更新下载地址:
http://www.atmel.com/dyn/resources/prod_documents/AVRStudio4.13SP2.exe
更新内容:
Welcome to AVR Studio 4.13 Service pack 2(12/2007)
This release contains all the contents of earlier service packs and part packs. Please see release history for information about earlier releases.
Part support
The following new parts have been added to AVR Studio:
- ATmega32HVB, ATmega1284P, ATtiny48, ATtiny43U
Check the device matrix to see which devices are supported by which tools: See a list of all supported devices and tools here.
New Features
Full support for the new STK600 starter kit, including programming front-end and command line tools.
New devices in Simulator V2: ATmega164P, ATmega324P, ATmega644P, ATmega1284P, ATmega48P, ATmega88P, ATmega168P, ATmega328P, ATmega32HVB, ATtiny48 and ATtiny43U.
ELF production file format support (more..).
Several enhancements in the IO view.
Bug Fixes
The following sections list the bugs that were present in AVR Studio 4.13 SP1, but that have been fixed in SP2. Several other minor bugs has also been fixed. Please also see the specific tools help books for a listing of bug fixes in specific tools.
4065: If selecting a device that did not support the current programming mode, the indicated programming mode in the dialog would change automatically to one supported by the device, but the JTAGICE mkII would not change its mode.
4742: Added strlen() function to the AVR Assembler preprocessor.
4835, 5132: The feedback when an error occurs in the programming dialog has been improved. There are now separate error messages for file errors, connection errors, programming errors etc.
5469: The edit boxes in the IO view would not let go of the focus when enter or escape was pressed. This has been fixed.
5658: 16Mhz was not listed in the "Frequency" drop down menu when using the simulator and AT90CAN128. This has been fixed.
6366: The "Font and Color" item on edit menu was grayed out when the contents of the editor was not saved. This has been fixed.
6367: The context menu item "Show next statement" did not work from a line without source code mapping. This has been fixed.
6411: The I/O view did not remember the selected sort order between sessions. This has been fixed.
6419: Compiling a project in WinAVR in AVR Studio sometimes would crash on Windows Vista. This has been fixed.
6428: The tool tip in the IO view would some times display erroneous info when the windows was in 'tree view' mode. This has been fixed.
6519: The boot start address in the boot size fuse settings for 644/644P was set to F000-FE00. This has been changed to 7000-7E00.
6587: AVR Studio could crash on Vista when selecting "Remove all breakpoints". This has been fixed.
6615: Fixed an error in the ADC voltage reference selection combo box in the IO view for ATmega1280/1281/1284P/164P/2560/2561/324P/640/644/644P and ATtiny48.
6651: The IO view now indicates clearly if an undefined value is specified for a configuration register.
6698: The interrupt names in the XML file for ATtiny25/45/85 has been corrected according to the device data sheet.
3969: FLASH/EEPROM programming in ISP mode is now limited to ISP frequencies above 5kHz to avoid communication time-outs during programming.
注意到这一条:
帮助文档中有关STK600的介绍:
STK600 Starter Kit User's Guide
Congratulation with your STK600 AVR® Flash MCU Starter Kit. The STK600 is a complete starter kit and development system for the AVR and AVR®32 flash microcontrollers from ATMEL® Corporation. It is designed to give designers a quick start to develop code on the AVR, combined with advanced features for using the starter kit to prototype and test new designs.
New firmware releases for STK600 are embedded with the releases of AVR Studio®. The upgrade process will start when you connect to the STK600 board (you will be asked to perform the procedure). If for some reason the automatic upgrade fails, please try the manual upgrade procedure.
附靓照:
功能介绍:
Features
AVR Studio 4/AVR32 Studio compatible
USB Interface to PC for programming and control
Powered from USB bus or from an external 9-15V DC power supply
Parallel and Serial High-Voltage Programming of AVR devices
Serial In-System Programming (ISP) of AVR devices
JTAG programming of AVR and AVR32 devices
ISP and JTAG programming of AVR devices in external target systems
Flexible routing and socket card system for easy mounting of all supported devices (see note)
8 push-buttons for general use
8 LEDs for general use
All AVR I/O ports easily accessible through pin header connectors
Expansion connectors for plug-in modules and prototyping area
On-board 2Mbit Dataflash for non-volatile data storage
USB mini-AB (On-The-Go) connector for USB devices
PHY and DSUB-9 connetor for RS232 interface
PHY and DSUB-9 connector for CAN bus
PHY and header for LIN bus
Device board with an ATmega2560 AVR microcontroller is included.
支持烧写的器件:
STK600 Device Support
Device Routing card Socket card Programming modes Comment
ATtiny11 STK600-RC008T-2 STK600-DIPZIF HVSP
ATtiny12 STK600-RC008T-2 STK600-DIPZIF HVSP, ISP
ATtiny13 STK600-RC008T-2 STK600-DIPZIF HVSP, ISP
ATtiny15 STK600-RC008T-7 STK600-DIPZIF HVSP, ISP
ATtiny2313 STK600-RC020T-1 STK600-DIPZIF HVPP, ISP
ATtiny43U STK600-Tiny23U_43U HVPP, ISP
ATtiny24 STK600-RC014T-12 STK600-DIPZIF HVSP, ISP
ATtiny44 STK600-RC014T-12 STK600-DIPZIF HVSP, ISP
ATtiny84 STK600-RC014T-12 STK600-DIPZIF HVSP, ISP
ATtiny25 STK600-RC008T-2 STK600-DIPZIF HVSP, ISP
ATtiny45 STK600-RC008T-2 STK600-DIPZIF HVSP, ISP
ATtiny85 STK600-RC008T-2 STK600-DIPZIF HVSP, ISP
ATtiny26 STK600-RC020T-8 STK600-DIPZIF HVPP, ISP
ATtiny261 STK600-RC020T-8 STK600-DIPZIF HVPP, ISP
ATtiny461 STK600-RC020T-8 STK600-DIPZIF HVPP, ISP
ATtiny861 STK600-RC020T-8 STK600-DIPZIF HVPP, ISP
ATtiny28 STK600-RC028T-3 STK600-DIPZIF HVSP
ATtiny48 STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega8515 STK600-RC040M-4 STK600-DIPZIF HVPP, ISP
ATmega8535 STK600-RC040M-5 STK600-DIPZIF HVPP, ISP
ATmega162 STK600-RC040M-4 STK600-DIPZIF HVPP, ISP, JTAG
ATmega16 STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega32 STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega164P STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega324P STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega644 STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega644P STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega1284P STK600-RC040M-5 STK600-DIPZIF HVPP, ISP, JTAG
ATmega8 STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega48 STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega88 STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega168 STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega48P STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega88P STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega168P STK600-RC028M-6 STK600-DIPZIF HVPP, ISP
ATmega328P STK600-RC028M-6 STK600-DIPZIF HVPP, ISP, JTAG
ATmega64 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
ATmega128 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
ATmega1281 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
ATmega2561 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
ATmega165 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega165P STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega169 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega169P STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega325 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega325P STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega329 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega329P STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega645 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega649 STK600-RC064M-10 STK600-TQFP64 HVPP, ISP, JTAG
ATmega640 STK600-RC100M-11 STK600-TQFP100 HVPP, ISP, JTAG
ATmega1280 STK600-RC100M-11 STK600-TQFP100 HVPP, ISP, JTAG
ATmega2560 STK600-RC100M-11 STK600-TQFP100 HVPP, ISP, JTAG
ATmega2560 STK600-ATMEGA2560 HVPP, ISP, JTAG
ATmega3250 STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
ATmega3250P STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
ATmega3290 STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
ATmega3290P STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
ATmega6450 STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
ATmega6490 STK600-RC100M-18 STK600-TQFP100 HVPP, ISP, JTAG
AT90USB82 STK600-RC32U-20 STK600-TQFP32 HVPP, ISP
AT90USB162 STK600-RC32U-20 STK600-TQFP32 HVPP, ISP
AT90USB646 STK600-RC064U-17 STK600-TQFP64 HVPP, ISP, JTAG
AT90USB1286 STK600-RC064U-17 STK600-TQFP64 HVPP, ISP, JTAG
AT90USB647 STK600-RC064U-17 STK600-TQFP64 HVPP, ISP, JTAG
AT90USB1287 STK600-RC064U-17 STK600-TQFP64 HVPP, ISP, JTAG
AT90CAN32 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
AT90CAN64 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
AT90CAN128 STK600-RC064M-9 STK600-TQFP64 HVPP, ISP, JTAG
AT90PWM2 STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
AT90PWM3 STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
AT90PWM2B STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
AT90PWM3B STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
AT90PWM216 STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
AT90PWM316 STK600-RCPWM-19 STK600-SOIC-01 HVPP, ISP
ATmega32HVB STK600-RC044M-24 STK600-TSSOP44 HVPP, ISP
AT32UC3A0512 STK600-uC3-144 JTAG
AT32UC3A0256 STK600-uC3-144 JTAG
AT32UC3B0256 STK600-RCuC3B64-21 STK600-TQFP64-2 JTAG
AT32UC3B0128 STK600-RCuC3B64-21 STK600-TQFP64-2 JTAG
AT32UC3B064 STK600-RCuC3B64-21 STK600-TQFP64-2 JTAG
支持AVR32哦:)
AVR32 Support
STK600 supports the UC3 family of AVR32 devices. However, AVR32 devices are not supported in AVR Studio 4. Please visit the www.atmel.com for more information about AVR32 Studio.
更多更新各位自己去挖掘:) |
