发表于 2006-10-20 20:09:53
这是一段家电控制上的汇编源程序,大家就悠着点看吧!眼睛痛不要找我啊!呵呵……
补充说明一点,是中颖的四位机,价格很便宜不超过4RMB。
;OSCILLATOR TYPE: Crystal oscillator
;WATCH DOG TIMER: Enable
;LVR VOLTAGE RAMGE:High LVR voltage
;OSCILLATOR RANGE:2~8MHZ
;LOW VOLTAGE RESET:Enable
;SYSTEM REGISTER DEFINE
IE EQU 00H ;INTERRUPT ENABLE FLAG
IRQ EQU 01H ;INTERRUPT REQUEST
T0M EQU 02H ;TIMER O SET
T1M EQU 03H ;TIMER 1 SET
T0L EQU 04H
T0H EQU 05H
T1L EQU 06H
T1H EQU 07H
PORTA EQU 08H ;PORT A
PORTB EQU 09H
PORTC EQU 0AH
PORTD EQU 0BH
PORTE EQU 0CH
PORTF EQU 0DH
TBR EQU 0EH ;TABLE BRANCH REGISTER
INX EQU 0FH ;PSEUDO INDEX REGISTER
DPL EQU 10H ;DATA POINTER FOR INX LOW NIBBLE
DPM EQU 11H ;DATA POINTER FOR INX MIDDLE NIBBLE
DPH EQU 12H ;DATA POINTER FOR INX HIGH NIBBLE
CMP_CONTROL EQU 13H ;COMPARATOR CONTROL REGISTER
CMP_STATUS EQU 14H ;COMPARATOR SUATUS REGISTER
T2SET EQU 15H ;TIMER2 SET
PAOUT EQU 16H ;PORT A INPUT/OUTPUT SET
PBOUT EQU 17H
PCOUT EQU 18H
PDOUT EQU 19H
PEOUT EQU 1AH
PFOUT EQU 1BH
T2_SIGNAL_SET EQU 1CH ;TIMER2 EXTERNAL SIGNAL SOURCE SET
;1DH RESERVED
WDT EQU 1EH ;WATCH DOG TIMER
ROM_BANK EQU 1FH ;BANK REGISTER FOR ROM
PGOUT EQU 20H ;PORT G INPUT/OUTPUT SET
PHOUT EQU 21H ;PORT H INPUT/OUTPUT SET
PORTG EQU 22H ;PORTG
PORTH EQU 23H ;PORTH
PA_PULL_HIGH EQU 24H ;PORTA PULL-HIGH CONTROL
PB_PULL_HIGH EQU 25H ;PORTB PULL-HIGH CONTROL
PC_PULL_HIGH EQU 26H ;PORTC PULL-HIGH CONTROL
PD_PULL_HIGH EQU 27H ;PORTD PULL-HIGH CONTROL
PE_PULL_HIGH EQU 28H ;PORTE PULL-HIGH CONTROL
PF_PULL_HIGH EQU 29H ;PORTF PULL-HIGH CONTROL
PG_PULL_HIGH EQU 2AH ;PORTG PULL-HIGH CONTROL
PH_PULL_HIGH EQU 2BH ;PORTH PULL-HIGH CONTROL
TONE1_VOLUME_L EQU 2CH ;TONE GENERATOR 1 VOLUME LOW NIBBLE
TONE1_VOLUME_H EQU 2DH ;TONE GENERATOR 1 VOLUME HIGH NIBBLE
TONE2_VOLUME_L EQU 2EH ;TONE GENERATOR 2 VOLUME LOW NIBBLE
TONE2_VOLUME_H EQU 2FH ;TONE GENERATOR 2 VOLUME HIGH NIBBLE
RB7_RDT_L EQU 00H ;ROM DATA TABLE ADDRESS/DATA REGISTER LOW NIBBLE
RB7_RDT_ML EQU 01H ;ROM DATA TABLE ADDRESS/DATA REGISTER MIDDLE LOW NIBBLE
RB7_RDT_MH EQU 02H ;ROM DATA TABLE ADDRESS/DATA REGISTER MIDDLE HIGH NIBBLE
RB7_RDT_H EQU 03H ;ROM DATA TABLE ADDRESS/DATA REGISTER HIGH NIBBLE
RB7_T2L EQU 04H ;TIMER2 LOAD/COUNTER REGISTER(LOW NIBBLE)
RB7_T2ML EQU 05H ;TIMER2 LOAD/COUNTER REGISTER(MIDDLE LOW NIBBLE)
RB7_T2MH EQU 06H ;TIMER2 LOAD/COUNTER REGISTER(MIDDLE HIGH NIBBLE)
RB7_T2H EQU 07H ;TIMER2 LOAD/COUNTER REGISTER(HIGH NIBBLE)
RB7_TONE1_L EQU 08H ;TONE GENERATOR 1 LOW NIBBLE
RB7_TONE1_M EQU 09H ;TONE GENERATOR 1 MIDDLE NIBBLE
RB7_TONE1_H EQU 0AH ;TONE GENERATOR 1 HIGH NIBBLE
RB7_TONE2_L EQU 0BH ;TONE GENERATOR 2 LOW NIBBLE
RB7_TONE2_M EQU 0CH ;TONE GENERATOR 2 MIDDLE NIBBLE
RB7_TONE2_H EQU 0DH ;TONE GENERATOR 2 HIGH NIBBLE
RB7_T2_PRE EQU 0EH ;TIMER2 PRE-SCALER REGISTER
RB7_COMPARATOR_SET EQU 0FH ;COMPARATOR CHANNEL SELECT & COMPARATOR OUTPUT DATA
RB7_PF_IE_FLAG EQU 10H ;PORTF INTERRUPT ENABLE FLAGS
RB7_PG_IE_FLAG EQU 11H ;PORTG INTERRUPT ENABLE FLAGS
RB7_PF_IRQ_FLAG EQU 12H ;PORTF INTERRUPT REQUEST FLAGS
RB7_PG_IRQ_FLAG EQU 13H ;PORTG INTERRUPT REQUEST FLAGS
RB7_CMP_IE_IRQ_F EQU 14H ;CMP INTERRUPT ENABLE FLAG
;DATA MEMORY DEFINE
;-------------BANK 0--------------------
ACC EQU 30H
;PROTECT ACCUMULATER REGISTER(ONLY TIMER0 USED)
TEMP EQU 31H
;TEMP REGISTER
CLRACC EQU 32H
;CLEAR ACCUMULATER USED REGISTER
RELAY_FLAG EQU 33H
;BIT0:BUZZER OUTPUT FLAG
;BIT1:WAVE OUTPUT FLAG
;BIT2:GRILL OUTPUT FLAG
;BIT3:LIGHT OUTPUT FLAG
MACHINE_TYPE EQU 34H
;MACHINE TYPE REGISTER
GRILL_CT0 EQU 35H
GRILL_CT1 EQU 36H
GRILL_CT2 EQU 37H
;GRILL WORK TIME TIMER USED REGISTERS
LONG_PRESS_EACH_CT EQU 38H
;LONG PRESS EACH TIME COUTER 0(BASE ON 12.25MS KEY SCAN TIMER)
TEMP_M EQU 39H
;MACRO PART USED TEMP REGISTER
TIMER_CLOCK_CT0 EQU 3AH
TIMER_CLOCK_CT1 EQU 3BH
TIMER_CLOCK_CT2 EQU 3CH
TIMER_CLOCK_CT3 EQU 3DH
TIMER_CLOCK_CT4 EQU 3EH
TIMER_CLOCK_CT5 EQU 3FH
;CLOCK TIMER USED REGISTERS
TIMER_5MIN_CT0 EQU 40H
;WORK TIME LONGER(EQUAL) THAN 5 MINUTES TIMER USED REGISTER 0
TIMER_5MIN_CT1 EQU 41H
TIMER_5MIN_CT2 EQU 42H
DEFROST_P EQU 43H
;DEFROST PERIOD REGISTER
TEMP_R0 EQU 44H
;TEMP REGISTER 0
TEMP_R1 EQU 45H
;TEMP REGISTER 1
TEMP_R2 EQU 46H
;TEMP REGISTER 2
TEMP_R3 EQU 47H
;TEMP REGISTER 3
TEMP_R4 EQU 48H
;TEMP REGISTER 4
TEMP_R5 EQU 49H
;TEMP REGISTER 5
TEMP_R6 EQU 4AH
;TEMP REGISTER 6
WORK_TYPE EQU 4BH
;00H:NOT WORK TYPE 01H:CLOCK TYPE 02H:PRESET TYPE 03H:MICRO TYPE
;04H:FAST COOK TYPE 05H:DEFROST 06H:GRILL COMBI TYPE 07H:AUTO COOK TYPE
;08H:NO GRILL,FAST COOK 09H:CHILD LOCK 0AH:NOT USED 0BH:NOT USED
;0CH:NOT USED 0DH:NOT USED 0EH:NOT USED 0FH:COOK FINISH TYPE
KEY_VALUE EQU 4CH
;ONE REAL KEY VALUE
KEY_VALUEH EQU 4DH
;WORK TYPE NUMBER HIGH NIBBLE
KEY_VALUEL EQU 4EH
;WORK TYPE NUMBER LOW NIBBLE
CODING_VALUEH EQU 4FH
;CODING VALUE HIGH NIBBLE
CODING_VALUEL EQU 50H
;CODING VALUE LOW NIBBLE
RELAY_ON_TIMEH EQU 51H
;WAVE/GRILL/ RELAY ON TIME HIGH NIBBLE
RELAY_ON_TIMEL EQU 52H
;WAVE/GRILL RELAY ON TIME LOW NIBBLE
KEY_LS EQU 53H
;0CH:CHILD LOCK KEY
;0EH:NO KEY 0FH:KEY ALREADY PROCESS
BUZZER_TYPE EQU 54H
;BUZZER TYPE REGISTER
BUZZER_TIMES EQU 55H
;BUZZER DEGREE REGISTER
DOOR_T EQU 56H
;SCAN KEY TIMES
KEY_T EQU 57H
;KEY SCAN TIMES
DISPLAY_BIT EQU 58H
;DISPLAY BIT REGISTER
LEVEL EQU 59H
;MICROWAVE/AUTOFUNCTION LEVEL REGISTER
AUTO_CONFIRM_CT EQU 5AH
;CLOCK AUTO CONFIRM TIMER USED REGISTER(BASED ON 500MS)
WORK_MINH EQU 5BH
;WORK TIME NINUTE HIGH NIBBLE
WORK_MINL EQU 5CH
;WORK TIME MINUTE LOW NIBBLE
WORK_SECH EQU 5DH
;WORK TIME SECOND HIGH NIBBLE
WORK_SECL EQU 5EH
;WORK TIME SECOND LOW NIBBLE
TIME_HORH EQU 5FH
;CLOCK HOUR HIGH NIBBLE
TIME_HORL EQU 60H
;CLOCK HOUR LOW NIBBLE
TIME_MINH EQU 61H
;CLOCK MINUTE HIGH NIBBLE
TIME_MINL EQU 62H
;CLOCK MINUTE LOW NIBBLE
PRE_TIME_MINH EQU 63H
;PRESET TIME MINUTE HIGH NIBBLE
PRE_TIME_MINL EQU 64H
;PRESET TIME MINUTE LOW NIBBLE
PRE_TIME_HORH EQU 65H
;PRESET TIME HOUR HIGH NIBBLE
PRE_TIME_HORL EQU 66H
;PRESET TIME HOUR LOW NIBBLE
WORK_FLAG8 EQU 67H
;BIT0:set_timer
;BIT1:auto_start
;BIT2:DURING KEY SCAN FLAG
;BIT3:POWER ON ALL LED ON FLAG
WORK_FLAG0 EQU 68H
;BIT0:LOOK POWER FLAG
;BIT1:1S DISPLAY RAY FLAG
;BIT2:500MS TIMER FLAG
;BIT3:500MS DISPLAY RAY FLAG
WORK_FLAG1 EQU 69H
;BIT0:START KEY INVILID FLAG
;BIT1:1S TIMER FLAG
;BIT2:50MS LONG PRESS KEY EACH FLAG
;BIT3:CLOCK ALREADY SET FLAG
WORK_FLAG2 EQU 6AH
;BIT0:CODE SWITCH IS "01"
;BIT1:CODE SWITCH IS "10"
;BIT2:CODE SWITCH DISABLE FLAG
;BIT3:5MS SCAN KEY FLAG
WORK_FLAG3 EQU 6BH
;BIT0:CHECK PRESET CLOCK CHECK
;BIT1:WORK START FLAG
;BIT2:WORK PAUSE FLAG
;BIT3:DOOR OPEN FLAG
WORK_FLAG4 EQU 6CH
;BIT0:SET TIME
;BIT1:run_timer
;BIT2:PRESET FLAG
;BIT3:LONG PRESS KEY ON FLAG
WORK_FLAG7 EQU 6DH
;BIT0:GRILL TYPE FLAG
;BIT1:TIMER1S
;BIT2:set_clock_start
;BIT3:LOCK_FIRST
NOW_COOK_TYPE_L EQU 6EH
;NOW COOK TYPE REGISTER LOW NIBBLE
CS_BUFFER EQU 70H
;CODDING SWITCH LAST STATE REGISTER
POWER_ON_LCD_ON_TIMER EQU 71H
;POWER ON LCE ON TIMER USED REGISTER(BASED ON 500MS)
TIMER_KEY_CT0 EQU 72H
;SCAN KEY TIMER USED REGISTER 0
TIMER_KEY_CT1 EQU 73H
;SCAN KEY TIMER USED REGISTER 1
TIMER_RAY_CT0 EQU 74H
;DISPLAY PART RAY TIMER USED REGISTER 0
TIMER_RAY_CT1 EQU 75H
;DISPLAY PART RAY TIMER USED REGISTER 1
TIMER_RAY_CT2 EQU 76H
;DISPLAY PART RAY TIMER USED REGISTER 2
TIMER_CODE_CT EQU 77H
;CODDING SWITCH SCAN TIMER USED REGISTER
TIMER_WT_CT0 EQU 78H
;WORK TIME TIEMR USED REGISTER 0
TIMER_WT_CT1 EQU 79H
;WORK TIME TIEMR USED REGISTER 1
TIMER_WT_CT2 EQU 7AH
;WORK TIME TIEMR USED REGISTER 2
TIMER_WT_CT3 EQU 7BH
;WORK TIME TIMER USED REGISTER 3
DIS_DATA_BUFFER_L EQU 7CH
;DISPLAY DATA BUFFER LOW NIBBLE
DIS_DATA_BUFFER_H EQU 7DH
;DISPLAY DATA BUFFER HIGH NIBBLE
TIMER_DIS_CT EQU 7EH
;DISPLAY TIMER USED REGISTER
SET_STATE EQU 7FH
;MICRO WAVE/GRILL/COMBI SET STATE(SOFT KEY MACHINE)
;----------RAM BANK 1(80H--FFH)------------
MUL_WORK_MINH1 EQU 00H
;MUL COOK WORK TIME MINUTE HIGH BANK 1
MUL_WORK_MINL1 EQU 01H
;MUL COOK WORK TIME MINUTE LOW BANK 1
MUL_WORK_SECH1 EQU 02H
;MUL COOK WORK TIME SECOND HIGH BANK 1
MUL_WORK_SECL1 EQU 03H
;MUL COOK WORK TIME SECOND LOW BANK 1
MUL_WORK_MINH3 EQU 08H
;MUL COOK WORK TIME MINUTE HIGH BANK 3
MUL_WORK_MINL3 EQU 09H
;MUL COOK WORK TIME MINUTE LOW BANK 3
MUL_WORK_SECH3 EQU 0AH
;MUL COOK WORK TIME SECOND HIGH BANK 3
MUL_WORK_SECL3 EQU 0BH
;MUL COOK WORK TIME SECOND LOW BANK 3
MUL_WORK_MINH4 EQU 0CH
;MUL COOK WORK TIME MINUTE HIGH BANK 4
MUL_WORK_MINL4 EQU 0DH
;MUL COOK WORK TIME MINUTE LOW BANK 4
MUL_WORK_SECH4 EQU 0EH
;MUL COOK WORK TIME SECOND HIGH BANK 4
MUL_WORK_SECL4 EQU 0FH
;MUL COOK WORK TIME SECOND LOW BANK 4
MUL_COOK_TYPE4H EQU 10H
;MUL COOK TYPE BANK 4 HIGH NIBBLE
MUL_COOK_TYPE4L EQU 11H
;MUL COOK TYPE BANK 4 LOW NIBBLE
MUL_COOK_TYPE3L EQU 12H
;MUL COOK TYPE BANK 3 LOW NIBBLE
MUL_COOK_TYPE3H EQU 13H
;MUL COOK TYPE BANK 3 HIGH NIBBLE
MUL_COOK_TYPE2L EQU 14H
;MUL COOK TYPE BANK 2 LOW NIBBLE
MUL_COOK_TYPE2H EQU 15H
;MUL COOK TYPE BANK 2 HIGH NIBBLE
MUL_COOK_TYPE1L EQU 16H
;MUL COOK TYPE BANK 1 LOW NIBBLE
MUL_COOK_TYPE1H EQU 17H
;MUL COOK TYPE BANK 1 HIGH NIBBLE
RB1_TIMER_BUZ_CT0 EQU 18H
;BUZZER TIME TIMER USED REGISTER 0
RB1_TIMER_BUZ_CT1 EQU 19H
;BUZZER TIME TIMER USED REGISTER 1
RB1_TIMER_BUZ_CT2 EQU 1AH
;BUZZER TIME TIMER USED REGISTER 2
RB1_TIMER_BUZ_CT3 EQU 1BH
;BUZZER TIME TIMER USED REGISTER 3
RB1_TIMER_SHARE_CT0 EQU 1CH
;LOOK STATE/CHILDLOCK TIMER USED REGISTER 0
RB1_TIMER_SHARE_CT1 EQU 1DH
;LOOK STATE/CHILDLOCK TIMER USED REGISTER 1
RB1_TIMER_SHARE_CT2 EQU 1EH
;LOOK STATE/CHILDLOCK TIMER USED REGISTER 2
RB1_TIMER_SHARE_CT3 EQU 1FH
;LOOK STATE/CHILDLOCK TIMER USED REGISTER 3
DEFROST_CT0 EQU 20H
;DEFROST 1/4 TIME 0.1 SECOND BIT NIBBLE
DEFROST_CT1 EQU 21H
;DEFROST 1/4 TIME SECOND BIT LOW NIBBLE
DEFROST_CT2 EQU 22H
;DEFROST 1/4 TIME SECOND BIT HIGH NIBBLE
DEFROST_CT3 EQU 23H
;DEFROST 1/4 TIME MINUTE BIT NIBBLE
DISPLAY_VALUE EQU 24H
;DISPLAY VAULE
RB1_DOOR_OPEN_CT3 EQU 25H
;500MS TIMER USED REGISTER
RB1_DOOR_OPEN_CT4 EQU 26H
RB1_DOOR_OPEN_CT5 EQU 27H
RB1_OPTION_PE_LAST EQU 2AH
RB1_OPTION_PC_LAST EQU 2BH
;MACHINE TYPE OPTION LAST STATE
RB1_GET_OPTION_TIME EQU 2CH
;MACHINE TYPE OPTION CHECK TIMES
DIS_LINE1H EQU 30H
;DISPLAY PART:LINE1 HIGH PART NIBBLE
DIS_LINE1L EQU 31H
;DISPLAY PART:LINE1 LOW PART NIBBLE
DIS_LINE2H EQU 32H
;DISPLAY PART:LINE2 HIGH PART NIBBLE
DIS_LINE2L EQU 33H
;DISPLAY PART:LINE2 LOW PART NIBBLE
DIS_LINE3H EQU 34H
;DISPLAY PART:LINE3 HIGH PART NIBBLE
DIS_LINE3L EQU 35H
;DISPLAY PART:LINE3 LOW PART NIBBLE
DIS_LINE4H EQU 36H
;DISPLAY PART:LINE4 HIGH PART NIBBLE
DIS_LINE4L EQU 37H
;DISPLAY PART:LINE4 LOW PART NIBBLE
DIS_LINE5H EQU 38H
;DISPLAY PART:LINE5 HIGH PART NIBBLE
DIS_LINE5L EQU 39H
;DISPLAY PART:LINE5 LOW PART NIBBLE
DIS_LINE6H EQU 3AH
;DISPLAY PART:LINE6 HIGH PART NIBBLE
DIS_LINE6L EQU 3BH
;DISPLAY PART:LINE7 LOW PART NIBBLE
DEF_AUTO EQU 3CH
RB1_END_CT0 EQU 40H
;AFTER COOK END,3 MINUTES TIMER USED REGISTER 0
RB1_END_CT1 EQU 41H
;AFTER COOK END,3 MINUTES TIMER USED REGISTER 1
RB1_END_CT2 EQU 42H
;AFTER COOK END,3 MINUTES TIMER USED REGISTER 2
RB1_RELAY_CHANGE_CT0 EQU 43H
;RELAY CHANGE DELAY 100MS TIMER USED REGISTER
RB1_RELAY_CHANGE_CT1 EQU 44H
RB1_RELAY_CHANGE_CT2 EQU 45H
AUTO_CANCEL_CT0 EQU 48H
;PRESET CLOCK 10SECONDS CANCEL REGISTER(BASED ON 500MS)
AUTO_CANCEL_CT1 EQU 49H
LONG_PRESS_TIME_CT EQU 4AH
;LONG PRESS KEY TIMER USED COUNTER(BASED ON 500MS)
LONG_PRESS_EACH_CT1 EQU 4BH
START_2_MINUTES_CT0 EQU 4CH
;START KEY 2 MINUTES NOT VILID TIMER USED REGISTER(BASED ON 500MS)
START_2_MINUTES_CT1 EQU 4DH
TIMER_NOTON_CT0 EQU 50H
;SET FUNCTION & NOT START TIMER USED REGISTER 0(BASED ON 500MS)
TIMER_NOTON_CT1 EQU 51H
;SET FUNCTION & NOT START TIMER USED REGISTER 1(BASED ON 500MS)
TIMER_NOTON_CT2 EQU 52H
;SET FUNCTION & NOT START TIMER USED REGISTER 2(BASED ON 500MS)
LINE1_CURRENT_DATA_B EQU 60H
;THE FIRST LINE KEY CURRENT NIBBLE(PORTB)
LINE1_CURRENT_DATA_D EQU 61H
;THE FIRST LINE KEY CURRENT NIBBLE(PORTD)
LINE1_CURRENT_DATA_H EQU 62H
;THE FIRST LINE KEY CURRENT NIBBLE(PORTH)
LINE2_CURRENT_DATA_B EQU 63H
;THE SECOND LINE KEY CURRENT NIBBLE(PORTB)
LINE2_CURRENT_DATA_D EQU 64H
;THE SECOND LINE KEY CURRENT NIBBLE(PORTD)
LINE2_CURRENT_DATA_H EQU 65H
;THE SECOND LINE KEY CURRENT NIBBLE(PORTH)
LINE3_CURRENT_DATA_B EQU 66H
;THE THIRD LINE KEY CURRENT NIBBLE(PORTB)
LINE3_CURRENT_DATA_D EQU 67H
;THE THIRD LINE KEY CURRENT NIBBLE(PORTD)
LINE3_CURRENT_DATA_H EQU 68H
;THE THIRD LINE KEY CURRENT NIBBLE(PORTH)
LINE4_CURRENT_DATA_B EQU 69H
;THE FOURTH LINE KEY CURRENT NIBBLE(PORTB)
LINE4_CURRENT_DATA_D EQU 6AH
;THE FOURTH LINE KEY CURRENT NIBBLE(PORTD)
LINE4_CURRENT_DATA_H EQU 6BH
;THE FOURTH LINE KEY CURRENT NIBBLE(PORTH)
LINE5_CURRENT_DATA_B EQU 6CH
;THE FIFTH LINE KEY CURRENT NIBBLE(PORTB)
LINE5_CURRENT_DATA_D EQU 6DH
;THE FIFTH LINE KEY CURRENT NIBBLE(PORTD)
LINE5_CURRENT_DATA_H EQU 6EH
;THE FIFTH LINE KEY CURRENT NIBBLE(PORTH)
LINE1_LAST_DATA_B EQU 70H
;THE FIRST LINE KEY LAST NIBBLE(PORTB)
LINE1_LAST_DATA_D EQU 71H
;THE FIRST LINE KEY LAST NIBBLE(PORTD)
LINE1_LAST_DATA_H EQU 72H
;THE FIRST LINE KEY LAST NIBBLE(PORTH)
LINE2_LAST_DATA_B EQU 73H
;THE SECOND LINE KEY LAST NIBBLE(PORTB)
LINE2_LAST_DATA_D EQU 74H
;THE SECOND LINE KEY LAST NIBBLE(PORTD)
LINE2_LAST_DATA_H EQU 75H
;THE SECOND LINE KEY LAST NIBBLE(PORTH)
LINE3_LAST_DATA_B EQU 76H
;THE THIRD LINE KEY LAST NIBBLE(PORTB)
LINE3_LAST_DATA_D EQU 77H
;THE THIRD LINE KEY LAST NIBBLE(PORTD)
LINE3_LAST_DATA_H EQU 78H
;THE THIRD LINE KEY LAST NIBBLE(PORTH)
LINE4_LAST_DATA_B EQU 79H
;THE FOURTH LINE KEY LAST NIBBLE(PORTB)
LINE4_LAST_DATA_D EQU 7AH
;THE FOURTH LINE KEY LAST NIBBLE(PORTD)
LINE4_LAST_DATA_H EQU 7BH
;THE FOURTH LINE KEY LAST NIBBLE(PORTH)
LINE5_LAST_DATA_B EQU 7CH
;THE FIFTH LINE KEY LAST NIBBLE(PORTB)
LINE5_LAST_DATA_D EQU 7DH
;THE FIFTH LINE KEY LAST NIBBLE(PORTD)
LINE5_LAST_DATA_H EQU 7EH
;THE FIFTH LINE KEY LAST NIBBLE(PORTH)
;----------RAM BANK 2(100H--167H)----------
TEMP_DEF_NUM EQU 00H
PAUSE_DEF_SECL EQU 01H
PAUSE_DEF_SECH EQU 02H
PAUSE_DEF_MINL EQU 03H
PAUSE_DEF_MINH EQU 04H
Time_second_timerL equ 05H
Time_second_timerH equ 06H
Time_minute_timerL equ 07H
Time_minute_timerH equ 08H
Time_disp_timer equ 09H
LOCK_COUNT equ 0aH
LOCK_BACK_COUNT equ 0bh
AUTO_START_COUNT equ 0ch
TIMER_PAUSE equ 0dh
BANK0 equ 0
BANK1 equ 1
BANK2 equ 2
; MACRO PART
INC8 MACRO B0XH ,B0XL
ADIM B0XL ,01H
LDI TEMP_M ,00H
ADCM B0XH ,00H
ENDM
DEC8 MACRO B0XH ,B0XL
SBIM B0XL ,01H
LDI TEMP_M ,00H
SBCM B0XH ,00H
ENDM
ADD8 MACRO B0XH,B0XL,IYH,IYL ;( XH,XL IS BANK0 )
ADIM B0XL ,IYL
LDI TEMP_M ,IYH
ADCM B0XH ,00H
ENDM
SUB8 MACRO B0XH,B0XL,IYH,IYL ;( XH,XL IS BANK0 )
SBIM B0XL ,IYL
LDI TEMP_M ,IYH
SBCM B0XH ,00H
ENDM
CJB4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BAZ $+2
BC ADDR
ENDM
CJB8 MACRO B0XH,B0XL,IYH,IYL,ADDR
SBI B0XH ,IYH
BAZ $+3
BC ADDR
JMP $+4
SBI B0XL ,IYL
BAZ $+2
BC ADDR
ENDM
CJBE4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BC ADDR
ENDM
CJBE8 MACRO B0XH,B0XL,IYH,IYL,ADDR
SBI B0XH ,IYH
BAZ $+3
BC ADDR
JMP $+3
SBI B0XL ,IYL
BC ADDR
ENDM
CJS4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BNC ADDR
ENDM
CJS8 MACRO B0XH,B0XL,IYH,IYL,ADDR
SBI B0XH ,IYH
BAZ $+3
BNC ADDR
JMP $+3
SBI B0XL ,IYL
BNC ADDR
ENDM
;CJSE4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BAZ ADDR
BNC ADDR
ENDM
CJSE8 MACRO B0XH,B0XL,IYH,IYL,ADDR
SBI B0XH ,IYH
BAZ $+3
BNC ADDR
JMP $+4
SBI B0XL ,IYL
BAZ ADDR
BNC ADDR
ENDM
CJE4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BAZ ADDR
ENDM
CJNE4 MACRO B0X ,IY ,ADDR
SBI B0X ,IY
BNZ ADDR
ENDM
CJE8 MACRO B0XH,B0XL,IYH,IYL,ADDR ;( XH,XL IS BANK0 )
SBI B0XH ,IYH
BNZ $+3
SBI B0XL ,IYL
BAZ ADDR
ENDM
CJNE8 MACRO B0XH,B0XL,IYH,IYL,ADDR ;( XH,XL IS BANK0 )
SBI B0XH ,IYH
BNZ ADDR
SBI B0XL ,IYL
BNZ ADDR
ENDM
DJZ4 MACRO B0X ,ADDR ;REALLY DECRESE 1
SBIM B0X ,01H
BAZ ADDR
ENDM
DJNZ4 MACRO B0X ,ADDR ;REALLY DECRESE 1
SBIM B0X ,01H
BNZ ADDR
ENDM
; VECTOR ADDRESS
ORG 00H
JMP RESET
JMP TIMER0INT ;TIMER 0 INTERRUPT
RTNI
RTNI
RTNI
;SUBROUTINE NAME:TIMER0 INTERRUPT SERVICE SUBROUTINE
;FUNCTION:TIMER0 INTERRUPT SERVICE SUBROUTINE
;INPUT PARAMETER:RELAY_FLAG,WORK_FLAG0,WORK_FLAG1,WORK_FLAG2,WORK_FLAG3,NOW_COOK_TYPE
;OUTPUT PARAMETER:WORK_FLAG0,WORK_FLAG1,WORK_FLAG2,WORK_FLAG4
;USED REGISTERS:ACC,CLRACC,TEMP,RB1_TIMER_BUZ_CT0~RB1_TIMER_BUZ_CT2
; :TIMER_RAY_CT0~TIMER_RAY_CT2,TIMER_CS_CT,TIMER_WT_CT0~TIMER_WT_CT3
; :RB1_TIMER_SHARE_CT0~RB1_TIMER_SHARE_CT3,RB1_TIMER_SHARE_CT0~RB1_TIMER_SHARE_CT3
; :TIMER_KEY_CT0~TIMER_KEY_CT1,RB1_TIMER_HF_CT0~TIMER_HF_CT3
; :TIMER_CLOCK_CT0~TIMER_CLOCK_CT4,TIMER_PZ_CT0~TIMER_PZ_CT1,RB7_ALARM_SET,RB7_ALARM_ENV
; :TIMER_DY_CT0~TIMER_DY_CT1,CS_BUFFER,DOOR_T,DIS_LINE1H,DIS_LINE1L
; :DIS_LINE2H,DIS_LINE2L,DIS_LINE3H,DIS_LINE3L,DIS_LINE4H,DIS_LINE4L
; :DIS_LINE5H,DIS_LINE5L,DIS_LINE6H,DIS_LINE6L,RB1_WAIT_TIME_CT0~2
TIMER0INT:
STA ACC ,00H
ANDIM IRQ ,0111B ;CLEAR TIMER0 IRQ
BUZZER_OUTPUT_PART:
LDA RELAY_FLAG ,00H ;BUZZER CHECK
BA0 BUZZER_OUTPUT_PART10
ANDIM PORTF ,1110B ;SET PF.0 AS LOW STATE
JMP BUZZER_OUTPUT_PART20
BUZZER_OUTPUT_PART10:
ORIM PFOUT ,0001B ;SET PF.0 AS OUTPUT I/O
EORIM PORTF ,0001B ;OPEN BUZZER
BUZZER_OUTPUT_PART20:
LDI TEMP ,01H
ADDM RB1_TIMER_BUZ_CT0 ,01H ;BUZZER TIME TIMER PART
LDI CLRACC ,00H ;页间处理
ADCM RB1_TIMER_BUZ_CT1 ,01H
LDI CLRACC ,00H
ADCM RB1_TIMER_BUZ_CT2 ,01H
LDI CLRACC ,00H
ADCM RB1_TIMER_BUZ_CT3 ,01H
BUZZER_OUTPUT_PART99:
RELAY_OUTPUT_PART: ;OPEN & CLOSE RELAY PART
CLOSE_WAVE_OUTPUT_PART:
LDA WORK_FLAG3 ,00H
BA1 CLOSE_WAVE_OUTPUT_PART_LIGHTON ;WORK START
LDA WORK_FLAG3 ,00H ;LIGHT RELAY STATE CHECK
BA3 CLOSE_WAVE_OUTPUT_PART_LIGHTON
JMP CLOSE_WAVE_OUTPUT_PART10
CLOSE_WAVE_OUTPUT_PART_LIGHTON:
ORIM PFOUT ,1000B ;SET PF.3 AS OUTPUT I/O
ORIM PORTF ,1000B ;CLOSE LIGHT RELAY
CLOSE_WAVE_OUTPUT_PART10:
LDA RELAY_FLAG ,00H ;CHECK MICRO-WAVE STATE
BA1 CLOSE_WAVE_OUTPUT_PART99
ORIM PFOUT ,0100B ;SET PF.2 AS OUTPUT I/O
ANDIM PORTF ,1011B ;CLOSE MICRO-WAVE RELAY
JMP CLOSE_WAVE_OUTPUT_PART99
CLOSE_WAVE_OUTPUT_PART99:
OPEN_WAVE_OUTPUT_PART:
BA1 OPEN_WAVE_OUTPUT_PART10
JMP OPEN_WAVE_OUTPUT_PART99
OPEN_WAVE_OUTPUT_PART10:
ORIM PORTF ,0100B ;OPEN MICRO-WAVE RELAY
OPEN_WAVE_OUTPUT_PART99:
CLOSE_GRILL_OUTPUT_PART:
LDA WORK_FLAG3 ,00H
BA3 CLOSE_GRILL_OUTPUT_PART_LIGHTON
ANDIM PORTF ,0111B ;CLOSE LIGHT RELAY
JMP CLOSE_GRILL_OUTPUT_PART10
CLOSE_GRILL_OUTPUT_PART_LIGHTON:
;CLOSE_GRILL_OUTPUT_PART: ;GRILL RELAY OPEN/CLOSE PART
; LDA RELAY_FLAG ,00H ;LIGHT RELAY STATE CHECK
; BA3 CLOSE_GRILL_OUTPUT_PART10
; ORIM PFOUT ,1000B ;SET PF.3 AS OUTPUT I/O
; ANDIM PORTF ,0111B ;CLOSE LIGHT RELAY
CLOSE_GRILL_OUTPUT_PART10:
LDA RELAY_FLAG ,00H ;CHECK GRILL REALY STATE
BA2 CLOSE_GRILL_OUTPUT_PART99
ORIM PFOUT ,0010B ;SET PF.1 AS OUTPUT I/O
ANDIM PORTF ,1101B ;CLOSE GRILL RELAY
JMP CLOSE_GRILL_OUTPUT_PART99
CLOSE_GRILL_OUTPUT_PART99:
OPEN_GRILL_OUTPUT_PART:
BA2 OPEN_GRILL_OUTPUT_PART10
JMP OPEN_GRILL_OUTPUT_PART99
OPEN_GRILL_OUTPUT_PART10:
ORIM PORTF ,0010B ;OPEN GRILL RELAY
OPEN_GRILL_OUTPUT_PART99:
RELAY_OUTPUT_PART99:
LOOK_TIME_POWER_TIMER_PART: ;LOOK TIME(POWER)/CHILD LOCK TIMER PART
LDI TEMP ,01H
ADDM RB1_TIMER_SHARE_CT0 ,01H ;RAM BANK 1 REGISTER
LDI CLRACC ,00H
ADCM RB1_TIMER_SHARE_CT2 ,01H ;RAM BANK 1 REGISTER
LDI CLRACC ,00H
ADCM RB1_TIMER_SHARE_CT3 ,01H ;RAM BANK 1 REGISTER
RELAY_CHANGE_DELAY_TIMER_PART: ;WAVE,GRILL RELAY CHANGE DELAY 100MS TIMER PART
LDA PORTF ,00H ;GRILL RELAY
BA1 RELAY_CHANGE_DELAY_TIMER_PART10
;WAVE RELAY
BA2 RELAY_CHANGE_DELAY_TIMER_PART10
LDI TEMP ,01H
ADDM RB1_RELAY_CHANGE_CT0 ,01H ;BANK 1 REGISTER
LDI CLRACC ,00H
ADCM RB1_RELAY_CHANGE_CT1 ,01H ;BANK 1 REGISTER
LDI CLRACC ,00H
ADCM RB1_RELAY_CHANGE_CT2 ,01H ;BANK 1 REGISTER
JMP RELAY_CHANGE_DELAY_TIMER_PART99
RELAY_CHANGE_DELAY_TIMER_PART10:
LDI CLRACC ,00H
STA RB1_RELAY_CHANGE_CT0 ,01H ;BANK 1 REGISTER
STA RB1_RELAY_CHANGE_CT1 ,01H ;BANK 1 REGISTER
STA RB1_RELAY_CHANGE_CT2 ,01H ;BANK 1 REGISTER
RELAY_CHANGE_DELAY_TIMER_PART99:
RAY_DISPLAY_TIMER_PART: ;DISPLAY RAY TIMER PART
ADIM TIMER_RAY_CT0 ,01H
LDI CLRACC ,00H
ADCM TIMER_RAY_CT1 ,00H
LDI CLRACC ,00H
ADCM TIMER_RAY_CT2 ,00H
CJS8 TIMER_RAY_CT2,TIMER_RAY_CT1,07H,0DH,RAY_DISPLAY_TIMER_PART99 ;500MS
LDI TIMER_RAY_CT0 ,00H ;CLEAR DISPLAY RAY TIMER
LDI TIMER_RAY_CT1 ,00H
LDI TIMER_RAY_CT2 ,00H
EORIM WORK_FLAG0 ,1000B ;SET 500MS DISPLAY RAY FLAG
BA3 RAY_DISPLAY_TIMER_PART99
EORIM WORK_FLAG0 ,0010B ;SET 1S DISPLAY RAY FLAG
RAY_DISPLAY_TIMER_PART99:
CLOCK_TIMER_PART: ;CLOCK TIMER PART
LDA WORK_FLAG1 ,00H
BA3 CLOCK_TIMER_PART10 ;CLOCK ALREADY SET
JMP CLOCK_TIMER_PART99
CLOCK_TIMER_PART10:
ADIM TIMER_CLOCK_CT0 ,01H
LDI CLRACC ,00H
ADCM TIMER_CLOCK_CT1 ,00H
LDI CLRACC ,00H
ADCM TIMER_CLOCK_CT2 ,00H
LDI CLRACC ,00H
ADCM TIMER_CLOCK_CT3 ,00H
LDI CLRACC ,00H
ADCM TIMER_CLOCK_CT4 ,00H
CLOCK_TIMER_PART99:
TIMER_500MS_PART: ;500MS TIMER PART
LDI TEMP ,01H
ADDM RB1_DOOR_OPEN_CT3 ,01H
LDI CLRACC ,00H
ADCM RB1_DOOR_OPEN_CT4 ,01H
LDI CLRACC ,00H
ADCM RB1_DOOR_OPEN_CT5 ,01H
STA TEMP ,00H
LDA RB1_DOOR_OPEN_CT4 ,01H
STA CLRACC ,00H
CJS8 TEMP,CLRACC,07H,0DH,TIMER_500MS_PART99 ;500MS
LDI CLRACC ,00H
STA RB1_DOOR_OPEN_CT3 ,01H ;CLEAR TIMER
STA RB1_DOOR_OPEN_CT4 ,01H
STA RB1_DOOR_OPEN_CT5 ,01H
ORIM WORK_FLAG0 ,0100B ;SET 500 MS FLAG
TIMER_500MS_PART99:
TIMER_1000MS_PART:
LDA LOCK_COUNT ,BANK2
BNZ TIMER_1000MS_PART10
LDA WORK_FLAG4 ,00H
BA1 TIMER_1000MS_PART10
SBI WORK_TYPE ,07H
BNZ $+4
LDA WORK_FLAG8 ,BANK0
BA1 $+2
JMP TIMER_1000MS_PART10
LDA WORK_FLAG3 ,00H ;WORK START CHECK
BA1 TIMER_1000MS_PART10 ;START STATE
BA2 TIMER_1000MS_PART99
LDI TIMER_WT_CT0 ,00H
LDI TIMER_WT_CT1 ,00H
LDI TIMER_WT_CT2 ,00H
LDI TIMER_WT_CT3 ,00H
ANDIM WORK_FLAG1 ,1101B ;CLEAR 1S FLAG
JMP TIMER_1000MS_PART99
TIMER_1000MS_PART10: ;WORK ALREADY START
ADIM TIMER_WT_CT0 ,01H
LDI CLRACC ,00H
ADCM TIMER_WT_CT1 ,00H
LDI CLRACC ,00H
ADCM TIMER_WT_CT2 ,00H
LDI CLRACC ,00H
ADCM TIMER_WT_CT3 ,00H
CJS8 TIMER_WT_CT2,TIMER_WT_CT1,0FH,0AH,TIMER_1000MS_PART99
ORIM WORK_FLAG1 ,0010B ;SET 1S FLAG
ORIM WORK_FLAG7 ,0010B
TIMER_1000MS_PART99:
KEY_SCAN_TIMER_PART: ;5MS KEY SCAN TIMER PART
ADIM TIMER_KEY_CT0 ,01H
LDI CLRACC ,00H
ADCM TIMER_KEY_CT1 ,00H
CJS8 TIMER_KEY_CT1,TIMER_KEY_CT0,03H,01H,KEY_SCAN_TIMER_PART99 ;12.25MS CHECK
ORIM WORK_FLAG2 ,1000B ;SET 12.25 MS SCAN KEY FLAG
LDI TIMER_KEY_CT0 ,00H
LDI TIMER_KEY_CT1 ,00H
ADIM LONG_PRESS_EACH_CT ,01H ;LONG PRESS EACH TIME TIMER USED REGISTER
CJS4 LONG_PRESS_EACH_CT,04H,KEY_SCAN_TIMER_PART99
LDI LONG_PRESS_EACH_CT ,00H
ORIM WORK_FLAG1 ,0100B ;SET 50MS(49MS) LONG PRESS KEY ENABLE FLAG
KEY_SCAN_TIMER_PART99:
DISPLAY_OUTPUT_PART: ;DISPLAY OUTPUT PART
ADIM TIMER_DIS_CT ,01H ;1MS CHECK
CJS4 TIMER_DIS_CT,07H,DISPLAY_OUTPUT_PART05
LDI TIMER_DIS_CT ,00H
ADIM DISPLAY_BIT ,01H
CJS4 DISPLAY_BIT,07H,DISPLAY_OUTPUT_PART05
LDI DISPLAY_BIT ,00H
JMP DISPLAY_OUTPUT_PART99
DISPLAY_OUTPUT_PART05: ;DISPLAY LINE SELECT
LDA WORK_FLAG8 ,00H ;SCAN KEY CHECK
BA2 DISPLAY_OUTPUT_PART99
LDI PBOUT ,0FH ;CLOSE DISPLAY
LDI PDOUT ,0FH
LDI PHOUT ,0FH
LDI PORTB ,00H
ANDIM PORTD ,0011B
LDI PORTH ,00H
CJE4 DISPLAY_BIT,01H,DISPLAY_OUTPUT_PART10
CJE4 DISPLAY_BIT,02H,DISPLAY_OUTPUT_PART20
CJE4 DISPLAY_BIT,03H,DISPLAY_OUTPUT_PART30
CJE4 DISPLAY_BIT,04H,DISPLAY_OUTPUT_PART40
CJE4 DISPLAY_BIT,05H,DISPLAY_OUTPUT_PART50
CJE4 DISPLAY_BIT,06H,DISPLAY_OUTPUT_PART60
DISPLAY_OUTPUT_PART10: ;THE FIRST LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,0111B ;SET PA.3 AS LOW STATE
ORIM PDOUT ,0011B
ORIM PORTD ,0011B
LDA DIS_LINE6H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
STA TEMP ,00H
ANDIM TEMP ,1100B
ORM PORTD ,00H
LDA DIS_LINE6L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART20: ;THE SECOND LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,1011B ;SET PA.2 AS LOW STATE
ORIM PDOUT ,0011B
ORIM PORTD ,0011B
LDA DIS_LINE5H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
STA TEMP ,00H
ANDIM TEMP ,1100B
ORM PORTD ,00H
LDA DIS_LINE5L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART30: ;THE THIRD LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,1101B ;SET PA.1 AS LOW STATE
ORIM PDOUT ,0011B
ORIM PORTD ,0011B
LDA DIS_LINE4H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
STA TEMP ,00H
ANDIM TEMP ,1100B
ORM PORTD ,00H
LDA DIS_LINE4L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART40: ;THE FOUTRH LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,1110B ;SET PA.0 AS LOW STATE
ORIM PDOUT ,0011B
ORIM PORTD ,0011B
LDA DIS_LINE3H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
STA TEMP ,00H
ANDIM TEMP ,1100B
ORM PORTD ,00H
LDA DIS_LINE3L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART50: ;THE FIFTH LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,0FH
ORIM PDOUT ,0011B
ANDIM PORTD ,1110B
ORIM PORTD ,0010B
LDA DIS_LINE2H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
STA TEMP ,00H
ORM PORTD ,00H
LDA DIS_LINE2L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART60: ;THE SIXTH LINE OUTPUT
LDI PAOUT ,0FH
LDI PORTA ,0FH
ORIM PDOUT ,0011B
ANDIM PORTD ,1101B
ORIM PORTD ,0001B
LDA DIS_LINE1H ,01H ;BANK 1 REGISTER
STA PORTH ,00H
ORM PORTD ,00H
LDA DIS_LINE1L ,01H ;BANK 1 REGISTER
STA PORTB ,00H
DISPLAY_OUTPUT_PART99:
JMP TIMER0INT99
TIMER0INT99:
LDI IE ,1000B ;OPEN TIMER0 INT
LDA ACC ,00H
RTNI
;SUBROUTINE NAME:INT DATA MEMORY
;FUNCTION:INT DATA MEMORY REGISTERS(030H--16FH)
;INPUT PARAMETER:NO PARAMETER
;OUTPUT PARAMETER:NO PARAMETER
;USED REGISTERS:CLRACC
INTDMR: ;INT DATA MEMORY REGISTERS(030H--16FH)
LDI DPH ,00H
LDI DPM ,03H
LDI DPL ,00H
INT0:
LDI INX ,00H
ADIM DPL ,01H
LDI CLRACC ,00H
ADCM DPM ,00H
LDA DPM ,00H
BNZ INT1
LDA DPL ,00H
BNZ INT1
ADIM DPH ,01H
INT1:
SBI DPH ,02H
BNZ INT0
SBI DPM ,06H
BNZ INT0
SBI DPL ,0FH
BNZ INT0
RTNI
; INT DISPLAY DATA
INT_DIS_DATA:
LDI TEMP_R0 ,0FH
STA DIS_LINE1H ,01H ;RAM BANK 1 REGISTER
STA DIS_LINE1L ,01H
STA DIS_LINE2H ,01H
STA DIS_LINE2L ,01H
STA DIS_LINE3H ,01H
STA DIS_LINE3L ,01H
STA DIS_LINE4H ,01H
STA DIS_LINE4L ,01H
STA DIS_LINE5H ,01H
STA DIS_LINE5L ,01H
STA DIS_LINE6H ,01H
STA DIS_LINE6L ,01H
RTNI
; DELAY PART
DELAY:
LDI TEMP_R2 ,0FH
LDI TEMP_R1 ,0FH
LDI TEMP_R0 ,0FH
DELAY1:
LDI WDT ,0101B ;CLEAR WATCH DOG(16MS)
NOP
NOP
NOP
NOP
NOP
SBIM TEMP_R0 ,01H
LDI TEMP_R3 ,00H
SBCM TEMP_R1 ,00H
LDI TEMP_R3 ,00H
SBCM TEMP_R2 ,00H
BC DELAY1
RTNI
KEY_DELAY:
LDI TEMP_R0 ,0AH ;DELAY
SBIM TEMP_R0 ,01H
BC $-1
RTNI
; MAIN PROGRAMME PART
RESET:
NOP
LDI IE ,00H
LDI T0M ,0111B ;4MHZ,0.25MS,SET TO SHARED WITH PORTC.3
LDI T0L ,06H
LDI T0H ,00H
LDI CMP_CONTROL ,00H ;COMPARATOR OUTPUT FALLING EDGE GENERATE INTERRUPT,PORTE.0 IS SHARED AS I/O,INTERNAL REFERENCE VOLTAGE(VDD/2) IS SELECTED AS COMPARATOR NEGATIVE INPUT,COMPARATOR DISABLE
LDI CMP_STATUS ,00H ;COMPARATOR0 IS NOT OPERATION,COMPARATOR POSITIVE INPUT IS FROM CMPP1
LDI T2SET ,00H ;TIMER2 TIMER/COUNTER STOPS
LDI T2_SIGNAL_SET ,00H ;NO EXTERNAL SIGNAL SOURCE IS SELECTED
LDI TONE1_VOLUME_H ,00H ;TONE GENERATOR 1 DISABLE
LDI TONE1_VOLUME_L ,00H
LDI TONE2_VOLUME_H ,00H ;TONE GENERATOR 2 DISABLE
LDI TONE2_VOLUME_L ,00H
LDI PORTA ,0FH ;CLOSE DISPLAY
LDI PORTB ,00H
LDI PORTC ,00H
LDI PORTD ,0011B
LDI PORTE ,00H
LDI PORTF ,00H ;CLOSE RELAY,BUZZER
LDI PAOUT ,0FH ;SET PORTA AS OUTPUT I/O
LDI PBOUT ,0FH ;SET PORTB AS OUTPUT I/O
LDI PCOUT ,00H ;SET PORTC AS INPUT I/O
LDI PDOUT ,0FH ;SET PORTD AS OUTPUT I/O
LDI PEOUT ,00H ;SET PORTE AS INPUT I/O
LDI PFOUT ,1111B ;SET PORTF AS OUTPUT I/O
CALL DELAY
CALL DELAY
CALL INTDMR ;CLEAR DATA MEMORY REGISTERS
LDI BUZZER_TYPE ,01H ;SET POWER ON BUZZER FLAG
ORIM WORK_FLAG2 ,0100B ;SET CODDING SWITCH DISABLE FLAG
CALL INT_DIS_DATA
ORIM WORK_FLAG8 ,1000B ;SET POWER ON LCD ON FLAG
LDI TIME_HORH ,01H
LDI TIME_HORL ,02H
LDI TIME_MINH ,00H
LDI TIME_MINL ,00H
ORIM WORK_FLAG1 ,1000B ;SET CLOCK ALREADY SET FLAG
;*******************2006/4/5 15:08**********************
LDI T0L ,06H
LDI T0H ,00H
LDI IRQ ,00H ;CLEAR INTERRUPT REQUEST
;*******************2006/4/7 09:00**********************
LDI KEY_LS ,0FH
MAINPART:
;SUBROUTINE NAME:KEY SCAN AND PROCESS PART
;FUNCTION:SCAN ALL KEY AND PROCESS
;INPUT PARAMETER:WORK_FLAG2,WORK_FLAG3,WORK_FLAG4,RB1_TIMER_SHARE_CT0~RB1_TIMER_SHARE_CT3
;WORK_FLAG7
;OUTPUT PARAMETER:WORK_TYPE,BUZZER_TYPE
;USED REGISTERS:TEMP_R0~TEMP_R5,DOOR_T,KEY_LS,KEY_T,KEY_VALUE,KEY_VALUEL,KEY_VALUEH
; :CODING_VALUEL,CODING_VALUEH,NOW_COOK_TYPE,MUL_COOK_TYPE1~MUL_COOK_TYPE3
; :MUL_WORK_MINH1~3,MUL_WORK_MINL1~3,MUL_WORK_SECH1~3,MUL_WORK_SECL1~3
; :MUL_ORDER1~3
KEY_SCAN:
LDA WORK_FLAG2 ,00H ;12.25 MS?NO,GOTO OUT KEYSCAN
BA3 READKEY
JMP OUT_KEY_PART
READKEY:
ANDIM WORK_FLAG2 ,0111B ;CLEAR 12.25 MS FLAG
ORIM WORK_FLAG8 ,0100B ;SET KEY SCAN FLAG
LDI PAOUT ,0FH ;CLOSE DISPLAY
LDI PORTA ,0FH
LDI PBOUT ,0FH
LDI PORTB ,00H
LDI PDOUT ,0FH
LDI PORTD ,0011B
LDI PHOUT ,0FH
LDI PORTH ,00H
NOP
LDI PBOUT ,00H ;SET PB AS INPUT I/O
LDI PDOUT ,0011B ;SET PD.3 PD.2 AS INPUT I/O
LDI PHOUT ,00H ;SET PH AS INPUT I/O
LDI PB_PULL_HIGH ,0FH ;SET PB PULL HIGH
LDI PD_PULL_HIGH ,1100B ;SET PD.3 PD.2 PULL HIGH
LDI PH_PULL_HIGH ,0FH ;SET PH PULL HIGH
READ_LINE1:
LDI PEOUT ,0FH ;SET PE AS OUTPUT I/O
LDI PORTE ,0FH
ORIM PCOUT ,0100B ;SET PC.2 AS OUTPUT I/O
ORIM PORTC ,0100B
LDI PEOUT ,00H
LDI PE_PULL_HIGH ,0FH ;SET PE PULL HIGH
ANDIM PORTC ,1011B ;SET PC.2 AS LOW STATE
CALL KEY_DELAY
LDA PORTB ,00H ;READ THE FIRST LINE
STA LINE1_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
LDA PORTD ,00H
STA LINE1_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
READ_LINE2:
LDI PORTE ,0FH
ORIM PORTC ,0100B
LDI PEOUT ,0100B ;SET PE.2 AS OUTPUT I/O
ANDIM PCOUT ,1011B ;SET PC.2 AS INPUT I/O
LDI PC_PULL_HIGH ,0100B ;PC.2 PULL HIGH
LDI PE_PULL_HIGH ,1011B ;SET PE.3 PE.1 PE.0 PULL HIGH
ANDIM PORTE ,1011B ;SET PE.2 AS LOW STATE
CALL KEY_DELAY
LDA PORTB ,00H ;READ THE SECOND LINE
STA LINE2_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
LDA PORTD ,00H
STA LINE2_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
READ_LINE3:
LDI PORTE ,0FH
ORIM PORTC ,0100B
LDI PEOUT ,0010B ;SET PE.1 AS OUTPUT I/O
ANDIM PORTE ,1101B ;SET PE.1 AS LOW STATE
LDI PE_PULL_HIGH ,1101B ;SET PE.3 PE.2 PE.0 PULL HIGH
CALL KEY_DELAY
LDA PORTB ,00H ;READ THE THIRD LINE
STA LINE3_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
LDA PORTD ,00H
STA LINE3_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
READ_LINE4:
LDI PORTE ,0FH
ORIM PORTC ,0100B
LDI PEOUT ,0001B ;SET PE.0 AS OUTPUT I/O
ANDIM PORTE ,1110B ;SET PE.0 AS LOW STATE
LDI PE_PULL_HIGH ,1110B ;SET PE.3 PE.2 PE.1 PULL HIGH
CALL KEY_DELAY
LDA PORTB ,00H ;READ THE FOURTH LINE
STA LINE4_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
LDA PORTD ,00H
STA LINE4_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
READ_LINE5:
LDI PORTE ,0FH
ORIM PORTC ,0100B
LDI PEOUT ,1000B ;SET PE.3 AS OUTPUT I/O
ANDIM PORTE ,0111B ;SET PE.3 AS LOW STATE
LDI PE_PULL_HIGH ,0111B ;SET PE.0 PE.2 PE.1 PULL HIGH
CALL KEY_DELAY
LDA PORTB ,00H ;READ THE FIFTH LINE
STA LINE5_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
LDA PORTD ,00H
STA LINE5_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
DOOR_CHECK:
LDI PORTA ,0FH
LDI PBOUT ,0FH
LDI PORTB ,00H
LDI PDOUT ,0FH
LDI PORTD ,0011B
LDI PHOUT ,0FH
LDI PORTH ,00H
ANDIM PAOUT ,1101B ;SET PA.1 AS INPUT I/O
LDI PA_PULL_HIGH ,1101B ;CLOSE PORTA.1 PULL HIGH
NOP
CALL KEY_DELAY
NOP
LDA PORTA ,00H ;SCAN DOOR STATE
BA1 DOOR_CHECK4
JMP DOOR_CHECK3
DOOR_CHECK3: ;DOOR CLOSE STATE
LDI DOOR_T ,00H ;CLEAR DOOR CHECK TIMES
ANDIM WORK_FLAG3 ,0111B ;CLEAR DOOR OPEN FLAG
JMP DOOR_CHECK99
DOOR_CHECK4:
ADIM DOOR_T ,01H ;DOOR OPEN STATE
CJS4 DOOR_T,08H,DOOR_CHECK99 ;CHECK DOOR STATE 8 TIMES
ORIM WORK_FLAG3 ,1000B ;SET DOOR OPEN FLAG
DOOR_CHECK99:
LDI PORTE ,00H ;SET PE AS LOW STATE
ORIM PDOUT ,0011B ;SET PD.1,PD.0 AS OUTPUT I/O
ORIM PORTD ,0011B ;SET PD.1,PD.0 AS HIGH STATE
ANDIM WORK_FLAG8 ,1011B ;CLEAR KEY SCAN FLAG
LDA MACHINE_TYPE ,00H ;TEST MODE CHECK
BA0 KEY_CHECK99
KEY_CHECK:
LDA LINE1_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
STA TEMP_R0 ,00H
ANDIM TEMP_R0 ,1100B ;CLEAR BIT1 BIT0
LDA LINE2_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
STA TEMP_R0 ,00H
LDA LINE3_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
STA TEMP_R0 ,00H
LDA LINE4_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
STA TEMP_R0 ,00H
LDA LINE5_CURRENT_DATA_D ,01H ;BANK 1 REGISTER
STA TEMP_R0 ,00H
LDI TEMP_R0 ,0FH ;NO KEY PRESS CHECK
SUB LINE1_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
BNZ KEY_CHECK01
LDI TEMP_R0 ,0FH
SUB LINE2_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
BNZ KEY_CHECK01
LDI TEMP_R0 ,0FH
SUB LINE3_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
BNZ KEY_CHECK01
LDI TEMP_R0 ,0FH
SUB LINE4_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
BNZ KEY_CHECK01
LDI TEMP_R0 ,0FH
SUB LINE5_CURRENT_DATA_B ,01H ;BANK 1 REGISTER
BNZ KEY_CHECK01
LDI TEMP_R0 ,0CH
SUB LINE1_CURRENT_DATA_D ,01H
BNZ KEY_CHECK01
LDI TEMP_R0 ,0CH
SUB LINE2_CURRENT_DATA_D ,01H
BNZ KEY_CHECK01
LDI TEMP_R0 ,0CH
SUB LINE3_CURRENT_DATA_D ,01H
BNZ KEY_CHECK01
LDI TEMP_R0 ,0CH
SUB LINE4_CURRENT_DATA_D ,01H
BNZ KEY_CHECK01
LDI TEMP_R0 ,0CH
SUB LINE5_CURRENT_DATA_D ,01H
BNZ KEY_CHECK01
CALL SAVE_KEY_SCAN_VALUE ;SAVE CURRENT KEY SCAN VALUE
LDI KEY_LS ,0EH ;NO KEY
LDA WORK_FLAG3 ,00H
BA0 KEY_CHECK00 ;CHECK LOOK TIME/PRE-TIME FLAG
LDA WORK_FLAG0 ,00H
BA0 KEY_CHECK00 ;CHECK LOOK POWER FLAG
CALL CLEAR_LOOK_TIME ;CLEAR LONG PRESS(CHILD LOCK) TIME
LDI LONG_PRESS_EACH_CT ,00H ;CLEAR LONG PRESS KEY USED COUNTER
STA LONG_PRESS_TIME_CT ,01H
STA LONG_PRESS_EACH_CT1 ,01H
ANDIM WORK_FLAG4 ,0111B ;CLEAR LONG PRESS KEY ON FLAG
-----此内容被lixu于2006-10-20,20:12:41编辑过
-----此内容被lixu于2006-10-20,20:15:27编辑过 |
