发表于 2006-11-5 14:00:40
回【48楼】 whimsy,应该是,见AVR-Doper.2006-10-23中的hardware.h。
Port | Function | dir | value
PORT B
0 | HVSP Supply [O] 1
1 OC1A | SMPS [O] 0
2 | HVSP RESETHV / LEDHV [O] 0
3 OC2 | HVSP SCI / ISP target clk [O] 0
4 | ISP driver enable [O] 0
5 | LED Prog active [O] 1
6 XTAL1 | XTAL
7 XTAL2 | XTAL
PORT C (ADC)
0 | SMPS feedback 0
1 | ISP voltage sense 0
2 | ISP SCK [O] 0
3 | ISP MISO [I] 1
4 | ISP MOSI [O] 0
5 | ISP RESET / HVSP RESET [O] 0
6 RESET | Reset
7 n/a | *
PORT D
0 RxD | ISP TxD [I] 1
1 TxD | ISP RxD [I] 1
2 Int0 | USB D+ 0
3 Int1 | USB D- 0
4 T0 | JUMPER Low Speed [I] 1
5 T1 | HVSP SII (PPD1) [I] 1
6 AIN0 | HVSP SDI (PPD0) [I] 1
7 AIN1 | HVSP SDO (PPD2) [I] 1
/* The following defines can be used with the PORT_* macros from utils.h */
#define HWPIN_HVSP_SUPPLY B, 0
#define HWPIN_SMPS_OUT B, 1
#define HWPIN_HVSP_HVRESET B, 2
#define HWPIN_HVSP_SCI B, 3
#define HWPIN_ISP_CLK B, 3
#define HWPIN_ISP_DRIVER B, 4
#define HWPIN_LED B, 5
#define HWPIN_ADC_SMPS C, 0
#define HWPIN_ADC_VTARGET C, 1
#define HWPIN_ISP_SCK C, 2
#define HWPIN_ISP_MISO C, 3
#define HWPIN_ISP_MOSI C, 4
#define HWPIN_ISP_RESET C, 5
#define HWPIN_HVSP_RESET C, 5
#define HWPIN_ISP_TXD D, 0
#define HWPIN_ISP_RXD D, 1
#define HWPIN_USB_DPLUS D, 2
#define HWPIN_USB_DMINUS D, 3
#define HWPIN_JUMPER D, 4
#define HWPIN_HVSP_SII D, 5
#define HWPIN_HVSP_SDI D, 6
#define HWPIN_HVSP_SDO D, 7
