在网站上下载一个程序把ucos移植到mega128后,怎么二极管不闪阿?
感觉到好像是时间延时这个没有一起任务的在在一次调度,是不是缺少一个定时器中断阿,这个中断该怎么设置,那位高手帮下忙给说说,谢谢了!(编译没有问题的,是不是还有一个变量没有设置阿)
#include <includes.h>
#define CPU_CLK_FREQ 3684000L
#define OS_TASK_START_STK_SIZE OS_TASK_STK_SIZE
#define OS_TASK_START_HARD_STK_SIZE OS_TASK_HARD_STK_SIZE
#define OS_TASK_1_STK_SIZE OS_TASK_STK_SIZE
#define OS_TASK_1_HARD_STK_SIZE OS_TASK_HARD_STK_SIZE
#define OS_TASK_2_STK_SIZE OS_TASK_STK_SIZE
#define OS_TASK_2_HARD_STK_SIZE OS_TASK_HARD_STK_SIZE
OS_STK AppTaskStartStk[OS_TASK_START_STK_SIZE];
OS_STK AppTask1Stk[OS_TASK_1_STK_SIZE];
OS_STK AppTask2Stk[OS_TASK_2_STK_SIZE];
void main(void);
static void AppTaskStart(void *p_arg);
static void AppTaskCreate(void);
static void AppTask1(void *p_arg);
static void AppTask2(void *p_arg);
static void AppIOInit(void);
static void LED_Toggle(INT8U led);
void main (void)
/*---- Any initialization code prior to calling OSInit() goes HERE --------------------------------*/
OSInit()
OSTaskStkSize = OS_TASK_STK_SIZE; /* Setup the default stack size */
OSTaskHardStkSize = OS_TASK_HARD_STK_SIZE; /* Setup the default hardware */
OSInit(); /* Initialize "uC/OS-II, The Real-Time */
/*---- Any initialization code before starting multitasking ---------------------------------------*/
OSTaskStkSize = OS_TASK_START_STK_SIZE; /* Setup the total stack */
OSTaskHardStkSize = OS_TASK_START_HARD_STK_SIZE; /* Setup the hardware */
OSTaskCreate(AppTaskStart, (void *)0, (OS_STK *)&AppTaskStartStk[OSTaskStkSize - 1], 0);
/*---- Create any other task you want before we start multitasking --------------------------------*/
OSStart();
static void AppTaskStart (void *p_arg)
p_arg = p_arg;
OSTickISR_Init();
AppIOInit();
AppTaskCreate();
while (TRUE) {
LED_Toggle(1);
OSTimeDly(OS_TICKS_PER_SEC / 10);
static void AppTaskCreate (void)
/*---- Task initialization code goes HERE! --------------------------------------------------------*/
OSTaskStkSize = OS_TASK_1_STK_SIZE; /* Setup the default stack size */
OSTaskHardStkSize = OS_TASK_1_HARD_STK_SIZE; /* Setup the default hardware stack size */
OSTaskCreate(AppTask1, (void *)0, (OS_STK *)&AppTask1Stk[OSTaskStkSize - 1], 1);
OSTaskStkSize = OS_TASK_2_STK_SIZE; /* Setup the default stack size */
OSTaskHardStkSize = OS_TASK_2_HARD_STK_SIZE; /* Setup the default hardware stack size */
OSTaskCreate(AppTask2, (void *)0, (OS_STK *)&AppTask2Stk[OSTaskStkSize - 1], 2);
* TASK #1
p_arg = p_arg;
while (TRUE)
LED_Toggle(2);
OSTimeDly(OS_TICKS_PER_SEC / 5);
* TASK #2
p_arg = p_arg;
while (TRUE)
LED_Toggle(3);
OSTimeDly(OS_TICKS_PER_SEC / 2);
* SETUP THE I/Os
static void AppIOInit (void)
DDRD = 0xFF;
PORTD = 0xFF;
* SETUP THE TICK RATE
void OSTickISR_Init (void)
TCCR0 = 0x07; /* Set TIMER0 prescaler to TIMSK = 0x01;
void OSTickISR_Handler (void)
TCNT0 = 256 - (CPU_CLK_FREQ / OS_TICKS_PER_SEC / 1024);
OSTimeTick();
static void LED_Toggle (INT8U led)
#if OS_CRITICAL_METHOD == 3 /* Allocate storage for CPU status register */
OS_CPU_SR cpu_sr;
OS_ENTER_CRITICAL();
switch (led) {
case 1:
PORTD ^= 0x01;
case 2:
PORTD ^= 0x02;
case 3:
PORTD ^= 0x04;
case 4:
PORTD ^= 0x08;
OS_EXIT_CRITICAL();
