回复: 41
用ad口做按键检测,25个按键,电压分辨幅度为0.2v。大家看看如何来滤波,如何来做。
发表于 2006-12-21 08:29:47 | 显示全部楼层 |阅读模式
用ad口做按键检测,基准电压5v,25个按键,电压构建等差数列,电压分辨幅度为0.2v。大家看看如何来滤波,如何来做。这个滤波调了好几天没有出来。
大家帮帮忙。
 楼主| 发表于 2006-12-21 11:11:01 | 显示全部楼层
大家说说啊
发表于 2006-12-21 11:47:08 | 显示全部楼层
在论坛里有见过相关的贴,通过不同的电阻进行分压,AD口得到不同的ADC值,某个范围内的ADC值对应某个按键,不过我没试过,呵呵
发表于 2006-12-21 13:25:43 | 显示全部楼层
上传一张文件给你看看。
 楼主| 发表于 2006-12-21 13:52:44 | 显示全部楼层
我采用的方法跟上面的差不多,但是按键会出现错误,采用那种滤波方式来消除按键抖动的问题。
发表于 2006-12-21 14:57:35 | 显示全部楼层
ZT
Robs-Projects MP3 Player V2
//        V2.6
//        Rob Riglar
//                                                        Copyright 2003,2004
//                                                Web:   http://www.robs-projects.com
//                                             Email: admin@robs-projects.com
//                            Compiled with Imagecraft C Compiler for the AVR series
//        (set stack to 50)
// This file is part of Robs-Projects MP3 Player V2.
// Robs-Projects MP3 Player V2 is free software; you can redistribute it and/or
// modify it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// Robs-Projects MP3 Player V2 is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with Robs-Projects MP3 Player V2; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
// Prototypes
void InitADC( void);
int ReadADC( unsigned char);
int CheckSonyInput(void);
void CalibrateSonyStick(void);
void FindButtonPress(word adcvalue);
word MakeCalibrate(void);
void UpdateCalibration(void);
// Structures
struct
          byte Detect;
          word values[10];
          word keyvalue[10];
} SonyStick;
byte recievedbyte;
// InitADC: Initialise ADC Channel
void InitADC( void)
        PORTF|= 0b01111111;
        DDRF|= 0b01111111;
    ADMUX = 7;          // Select channel 7 = 0000 0111
    ADCSR = 0xC0;       // Enable ADC & start 1:st dummy conversion
// ReadADC: Read ADC value
int ReadADC( byte channel)
    int i;
        // Select channel
    ADMUX = channel;
    // Start conversion
    ADCSR |= 0x40;
        // Check if converstion is ready
    while (!(ADCSR & 0x10));
        // Clear Conversion ready flag by setting the bit
    ADCSR |= 0x10;
        // Read 8 low bits first (important)
    i = ADCL;
        // Read 2 high bits and multiply with 256
    i += (int)ADCH << 8;
        // Return value read
    return i;
// CheckSonyInput: Does a threshold check and then samples ADC 10 times to
//                                    see which button is pressed.
//                                    Return 0 for no button pressed, 1 if detected.
  word adcvalue;
  int i;
  int medium=0;
  // Read ADC for Sony Stick Input
  adcvalue = ReadADC(7);
  // Check threshold button
  if (adcvalue<100)
       return 0;
  // If button detected
           // Sample 10 times
           for (i=0;i<10;i++)
                      SonyStick.values = ReadADC(7);
                  // printf("\r
ADC Value is %d", SonyStick.values);
           // Calculate mean value
           for (i=0;i<10;i++)
                      medium = medium + SonyStick.values;
           medium = medium / 10;
           //printf("\r
Average value is %d", medium);
           // Decode input
           FindButtonPress(medium);
printf("\r
Button was %d", medium);
           printf("\r
Button was %c", recievedbyte);
           return 1;
// FindButtonPress: Match ADC read value with calibrations for buttons
        // Reset buffer
        recievedbyte = 0;
        // Check for Volume Up
        if ( (SonyStick.keyvalue[0]-7<adcvalue) && (SonyStick.keyvalue[0]+7>adcvalue) )
           recievedbyte = '*';
           printf("\r
Volume Up");
        // Check for Volume Down
        if ( (SonyStick.keyvalue[1]-7<adcvalue) && (SonyStick.keyvalue[1]+7>adcvalue) )
           recievedbyte = '/';
           printf("\r
Volume Down");
        // Check for Track Up
        if ( (SonyStick.keyvalue[2]-7<adcvalue) && (SonyStick.keyvalue[2]+12>adcvalue) )
           recievedbyte = '>';
           printf("\r
Track Up");
        // Check for Track Down
        if ( (SonyStick.keyvalue[3]-12<adcvalue) && (SonyStick.keyvalue[3]+7>adcvalue) )
           recievedbyte = '<';
           printf("\r
Track Down");
        // Check for album up
        if ( (SonyStick.keyvalue[9]-15<adcvalue) && (SonyStick.keyvalue[9]+15>adcvalue) )
           recievedbyte = 'S';
           printf("\r
Album Forward Pressed");
        // Check for album down
        if ( (SonyStick.keyvalue[4]-15<adcvalue) && (SonyStick.keyvalue[4]+15>adcvalue) )
           printf("\r
Album Backward Pressed");
           recievedbyte = 'A';
        // Check for 'Play'
        if ( (SonyStick.keyvalue[5]-20<adcvalue) && (SonyStick.keyvalue[5]+20>adcvalue) )
           printf("\r
Play Pressed");
           recievedbyte = 'P';
        // Check for 'Pause'
        if ( (SonyStick.keyvalue[6]-10<adcvalue) && (SonyStick.keyvalue[6]+10>adcvalue) )
           printf("\r
Pause Pressed");
           recievedbyte = 'U';
// Load Calibration Values
         SonyStick.keyvalue[0] = 999; // Volume Up
         SonyStick.keyvalue[1] = 999; // Volume Down
         SonyStick.keyvalue[2] = 847; // Track Up
         SonyStick.keyvalue[3] = 872; // Track Down
         SonyStick.keyvalue[4] = 771; // Album Back
         SonyStick.keyvalue[5] = 527; // Play Button
         SonyStick.keyvalue[6] = 639; // Pause
         SonyStick.keyvalue[7] = 999; // Sound
         SonyStick.keyvalue[8] = 1000; // Mode
         SonyStick.keyvalue[9] = 608; // Album Fwd
-----此内容被back于2006-12-21,14:59:41编辑过
发表于 2006-12-21 19:06:33 | 显示全部楼层
有启发,留名,下载,刻盘,备份~~~呵呵~~~~
发表于 2006-12-22 08:03:09 | 显示全部楼层
对应3楼的源代码
/*  PROJECT                :Atmel AVR Design Contest 2006: AT3244                           */
/*  FILE        :KeyPad.c                                              */
/*  DATE        :April 27, 2006                                               */
/*  DESCRIPTION :This file contains the basic set of functions to            */
/*               input data from the keypad.                                 */
#include <avr/interrupt.h>
#include <avr/pgmspace.h>
#include "usbdrv.h"
#include "KeyPad.h"
#include "LCD.h"
#include "ADC.h"
#include "ISO7816.h"
const char KeyPad[10][10] PROGMEM = {
    {'@', '0', '#', '_', '&', '$', '.', '(', ')', '\0'},    // Keypad '0'
    {' ', '1', '*', '+', '-', '/', '?', '!', '%', '\0'},    // Keypad '1'
    {'a', 'b', 'c', '2', 'A', 'B', 'C', '\0', '\0', '\0'},  // Keypad '2'
    {'d', 'e', 'f', '3', 'D', 'E', 'F', '\0', '\0', '\0'},  // Keypad '3'
    {'g', 'h', 'i', '4', 'G', 'H', 'I', '\0', '\0', '\0'},  // Keypad '4'
    {'j', 'k', 'l', '5', 'J', 'K', 'L', '\0', '\0', '\0'},  // Keypad '5'
    {'m', 'n', 'o', '6', 'M', 'N', 'O', '\0', '\0', '\0'},  // Keypad '6'
    {'p', 'q', 'r', 's', '7', 'P', 'Q', 'R', 'S', '\0'},    // Keypad '7'
    {'t', 'u', 'v', '8', 'T', 'U', 'V', '\0', '\0', '\0'},  // Keypad '8'
    {'w', 'x', 'y', 'z', '9', 'W', 'X', 'Y', 'Z', '\0'},    // Keypad '9'
Parameters:  None
Returns:     Key pressed coded in BCD (16 keys)
Description: This function gets a key from a 16-key keypad using the ADC
                         converter. To improve the reliability it takes two samples
                         before deciding on the key value
unsigned char KeyPad_GetKey (void)
        unsigned char i;
        unsigned short raw[KEYPAD_MAX_SAMPLES];
        do {
                for (i = 0; i < KEYPAD_MAX_SAMPLES; i++) {
                        raw = ADC_Read (KBD);                            // Get raw ADC converter value
                        if (raw >= KEYPAD_RAW_NO_KEY) {            // Lower digital Limit for checking the
        // corresponding digital value of 'NO KEY'
                                return KEYPAD_NO_KEY;                              // Return 'NO KEY' pressed code
                        else if (raw >= KEYPAD_RAW_D) {             // Lower digital Limit for checking the
        // corresponding digital value of 'D' key
                                raw = KEYPAD_D;                                // Key 'D' code in BCD
                                continue;                                                    // Try again
                        else if (raw >= KEYPAD_RAW_C) {             // Lower digital Limit for checking the
        // corresponding digital value of 'C' key
                                raw = KEYPAD_C;                                 // Key 'C' code in BCD
                        else if (raw >= KEYPAD_RAW_B) {             // Lower digital Limit for checking the
        // corresponding digital value of 'B' key
                               raw = KEYPAD_B;                                 // Key 'B' code in BCD
                    else if (raw >= KEYPAD_RAW_A) {             // Lower digital Limit for checking the
        // corresponding digital value of 'A' key
                               raw = KEYPAD_A;                                 // Key 'A' code in BCD
                    else if (raw >= KEYPAD_RAW_ENTER) {  // Lower digital Limit for checking the
        // corresponding digital value of 'ENTER' key
                               raw = KEYPAD_ENTER;                           // Key 'ENTER' code in BCD
                    else if (raw >= KEYPAD_RAW_9) {      // Lower digital Limit for checking the
        // corresponding digital value of '9' key
                               raw = KEYPAD_9;                               // Key '9' code in BCD
                    else if (raw >= KEYPAD_RAW_6) {             // Lower digital Limit for checking the
        // corresponding digital value of '6' key
                               raw = KEYPAD_6;                                 // Key '6' code in BCD
                    else if (raw >= KEYPAD_RAW_3) {             // Lower digital Limit for checking the
        // corresponding digital value of '3' key
                               raw = KEYPAD_3;                                 // Key '3' code in BCD
                        else if (raw >= KEYPAD_RAW_0) {             // Lower digital Limit for checking the
        // corresponding digital value of '0' key
                               raw = KEYPAD_0;                                 // Key '0' code in BCD
                    else if (raw >= KEYPAD_RAW_8) {             // Lower digital Limit for checking the
        // corresponding digital value of '8' key
                               raw = KEYPAD_8;                          // Key '8' code in BCD
                    else if (raw >= KEYPAD_RAW_5) {             // Lower digital Limit for checking the
        // corresponding digital value of '5' key
                               raw = KEYPAD_5;                                 // Key '5' code in BCD
                        else if (raw >= KEYPAD_RAW_2) {             // Lower digital Limit for checking the
        // corresponding digital value of '2' key
                                raw = KEYPAD_2;                                 // Key '2' code in BCD
                    else if (raw >= KEYPAD_RAW_ESC) {    // Lower digital Limit for checking the
        // corresponding digital value of 'ESC' key
                               raw = KEYPAD_ESC;                               // Key 'ESC' code in BCD
                    else if (raw >= KEYPAD_RAW_7) {             // Lower digital Limit for checking the
        // corresponding digital value of '7' key
                               raw = KEYPAD_7;                                 // Key '7' code in BCD
                        else if (raw >= KEYPAD_RAW_4) {             // Lower digital Limit for checking the
        // corresponding digital value of '4' key
                                raw = KEYPAD_4;                                 // Key '4' code in BCD
                    else {                                             // Lower digital Limit for checking the
        // corresponding digital value of '1' key
                                   raw = KEYPAD_1;                                 // Key '1' code in BCD
        } while (raw[0] != raw[1]);                                            // Repeat until both samples are equal
        return raw[1];        // Return key code in BCD
Parameters:  None
Returns:     None
Description: This function waits for a key release
void KeyPad_WaitKeyRelease (void)
    unsigned char key = KEYPAD_NO_KEY;
    do {                                            // Wait until the key has been released
        key = KeyPad_GetKey();                      // Sample keypad
    } while ((key < KEYPAD_NO_KEY) && ISO7816_SmartCardReady());
Parameters:  key_buff -> keys pressed string in ASCII
             digits -> number of digits to read
                         mode -> KEY_HIDE (1): show asterisks instead of digits
                                          KEY_SHOW (0): show the entered numbers
Returns:     None
Description: This function waits for a numeric input from the keypad and
                         at the same time displays the key pressed on the LCD. Depending
                         on the mode (HIDE / SHOW) the key is masked or not with '*'
void KeyPad_GetDigit (unsigned char *digit_buff, unsigned char digits, unsigned char mode)
        unsigned char i = 0;
    unsigned char state = KEYPAD_WAIT_STATE;
    unsigned char last_key = KEYPAD_NO_KEY;
        unsigned char lcd_buff [LCD_CHARS_PER_LINE + 1];
    *digit_buff = '\0';                                 // Initialize display buffers
    *lcd_buff = '\0';
    if (mode)
                LCD_String (LCD_LINE2, lcd_buff);                        // Display value masked with asterisks or
                LCD_String (LCD_LINE2, digit_buff);                        // Display plain value
    LCD_Cursor (LCD_CURSOR_ON);                         // Show cursor
    while (ISO7816_SmartCardReady() && (i < LCD_CHARS_PER_LINE)) {
        switch (state) {
            case KEYPAD_WAIT_STATE:                     // Wait for a numeric key press
                do {
                    usbPoll();                          // Refresh USB connection
                } while ((key > KEYPAD_ENTER) && ISO7816_SmartCardReady());
                if (!ISO7816_SmartCardReady()) {        // If the smart card is removed
                    *digit_buff = '\0';                 // Clear display buffers
                    *lcd_buff = '\0';
                    LCD_Cursor (LCD_CURSOR_OFF);        // Hide cursor
                    return;                             // Exit
                state = KEYPAD_HANDLING_STATE;          // Set next keypad state
            case KEYPAD_HANDLING_STATE:                 // Key handling
                switch (key) {
                    case KEYPAD_ESC:                    // Delete previous number
                        if (i > 0) {                    // If cursor position other than first
                                        i--;
                        *(digit_buff + i) = ' ';
                        *(digit_buff + i + 1) = '\0';
                        *(lcd_buff + i) = ' ';
                        *(lcd_buff + i + 1) = '\0';
                    case KEYPAD_ENTER:                  // Enter key
                        *(digit_buff + i) = '\0';       // Finish the input string
                        *(lcd_buff + i) = '\0';
                        return;
                    default:                            // Numeric key: 0 to 9
                        if (i < digits) {               // Convert to ASCII
                            *(digit_buff + i) = (char)(key + '0');
                            *(lcd_buff + i) = '*';      // Display asterisk
                            i++;
                last_key = key;                         // Save the last key pressed value
                if (mode)
                if (key == KEYPAD_ESC)                  // If the DEL/ESC key was pressed
                    LCD_Cursor (LCD_CURSOR_LEFT);       // Move cursor to the left
                state = KEYPAD_PRESSED_STATE;           // Set next keypad state
            case KEYPAD_PRESSED_STATE:                        // Wait for numeric key release
                do {
                } while ((key <= KEYPAD_ENTER) && ISO7816_SmartCardReady());
                if (!ISO7816_SmartCardReady()) {        // If smart card withdrawal
                    *digit_buff = '\0';                 // Discard buffer contents
                    *lcd_buff = '\0';
                    return;                             // Exit
                state = KEYPAD_WAIT_STATE;              // Re-initialize state machine
Parameters:  alpha_buff -> keys pressed string in ASCII
                         letters -> number of alphanumeric characters to read
Returns:     None
Description: This function waits for an alphanumeric input from the keypad and
                         at the same time displays the key pressed on the LCD. The
             alphanumeric data is entered using a multiple keystroke algorithm
             similar to the input mechanism found on a cellular phone.
void KeyPad_GetAlpha (unsigned char *alpha_buff, unsigned char letters)
    unsigned char j = 0;
    unsigned long int timeout = 1000;
    *alpha_buff = '\0';                                 // Initialize display buffer
    LCD_String (LCD_LINE2, alpha_buff);                            // Display string
        switch (state) {
                do {
                    *alpha_buff = '\0';                 // Clear display buffers
                    return;                             // Exit
                switch (key) {
                    case KEYPAD_ESC:                    // If DEL/ESC key pressed
                        if (i > 0) {
                                        i--;                        // Clear previous character
                        *(alpha_buff + i) = ' ';        // Delete with white space
                        *(alpha_buff + i + 1) = '\0';
                    case KEYPAD_ENTER:
                        *(alpha_buff + i) = '\0';       // Finish the input string
                        return;                         // Exit
                    default:
                        if (i < letters) {              // Get first character of the key
                            *(alpha_buff + i) = pgm_read_byte (&KeyPad[key][0]);
                            j = 0;
                if (i < letters) {
                    last_key = key;                     // Save value of last key pressed
                    LCD_String (LCD_LINE2, alpha_buff);        // Display letter
            case KEYPAD_PRESSED_STATE:                  // Key release
                timeout = 1000;                         // Set timeout
                do {                                    // Do until key is released or timeout
                } while ((key <= KEYPAD_ENTER) && (--timeout) && ISO7816_SmartCardReady());         // Release
                    return;                             // Exit
                state = KEYPAD_PRESSED_TIMEOUT_STATE;   // Set next keypad state
            case KEYPAD_PRESSED_TIMEOUT_STATE:
                if (timeout == 0) {                     // If key is still pressed
                    if (key == KEYPAD_ESC) {            // And the key pressed is ESC key
                        *alpha_buff = '\0';             // Clear the LCD display
                        LCD_String (LCD_LINE2, "                ");
                        i = 0;
                    else {
                        if (i < letters) {              // Display numeric value of the key pressed
                            *(alpha_buff + i) = (char)(key + '0');  // Convert to ASCII
                            LCD_String (LCD_LINE2, alpha_buff);                // Display value
                            i++;
                    do {                                // Wait until key is released
                        return;                         // Exit
                    state = KEYPAD_WAIT_STATE;          // Set next keypad state
                else {
                    if ((last_key == KEYPAD_ESC) || (i >= letters)) {
                    else {
                        state = KEYPAD_RELEASE_STATE;   // Set next keypad state
            case KEYPAD_RELEASE_STATE:
                do {                                    // Wait for a key press or timeout
                } while ((key > KEYPAD_ENTER) && (--timeout) && ISO7816_SmartCardReady());
                    return;                             // Exit
                state = KEYPAD_RELEASE_TIMEOUT_STATE;   // Set next keypad state
            case KEYPAD_RELEASE_TIMEOUT_STATE:
                if (timeout == 0) {                     // If no key is pressed
                    i++;                                // Increment display index
                    LCD_Cursor (LCD_CURSOR_RIGHT);      // Move cursor to the right
                else {                                  // If a key pressed within timeout
                    j++;                                // Select next character of key
                    state = KEYPAD_NEXT_CHAR_STATE;     // Set next keypad state
            case KEYPAD_NEXT_CHAR_STATE:
                if (key == last_key) {                  // If key pressed is the same key
                    *(alpha_buff + i) = pgm_read_byte (&KeyPad[key][j % strlen_P (KeyPad[key])]);//KeyPad[key][j % strlen (KeyPad[key])];
                else {                                  // If key different from previous key
                    i++;
发表于 2006-12-22 08:43:09 | 显示全部楼层
就类似触摸屏的原理。
发表于 2008-7-14 16:56:16 | 显示全部楼层
MAKE
发表于 2008-7-14 17:00:00 | 显示全部楼层
MAKE
出0入46汤圆
发表于 2008-7-14 17:35:42 | 显示全部楼层
mark!
发表于 2008-7-14 20:22:13 | 显示全部楼层
第一次采集到的值 在延时20ms 再采集一次
如果误差范围之类 就算是一次稳定的按键
不过用AD做按键,很怕多个按键同时按下
不知道你的那个不能区分的出来
发表于 2008-9-9 09:51:11 | 显示全部楼层
mark
发表于 2008-9-9 10:03:20 | 显示全部楼层
用电容的话,一定要小,不然有响应问题!
发表于 2008-9-9 10:46:02 | 显示全部楼层
0.2v 应该可以分别吧!
5/1024=5mv啊
设置采样计算值 最小偏差< <最大偏差
发表于 2008-9-9 11:09:43 | 显示全部楼层
先读出AD的值,同一按键 多次按是不是一样,
发表于 2008-9-9 11:16:54 | 显示全部楼层
我试过ad按键,10位ad读出来的值非常稳,基本不会变,最多有+-1的变化,根本不需要滤波。用的vcc做基准,vcc是从7805出来的。楼主还是用示波器量一下按键时的电平,以及基准是否稳定。
发表于 2009-4-5 22:48:33 | 显示全部楼层
mark
发表于 2009-4-7 20:23:35 | 显示全部楼层
好像多个按键同时按下时就不太好处理了吧
发表于 2009-4-7 22:48:35 | 显示全部楼层
记号
发表于 2009-4-8 18:30:35 | 显示全部楼层
标记
发表于 2009-4-8 18:37:59 | 显示全部楼层
好图
发表于 2009-4-25 20:40:39 | 显示全部楼层
参考一下!
发表于 2009-9-8 08:54:39 | 显示全部楼层
let me mark it
发表于 2010-1-5 22:40:23 | 显示全部楼层
好方法  支持下
发表于 2010-1-6 09:39:24 | 显示全部楼层
mark
发表于 2010-11-15 20:58:17 | 显示全部楼层
mark
发表于 2010-12-7 15:13:58 | 显示全部楼层
mark
发表于 2011-9-2 10:47:49 | 显示全部楼层
mark 可以参考一下。
发表于 2011-9-28 15:13:53 | 显示全部楼层
mark,学习下
发表于 2011-12-2 16:33:21 | 显示全部楼层
mark..
出20入118汤圆
发表于 2013-5-5 11:47:18 | 显示全部楼层
mark 好东西
发表于 2013-5-5 12:51:27 | 显示全部楼层
cool !
发表于 2013-5-6 22:37:18 | 显示全部楼层
以前 有些 CRT彩电不就是用电阻分压做的按键,使用时间久了之后按键识别就不准了;学习用可以的;做产品还是算了吧
发表于 2013-5-7 08:58:30 | 显示全部楼层
太棒了!!!
发表于 2013-6-24 08:45:09 | 显示全部楼层
好方法,收藏了~
发表于 2013-6-24 09:26:06 | 显示全部楼层
ZLG7290,还是很好用的
发表于 2013-6-24 09:48:42 | 显示全部楼层
这个论题很好,值得收藏
GMT+8, 2024-8-26 23:24
