发表于 2006-6-30 02:53:40
I installed it successfully. First you have to remove any old license key from license manager, then you uninstall any older copy of IAR ARM Workbench. When install the latest v4.40 evaluation copy, you must use the new ID and license key generated from new keygen (see above reply 1楼). You should have fully working evaluation copy without code size and time limit.
By the way, there is update for v4.40 at IAR website but it is for full version only. Any idea where/how to get full verison with crack? |
