回复: 2
马老师能否发一个bascom驱动T6963点阵液晶屏显示汉字的程序?!
发表于 2007-11-28 10:12:18 | 显示全部楼层 |阅读模式
最近在作一个电路,其中一部分是使用t6963c控制的240*64液晶屏,
经过一段研究,已经可以显示图片或者英文字符了,
但对于怎么显示汉字,一直没有成功。
不知道老师是否作过相关的程序。如果有,希望能发一个例程,参考下。
非常感谢。
发表于 2007-11-28 17:19:50 | 显示全部楼层
'name                     : t6963_240_128.bas
'copyright                : (c) 1995-2005, MCS Electronics
'purpose                  : T6963C graphic display support demo 240 * 128
'micro                    : Mega8535
'suited for demo          : yes
'commercial addon needed  : no
$regfile = "m8535.dat"                                      ' specify the used micro
$crystal = 8000000                                          ' used crystal frequency
$baud = 19200                                               ' use baud rate
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
'                     (c) 2001-2003 MCS Electronics
'                 T6963C graphic display support demo 240 * 128
'The connections of the LCD used in this demo
'LCD pin                  connected to
' 1        GND            GND
'2        GND            GND
'3        +5V            +5V
'4        -9V            -9V potmeter
'5        /WR            PORTC.0
'6        /RD            PORTC.1
'7        /CE            PORTC.2
'8        C/D            PORTC.3
'9        NC             not conneted
'10       RESET          PORTC.4
'11-18    D0-D7           PA
'19       FS             PORTC.5
'20       NC             not connected
'First we define that we use a graphic LCD
' Only 240*64 supported yet
Config Graphlcd = 240 * 128 , Dataport = Porta , Controlport = Portc , Ce = 2 , Cd = 3 , Wr = 0 , Rd = 1 , Reset = 4 , Fs = 5 , Mode = 8
'The dataport is the portname that is connected to the data lines of the LCD
'The controlport is the portname which pins are used to control the lcd
'CE, CD etc. are the pin number of the CONTROLPORT.
' For example CE =2 because it is connected to PORTC.2
'mode 8 gives 240 / 8 = 30 columns , mode=6 gives 240 / 6 = 40 columns
'Dim variables (y not used)
Dim X As Byte , Y As Byte
'Clear the screen will both clear text and graph display
Cls
'Other options are :
' CLS TEXT   to clear only the text display
' CLS GRAPH  to clear only the graphical part
Cursor Off
Wait 1
'locate works like the normal LCD locate statement
' LOCATE LINE,COLUMN LINE can be 1-8 and column 0-30
Locate 1 , 1
'Show some text
Lcd "MCS Electronics"
'And some othe text on line 2
Locate 2 , 1 : Lcd "T6963c support"
Locate 3 , 1 : Lcd "1234567890123456789012345678901234567890"
Locate 16 , 1 : Lcd "write this to the lower line"
Wait 2
Cls Text
'use the new LINE statement to create a box
'LINE(X0,Y0) - (X1,Y1), on/off
Line(0 , 0) -(239 , 127) , 255                              ' diagonal line
Line(0 , 127) -(239 , 0) , 255                              ' diagonal line
Line(0 , 0) -(240 , 0) , 255                                ' horizontal upper line
Line(0 , 127) -(239 , 127) , 255                            'horizontal lower line
Line(0 , 0) -(0 , 127) , 255                                ' vertical left line
Line(239 , 0) -(239 , 127) , 255                            ' vertical right line
Wait 2
' draw a line using PSET X,Y, ON/OFF
' PSET on.off param is 0 to clear a pixel and any other value to turn it on
For X = 0 To 140
   Pset X , 20 , 255                                        ' set the pixel
Next
For X = 0 To 140
   Pset X , 127 , 255                                       ' set the pixel
Next
Wait 2
'circle time
'circle(X,Y), radius, color
'X,y is the middle of the circle,color must be 255 to show a pixel and 0 to clear a pixel
For X = 1 To 10
  Circle(20 , 20) , X , 255                                 ' show circle
  Wait 1
  Circle(20 , 20) , X , 0                                   'remove circle
  Wait 1
Next
Wait 2
For X = 1 To 10
  Waitms 200
Next
Wait 2
'Now it is time to show a picture
'SHOWPIC X,Y,label
'The label points to a label that holds the image data
Test:
Showpic 0 , 0 , Plaatje
Showpic 0 , 64 , Plaatje                                    ' show 2 since we have a big display
Wait 2
Cls Text                                                    ' clear the text
End
'This label holds the mage data
Plaatje:
'$BGF will put the bitmap into the program at this location
$bgf "mcs.bgf"
'You could insert other picture data here
以上是BASCON-AVR中的例子,你可以参考,下面还有一个.
BASCOM-AVR中有直接支持T6963的底层,可以方便的支持T6963.尽管例子中显示英文,但显示中文应该方便的.
另外你的屏是带汉字库还是没有字库也不同.没有字库,自己写个字库,按图形方式显示就可以了.
' 1        GND            GND
'2        GND            GND
'3        +5V            +5V
'4        -9V            -9V potmeter
'5        /WR            PORTC.0
'6        /RD            PORTC.1
'7        /CE            PORTC.2
'8        C/D            PORTC.3
'9        NC             not conneted
'10       RESET          PORTC.4
'11-18    D0-D7           PA
'19       FS             PORTC.5
$crystal = 8000000
$regfile = "m32def.dat"
Cls
Cursor Off
Wait 1
Locate 1 , 1
'Show some text
Wait 2
Cls Text
For X = 0 To 140
Next
Wait 2
'SHOWPIC X,Y,label
Wait 2
End
Plaatje:
$bgf "mcs.bgf"
 楼主| 发表于 2007-12-10 16:02:51 | 显示全部楼层
谢谢。最近出差,回复的晚了点。
我也是参考了avr帮助中的t6963的例程。本想写一个bascom语言的,根据“初始化-写命令--写数据”的方式显示汉字的程序。因为时间紧,或许我可以试着把每个汉字都变成一个个的小图片,然后写进去~。
这样是比较简单的实现方法。只是这样作出来的 “字”,有些不很整齐,漂亮,呵呵。
GMT+8, 2024-8-25 22:54
