回复: 1
From "Prof. Ma Chao (Âí³±)" <ma-chao@o
发表于 2007-9-20 22:31:09 | 显示全部楼层 |阅读模式
网上闲逛,找isp资料时翻到得。呵呵来晒晒。。。。
[bascom] BASCOM AVR ISP Programmer
From "Prof. Ma Chao (&Acirc;í&sup3;±)" <ma-chao@online.sh.cn>
Date Thu, 2 Nov 2000 10:52:10 +0800
Cc "bascom@grote.net" <bascom@grote.net>
Organization DEPT. OF ELECTRONIC SCIENCE & TECHNOLOGY ,EAST CHINA NORMAL UNIVERSITY
Hi Mark Alberts,
Thanks for your mail.
1.According Application Notes AVR910 "In-System Programming" from ATMEL
I have bulild a hardware "Programmer Board". On the board I use a chip
90S1200,the Source Code is the avr910.asm.
2.By PC I use the AVRprog131.exe (also from ATMEL) and COM1 port.They work
well with my programmer board. I have tested it with 1200,2313,4414,8515,
all are OK.
3.When I use BASCOM AVR ISP Programmer(I have 1.11b),it is not work with my
programmer board. The frist err wondow is  "Could not identy chip" then comes
with "Selected chip and target chip do not match 90s2313 <> 90s8515".(the 2nd
err wondow is not show frist.)
4.So I think BASCOM AVR ISP Programmer can frist communicate with my board,
but there are somting still no-match.
5.Now I had to use BASCOM-AVR and AVRprog131.exe for my projects. But it
would be better that only need BASCOM-AVR.
6.I will send you the newly avr910.asm. Maybe you could do some test and help
me.
Thanks,
            Prof. Ma Chao  2000-11-02 10:09:08
At 2000-11-01 22:33:00 you wrote:
>Hello prof. Ma
>I tested the ISP COM programmer with the latest IDE (1.11b) and it works
>fine.
>I have build hardware from Atmel that is based on the avr910.asm note.
>When the AVR software is working, BASCOM ISP programmer should work too!
>Which chip are you using?
>I have tested it with the 2313.
>Do you have version 1.11b of the IDE? If not please try this one. If you
>do let me know and I will run some more tests.
>Best regards,
>Mark Alberts
>> -----Original Message-----
>> From: Prof. Ma Chao (马潮) [mailto:ma-chao@online.sh.cn]
>> Sent: woensdag 1 november 2000 18:16
>> To: mark@mcselec.com
>> Cc: bascom@grote.net
>> Subject:
>> Hi Mark,
>> Is the AVR ISP Programmer good work with the AVR910.asm by using
>> COM port ?
>>      I build a programmer board based on the AVR910.asm application note.
>> It is good work with the ISP program AVRprog131.exe from ATMEL
>> (I use the PC serial port COM1). But the Bascom-avr's AVR ISP programmer
>> can not work with this board. It shows the err wondow "Cond not
>> identyfi chip".
>> May be some thing wrong with the programmer board or AVR910.asm?
>> Thanks,
>>             Ma Chao
>>             cma@kali.com.cn
-----------------好好学习天天向上---------------------------------------------------------------
发表于 2007-9-22 10:45:04 | 显示全部楼层
7年前的东西,早过时了,已经没有任何价值。
Mark Alberts是BASCOM-AVR和BASCOM-51的作者,最早的两个系统平台都是他开发的。
我了解AVR后,希望从汇编跳出了,购买了正版的这两个系统。现在还在使用,如硬件调试和一些系统的开发,非常方便。
后来又搞到正版的ICC、CVAVR。现在我的电脑上装有:AVR STUDIO、ICC、CVAVR、BASCOM-AVR、SLISP、BASCOM-51、KEIL、U51。
GMT+8, 2024-7-23 02:26
