MEGA16读AD7705程序
#include <iom16v.h>
#include <macros.h>
#define uint unsigned int
#define Add_key PINC
#define CS_1 (PORTB|= (1<<4 ))
#define CS_0 (PORTB&= ~(1<<4 ))
#define LED_1 (PORTB|= (1<<0 ))
#define LED_0 (PORTB&= ~(1<<0 ))
#define LED1_1 (PORTB|= (1<<1 ))
#define LED1_0 (PORTB&= ~(1<<1 ))
#define DRDY (PINB& 0x08)
#define ADDR (PINC& 0x01)
#define SPE_1 (SPCR|= (1<<6 ))
uint value,value1,value2;
//**********************短延时程序50us**************************//
void delay50us(uint t)
uint j;
for(;t>0;t--)
for(j=0;j<70;j++)
//**********************短延时程序5us**************************//
void delay5us(uint t)
uint j;
for(;t>0;t--)
for(j=0;j<7;j++)
//**********************长延时程序50ms**************************//
void delay50ms(uint t)
uint i;
for(;t>0;t--)
for(i=0;i<52642;i++)
//**************************端口初始化*************************//
void IO_Init(void)
DDRC=0x00;
PORTC=0x00;
DDRB=0b10110111; //PB3\PB6输入
PORTB=0b11110111; //MISO输入加上拉电阻
void spi_init(void)
SPCR = 0b01011111; //使能SPI,MSB先发送,主机,SCK空闲高,模式三,128分频
SPSR = 0x00; //setup SPI,主机倍频
//CS_0; //使能SPI器件
//******************SPI写寄存器函数*******************************//
void WriteToReg_ADC(uint byteword)
CS_0; //使能SPI器件
//SPE_1;
SPDR=byteword; //发送数据
while(!(SPSR & (1<<SPIF)));//等待发送完毕
CS_1; //禁止SPI器件
// delay5us(10);
//******************SPI读函数*******************************//
unsigned char Read_Byte_SPI(void)
SPDR = 0xff; //发送数据,给AD7705提供脉冲
while (!(SPSR &(1<<SPIF)));
return SPDR;
//******************SPI读数据寄存器函数*******************************//
uint Read_ADC16BitValue(void)
uchar temp1=0;
uint temp=0;
CS_0; //使能SPI器件
temp=Read_Byte_SPI();
temp=temp<<8;
temp1=Read_Byte_SPI();
temp=temp|temp1;
CS_1; //禁止SPI器件
return temp;
//******************绿灯闪烁******************************//
void greenled(void)
LED_0;
delay50us(50);
LED_1;
delay50us(50);
LED_0;
delay50us(50);
LED_1;
delay50us(50);
void yellowled(void)
LED1_0;
delay50us(50);
LED1_1;
delay50us(50);
LED1_0;
delay50us(50);
LED1_1;
delay50us(50);
//**************************AD初始化*************************//
void ADC_Init(void)
uchar i;
for(i=10;i>0;i--)
{WriteToReg_ADC(0xff);} //持续DIN高电平写操作,恢复AD7705接口
WriteToReg_ADC(0x20); //通道1,下一个写时钟寄存器
WriteToReg_ADC(0x0c); //写时钟寄存器设置更新速率为200hz
WriteToReg_ADC(0x10); //通道1,下一个写设置寄存器
WriteToReg_ADC(0x44); //自校准,增益1,单极,无缓冲
delay50us(100); //延时
//WriteToReg_ADC(0x21); //通道2,下一个写时钟寄存器
// WriteToReg_ADC(0x0c); //写时钟寄存器设置更新速率为200hz
// WriteToReg_ADC(0x11); //通道2,下一个写设置寄存器
//WriteToReg_ADC(0x44); //自校准,增益1,单极,无缓冲
// delay50us(100);
//***************************读取****************************//
void ceshi(void)
if(DRDY==0) //数据准备好
WriteToReg_ADC(0x38); //下一操作为读数据寄存器1
value1=Read_ADC16BitValue();//读取
LED_1; //进入AD,指示等灭
yellowled(); //黄灯闪烁
greenled(); //绿灯闪烁
delay50us(100); //延时等待外围器件稳定
IO_Init();
spi_init();
ADC_Init();
ceshi(); //读取AD数据
AD7705精度在16位,第一次用16位的AD,很好....先前一直不能正确读取数值.是因为AD7705坏了,损坏的原因是设计上的失误,我把REF IN+接地了,REF IN-接参考电压..后来重新焊接了一个板子,把REF IN+修改了.就好了,哎,不是问题的问题!!
大家看下面的图,REF IN+接错了,其它的还是比较准确的,程序已经测试过了,谁要用的着的,可以看看,
![](http://cache.amobbs.com/bbs_upload782111/files_6/armok01146979.jpg) |
