使用者只需把这个nokia3310.h的文件复制到工程目录即可
使用nokia3310库函数时,请先定义3310与MCU的连接
本例子3310LCD与单片机的连接如下
RESET PB1
D/C PB2
SDIN PB3
SCLK PB5
SCE GND
英文字库,5*8点阵,每一个字符占用5个字节,共94个可显示字符数据**/
#define RESET PORTB.1 //RESET=0时,LCD复位
#define DC PORTB.2 //DC=0_指令,DC=1_数据
#define SDIN PORTB.3
#define SCLK PORTB.5
#define RESET_DDRn DDRB.1 //RESET=0时,LCD复位
#define DC_DDRn DDRB.2 //DC=0_指令,DC=1_数据
#define SDIN_DDRn DDRB.3
#define SCLK_DDRn DDRB.5
flash unsigned char data[]={
0x00, 0x00, 0x00, 0x00, 0x00, // sp
0x00, 0x00, 0x2f, 0x00, 0x00, // !
0x00, 0x07, 0x00, 0x07, 0x00, // "
0x14, 0x7f, 0x14, 0x7f, 0x14, // #
0x24, 0x2a, 0x7f, 0x2a, 0x12, // $
0x62, 0x64, 0x08, 0x13, 0x23, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // ’
0x00, 0x1c, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1c, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x00, 0xA0, 0x60, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x00, 0x42, 0x7F, 0x40, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x21, 0x41, 0x45, 0x4B, 0x31, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3C, 0x4A, 0x49, 0x49, 0x30, // 6
0x01, 0x71, 0x09, 0x05, 0x03, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x06, 0x49, 0x49, 0x29, 0x1E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x32, 0x49, 0x59, 0x51, 0x3E, // @
0x7C, 0x12, 0x11, 0x12, 0x7C, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x22, 0x1C, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x49, 0x49, 0x7A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x20, 0x40, 0x41, 0x3F, 0x01, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x04, 0x08, 0x10, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x3E, 0x41, 0x51, 0x21, 0x5E, // Q
0x7F, 0x09, 0x19, 0x29, 0x46, // R
0x46, 0x49, 0x49, 0x49, 0x31, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x3F, 0x40, 0x38, 0x40, 0x3F, // W
0x63, 0x14, 0x08, 0x14, 0x63, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x41, 0x00, // [
0x55, 0x2A, 0x55, 0x2A, 0x55, // 55
0x00, 0x41, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // ’
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x48, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x20, // c
0x38, 0x44, 0x44, 0x48, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x08, 0x7E, 0x09, 0x01, 0x02, // f
0x18, 0xA4, 0xA4, 0xA4, 0x7C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x40, 0x80, 0x84, 0x7D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x18, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0xFC, 0x24, 0x24, 0x24, 0x18, // p
0x18, 0x24, 0x24, 0x18, 0xFC, // q
0x7C, 0x08, 0x04, 0x04, 0x08, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x3F, 0x44, 0x40, 0x20, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x1C, 0xA0, 0xA0, 0xA0, 0x7C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x00, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x00, 0x41, 0x36, 0x08, 0x00, // }
0x08, 0x10, 0x08, 0x04, 0x08 // ~
void lcd_write(unsigned char data) //写LCD函数
unsigned char n=8;
while(n>0)
n--;
SDIN=data<<7-n>>7; //先发送数据高位MSB,后发送数据低位LSB
SCLK=0; SCLK=1; //产生一个时钟
/*上面的是模拟SPI发送数据函数,下面的是硬件SPI发送数据函数
SPCR=80;
SPDR=data; //开始发送数据
while((SPSR>>7)==0); //等待发送接收结束
void lcd_cls(void) //nokia3310清屏,光标复位
unsigned int i=0;
DC=0;
lcd_write(128); //光标回到0列
lcd_write(64); //光标回到0行
DC=1; //准备写数据
for(i=0;i<504;i++) //写504个0数据,就是清屏
lcd_write(0);
void lcd_init(void) //nokia3310初始化函数
RESET_DDRn =1; //设置4个驱动LCD的IO脚为输出
DC_DDRn =1;
SDIN_DDRn =1;
SCLK_DDRn =1;
RESET=0;
RESET=1; //复位结束
DC=0; //准备写指令
lcd_write(32+1); //进入扩展指令
lcd_write(128+38); //设置Vop,相当于亮度
lcd_write(4+3); //设置温度系数,相当于对比度
lcd_write(16+3); //设置偏置,这句要与不要的实际效果好像一样
lcd_write(32+0); //进入基本指令
lcd_write(12); //使能芯片活动/垂直寻址
//光标定位,x(0-83)是列地址,y(0-5)是行地址
void lcd_gotoxy(unsigned char x,unsigned char y)
DC=0;
lcd_write(x+128);
lcd_write(y+64);
void lcd_putchar(unsigned char character) //显示ASCII值的字符
unsigned char i=0;
unsigned int No;
No=character-32; //字模数据是由空格开始,空格字符的ASCII的值就是32
No=No*5; //每个字符的字模是5个字节
DC=1;
while(i<5) //一个字符的字模是5个字节,就是5*8点阵
lcd_write(data[No]);
i++;
No++;
lcd_write(0); //每个字符之间空一列
void lcd_put(unsigned char byte_data) //以十进制显示一个字符变量
lcd_putchar(byte_data/100+48); //百位数转化为ASCII值再显示
lcd_putchar(byte_data/10%10+48); //十位数转化为ASCII值再显示
lcd_putchar(byte_data%10+48); //个位数转化为ASCII再再显示
void lcd_puthex(unsigned char byte_data) //以十六进制显示一个字节变量
unsigned char temp_data;
temp_data=byte_data>>4; //求高4位
if(temp_data<10) temp_data+=48; else temp_data+=55; //转化为ASCII值
lcd_putchar(temp_data); //显示
temp_data=byte_data&15; //求低4位
void lcd_putsf(flash unsigned char *string , unsigned char n) //显示FLASH里面的字符串
unsigned char i=0;
while(i<n)
lcd_putchar( string[ i ] ); //顺序显示字符
i++;
