#include <mega16.h>
#include <USART.h>
#include <DELAY.h>
#include <Types.h>
开发板类型:AVRKIT V2
芯片小板 :M16
连线方法 :
ISP1 -- ISP2
PORTB -- LED.G
PORTC -- LED.R
#pragma warn-
#define MAXEEPROM 512
eeprom unsigned char EEPROMS[MAXEEPROM];
#pragma warn+
void port_init(void)
PORTB = 0xFF;
DDRB = 0xFF;
PORTC = 0xFF;
DDRC = 0xFF;
PORTD = 0xFF;
DDRD = 0x00;
USART_Init(47); //3.6864M=23, 7.3728M=47
void TestCmd(void)
unsigned char Cmd; //命令缓冲区
unsigned char LED; //LED数据缓冲区
unsigned char State; //LED显示状态
State=0;
LED=0;
PORTC.0=0;
TransmitLineF("USART EXAMPLE"); //从串口送出字符串
while (1)
Cmd=0;
if (UCSRA&(1<<RXC)) //串口有信息吗?
Cmd=UDR; //如果有,接收一个字节
if ((Cmd>='0')&&(Cmd<='9'))
State=Cmd-'0';
//PORTD=~PORTD;
switch (Cmd)
case '0':
PORTC=~(1<<0);
case '1':
TransmitLineF("Inc Counter");
PORTC=~(1<<1);
case '2':
TransmitLineF("Dec Counter");
PORTC=~(1<<2);
case '3':
TransmitLineF("Shift Left");
PORTC=~(1<<3);
case '4':
TransmitLineF("Shift Right");
PORTC=~(1<<4);
case '5':
TransmitLineF("Logic Not ");
PORTC=~(1<<5);
case '6':
TransmitLineF("Data Test Mode");
PORTC=~(1<<6);
case '7':
TransmitLineF("Swap High and Low");
PORTC=~(1<<7);
default:
TransmitLineF("Error CMD");
switch (State) //如果LED显示状态条件为...
case 1: //如果LED显示模式为第一种
LED++; //LED显示模式做加法运算
case 2:
LED--; //LED显示模式做加法运算
case 3:
LED=LED<<1; //LED显示模式做左移位运算
if (!LED) LED=0x03; //如果超越范围<灯全灭了>,则重新初始为0x03,就是只有右边[A0,A1]二灯亮
case 4:
LED=LED>>1; //LED显示模式做右移位运算
if (!LED) LED=0xC0;//如果超越范围<灯全灭了>,则重新初始为0xC0,就是只有左边[A7,A6]二灯亮
case 5:
if ((LED!=0) && (LED!=0xFF)) {LED=0;} //如果所有的LED灯不是全亮或全灭,则设置为全灭
LED=~LED; //LED显示模式做取反运算
case 6:
if (LED==0x55)
{LED=0xAA;} //LED做相隔一位
{LED=0x55;}
case 7:
if (LED==0xF0)
{LED=0x0F;} //LED高4位和低4位相互亮
{LED=0xF0;}
case 8:
//LED=0x00; //没代码,LED不动,这个地方大家可随便自己改点什么的。
PORTB=~LED;
delay_ms(200);
char StrCmpF(unsigned char * Sour, flash unsigned char * Dest, unsigned char Case)
register char s;
register char d;
while ((*Sour)&&(*Dest))
s=*Sour;
d=*Dest;
if (Case)
if ((s>=0x61)&&(s<=0x7A)) {s&=0B11011111;};
if ((d>=0x61)&&(d<=0x7A)) {d&=0B11011111;};
if (s==d)
Sour++;
Dest++;
return 0;
if ((*Sour==0)&&(*Dest!=0)) {return 0;}
if ((*Sour!=0)&&(*Dest==0)) {return 0;}
return 1;
void TestString(void)
unsigned char CmdBuf[CMD_MAXBUFFER];
unsigned char * str;
unsigned char i;
PORTC.1=0;
str=&CmdBuf[1];
TransmitLineF("USART String Example"); //从串口送出字符串
while (1)
ReceiveString(CmdBuf);
if (CmdBuf[0]>0)
PORTC.7=0;
//TransmitByte(CmdBuf[0]);
//TransmitString(str);
if (StrCmpF(str,"Hi",1))
TransmitStringF("Hello");
TransmitByte(0);
goto next;
if (StrCmpF(str,"Who",1))
TransmitStringF("Aleyn");
TransmitByte(0);
goto next;
if (StrCmpF(str,"Date",1))
TransmitStringF("2006-04-28");
TransmitByte(0);
goto next;
if (StrCmpF(str,"Time",1))
TransmitStringF("22:39:01");
TransmitByte(0);
goto next;
if (StrCmpF(str,"Good",1))
TransmitStringF("Thank you");
TransmitByte(0);
goto next;
if (StrCmpF(str,"GoodBye",1))
TransmitStringF("See you next time");
TransmitByte(0);
goto next;
TransmitStringF("Error Command");
TransmitByte(0);
next:
PORTC.7=1;
for (i=0;i<CMD_MAXBUFFER;i++) {CmdBuf=0;}
#define CMD_HELP 72
#define CMD_READ 82
#define CMD_WRITE 87
void TestProtocol(void)
unsigned int i;
unsigned char CmdBuf[CMD_MAXBUFFER]; //命令缓冲区
unsigned int Addr; //内存地址
unsigned int Cnt; //读取长度
PORTC.2=0;
while (1)
ReceiveCMD(CmdBuf); //读取一条命令行
if (CmdBuf[0]>0) //如果命令行长度不为零
PORTC.7=0;
TransmitByte(CMD_BEGIN); //送出命令开始符
if (CmdBuf[1]==CMD_HELP) //如果接收的是帮助命令
TransmitByte(CMD_HELP); //送出命令
TransmitStringF("Test Protocol Version 1.0");
TransmitByte(13);
TransmitStringF("Command format(Hex):'1B CMD 1C'");
TransmitByte(13);
TransmitStringF("Read EEPROM Data:'R','Addr','Count'");
TransmitByte(13);
TransmitStringF("Write EEPROM Data:'W','Addr','Data'");
TransmitByte(13);
TransmitStringF("Show Help:'H'");
TransmitByte(13);
if (CmdBuf[1]==CMD_READ) //如果接收的是读取EEPROM命令
Addr=(((unsigned int)HexToByte(&CmdBuf[6]))<<8)|((unsigned int)HexToByte(&CmdBuf[8])); //内存地址
Cnt=(((unsigned int)HexToByte(&CmdBuf[10]))<<8)|((unsigned int)HexToByte(&CmdBuf[12])); //读写个数
if (Addr+Cnt<=MAXEEPROM)
TransmitByte(CMD_READ); //送出命令
for (i=0;i<Cnt;i++)
TransmitString(ByteToHex(EEPROMS[Addr+i])); //送回上位机
TransmitByte(32);
TransmitStringF("ERROR:Addr+Count Large then 512");
if (CmdBuf[1]==CMD_WRITE) //如果接收的是写入EEPROM命令
if (Addr<MAXEEPROM)
TransmitByte(CMD_WRITE); //送出命令
EEPROMS[Addr]=HexToByte(&CmdBuf[10]);
delay_ms(2); //写EEPROM的时候要隔5ms
TransmitString(ByteToHex(EEPROMS[Addr])); //回送给上位机做检查
TransmitStringF("ERROR:Addr Large then 512");
TransmitByte(CMD_END); //送出命令结束符
for (i=0;i<CMD_MAXBUFFER;i++) CmdBuf=0; //清空命令缓冲区
PORTC.7=1;
void main()
port_init();
while (1)
if (!PIND.4) TestCmd();
if (!PIND.5) TestString();
if (!PIND.6) TestProtocol();
AVR源程序
DELPHI源程序 |
