发表于 2007-12-17 16:55:51
阿莫此言错矣。企业级的应用都是早就放在高端的64位机器上跑了,这样的机器上跑oralce跟pc上跑根本就不是一个级别的。秀一下我们的开发平台。
$ machinfo
$ machinfo
CPU info:
Number of CPUs = 2
Clock speed = 1500 MHz
CPUID registers
vendor information = "GenuineIntel"
processor serial number = 0x0000000000000000
processor version info = 0x000000001f010504
architecture revision: 0
processor family: 31 Intel(R) Itanium 2 Family Processors
processor model: 1 Intel(R) Itanium 2 processor
processor revision: 5 stepping B1
largest CPUID reg: 4
processor capabilities = 0x0000000000000001
implements long branch: 1
Bus features
implemented = 0xbdf0000060000000
selected = 0x0000000040000000
Bus Lock Signal masked
Cache info:
L1 Instruction: size = 16 KB, associativity = 4
L1 Data: size = 16 KB, associativity = 4
L2 Unified: size = 256 KB, associativity = 8
L3 Unified: size = 6144 KB, associativity = 24
Memory = 4084 MB (3.988281 GB)
Firmware info:
Firmware revision = 03.23
FP SWA driver revision: 1.18
IPMI is supported on this system.
ERROR: Unable to obtain manageability firmware revision info.
Platform info:
model string = "ia64 hp server rx5670"
machine id number = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
machine serial number = xxxxxxxxx
OS info:
sysname = HP-UX
nodename = xxxxxxxxx
release = B.11.23
version = U (unlimited-user license)
machine = ia64
idnumber = xxxxxxxxx
vmunix _release_version:
@(#) $Revision: vmunix: B11.23_LR FLAVOR=perf Fri Aug 29 22:35:38 PDT 2003
$ export JAVA_HOME=/opt/java1.5
$ javac -version
javac 1.5.0.11
javac: no source files
$ java -version
java version "1.5.0.11"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0.11-_07_nov_2007_10_59)
Java HotSpot(TM) Server VM (build 1.5.0.11 jinteg:11.07.07-16:23 IA64, mixed mod |
