发表于 2006-9-13 14:51:33
#ifndef __USB_H__
#define __USB_H__
#include <stdlib.h>
* 'interface' is defined somewhere in the Windows header files. This macro
* is deleted here to avoid conflicts and compile errors.
#ifdef interface
#undef interface
* PATH_MAX from limits.h can't be used on Windows if the dll and
* import libraries are build/used by different compilers
#define LIBUSB_PATH_MAX 512
* USB spec information
* This is all stuff grabbed from various USB specs and is pretty much
* not subject to change
* Device and/or Interface Class codes
#define USB_CLASS_PER_INTERFACE 0 /* for DeviceClass */
#define USB_CLASS_AUDIO 1
#define USB_CLASS_COMM 2
#define USB_CLASS_HID 3
#define USB_CLASS_PRINTER 7
#define USB_CLASS_MASS_STORAGE 8
#define USB_CLASS_HUB 9
#define USB_CLASS_DATA 10
#define USB_CLASS_VENDOR_SPEC 0xff
* Descriptor types
#define USB_DT_DEVICE 0x01
#define USB_DT_CONFIG 0x02
#define USB_DT_STRING 0x03
#define USB_DT_INTERFACE 0x04
#define USB_DT_ENDPOINT 0x05
#define USB_DT_HID 0x21
#define USB_DT_REPORT 0x22
#define USB_DT_PHYSICAL 0x23
#define USB_DT_HUB 0x29
* Descriptor sizes per descriptor type
#define USB_DT_DEVICE_SIZE 18
#define USB_DT_CONFIG_SIZE 9
#define USB_DT_INTERFACE_SIZE 9
#define USB_DT_ENDPOINT_SIZE 7
#define USB_DT_ENDPOINT_AUDIO_SIZE 9 /* Audio extension */
#define USB_DT_HUB_NONVAR_SIZE 7
/* ensure byte-packed structures */
#include <pshpack1.h>
/* All standard descriptors have these 2 fields in common */
struct usb_descriptor_header {
unsigned char bLength;
unsigned char bDescriptorType;
/* String descriptor */
struct usb_string_descriptor {
unsigned short wData[1];
/* HID descriptor */
struct usb_hid_descriptor {
unsigned short bcdHID;
unsigned char bCountryCode;
unsigned char bNumDescriptors;
/* Endpoint descriptor */
#define USB_MAXENDPOINTS 32
struct usb_endpoint_descriptor {
unsigned char bEndpointAddress;
unsigned char bmAttributes;
unsigned short wMaxPacketSize;
unsigned char bInterval;
unsigned char bRefresh;
unsigned char bSynchAddress;
unsigned char *extra; /* Extra descriptors */
int extralen;
#define USB_ENDPOINT_ADDRESS_MASK 0x0f /* in bEndpointAddress */
#define USB_ENDPOINT_DIR_MASK 0x80
#define USB_ENDPOINT_TYPE_MASK 0x03 /* in bmAttributes */
#define USB_ENDPOINT_TYPE_CONTROL 0
#define USB_ENDPOINT_TYPE_ISOCHRONOUS 1
#define USB_ENDPOINT_TYPE_BULK 2
#define USB_ENDPOINT_TYPE_INTERRUPT 3
/* Interface descriptor */
#define USB_MAXINTERFACES 32
struct usb_interface_descriptor {
unsigned char bInterfaceNumber;
unsigned char bAlternateSetting;
unsigned char bNumEndpoints;
unsigned char bInterfaceClass;
unsigned char bInterfaceSubClass;
unsigned char bInterfaceProtocol;
unsigned char iInterface;
struct usb_endpoint_descriptor *endpoint;
int extralen;
#define USB_MAXALTSETTING 128 /* Hard limit */
struct usb_interface {
struct usb_interface_descriptor *altsetting;
int num_altsetting;
/* Configuration descriptor information.. */
#define USB_MAXCONFIG 8
struct usb_config_descriptor {
unsigned short wTotalLength;
unsigned char bNumInterfaces;
unsigned char bConfigurationValue;
unsigned char iConfiguration;
unsigned char MaxPower;
struct usb_interface *interface;
int extralen;
/* Device descriptor */
struct usb_device_descriptor {
unsigned short bcdUSB;
unsigned char bDeviceClass;
unsigned char bDeviceSubClass;
unsigned char bDeviceProtocol;
unsigned char bMaxPacketSize0;
unsigned short idVendor;
unsigned short idProduct;
unsigned short bcdDevice;
unsigned char iManufacturer;
unsigned char iProduct;
unsigned char iSerialNumber;
unsigned char bNumConfigurations;
struct usb_ctrl_setup {
unsigned char bRequestType;
unsigned char bRequest;
unsigned short wValue;
unsigned short wIndex;
unsigned short wLength;
* Standard requests
#define USB_REQ_GET_STATUS 0x00
#define USB_REQ_CLEAR_FEATURE 0x01
/* 0x02 is reserved */
#define USB_REQ_SET_FEATURE 0x03
/* 0x04 is reserved */
#define USB_REQ_SET_ADDRESS 0x05
#define USB_REQ_GET_DESCRIPTOR 0x06
#define USB_REQ_SET_DESCRIPTOR 0x07
#define USB_REQ_GET_CONFIGURATION 0x08
#define USB_REQ_SET_CONFIGURATION 0x09
#define USB_REQ_GET_INTERFACE 0x0A
#define USB_REQ_SET_INTERFACE 0x0B
#define USB_REQ_SYNCH_FRAME 0x0C
#define USB_TYPE_STANDARD (0x00 << 5)
#define USB_TYPE_CLASS (0x01 << 5)
#define USB_TYPE_VENDOR (0x02 << 5)
#define USB_TYPE_RESERVED (0x03 << 5)
#define USB_RECIP_DEVICE 0x00
#define USB_RECIP_INTERFACE 0x01
#define USB_RECIP_ENDPOINT 0x02
#define USB_RECIP_OTHER 0x03
* Various libusb API related stuff
#define USB_ENDPOINT_IN 0x80
#define USB_ENDPOINT_OUT 0x00
/* Error codes */
#define USB_ERROR_BEGIN 500000
* This is supposed to look weird. This file is generated from autoconf
* and I didn't want to make this too complicated.
#define USB_LE16_TO_CPU(x)
/* Data types */
/* struct usb_device; */
/* struct usb_bus; */
struct usb_device {
struct usb_device *next, *prev;
char filename[LIBUSB_PATH_MAX];
struct usb_bus *bus;
struct usb_device_descriptor descriptor;
struct usb_config_descriptor *config;
void *dev; /* Darwin support */
unsigned char devnum;
unsigned char num_children;
struct usb_device **children;
struct usb_bus {
struct usb_bus *next, *prev;
char dirname[LIBUSB_PATH_MAX];
struct usb_device *devices;
unsigned long location;
struct usb_device *root_dev;
/* Version information, Windows specific */
struct usb_version {
struct {
int major;
int minor;
int micro;
int nano;
} dll;
struct {
int major;
int minor;
int micro;
int nano;
} driver;
struct usb_dev_handle;
typedef struct usb_dev_handle usb_dev_handle;
/* Variables */
extern struct usb_bus *usb_busses;
#include <poppack.h>
#ifdef __cplusplus
extern "C" {
/* Function prototypes */
/* usb.c */
usb_dev_handle *usb_open(struct usb_device *dev);
int usb_close(usb_dev_handle *dev);
int usb_get_string(usb_dev_handle *dev, int index, int langid, char *buf,
size_t buflen);
int usb_get_string_simple(usb_dev_handle *dev, int index, char *buf,
size_t buflen);
/* descriptors.c */
int usb_get_descriptor_by_endpoint(usb_dev_handle *udev, int ep,
unsigned char type, unsigned char index,
void *buf, int size);
int usb_get_descriptor(usb_dev_handle *udev, unsigned char type,
unsigned char index, void *buf, int size);
/* <arch>.c */
int usb_bulk_write(usb_dev_handle *dev, int ep, char *bytes, int size,
int timeout);
int usb_bulk_read(usb_dev_handle *dev, int ep, char *bytes, int size,
int timeout);
int usb_interrupt_write(usb_dev_handle *dev, int ep, char *bytes, int size,
int timeout);
int usb_interrupt_read(usb_dev_handle *dev, int ep, char *bytes, int size,
int timeout);
int usb_control_msg(usb_dev_handle *dev, int requesttype, int request,
int value, int index, char *bytes, int size,
int timeout);
int usb_set_configuration(usb_dev_handle *dev, int configuration);
int usb_claim_interface(usb_dev_handle *dev, int interface);
int usb_release_interface(usb_dev_handle *dev, int interface);
int usb_set_altinterface(usb_dev_handle *dev, int alternate);
int usb_resetep(usb_dev_handle *dev, unsigned int ep);
int usb_clear_halt(usb_dev_handle *dev, unsigned int ep);
int usb_reset(usb_dev_handle *dev);
char *usb_strerror(void);
void usb_init(void);
void usb_set_debug(int level);
int usb_find_busses(void);
int usb_find_devices(void);
struct usb_device *usb_device(usb_dev_handle *dev);
struct usb_bus *usb_get_busses(void);
/* Windows specific functions */
#define LIBUSB_HAS_INSTALL_SERVICE_NP 1
int usb_install_service_np(void);
#define LIBUSB_HAS_UNINSTALL_SERVICE_NP 1
int usb_uninstall_service_np(void);
#define LIBUSB_HAS_INSTALL_DRIVER_NP 1
int usb_install_driver_np(const char *inf_file);
const struct usb_version *usb_get_version(void);
int usb_isochronous_setup_async(usb_dev_handle *dev, void **context,
unsigned char ep, int pktsize);
int usb_bulk_setup_async(usb_dev_handle *dev, void **context,
unsigned char ep);
int usb_interrupt_setup_async(usb_dev_handle *dev, void **context,
unsigned char ep);
int usb_submit_async(void *context, char *bytes, int size);
int usb_reap_async(void *context, int timeout);
int usb_free_async(void **context);
#ifdef __cplusplus
#endif /* __USB_H__ */ |
