HT1621B作为一片便宜的LCD驱动器,真是不错!控制也很方便!这是我产品上用的一个分支程序!希望对大家有用!
觉得有用就顶一下啊!谢谢!
下面是我的程序:注释个人觉得很清晰!
#define uint unsigned int
//定义HT1621的命令
#define ComMode 0x52 //4COM,1/3bias 1000 010 1001 0
#define RCosc 0x30 //内部RC振荡器(上电默认)1000 0011 0000
#define LCD_on 0x06 //打开LCD 偏压发生器1000 0000 0 11 0
#define LCD_off 0x04 //关闭LCD显示
#define Sys_en 0x02 //系统振荡器开 1000 0000 0010
#define Ctrl_cmd 0x80 //写控制命令
#define Data_cmd 0xa0 //写数据命令
//定义端口HT1621数据端口
#define WR1 sbi(PORTD, 7)
#define WR0 cbi(PORTD, 7)
#define DATA1 sbi(PORTD, 6)
#define DATA0 cbi(PORTD, 6)
#define CS1 sbi(PORTC, 0)
#define CS0 cbi(PORTC, 0)
#define ZA 10
#define ZB 11
#define ZC 12
#define ZD 13
#define ZE 14
#define ZF 15
#define H 16
#define L 17
#define T 18
#define N 19
#define SUBB 20
#define P 21
#define R 22
#define NO 23
const char num[]={0x5f,0x06,0x6b,0x2f,0x36,0x3d,0x7d,0x07,0x7f,0x3f,
//0 1 2 3 4 5 6 7 8 9
0x77,0x7c,0x59,0x6e,0x79,0x71,0x76,0x58,0x51,0x57,0x20,0x73,0x60,0x00,
// A B C D E F H L T N - P R NO
uchar SMG1=0; //1号数码管
uchar SMG2=0; //2号数码管
uchar SMG3=0; //3号数码管
uchar SMG4=0; //4号数码管
uchar SMG5=0; //5号数码管
uchar SMG6=0; //6号数码管
uchar SIGN1=0; //标志1
uchar SIGN2=0; //标志2
#define ADD_SMG1 0x0
#define S1 (SMG1&0x80)
#define S1_ON (SMG1|=0x80) //标志S1"ON"
#define S1_OFF (SMG1&=0x7f)
#define ADD_SMG2 0x02
#define S2 (SMG2&0x80)
#define S2_ON (SMG2|=0x80) //标志S2"OFF"
#define S2_OFF (SMG2&=0x7f)
#define ADD_SMG3 0x04 //数码管3的地址00 010000
#define COL (SMG3&0x80)
#define COL_ON (SMG3|=0x80) //标志COL":"
#define COL_OFF (SMG3&=0x7f)
#define ADD_SMG4 0x06 //数码管4的地址 00 01 1000
#define ADD_SMG5 0x0a //数码管5的地址0010 1000
#define S14 (SMG5&0x80)
#define S14_ON (SMG5|=0x80) //标志S14
#define S14_OFF (SMG5&=0x7f)
#define ADD_SMG6 0x0c
#define S15 (SMG6&0x80)
#define S15_ON (SMG6|=0x80) //标志S15,除霜标志
#define S15_OFF (SMG6&=0x7f)
#define ADD_SIGN1 0x08 //标志1
#define ADD_SIGN2 0x0e //标志2
#define S13_ON (SIGN1|=0x80) //标志S13,加热的中心标志
#define S13_OFF (SIGN1&=0x7f)
#define S10_ON (SIGN1|=0x40) //标志S10
#define S10_OFF (SIGN1&=0xbf)
#define S5_ON (SIGN1|=0x20) //标志S5
#define S5_OFF (SIGN1&=0xdf)
#define S11_ON (SIGN1|=0x10) //标志S11
#define S11_OFF (SIGN1&=0xef)
#define S9_ON (SIGN1|=0x08) //标志S9
#define S9_OFF (SIGN1&=0xf7)
#define S8_ON (SIGN1|=0x04) //标志S8
#define S8_OFF (SIGN1&=0xfb)
#define S7_ON (SIGN1|=0x02) //标志S7
#define S7_OFF (SIGN1&=0xfd)
#define S6_ON (SIGN1|=0x01) //标志S6,S5-S11风扇旋转标志
#define S6_OFF (SIGN1&=0xfe)
#define S20_ON (SIGN2|=0x80) //标志S20,"Lock"标志
#define S20_OFF (SIGN2&=0x7f)
#define S12_ON (SIGN2|=0x40) //标志S12,摄氏度标志
#define S12_OFF (SIGN2&=0xbf)
#define S4_ON (SIGN2|=0x20) //标志S4,"Warm"标志
#define S4_OFF (SIGN2&=0xdf)
#define S3_ON (SIGN2|=0x10) //标志S3,"Time"标志
#define S3_OFF (SIGN2&=0xef)
#define S19_ON (SIGN2|=0x08) //标志S19
#define S19_OFF (SIGN2&=0xf7)
#define S18_ON (SIGN2|=0x04) //标志S18
#define S18_OFF (SIGN2&=0xfb)
#define S17_ON (SIGN2|=0x02) //标志S17
#define S17_OFF (SIGN2&=0xfd)
#define S16_ON (SIGN2|=0x01) //标志S16,S16-s19,加热标志
#define S16_OFF (SIGN2&=0xfe)
void SendBit_1621(uchar sdata,uchar cnt) //data 的高cnt 位写入HT1621,高位在前
uchar i;
for(i=0;i<cnt;i++)
WR0;
if(sdata&0x80) DATA1;
else DATA0;
WR1;
sdata<<=1;
void SendCmd_1621(uchar command)
CS0;
SendBit_1621(0x80,4); //写入标志码“100”和9 位command 命令,由于
SendBit_1621(command,8); //没有使有到更改时钟输出等命令,为了编程方便
CS1; //直接将command 的最高位写“0”
void Write_1621(uchar addr,uchar sdata)
addr<<=2;
CS0;
SendBit_1621(0xa0,3); //写入标志码“101”
SendBit_1621(addr,6); //写入addr 的高6位
SendBit_1621(sdata,8); //写入data 的8位
CS1;
void HT1621_all_off(void)
{ uchar i;
uchar addr=0;
for(i=0;i<8;i++)
Write_1621(addr,0x00);
addr+=2;
void HT1621_all_on(void)
{ uchar i;
uchar addr=0;
for(i=0;i<8;i++)
Write_1621(addr,0xff);
addr+=2;
void Init_1621(void)
SendCmd_1621(Sys_en);
SendCmd_1621(RCosc);
SendCmd_1621(ComMode);
SendCmd_1621(LCD_on);
void LCDoff(void)
SendCmd_1621(LCD_off);
void LCDon(void)
void sun_turn1(void)
S6_ON;S8_ON;S10_ON; S7_OFF;S9_OFF;S11_OFF;
void sun_turn2(void)
S7_ON;S9_ON;S11_ON; S6_OFF;S8_OFF;S10_OFF;
void sun_turn12off(void)
S6_OFF;S8_OFF;S10_OFF;S7_OFF;S9_OFF;S11_OFF;S5_OFF;
void burn1(void)
S16_ON;S18_ON;S17_OFF;S19_OFF;
void burn2(void)
S16_OFF;S18_OFF;S17_ON;S19_ON;
void burn12off(void)
S16_OFF;S18_OFF;S17_OFF;S19_OFF;
void Disp_RSTS(void)
SMG1=R;SMG2=5;SMG3=T;SMG4=5;
void Disp_RS__(void)
SMG1=R;SMG2=5;SMG3=SUBB;SMG4=SUBB;
void Disp_CSTS(void)
SMG1=ZC;SMG2=5;SMG3=T;SMG4=5;
void Disp_CSOS(void)
SMG1=ZC;SMG2=5;SMG3=0;SMG4=5;
void Disp_ENTE(void)
SMG1=ZE;SMG2=N;SMG3=T;SMG4=ZE;
void Disp_ONOF(void)
SMG1=0;SMG2=N;SMG3=0;SMG4=ZF;
void Disp_HTTS(void)
SMG1=H;SMG2=T;SMG3=T;SMG4=5;
void Disp_CSTC(void)
SMG1=ZC;SMG2=5;SMG3=T;SMG4=ZC;
void Disp_STS8(void)
SMG1=5;SMG2=T;SMG3=5;SMG4=8;
void Disp_08__(void)
SMG1=0;SMG2=8;SMG3=SUBB;SMG4=SUBB;
void Disp_10__(void)
SMG1=SUBB;SMG2=SUBB;SMG3=1;SMG4=0;
void Disp_DONH(void)
SMG1=ZD;SMG2=0;SMG3=N;SMG4=H;
void Disp_DONF(void)
SMG1=ZD;SMG2=0;SMG3=N;SMG4=ZF;
void Disp_DOFH(void)
SMG1=ZD;SMG2=0;SMG3=ZF;SMG4=H;
void Disp_DOFF(void)
SMG1=ZD;SMG2=0;SMG3=ZF;SMG4=ZF;
void Disp_LOCT(void)
SMG1=L;SMG2=0;SMG3=ZC;SMG4=T;
void Disp_ES(void)
SMG5=ZE;SMG6=5;
void Disp_EL(void)
SMG5=ZE;SMG6=L;
void Disp_EH(void)
SMG5=ZE;SMG6=H;
void Disp_EE(void)
SMG5=ZE;SMG6=ZE;
void Disp_NND(void)
SMG1=NO;SMG2=NO;SMG3=ZD;
void Disp_on(void)
SMG5=0;SMG6=N;
void Disp_of(void)
SMG5=0;SMG6=ZF;
void Disp_pb_t(void)
SMG1=P;SMG2=ZB;SMG3=SUBB;SMG4=T;
void Disp_PP(void)
SMG5=P;SMG6=P;
-----此内容被gphs于2006-09-18,09:44:58编辑过 |
