_scan_results_buffer;
+ u8 *buffer = pending_scan_result->buffer;
+ int length = pending_scan_result->length;
+ int first = pending_scan_result->first;
+ int byte_length = (pending_scan_result->length + 7) / 8;
+ scan_command_t *command = pending_scan_result->command;
+ /* Copy to buffer */
+ buf_set_buf(tdo_buffer, first, buffer, 0, length);
+ // DEBUG("pending scan result, length = %d", length);
+ // jlink_debug_buffer(buffer, byte_length);
+ if (jtag_read_buffer(buffer, command)!= ERROR_OK)
+ return ERROR_JTAG_QUEUE_FAILED;
+ if (pending_scan_result->buffer != NULL)
+ free(pending_scan_result->buffer);
+ else
+ ERROR(
+ "jlink_tap_execute, wrong result %d, expected %d",
+ result,
+ byte_length);
+ jlink_tap_init();
+ return ERROR_OK;
+/* JLink USB low-level functions */
+static jlink_jtag_t* jlink_usb_open()
+ struct usb_bus *busses;
+ struct usb_bus *bus;
+ struct usb_device *dev;
+ jlink_jtag_t *result;
+ result = (jlink_jtag_t*) malloc(sizeof(jlink_jtag_t));
+ usb_init();
+ usb_find_busses();
+ usb_find_devices();
+ busses = usb_get_busses();
+ /* find jlink_jtag device in usb bus */
+ for (bus = busses; bus; bus = bus->next)
+ for (dev = bus->devices; dev; dev = dev->next)
+ if (dev->descriptor.idVendor == VID&& dev->descriptor.idProduct
+ == PID)
+ result->usb_handle = usb_open(dev);
+ usb_set_configuration(
+ result->usb_handle,
+ dev->config[0].bConfigurationValue);
+ usb_claim_interface(result->usb_handle, 0);
+ usb_set_altinterface(result->usb_handle, 0);
+ return result;
+ free(result);
+ return NULL;
+ usb_close(jlink_jtag->usb_handle);
+ free(jlink_jtag);
+/* Send a message and receive the reply. */
+ int out_length,
+ int in_length)
+ int result;
+ result = jlink_usb_write(jlink_jtag, out_length);
+ if (result == out_length)
+ result = jlink_usb_read(jlink_jtag);
+ if (result == in_length)
+ return result;
+ else
+ ERROR(
+ "usb_bulk_read failed (requested=%d, result=%d)",
+ in_length,
+ result);
+ return -1;
+ else
+ ERROR(
+ "usb_bulk_write failed (requested=%d, result=%d)",
+ out_length,
+ result);
+ return -1;
+/* Write data from out_buffer to USB. */
+ int result;
+ if (out_length > JLINK_OUT_BUFFER_SIZE)
+ ERROR("jlink_jtag_write illegal out_length=%d (max=%d)", out_length,
+ JLINK_OUT_BUFFER_SIZE);
+ return -1;
+ result = usb_bulk_write(
+ jlink_jtag->usb_handle,
+ JLINK_WRITE_ENDPOINT,
+ usb_out_buffer,
+ out_length,
+ JLINK_USB_TIMEOUT);
+ // DEBUG("jlink_usb_write, out_length = %d, result = %d", out_length, result);
+ // jlink_debug_buffer(usb_out_buffer, out_length);
+ return result;
+/* Read data from USB into in_buffer. */
+ int result = usb_bulk_read(
+ JLINK_READ_ENDPOINT,
+ usb_in_buffer,
+ JLINK_IN_BUFFER_SIZE,
+ // DEBUG("jlink_usb_read, result = %d", result);
+ // jlink_debug_buffer(usb_in_buffer, result);
+ return result;
+#define BYTES_PER_LINE 16
+ char line[81];
+ char s[4];
+ int i;
+ int j;
+ for (i = 0; i < length; i += BYTES_PER_LINE)
+ snprintf(line, 5, "%04x", i);
+ for (j = i; j < i + BYTES_PER_LINE && j < length; j++)
+ snprintf(s, 4, " %02x", buffer[j]);
+ strcat(line, s);
+ DEBUG(line);
Index: src/jtag/jtag.c
--- src/jtag/jtag.c (revision 184)
+++ src/jtag/jtag.c (working copy)
@@ -170,6 +170,10 @@
extern jtag_interface_t usbprog_interface;
+#if BUILD_JLINK == 1
+ extern jtag_interface_t jlink_interface;
+#endif
jtag_interface_t *jtag_interfaces[] = {
#if BUILD_PARPORT == 1
&parport_interface,
@@ -198,6 +202,9 @@
#if BUILD_USBPROG == 1
&usbprog_interface,
+ &jlink_interface,
+#endif
NULL,
Index: src/jtag/Makefile.am
--- src/jtag/Makefile.am (revision 184)
+++ src/jtag/Makefile.am (working copy)
@@ -77,7 +77,23 @@
USBPROGFILES =
endif
-libjtag_a_SOURCES = jtag.c $(BITBANGFILES) $(PARPORTFILES) $(FT2232FILES) $(AMTJTAGACCELFILES) $(EP93XXFILES) \
- $(AT91RM9200FILES) $(GW16012FILES) $(BITQFILES) $(PRESTOFILES) $(USBPROGFILES)
+if JLINK
+JLINKFILES = jlink.c
+else
+JLINKFILES =
+endif
+libjtag_a_SOURCES = jtag.c \
+ $(BITBANGFILES) \
+ $(PARPORTFILES) \
+ $(FT2232FILES) \
+ $(AMTJTAGACCELFILES) \
+ $(EP93XXFILES) \
+ $(AT91RM9200FILES) \
+ $(GW16012FILES) \
+ $(BITQFILES) \
+ $(PRESTOFILES) \
+ $(USBPROGFILES) \
+ $(JLINKFILES)
noinst_HEADERS = bitbang.h jtag.h
Index: src/Makefile.am
--- src/Makefile.am (revision 184)
+++ src/Makefile.am (working copy)
@@ -25,8 +25,12 @@
if USBPROG
LIBUSB = -lusb
+if JLINK
+LIBUSB = -lusb
+else
LIBUSB =
endif
+endif
if IS_WIN32
if FTD2XXDIR |
