发表于 2006-10-31 14:57:56
!E F:/ucos&128/source/os_core.c(332): undeclared identifier `OSTCBPrioTbl'
!E F:/ucos&128/source/os_core.c(332): type error: pointer expected
!E F:/ucos&128/source/os_core.c(336): undeclared identifier `OSCtxSwCtr'
!W F:/ucos&128/source/os_core.c(337):[warning] calling function without prototype may cause errors
!E F:/ucos&128/source/os_core.c(378): unrecognized declaration
!E F:/ucos&128/source/os_core.c(423): unrecognized declaration
!E F:/ucos&128/source/os_core.c(450): undeclared identifier `OSRunning'
!E F:/ucos&128/source/os_core.c(451): undeclared identifier `OSRdyGrp'
!E F:/ucos&128/source/os_core.c(452): undeclared identifier `OSRdyTbl'
!E F:/ucos&128/source/os_core.c(452): too many errors
F:\icc\bin\imakew.exe: Error code 1
Done: there are error(s). Exit code: 1
这些我在以下文件中有定义阿
* uC/OS-II
* The Real-Time Kernel
* (c) Copyright 1992-2003, Jean J. Labrosse, Weston, FL
* All Rights Reserved
* File : uCOS_II.H
* By : Jean J. Labrosse
* Version : V2.76
// by yhl
//#ifndef ucos_ii.h
//#define ucos_ii.h
//#endif
#ifndef OS_uCOS_II_H
#define OS_uCOS_II_H
#include <os_cpu.h>
#include <os_cfg.h>
#ifdef __cplusplus
extern "C"
//#endif
* MISCELLANEOUS
#define OS_VERSION 276u /* Version of uC/OS-II (Vx.yy mult. by 100) */
#ifdef OS_GLOBALS
#define OS_EXT
#else
#define OS_EXT extern
#ifndef FALSE
#define FALSE 0
#ifndef TRUE
#define TRUE 1
#define OS_ASCII_NUL (char)0
#define OS_PRIO_SELF 0xFF /* Indicate SELF priority */
#if OS_TASK_STAT_EN > 0
#define OS_N_SYS_TASKS 2 /* Number of system tasks */
#else
#define OS_N_SYS_TASKS 1
#define OS_STAT_PRIO (OS_LOWEST_PRIO - 1) /* Statistic task priority */
#define OS_IDLE_PRIO (OS_LOWEST_PRIO) /* IDLE task priority */
#define OS_EVENT_TBL_SIZE ((OS_LOWEST_PRIO) / 8 + 1) /* Size of event table */
#define OS_RDY_TBL_SIZE ((OS_LOWEST_PRIO) / 8 + 1) /* Size of ready table */
#define OS_TASK_IDLE_ID 65535u /* I.D. numbers for Idle and Stat tasks */
#define OS_TASK_STAT_ID 65534u
#define OS_EVENT_EN (((OS_Q_EN > 0) && (OS_MAX_QS > 0)) || (OS_MBOX_EN > 0) || (OS_SEM_EN > 0) || (OS_MUTEX_EN > 0))
/*$PAGE*/.
* TASK STATUS (Bit definition for OSTCBStat)
#define OS_STAT_RDY 0x00 /* Ready to run */
#define OS_STAT_SEM 0x01 /* Pending on semaphore */
#define OS_STAT_MBOX 0x02 /* Pending on mailbox */
#define OS_STAT_Q 0x04 /* Pending on queue */
#define OS_STAT_SUSPEND 0x08 /* Task is suspended */
#define OS_STAT_MUTEX 0x10 /* Pending on mutual exclusion semaphore */
#define OS_STAT_FLAG 0x20 /* Pending on event flag group */
#define OS_STAT_PEND_ANY (OS_STAT_SEM | OS_STAT_MBOX | OS_STAT_Q | OS_STAT_MUTEX | OS_STAT_FLAG)
* OS_EVENT types
#define OS_EVENT_TYPE_UNUSED 0
#define OS_EVENT_TYPE_MBOX 1
#define OS_EVENT_TYPE_Q 2
#define OS_EVENT_TYPE_SEM 3
#define OS_EVENT_TYPE_MUTEX 4
#define OS_EVENT_TYPE_FLAG 5
* EVENT FLAGS
#define OS_FLAG_WAIT_CLR_ALL 0 /* Wait for ALL the bits specified to be CLR (i.e. 0) */
#define OS_FLAG_WAIT_CLR_AND 0
#define OS_FLAG_WAIT_CLR_ANY 1 /* Wait for ANY of the bits specified to be CLR (i.e. 0) */
#define OS_FLAG_WAIT_CLR_OR 1
#define OS_FLAG_WAIT_SET_ALL 2 /* Wait for ALL the bits specified to be SET (i.e. 1) */
#define OS_FLAG_WAIT_SET_AND 2
#define OS_FLAG_WAIT_SET_ANY 3 /* Wait for ANY of the bits specified to be SET (i.e. 1) */
#define OS_FLAG_WAIT_SET_OR 3
#define OS_FLAG_CONSUME 0x80 /* Consume the flags if condition(s) satisfied */
#define OS_FLAG_CLR 0
#define OS_FLAG_SET 1
* Values for OSTickStepState
* Note(s): This feature is used by uC/OS-View.
#if OS_TICK_STEP_EN > 0
#define OS_TICK_STEP_DIS 0 /* Stepping is disabled, tick runs as mormal */
#define OS_TICK_STEP_WAIT 1 /* Waiting for uC/OS-View to set OSTickStepState to _ONCE */
#define OS_TICK_STEP_ONCE 2 /* Process tick once and wait for next cmd from uC/OS-View */
* Possible values for 'opt' argument of OSSemDel(), OSMboxDel(), OSQDel() and OSMutexDel()
#define OS_DEL_NO_PEND 0
#define OS_DEL_ALWAYS 1
* OS???PostOpt() OPTIONS
* These #defines are used to establish the options for OSMboxPostOpt() and OSQPostOpt().
#define OS_POST_OPT_NONE 0x00 /* Post to highest priority task waiting */
#define OS_POST_OPT_BROADCAST 0x01 /* Broadcast message to ALL tasks waiting */
#define OS_POST_OPT_FRONT 0x02 /* Post to highest priority task waiting */
* TASK OPTIONS (see OSTaskCreateExt())
#define OS_TASK_OPT_STK_CHK 0x0001 /* Enable stack checking for the task */
#define OS_TASK_OPT_STK_CLR 0x0002 /* Clear the stack when the task is create */
#define OS_TASK_OPT_SAVE_FP 0x0004 /* Save the contents of any floating-point registers */
* ERROR CODES
#define OS_NO_ERR 0
#define OS_ERR_EVENT_TYPE 1u
#define OS_ERR_PEND_ISR 2u
#define OS_ERR_POST_NULL_PTR 3u
#define OS_ERR_PEVENT_NULL 4u
#define OS_ERR_POST_ISR 5u
#define OS_ERR_QUERY_ISR 6u
#define OS_ERR_INVALID_OPT 7u
#define OS_ERR_TASK_WAITING 8u
#define OS_TIMEOUT 10u
#define OS_TASK_NOT_EXIST 11u
#define OS_ERR_EVENT_NAME_TOO_LONG 12u
#define OS_ERR_FLAG_NAME_TOO_LONG 13u
#define OS_ERR_TASK_NAME_TOO_LONG 14u
#define OS_ERR_PNAME_NULL 15u
#define OS_ERR_TASK_CREATE_ISR 16u
#define OS_MBOX_FULL 20u
#define OS_Q_FULL 30u
#define OS_Q_EMPTY 31u
#define OS_PRIO_EXIST 40u
#define OS_PRIO_ERR 41u
#define OS_PRIO_INVALID 42u
#define OS_SEM_OVF 50u
#define OS_TASK_DEL_ERR 60u
#define OS_TASK_DEL_IDLE 61u
#define OS_TASK_DEL_REQ 62u
#define OS_TASK_DEL_ISR 63u
#define OS_NO_MORE_TCB 70u
#define OS_TIME_NOT_DLY 80u
#define OS_TIME_INVALID_MINUTES 81u
#define OS_TIME_INVALID_SECONDS 82u
#define OS_TIME_INVALID_MILLI 83u
#define OS_TIME_ZERO_DLY 84u
#define OS_TASK_SUSPEND_PRIO 90u
#define OS_TASK_SUSPEND_IDLE 91u
#define OS_TASK_RESUME_PRIO 100u
#define OS_TASK_NOT_SUSPENDED 101u
#define OS_MEM_INVALID_PART 110u
#define OS_MEM_INVALID_BLKS 111u
#define OS_MEM_INVALID_SIZE 112u
#define OS_MEM_NO_FREE_BLKS 113u
#define OS_MEM_FULL 114u
#define OS_MEM_INVALID_PBLK 115u
#define OS_MEM_INVALID_PMEM 116u
#define OS_MEM_INVALID_PDATA 117u
#define OS_MEM_INVALID_ADDR 118u
#define OS_MEM_NAME_TOO_LONG 119u
#define OS_ERR_NOT_MUTEX_OWNER 120u
#define OS_TASK_OPT_ERR 130u
#define OS_ERR_DEL_ISR 140u
#define OS_ERR_CREATE_ISR 141u
#define OS_FLAG_INVALID_PGRP 150u
#define OS_FLAG_ERR_WAIT_TYPE 151u
#define OS_FLAG_ERR_NOT_RDY 152u
#define OS_FLAG_INVALID_OPT 153u
#define OS_FLAG_GRP_DEPLETED 154u
* EVENT CONTROL BLOCK
#if OS_EVENT_EN && (OS_MAX_EVENTS > 0)
typedef struct os_event
INT8U OSEventType; /* Type of event control block (see OS_EVENT_TYPE_???) */
INT8U OSEventGrp; /* Group corresponding to tasks waiting for event to occur */
INT16U OSEventCnt; /* Semaphore Count (not used if other EVENT type) */
void *OSEventPtr; /* Pointer to message or queue structure */
INT8U OSEventTbl[OS_EVENT_TBL_SIZE]; /* List of tasks waiting for event to occur */
#if OS_EVENT_NAME_SIZE > 1
char OSEventName[OS_EVENT_NAME_SIZE];
} OS_EVENT;
* EVENT FLAGS CONTROL BLOCK
#if (OS_VERSION >= 251) && (OS_FLAG_EN > 0) && (OS_MAX_FLAGS > 0)
typedef struct os_flag_grp { /* Event Flag Group */
INT8U OSFlagType; /* Should be set to OS_EVENT_TYPE_FLAG */
void *OSFlagWaitList; /* Pointer to first NODE of task waiting on event flag */
OS_FLAGS OSFlagFlags; /* 8, 16 or 32 bit flags */
#if OS_FLAG_NAME_SIZE > 1
char OSFlagName[OS_FLAG_NAME_SIZE];
} OS_FLAG_GRP;
typedef struct os_flag_node
{ /* Event Flag Wait List Node */
void *OSFlagNodeNext; /* Pointer to next NODE in wait list */
void *OSFlagNodePrev; /* Pointer to previous NODE in wait list */
void *OSFlagNodeTCB; /* Pointer to TCB of waiting task */
void *OSFlagNodeFlagGrp; /* Pointer to Event Flag Group */
OS_FLAGS OSFlagNodeFlags; /* Event flag to wait on */
INT8U OSFlagNodeWaitType; /* Type of wait: */
/* OS_FLAG_WAIT_AND */
/* OS_FLAG_WAIT_ALL */
/* OS_FLAG_WAIT_OR */
/* OS_FLAG_WAIT_ANY */
} OS_FLAG_NODE;
* MESSAGE MAILBOX DATA
#if OS_MBOX_EN > 0
typedef struct os_mbox_data {
void *OSMsg; /* Pointer to message in mailbox */
} OS_MBOX_DATA;
* MEMORY PARTITION DATA STRUCTURES
#if (OS_MEM_EN > 0) && (OS_MAX_MEM_PART > 0)
typedef struct os_mem { /* MEMORY CONTROL BLOCK */
void *OSMemAddr; /* Pointer to beginning of memory partition */
void *OSMemFreeList; /* Pointer to list of free memory blocks */
INT32U OSMemBlkSize; /* Size (in bytes) of each block of memory */
INT32U OSMemNBlks; /* Total number of blocks in this partition */
INT32U OSMemNFree; /* Number of memory blocks remaining in this partition */
#if OS_MEM_NAME_SIZE > 1
char OSMemName[OS_MEM_NAME_SIZE]; /* Memory partition name */
} OS_MEM;
typedef struct os_mem_data {
void *OSAddr; /* Pointer to the beginning address of the memory partition */
void *OSFreeList; /* Pointer to the beginning of the free list of memory blocks */
INT32U OSBlkSize; /* Size (in bytes) of each memory block */
INT32U OSNBlks; /* Total number of blocks in the partition */
INT32U OSNFree; /* Number of memory blocks free */
INT32U OSNUsed; /* Number of memory blocks used */
} OS_MEM_DATA;
* MUTUAL EXCLUSION SEMAPHORE DATA
#if OS_MUTEX_EN > 0
typedef struct os_mutex_data {
INT8U OSValue; /* Mutex value (0 = used, 1 = available) */
INT8U OSOwnerPrio; /* Mutex owner's task priority or 0xFF if no owner */
INT8U OSMutexPIP; /* Priority Inheritance Priority or 0xFF if no owner */
} OS_MUTEX_DATA;
* MESSAGE QUEUE DATA
#if OS_Q_EN > 0
typedef struct os_q { /* QUEUE CONTROL BLOCK */
struct os_q *OSQPtr; /* Link to next queue control block in list of free blocks */
void **OSQStart; /* Pointer to start of queue data */
void **OSQEnd; /* Pointer to end of queue data */
void **OSQIn; /* Pointer to where next message will be inserted in the Q */
void **OSQOut; /* Pointer to where next message will be extracted from the Q */
INT16U OSQSize; /* Size of queue (maximum number of entries) */
INT16U OSQEntries; /* Current number of entries in the queue */
} OS_Q;
typedef struct os_q_data {
void *OSMsg; /* Pointer to next message to be extracted from queue */
INT16U OSNMsgs; /* Number of messages in message queue */
INT16U OSQSize; /* Size of message queue */
} OS_Q_DATA;
* SEMAPHORE DATA
#if OS_SEM_EN > 0
typedef struct os_sem_data {
INT16U OSCnt; /* Semaphore count */
} OS_SEM_DATA;
* TASK STACK DATA
#if OS_TASK_CREATE_EXT_EN > 0
typedef struct os_stk_data {
INT32U OSFree; /* Number of free bytes on the stack */
INT32U OSUsed; /* Number of bytes used on the stack */
} OS_STK_DATA;
* TASK CONTROL BLOCK
typedef struct os_tcb {
OS_STK *OSTCBStkPtr; /* Pointer to current top of stack */
void *OSTCBExtPtr; /* Pointer to user definable data for TCB extension */
OS_STK *OSTCBStkBottom; /* Pointer to bottom of stack */
INT32U OSTCBStkSize; /* Size of task stack (in number of stack elements) */
INT16U OSTCBOpt; /* Task options as passed by OSTaskCreateExt() */
INT16U OSTCBId; /* Task ID (0..65535) */
struct os_tcb *OSTCBNext; /* Pointer to next TCB in the TCB list */
struct os_tcb *OSTCBPrev; /* Pointer to previous TCB in the TCB list */
#if OS_EVENT_EN
OS_EVENT *OSTCBEventPtr; /* Pointer to event control block */
#if ((OS_Q_EN > 0) && (OS_MAX_QS > 0)) || (OS_MBOX_EN > 0)
void *OSTCBMsg; /* Message received from OSMboxPost() or OSQPost() */
#if OS_TASK_DEL_EN > 0
OS_FLAG_NODE *OSTCBFlagNode; /* Pointer to event flag node */
OS_FLAGS OSTCBFlagsRdy; /* Event flags that made task ready to run */
INT16U OSTCBDly; /* Nbr ticks to delay task or, timeout waiting for event */
INT8U OSTCBStat; /* Task status */
BOOLEAN OSTCBPendTO; /* Flag indicating PEND timed out (TRUE == timed out) */
INT8U OSTCBPrio; /* Task priority (0 == highest, 63 == lowest) */
INT8U OSTCBX; /* Bit position in group corresponding to task priority (0..7) */
INT8U OSTCBY; /* Index into ready table corresponding to task priority */
INT8U OSTCBBitX; /* Bit mask to access bit position in ready table */
INT8U OSTCBBitY; /* Bit mask to access bit position in ready group */
INT8U OSTCBDelReq; /* Indicates whether a task needs to delete itself */
#if OS_TASK_PROFILE_EN > 0
INT32U OSTCBCtxSwCtr; /* Number of time the task was switched in */
INT32U OSTCBCyclesTot; /* Total number of clock cycles the task has been running */
INT32U OSTCBCyclesStart; /* Snapshot of cycle counter at start of task resumption */
OS_STK *OSTCBStkBase; /* Pointer to the beginning of the task stack */
INT32U OSTCBStkUsed; /* Number of bytes used from the stack */
#if OS_TASK_NAME_SIZE > 1
char OSTCBTaskName[OS_TASK_NAME_SIZE];
} OS_TCB;
* GLOBAL VARIABLES
OS_EXT INT32U OSCtxSwCtr; /* Counter of number of context switches */
OS_EXT OS_EVENT *OSEventFreeList; /* Pointer to list of free EVENT control blocks */
OS_EXT OS_EVENT OSEventTbl[OS_MAX_EVENTS];/* Table of EVENT control blocks */
OS_EXT OS_FLAG_GRP OSFlagTbl[OS_MAX_FLAGS]; /* Table containing event flag groups */
OS_EXT OS_FLAG_GRP *OSFlagFreeList; /* Pointer to free list of event flag groups */
OS_EXT INT8S OSCPUUsage; /* Percentage of CPU used */
OS_EXT INT32U OSIdleCtrMax; /* Max. value that idle ctr can take in 1 sec. */
OS_EXT INT32U OSIdleCtrRun; /* Val. reached by idle ctr at run time in 1 sec. */
OS_EXT BOOLEAN OSStatRdy; /* Flag indicating that the statistic task is rdy */
OS_EXT OS_STK OSTaskStatStk[OS_TASK_STAT_STK_SIZE]; /* Statistics task stack */
OS_EXT INT8U OSIntNesting; /* Interrupt nesting level */
OS_EXT INT8U OSLockNesting; /* Multitasking lock nesting level */
OS_EXT INT8U OSPrioCur; /* Priority of current task */
OS_EXT INT8U OSPrioHighRdy; /* Priority of highest priority task */
OS_EXT INT8U OSRdyGrp; /* Ready list group */
OS_EXT INT8U OSRdyTbl[OS_RDY_TBL_SIZE]; /* Table of tasks which are ready to run */
OS_EXT BOOLEAN OSRunning; /* Flag indicating that kernel is running */
OS_EXT INT8U OSTaskCtr; /* Number of tasks created */
OS_EXT volatile INT32U OSIdleCtr; /* Idle counter */
OS_EXT OS_STK OSTaskIdleStk[OS_TASK_IDLE_STK_SIZE]; /* Idle task stack */
OS_EXT OS_TCB *OSTCBCur; /* Pointer to currently running TCB */
OS_EXT OS_TCB *OSTCBFreeList; /* Pointer to list of free TCBs */
OS_EXT OS_TCB *OSTCBHighRdy; /* Pointer to highest priority TCB R-to-R */
OS_EXT OS_TCB *OSTCBList; /* Pointer to doubly linked list of TCBs */
OS_EXT OS_TCB *OSTCBPrioTbl[OS_LOWEST_PRIO + 1];/* Table of pointers to created TCBs */
OS_EXT OS_TCB OSTCBTbl[OS_MAX_TASKS + OS_N_SYS_TASKS]; /* Table of TCBs */
OS_EXT INT8U OSTickStepState; /* Indicates the state of the tick step feature */
OS_EXT OS_MEM *OSMemFreeList; /* Pointer to free list of memory partitions */
OS_EXT OS_MEM OSMemTbl[OS_MAX_MEM_PART];/* Storage for memory partition manager */
#if (OS_Q_EN > 0) && (OS_MAX_QS > 0)
OS_EXT OS_Q *OSQFreeList; /* Pointer to list of free QUEUE control blocks */
OS_EXT OS_Q OSQTbl[OS_MAX_QS]; /* Table of QUEUE control blocks */
#if OS_TIME_GET_SET_EN > 0
OS_EXT volatile INT32U OSTime; /* Current value of system time (in ticks) */
extern INT8U const OSMapTbl[8]; /* Priority->Bit Mask lookup table */
extern INT8U const OSUnMapTbl[256]; /* Priority->Index lookup table */
* FUNCTION PROTOTYPES
* (Target Independent Functions)
* MISCELLANEOUS
#if OS_EVENT_EN && (OS_EVENT_NAME_SIZE > 1)
INT8U OSEventNameGet(OS_EVENT *pevent, char *pname, INT8U *err);
void OSEventNameSet(OS_EVENT *pevent, char *pname, INT8U *err);
* EVENT FLAGS MANAGEMENT
#if OS_FLAG_ACCEPT_EN > 0
OS_FLAGS OSFlagAccept(OS_FLAG_GRP *pgrp, OS_FLAGS flags, INT8U wait_type, INT8U *err);
OS_FLAG_GRP *OSFlagCreate(OS_FLAGS flags, INT8U *err);
#if OS_FLAG_DEL_EN > 0
OS_FLAG_GRP *OSFlagDel(OS_FLAG_GRP *pgrp, INT8U opt, INT8U *err);
#if (OS_FLAG_EN > 0) && (OS_FLAG_NAME_SIZE > 1)
INT8U OSFlagNameGet(OS_FLAG_GRP *pgrp, char *pname, INT8U *err);
void OSFlagNameSet(OS_FLAG_GRP *pgrp, char *pname, INT8U *err);
OS_FLAGS OSFlagPend(OS_FLAG_GRP *pgrp, OS_FLAGS flags, INT8U wait_type, INT16U timeout, INT8U *err);
OS_FLAGS OSFlagPendGetFlagsRdy(void);
OS_FLAGS OSFlagPost(OS_FLAG_GRP *pgrp, OS_FLAGS flags, INT8U opt, INT8U *err);
#if OS_FLAG_QUERY_EN > 0
OS_FLAGS OSFlagQuery(OS_FLAG_GRP *pgrp, INT8U *err);
* MESSAGE MAILBOX MANAGEMENT
#if OS_MBOX_EN > 0
#if OS_MBOX_ACCEPT_EN > 0
void *OSMboxAccept(OS_EVENT *pevent);
OS_EVENT *OSMboxCreate(void *msg);
#if OS_MBOX_DEL_EN > 0
OS_EVENT *OSMboxDel(OS_EVENT *pevent, INT8U opt, INT8U *err);
void *OSMboxPend(OS_EVENT *pevent, INT16U timeout, INT8U *err);
#if OS_MBOX_POST_EN > 0
INT8U OSMboxPost(OS_EVENT *pevent, void *msg);
#if OS_MBOX_POST_OPT_EN > 0
INT8U OSMboxPostOpt(OS_EVENT *pevent, void *msg, INT8U opt);
#if OS_MBOX_QUERY_EN > 0
INT8U OSMboxQuery(OS_EVENT *pevent, OS_MBOX_DATA *p_mbox_data);
* MEMORY MANAGEMENT
OS_MEM *OSMemCreate(void *addr, INT32U nblks, INT32U blksize, INT8U *err);
void *OSMemGet(OS_MEM *pmem, INT8U *err);
INT8U OSMemNameGet(OS_MEM *pmem, char *pname, INT8U *err);
void OSMemNameSet(OS_MEM *pmem, char *pname, INT8U *err);
INT8U OSMemPut(OS_MEM *pmem, void *pblk);
#if OS_MEM_QUERY_EN > 0
INT8U OSMemQuery(OS_MEM *pmem, OS_MEM_DATA *p_mem_data);
* MUTUAL EXCLUSION SEMAPHORE MANAGEMENT
#if OS_MUTEX_EN > 0
#if OS_MUTEX_ACCEPT_EN > 0
INT8U OSMutexAccept(OS_EVENT *pevent, INT8U *err);
OS_EVENT *OSMutexCreate(INT8U prio, INT8U *err);
#if OS_MUTEX_DEL_EN > 0
OS_EVENT *OSMutexDel(OS_EVENT *pevent, INT8U opt, INT8U *err);
void OSMutexPend(OS_EVENT *pevent, INT16U timeout, INT8U *err);
INT8U OSMutexPost(OS_EVENT *pevent);
#if OS_MUTEX_QUERY_EN > 0
INT8U OSMutexQuery(OS_EVENT *pevent, OS_MUTEX_DATA *p_mutex_data);
* MESSAGE QUEUE MANAGEMENT
#if OS_Q_ACCEPT_EN > 0
void *OSQAccept(OS_EVENT *pevent, INT8U *err);
OS_EVENT *OSQCreate(void **start, INT16U size);
#if OS_Q_DEL_EN > 0
OS_EVENT *OSQDel(OS_EVENT *pevent, INT8U opt, INT8U *err);
#if OS_Q_FLUSH_EN > 0
INT8U OSQFlush(OS_EVENT *pevent);
void *OSQPend(OS_EVENT *pevent, INT16U timeout, INT8U *err);
#if OS_Q_POST_EN > 0
INT8U OSQPost(OS_EVENT *pevent, void *msg);
#if OS_Q_POST_FRONT_EN > 0
INT8U OSQPostFront(OS_EVENT *pevent, void *msg);
#if OS_Q_POST_OPT_EN > 0
INT8U OSQPostOpt(OS_EVENT *pevent, void *msg, INT8U opt);
#if OS_Q_QUERY_EN > 0
INT8U OSQQuery(OS_EVENT *pevent, OS_Q_DATA *p_q_data);
/*$PAGE*/.
* SEMAPHORE MANAGEMENT
#if OS_SEM_EN > 0
#if OS_SEM_ACCEPT_EN > 0
INT16U OSSemAccept(OS_EVENT *pevent);
OS_EVENT *OSSemCreate(INT16U cnt);
#if OS_SEM_DEL_EN > 0
OS_EVENT *OSSemDel(OS_EVENT *pevent, INT8U opt, INT8U *err);
void OSSemPend(OS_EVENT *pevent, INT16U timeout, INT8U *err);
INT8U OSSemPost(OS_EVENT *pevent);
#if OS_SEM_QUERY_EN > 0
INT8U OSSemQuery(OS_EVENT *pevent, OS_SEM_DATA *p_sem_data);
#if OS_SEM_SET_EN > 0
void OSSemSet(OS_EVENT *pevent, INT16U cnt, INT8U *err);
/*$PAGE*/.
* TASK MANAGEMENT
#if OS_TASK_CHANGE_PRIO_EN > 0
INT8U OSTaskChangePrio(INT8U oldprio, INT8U newprio);
#if OS_TASK_CREATE_EN > 0
INT8U OSTaskCreate(void (*task)(void *pd), void *p_arg, OS_STK *ptos, INT8U prio);
INT8U OSTaskCreateExt(void (*task)(void *pd),
void *p_arg,
OS_STK *ptos,
INT8U prio,
INT16U id,
OS_STK *pbos,
INT32U stk_size,
void *pext,
INT16U opt);
INT8U OSTaskDel(INT8U prio);
INT8U OSTaskDelReq(INT8U prio);
INT8U OSTaskNameGet(INT8U prio, char *pname, INT8U *err);
void OSTaskNameSet(INT8U prio, char *pname, INT8U *err);
#if OS_TASK_SUSPEND_EN > 0
INT8U OSTaskResume(INT8U prio);
INT8U OSTaskSuspend(INT8U prio);
INT8U OSTaskStkChk(INT8U prio, OS_STK_DATA *p_stk_data);
#if OS_TASK_QUERY_EN > 0
INT8U OSTaskQuery(INT8U prio, OS_TCB *p_task_data);
* TIME MANAGEMENT
void OSTimeDly(INT16U ticks);
#if OS_TIME_DLY_HMSM_EN > 0
INT8U OSTimeDlyHMSM(INT8U hours, INT8U minutes, INT8U seconds, INT16U milli);
#if OS_TIME_DLY_RESUME_EN > 0
INT8U OSTimeDlyResume(INT8U prio);
INT32U OSTimeGet(void);
void OSTimeSet(INT32U ticks);
void OSTimeTick(void);
* MISCELLANEOUS
void OSInit(void);
void OSIntEnter(void);
void OSIntExit(void);
#if OS_SCHED_LOCK_EN > 0
void OSSchedLock(void);
void OSSchedUnlock(void);
void OSStart(void);
void OSStatInit(void);
INT16U OSVersion(void);
* INTERNAL FUNCTION PROTOTYPES
* (Your application MUST NOT call these functions)
void OS_Dummy(void);
#if OS_EVENT_EN
INT8U OS_EventTaskRdy(OS_EVENT *pevent, void *msg, INT8U msk);
void OS_EventTaskWait(OS_EVENT *pevent);
void OS_EventTO(OS_EVENT *pevent);
void OS_EventWaitListInit(OS_EVENT *pevent);
void OS_FlagInit(void);
void OS_FlagUnlink(OS_FLAG_NODE *pnode);
void OS_MemClr(INT8U *pdest, INT16U size);
void OS_MemCopy(INT8U *pdest, INT8U *psrc, INT16U size);
void OS_MemInit(void);
#if OS_Q_EN > 0
void OS_QInit(void);
void OS_Sched(void);
#if (OS_EVENT_NAME_SIZE > 1) || (OS_FLAG_NAME_SIZE > 1) || (OS_MEM_NAME_SIZE > 1) || (OS_TASK_NAME_SIZE > 1)
INT8U OS_StrCopy(char *pdest, char *psrc);
INT8U OS_StrLen(char *psrc);
void OS_TaskIdle(void *p_arg);
void OS_TaskStat(void *p_arg);
void OS_TaskStkClr(OS_STK *pbos, INT32U size, INT16U opt);
#if (OS_TASK_STAT_STK_CHK_EN > 0) && (OS_TASK_CREATE_EXT_EN > 0)
void OS_TaskStatStkChk(void);
INT8U OS_TCBInit(INT8U prio, OS_STK *ptos, OS_STK *pbos, INT16U id, INT32U stk_size, void *pext, INT16U opt);
* (Target Specific Functions)
#if OS_VERSION >= 270 && OS_DEBUG_EN > 0
void OSDebugInit(void);
#if OS_VERSION >= 204
void OSInitHookBegin(void);
void OSInitHookEnd(void);
void OSIntCtxSw(void);
void OSStartHighRdy(void);
void OSTaskCreateHook(OS_TCB *ptcb);
void OSTaskDelHook(OS_TCB *ptcb);
#if OS_VERSION >= 251
void OSTaskIdleHook(void);
void OSTaskStatHook(void);
OS_STK *OSTaskStkInit(void (*task)(void *pd), void *p_arg, OS_STK *ptos, INT16U opt);
#if OS_TASK_SW_HOOK_EN > 0
void OSTaskSwHook(void);
void OSTCBInitHook(OS_TCB *ptcb);
#if OS_TIME_TICK_HOOK_EN > 0
void OSTimeTickHook(void);
* (Compiler Specific ISR prototypes)
#ifndef OS_ISR_PROTO_EXT
void OSCtxSw(void);
void OSTickISR(void);
* LOOK FOR MISSING #define CONSTANTS
* This section is used to generate ERROR messages at compile time if certain #define constants are
* MISSING in OS_CFG.H. This allows you to quickly determine the source of the error.
* You SHOULD NOT change this section UNLESS you would like to add more comments as to the source of the
* compile time error.
* EVENT FLAGS
#ifndef OS_FLAG_EN
#error "OS_CFG.H, Missing OS_FLAG_EN: Enable (1) or Disable (0) code generation for Event Flags"
#else
#ifndef OS_MAX_FLAGS
#error "OS_CFG.H, Missing OS_MAX_FLAGS: Max. number of Event Flag Groups in your application"
#else
#if OS_MAX_FLAGS > 65500
#error "OS_CFG.H, OS_MAX_FLAGS must be <= 65500"
#ifndef OS_FLAG_WAIT_CLR_EN
#error "OS_CFG.H, Missing OS_FLAG_WAIT_CLR_EN: Include code for Wait on Clear EVENT FLAGS"
#ifndef OS_FLAG_ACCEPT_EN
#error "OS_CFG.H, Missing OS_FLAG_ACCEPT_EN: Include code for OSFlagAccept()"
#ifndef OS_FLAG_DEL_EN
#error "OS_CFG.H, Missing OS_FLAG_DEL_EN: Include code for OSFlagDel()"
#ifndef OS_FLAG_NAME_SIZE
#error "OS_CFG.H, Missing OS_FLAG_NAME_SIZE: Determines the size of flag group names"
#ifndef OS_FLAG_QUERY_EN
#error "OS_CFG.H, Missing OS_FLAG_QUERY_EN: Include code for OSFlagQuery()"
* MESSAGE MAILBOXES
#ifndef OS_MBOX_EN
#error "OS_CFG.H, Missing OS_MBOX_EN: Enable (1) or Disable (0) code generation for MAILBOXES"
#else
#ifndef OS_MBOX_ACCEPT_EN
#error "OS_CFG.H, Missing OS_MBOX_ACCEPT_EN: Include code for OSMboxAccept()"
#ifndef OS_MBOX_DEL_EN
#error "OS_CFG.H, Missing OS_MBOX_DEL_EN: Include code for OSMboxDel()"
#ifndef OS_MBOX_POST_EN
#error "OS_CFG.H, Missing OS_MBOX_POST_EN: Include code for OSMboxPost()"
#ifndef OS_MBOX_POST_OPT_EN
#error "OS_CFG.H, Missing OS_MBOX_POST_OPT_EN: Include code for OSMboxPostOpt()"
#ifndef OS_MBOX_QUERY_EN
#error "OS_CFG.H, Missing OS_MBOX_QUERY_EN: Include code for OSMboxQuery()"
* MEMORY MANAGEMENT
#ifndef OS_MEM_EN
#error "OS_CFG.H, Missing OS_MEM_EN: Enable (1) or Disable (0) code generation for MEMORY MANAGER"
#else
#ifndef OS_MAX_MEM_PART
#error "OS_CFG.H, Missing OS_MAX_MEM_PART: Max. number of memory partitions"
#else
#if OS_MAX_MEM_PART > 65500
#error "OS_CFG.H, OS_MAX_MEM_PART must be <= 65500"
#ifndef OS_MEM_NAME_SIZE
#error "OS_CFG.H, Missing OS_MEM_NAME_SIZE: Determines the size of memory partition names"
#ifndef OS_MEM_QUERY_EN
#error "OS_CFG.H, Missing OS_MEM_QUERY_EN: Include code for OSMemQuery()"
* MUTUAL EXCLUSION SEMAPHORES
#ifndef OS_MUTEX_EN
#error "OS_CFG.H, Missing OS_MUTEX_EN: Enable (1) or Disable (0) code generation for MUTEX"
#else
#ifndef OS_MUTEX_ACCEPT_EN
#error "OS_CFG.H, Missing OS_MUTEX_ACCEPT_EN: Include code for OSMutexAccept()"
#ifndef OS_MUTEX_DEL_EN
#error "OS_CFG.H, Missing OS_MUTEX_DEL_EN: Include code for OSMutexDel()"
#ifndef OS_MUTEX_QUERY_EN
#error "OS_CFG.H, Missing OS_MUTEX_QUERY_EN: Include code for OSMutexQuery()"
* MESSAGE QUEUES
#ifndef OS_Q_EN
#error "OS_CFG.H, Missing OS_Q_EN: Enable (1) or Disable (0) code generation for QUEUES"
#else
#ifndef OS_MAX_QS
#error "OS_CFG.H, Missing OS_MAX_QS: Max. number of queue control blocks"
#else
#if OS_MAX_QS > 65500
#error "OS_CFG.H, OS_MAX_QS must be <= 65500"
#ifndef OS_Q_ACCEPT_EN
#error "OS_CFG.H, Missing OS_Q_ACCEPT_EN: Include code for OSQAccept()"
#ifndef OS_Q_DEL_EN
#error "OS_CFG.H, Missing OS_Q_DEL_EN: Include code for OSQDel()"
#ifndef OS_Q_FLUSH_EN
#error "OS_CFG.H, Missing OS_Q_FLUSH_EN: Include code for OSQFlush()"
#ifndef OS_Q_POST_EN
#error "OS_CFG.H, Missing OS_Q_POST_EN: Include code for OSQPost()"
#ifndef OS_Q_POST_FRONT_EN
#error "OS_CFG.H, Missing OS_Q_POST_FRONT_EN: Include code for OSQPostFront()"
#ifndef OS_Q_POST_OPT_EN
#error "OS_CFG.H, Missing OS_Q_POST_OPT_EN: Include code for OSQPostOpt()"
#ifndef OS_Q_QUERY_EN
#error "OS_CFG.H, Missing OS_Q_QUERY_EN: Include code for OSQQuery()"
* SEMAPHORES
#ifndef OS_SEM_EN
#error "OS_CFG.H, Missing OS_SEM_EN: Enable (1) or Disable (0) code generation for SEMAPHORES"
#else
#ifndef OS_SEM_ACCEPT_EN
#error "OS_CFG.H, Missing OS_SEM_ACCEPT_EN: Include code for OSSemAccept()"
#ifndef OS_SEM_DEL_EN
#error "OS_CFG.H, Missing OS_SEM_DEL_EN: Include code for OSSemDel()"
#ifndef OS_SEM_QUERY_EN
#error "OS_CFG.H, Missing OS_SEM_QUERY_EN: Include code for OSSemQuery()"
#ifndef OS_SEM_SET_EN
#error "OS_CFG.H, Missing OS_SEM_SET_EN: Include code for OSSemSet()"
* TASK MANAGEMENT
#ifndef OS_MAX_TASKS
#error "OS_CFG.H, Missing OS_MAX_TASKS: Max. number of tasks in your application"
#else
#if OS_MAX_TASKS < 2
#error "OS_CFG.H, OS_MAX_TASKS must be >= 2"
#if OS_MAX_TASKS > 63
#error "OS_CFG.H, OS_MAX_TASKS must be <= 63"
#ifndef OS_TASK_IDLE_STK_SIZE
#error "OS_CFG.H, Missing OS_TASK_IDLE_STK_SIZE: Idle task stack size"
#ifndef OS_TASK_STAT_EN
#error "OS_CFG.H, Missing OS_TASK_STAT_EN: Enable (1) or Disable(0) the statistics task"
#ifndef OS_TASK_STAT_STK_SIZE
#error "OS_CFG.H, Missing OS_TASK_STAT_STK_SIZE: Statistics task stack size"
#ifndef OS_TASK_STAT_STK_CHK_EN
#error "OS_CFG.H, Missing OS_TASK_STAT_STK_CHK_EN: Check task stacks from statistics task"
#ifndef OS_TASK_CHANGE_PRIO_EN
#error "OS_CFG.H, Missing OS_TASK_CHANGE_PRIO_EN: Include code for OSTaskChangePrio()"
#ifndef OS_TASK_CREATE_EN
#error "OS_CFG.H, Missing OS_TASK_CREATE_EN: Include code for OSTaskCreate()"
#ifndef OS_TASK_CREATE_EXT_EN
#error "OS_CFG.H, Missing OS_TASK_CREATE_EXT_EN: Include code for OSTaskCreateExt()"
#ifndef OS_TASK_DEL_EN
#error "OS_CFG.H, Missing OS_TASK_DEL_EN: Include code for OSTaskDel()"
#ifndef OS_TASK_NAME_SIZE
#error "OS_CFG.H, Missing OS_TASK_NAME_SIZE: Determine the size of task names"
#ifndef OS_TASK_SUSPEND_EN
#error "OS_CFG.H, Missing OS_TASK_SUSPEND_EN: Include code for OSTaskSuspend() and OSTaskResume()"
#ifndef OS_TASK_QUERY_EN
#error "OS_CFG.H, Missing OS_TASK_QUERY_EN: Include code for OSTaskQuery()"
* TIME MANAGEMENT
#ifndef OS_TICKS_PER_SEC
#error "OS_CFG.H, Missing OS_TICKS_PER_SEC: Sets the number of ticks in one second"
#ifndef OS_TIME_DLY_HMSM_EN
#error "OS_CFG.H, Missing OS_TIME_DLY_HMSM_EN: Include code for OSTimeDlyHMSM()"
#ifndef OS_TIME_DLY_RESUME_EN
#error "OS_CFG.H, Missing OS_TIME_DLY_RESUME_EN: Include code for OSTimeDlyResume()"
#ifndef OS_TIME_GET_SET_EN
#error "OS_CFG.H, Missing OS_TIME_GET_SET_EN: Include code for OSTimeGet() and OSTimeSet()"
* MISCELLANEOUS
#ifndef OS_ARG_CHK_EN
#error "OS_CFG.H, Missing OS_ARG_CHK_EN: Enable (1) or Disable (0) argument checking"
#ifndef OS_CPU_HOOKS_EN
#error "OS_CFG.H, Missing OS_CPU_HOOKS_EN: uC/OS-II hooks are found in the processor port files when 1"
#ifndef OS_LOWEST_PRIO
#error "OS_CFG.H, Missing OS_LOWEST_PRIO: Defines the lowest priority that can be assigned"
#ifndef OS_MAX_EVENTS
#error "OS_CFG.H, Missing OS_MAX_EVENTS: Max. number of event control blocks in your application"
#else
#if OS_MAX_EVENTS > 65500
#error "OS_CFG.H, OS_MAX_EVENTS must be <= 65500"
#ifndef OS_SCHED_LOCK_EN
#error "OS_CFG.H, Missing OS_SCHED_LOCK_EN: Include code for OSSchedLock() and OSSchedUnlock()"
#ifndef OS_TASK_PROFILE_EN
#error "OS_CFG.H, Missing OS_TASK_PROFILE_EN: Include data structure for run-time task profiling"
#ifndef OS_TASK_SW_HOOK_EN
#error "OS_CFG.H, Missing OS_TASK_SW_HOOK_EN: Allows you to include the code for OSTaskSwHook() or not"
#ifndef OS_TICK_STEP_EN
#error "OS_CFG.H, Missing OS_TICK_STEP_EN: Allows to 'step' one tick at a time with uC/OS-View"
#ifndef OS_TIME_TICK_HOOK_EN
#error "OS_CFG.H, Missing OS_TIME_TICK_HOOK_EN: Allows you to include the code for OSTimeTickHook() or not"
#ifndef OS_DEBUG_EN
#error "OS_CFG.H, Missing OS_DEBUG_EN: Allows you to include variables for debugging or not"
#ifdef __cplusplus
这个文件中包含了对上述问题的定义,但是好像不认这个文件
ucos的文件www.ouravr.com有啊 |
