回复: 19
利用ATmega128通用IO软件模拟SPI读取AT45DB041B的状态寄存器,总是0xFF,为什么?
发表于 2007-7-9 23:15:49 | 显示全部楼层 |阅读模式
程序如下:
#include <mega128.h>
#define UCHAR unsigned char
#define UINT unsigned int
#define DF_Write                PORTD   //SPI port register
#define DF_Read                PIND    //Data PIN
#define DF_Direction_REG        DDRD    //Direction register
#define DF_CS_Write                PORTA        //SPI CS port register
#define DF_CS_Direction_REG        DDRA    //CS Direction register
#define SPI_DI_PIN                3        //DF_SI_PIN,MCU_SO_PIN
#define SPI_DO_PIN                2        //DF_SO_PIN,MCU_SI_PIN
#define SPI_CLK_PIN                 5        //DF_CLK_PIN,MCU_CLK_PIN
#define SPI_CS_PIN               3        //DF_CS_PIN
#define SPI_SI              DF_Write.SPI_DI_PIN
#define SPI_SO              DF_Read.SPI_DO_PIN
#define SPI_SCK             DF_Write.SPI_CLK_PIN
#define SPI_CS              DF_CS_Write.SPI_CS_PIN
void SPI_Port_Init(void)
   //Config ports
   DF_Direction_REG.SPI_DI_PIN=1;          //Set Pin DF_DI as Input, MCU pin as Output
   DF_Direction_REG.SPI_CLK_PIN=1;         //Set Pin DF_Clock as Input, MCU pin as Output
   DF_Direction_REG.SPI_DO_PIN=0;          //Set Pin DF_DO as Output, MCU pin as Input
   DF_CS_Direction_REG.SPI_CS_PIN=1;       //Set Pin DF_CS as Input,MCU pin as Output
   SPI_CS=1;                        //Set DF_Chip_Select to High, DATAFLASH Invalid.
unsigned char SPI_MCUReadByte(void)
        unsigned char i,rByte=0;
        for(i=0;i<8;i++)
                SPI_SCK=0;
                SPI_SCK=1;
                rByte<<=1;
                rByte|=SPI_SO;
        return rByte;
void SPI_MCUWriteByte(unsigned char wByte)
        unsigned char i;
        for(i=0;i<8;i++)
                if((wByte<<i)&0x80){SPI_SI=1;}
                else{SPI_SI=0;}
                SPI_SCK=0;
                SPI_SCK=1;
unsigned char AT45DB041B_StatusRegisterRead(void)
        unsigned char i;
        SPI_CS=0;
        SPI_MCUWriteByte(0x57);
        i=SPI_MCUReadByte();
        SPI_CS=1;
        return i;
        unsigned char status=0;
        SPI_Port_Init();
        status=AT45DB041B_StatusRegisterRead();
        while(1){}
大家帮忙看一下,为什么啊?
发表于 2007-7-10 08:42:11 | 显示全部楼层
以前用硬件SPI时碰到过,好像是SPI模式3才能工作。建议看看SPI模式和时序!
 楼主| 发表于 2007-7-10 09:24:24 | 显示全部楼层
状态寄存器读出来应该是什么值?
是不是对于at45db41b来说,5位到2位固定的为0111 其他位就看情况了?
我按楼上的把操作码改成改为d7H  结果读出来还是0xff
-----此内容被weizhonghui于2007-07-10,09:30:57编辑过
发表于 2008-6-23 10:41:46 | 显示全部楼层
此问题有待高人指点,我现在也遇到同样的问题,头都大了。
发表于 2008-7-28 00:36:09 | 显示全部楼层
我可以读出状态码,但读产家ID的时候总是0XFF,不知道是怎么回事,请指点一下
//AT45DB041D-SPI-16.c
#include <iom16v.h>
#include <macros.h>
#include <string.h>
#include "AT45DB041D-SPI-16.h"
*AT45DB041D全局变量
unsigned char Write_Buffer[264];
unsigned char Read_Buffer[264];
unsigned int Read_Buffer_Addr =0;
unsigned int Write_Buffer_Addr=0;
unsigned int Read_Buffer_Size =0;
unsigned int Write_Buffer_Size=0;
unsigned int Read_Page_Addr   =0;
unsigned int Write_Page_Addr  =0;
*SPI宏定义
#define  SPI_DDR             DDRB
#define  SPI_PORT            PORTB
#define  SPI_PIN              PINB
#define  SS              4
#define  SCK             7
#define  MOSI            5
#define  MISO            6
#define  RESET           3
*AT45DB041D宏定义
*RST由硬件实现(接WatchDog的复位脚)
#define  Enable_DFLASH()   SPI_PORT&=~(1<<SS)     //使能DataFlash
#define  Disable_DFLASH()  SPI_PORT|=(1<<SS)          //禁止DataFlash
*Init SPI Port
  SPI_DDR  |= ((1<<SS)|(1<<SCK)|(1<<MOSI));
  //SPI_DDR  &=~ (1<<MISO);
  SPI_PORT |= ((1<<SS)|(1<<SCK))|(1<<MOSI);
  //SPI_PORT &=~ ((1<<SCK)|(1<<MOSI));
  SPI_DDR|=(1<<RESET);
*初始化SPI
void SPI_Init(void)
  SPI_Port_Init();
  // SPI中断禁止, SPI使能, master模式, MSB 前,  SPI 模式 3, SCK频率Fcl/4
  SPCR |= (1<<SPE)|(1<<MSTR)|(1<<CPOL)|(1<<CPHA);//mode 3
  //SPSR |= (1<<SPI2X);
*DataFlash Init
void DataFlash_Init(void)
  SPI_Init();
*SPI send a Byte
void SPI_Write_Byte(unsigned char cData)
  SPDR = cData;                //write data
  while(!(SPSR & (1<<SPIF)));  //wait write ok
*SPI Read char
unsigned char SPI_Read_Byte(unsigned char cData)
  while(!(SPSR & (1<<SPIF)));  //wait receive ok
  return SPDR;                 //返回数据
unsigned char DF_Read_status_Register(void)
  unsigned char rData=0;
  Enable_DFLASH();
  SPI_Write_Byte(Status_Register_Opcode);//write opcode
  rData = SPI_Read_Byte(0x00);//read device's status
  Disable_DFLASH();
  PORTA=rData;
  return rData;
*check busy status
*返回1表示不忙,否则为忙
void DF_Check_Busy_State(void)
  unsigned char state;
     state=DF_Read_status_Register();
         if(state & 0x80) //读取的最高位0时器件忙
  PORTA=state;
*该函数为了测试该芯片有没有正常运行,正常会返回0X1F
unsigned char DF_Manufacturer_and_Device_ID(void)
  unsigned char i;
  unsigned char ID_Inf[4]={0,0,0,0};
  DF_Check_Busy_State();
  Enable_DFLASH();
  SPI_Write_Byte(Device_ID_Opcode);
  for(i=0;i<4;i++)
    ID_Inf = SPI_Read_Byte(0);
  for(i=0;i<4;i++)
  Disable_DFLASH();
  if(ID_Inf[0] == 0x1F)  return 1;//这里只判断产家ID
  PORTA=ID_Inf[0];
  return  0;
void main_delay(unsigned int n);
void DF_Reset(void)
  SPI_PORT&=~(1<<RESET);
  main_delay(10);
  SPI_PORT|=(1<<RESET);
  main_delay(10);
  unsigned int i;
  unsigned int j;
  for(i=0;i<n;i++)
    for(j=0;j<255;j++)
          asm("nop");
  main_delay(1000);
  DDRA =0XFF;
  PORTA=0X88;
  DataFlash_Init();
  DF_Reset();
    DF_Manufacturer_and_Device_ID();
    main_delay(10);
//AT45DB041D-SPI-16.h
#ifndef _AT45DB041D_H
#define _AT45DB041D_H
//设置Page Size的大小
//芯片默认为264 bytes
#define Page_Size_264   //如果有定义Page_Size_264则AT45DB041D全部Page Size为264计算,
                        //否则以256计算
//AT45DB041D有两个缓冲区Buffer1和Buffer2 (SRAM)
#define Buffer1       1
#define Buffer2       2
#define ReadBuffer    1
#define WriteBuffer   2
*opcode-操作码
#define Status_Register_Opcode   0xD7
#define Device_ID_Opcode         0x9F
//Read from buffer
//#define Read_Data_from_Buffer1  0xD4
#define Read_Data_from_Buffer1  0xD1   //lower frequency
//#define Read_Data_from_Buffer2  0xD6
#define Read_Data_from_Buffer2  0xD3   //lower frequency
//Write to buffer
#define Write_Data_to_Buffer1   0x84
#define Write_Data_to_Buffer2   0x87
//Read page to buffer
#define Read_Page_to_Buffer1   0x53
#define Read_Page_to_Buffer2   0x55
//Write buffer to page
#define Write_Buffer1_to_Page_whin_Erase   0x83
#define Write_Buffer2_to_Page_whin_Erase   0x86
//Continuous Array Read
//Page to Buffer Compare
#define Page_to_Buffer1_Compare   0x60
#define Page_to_Buffer2_Compare   0x61
发表于 2009-10-3 15:29:30 | 显示全部楼层
我也遇到同样问题,而且at45db041d的状态寄存器读出来始终为0,为什么?
发表于 2010-1-12 11:20:15 | 显示全部楼层
回复【5楼】bioe
我也是,读出来的全是FF ,楼上的几位,有已经解决这个问题的人么?帮帮忙啊
发表于 2010-7-15 15:52:22 | 显示全部楼层
我也晕倒同样问题~~~~~~~~
发表于 2010-7-25 22:48:54 | 显示全部楼层
怎么没有人来解决这个问题啊!!!!
发表于 2010-7-26 08:35:24 | 显示全部楼层
我用硬件的SPI可以的。
发表于 2010-12-3 14:34:04 | 显示全部楼层
我也是读出全是0xff,不知道是哪里的问题,哪位高人给指点一下吧
发表于 2010-12-27 18:36:30 | 显示全部楼层
SPI模式一定要和操作码对上,否则读出来的就不对!
发表于 2011-4-28 14:07:10 | 显示全部楼层
回复【楼主位】weizhonghui
lz,你的at45db041 模拟弄出来了吗 ? 我也在弄 现在读出状态是0x80,不是ox9c啊,
发表于 2011-4-28 17:38:22 | 显示全部楼层
有人能回答问题啊!
发表于 2011-5-14 11:46:31 | 显示全部楼层
回复【4楼】ahui2
你好,不知道你现在at45dbflash  可调试好了,我状态一会儿读出来是0x80,一会儿是0x00,怎么回事
发表于 2011-7-5 16:46:47 | 显示全部楼层
mark
发表于 2011-7-5 17:59:08 | 显示全部楼层
还没有高手回答??
发表于 2011-8-8 15:22:50 | 显示全部楼层
我读出来的值全是0xff,不知道大家的问题解决了没?
出35入0汤圆
发表于 2014-3-3 16:34:16 | 显示全部楼层
解决了没??
发表于 2017-8-5 07:45:57 | 显示全部楼层
1、检查硬件单片机配置
2、初始化有没有错
3、看看那个寄存器支持读吗
4、查时序
GMT+8, 2024-8-25 18:52
