发表于 2006-4-20 22:29:18
软件包
#include "rtl8019.h"
* Module Name: Realtek 8019AS Driver
* Created By: Louis Beaudoin (www.embedded-creations.com)
* Original Release: September 21, 2002
* Module Description:
* Provides functions to initialize the Realtek 8019AS, and send and retreive
* packets
* November 16, 2003 - Louis Beaudoin
* The rtl8019Write and Read functions/macros were changed to support
* three methods of communcating with the NIC
* Interfacing with the AVR ports changed from sbi/cbi/etc functions
* to direct port names
* Renamed functions to be more consistant with the two NIC drivers
* Overrun function now retransmits if resend is set (thanks Krzysztof)
* November 15, 2002 - Louis Beaudoin
* processRTL8019Interrupt() - bit mask mistake fixed
* November 8, 2003 - Louis Beaudoin
* Changed delay library function calls
* September 30, 2002 - Louis Beaudoin
* Receive functions modified to handle errors encountered when receiving a
* fast data stream. Functions now manually retreive data instead of
* using the send packet command. Interface improved by checking for
* overruns and data in the buffer internally.
* Corrected the overrun function - overrun flag was not reset after overrun
* Added support for the Imagecraft Compiler
* Added support to communicate with the NIC using general I/O ports
* rtl8019Write( RTL_ADDRESS, RTL_DATA )
* Args: 1. unsigned char RTL_ADDRESS - register offset of RTL register
* 2. unsigned char RTL_DATA - data to write to register
* Date: September 21, 2002
* Description: Writes byte to RTL8019 register.
* Notes - If using the External SRAM Interface, performs a write to
* address MEMORY_MAPPED_RTL8019_OFFSET + (RTL_ADDRESS<<8)
* The address is sent in the non-multiplxed upper address port so
* no latch is required.
* If using general I/O ports, the data port is left in the input
* state with pullups enabled
#if NIC_CONNECTION == MEMORY_MAPPED_HIGHADDR
#define rtl8019Write(RTL_ADDRESS,RTL_DATA) do{ *(volatile unsigned char *) \
(MEMORY_MAPPED_RTL8019_OFFSET \
+ (((unsigned char)(RTL_ADDRESS)) << 8)) = \
(unsigned char)(RTL_DATA); } while(0)
+ (unsigned char)(RTL_ADDRESS)) = \
#if NIC_CONNECTION == GENERAL_IO
void rtl8019Write(unsigned char address, unsigned char data)
// assert the address, leaving the non-address pins intact
address |= (RTL8019_ADDRESS_PORT & ~RTL8019_ADDRESS_MASK);
RTL8019_ADDRESS_PORT = address;
// set data bus as output and place data on bus
RTL8019_DATA_DDR = 0xFF;
RTL8019_DATA_PORT = data;
// toggle write pin
RTL8019_CONTROL_PORT &= ~_BV(RTL8019_CONTROL_WRITEPIN);
nop();
RTL8019_CONTROL_PORT |= _BV(RTL8019_CONTROL_WRITEPIN);
// set data port back to input with pullups enabled
RTL8019_DATA_DDR = 0x00;
RTL8019_DATA_PORT = 0xFF;
* rtl8019Read(RTL_ADDRESS)
* Args: unsigned char RTL_ADDRESS - register offset of RTL register
* Description: Reads byte from RTL8019 register
* Notes - If using the External SRAM Interface, performs a read from
* If using general I/O ports, the data port is assumed to already be
* an input, and is left as an input port when done
#define rtl8019Read(RTL_ADDRESS) (*(volatile unsigned char *) \
+ (((unsigned char)(RTL_ADDRESS)) << 8)) )
+ (unsigned char)(RTL_ADDRESS)) )
unsigned char rtl8019Read(unsigned char address)
unsigned char byte;
// assert read
RTL8019_CONTROL_PORT &= ~_BV(RTL8019_CONTROL_READPIN);
nop();
// read in the data
byte = RTL8019_DATA_PIN;
// negate read
RTL8019_CONTROL_PORT |= _BV(RTL8019_CONTROL_READPIN);
return byte;
* RTL8019setupPorts(void);
* Description: Sets up the ports used for communication with the RTL8019 NIC
* (data bus, address bus, read, write, and reset)
void rtl8019SetupPorts(void)
// make the address port output
RTL8019_ADDRESS_DDR = RTL8019_ADDRESS_MASK;
// make the data port input with pull-ups
// make the control port read and write pins outputs and asserted
RTL8019_CONTROL_DDR |= _BV(RTL8019_CONTROL_READPIN);
RTL8019_CONTROL_DDR |= _BV(RTL8019_CONTROL_WRITEPIN);
#else
// enable external SRAM interface - no wait states
MCUCR |= _BV(SRE);
// enable output pin for Resetting the RTL8019
RTL8019_RESET_DDR |= _BV(RTL8019_RESET_PIN);
* HARD_RESET_RTL8019()
* Description: Simply toggles the pin that resets the NIC
#define HARD_RESET_RTL8019() do{ RTL8019_RESET_PORT |= _BV(RTL8019_RESET_PIN);\
delay_ms(10); \
RTL8019_RESET_PORT &= ~_BV(RTL8019_RESET_PIN);}\
while(0)
* rtl8019Overrun(void);
* Description: "Canned" receive buffer overrun function originally from
* a National Semiconductor appnote
* Notes: This function must be called before retreiving packets from
* the NIC if there is a buffer overrun
void rtl8019Overrun(void);
//* REALTEK CONTROL REGISTER OFFSETS
//* All offsets in Page 0 unless otherwise specified
//* All functions accessing CR must leave CR in page 0 upon exit
#define CR 0x00
#define PSTART 0x01
#define PAR0 0x01 // Page 1
#define CR9346 0x01 // Page 3
#define PSTOP 0x02
#define BNRY 0x03
#define TSR 0x04
#define TPSR 0x04
#define TBCR0 0x05
#define NCR 0x05
#define TBCR1 0x06
#define ISR 0x07
#define CURR 0x07 // Page 1
#define RSAR0 0x08
#define CRDA0 0x08
#define RSAR1 0x09
#define CRDA1 0x09
#define RBCR0 0x0A
#define RBCR1 0x0B
#define RSR 0x0C
#define RCR 0x0C
#define TCR 0x0D
#define CNTR0 0x0D
#define DCR 0x0E
#define CNTR1 0x0E
#define IMR 0x0F
#define CNTR2 0x0F
#define RDMAPORT 0x10
#define RSTPORT 0x18
* RTL ISR Register Bits
#define ISR_RST 7
#define ISR_OVW 4
#define ISR_PRX 0
#define ISR_RDC 6
#define ISR_PTX 1
* RTL Register Initialization Values
// RCR : accept broadcast packets and packets destined to this MAC
// drop short frames and receive errors
#define RCR_INIT 0x04
// TCR : default transmit operation - CRC is generated
#define TCR_INIT 0x00
// DCR : allows send packet to be used for packet retreival
// FIFO threshold: 8-bits (works)
// 8-bit transfer mode
#define DCR_INIT 0x58
// IMR : interrupt enabled for receive and overrun events
#define IMR_INIT 0x11
// buffer boundaries - transmit has 6 256-byte pages
// receive has 26 256-byte pages
// entire available packet buffer space is allocated
#define TXSTART_INIT 0x40
#define RXSTART_INIT 0x46
#define RXSTOP_INIT 0x60
void rtl8019BeginPacketSend(unsigned int packetLength)
unsigned int sendPacketLength;
sendPacketLength = (packetLength>=ETHERNET_MIN_PACKET_LENGTH) ?
packetLength : ETHERNET_MIN_PACKET_LENGTH ;
//start the NIC
rtl8019Write(CR,0x22);
// still transmitting a packet - wait for it to finish
while( rtl8019Read(CR) & 0x04 );
//load beginning page for transmit buffer
rtl8019Write(TPSR,TXSTART_INIT);
//set start address for remote DMA operation
rtl8019Write(RSAR0,0x00);
rtl8019Write(RSAR1,0x40);
//clear the packet stored interrupt
rtl8019Write(ISR,(1<<ISR_PTX));
//load data byte count for remote DMA
rtl8019Write(RBCR0, (unsigned char)(packetLength));
rtl8019Write(RBCR1, (unsigned char)(packetLength>>8));
rtl8019Write(TBCR0, (unsigned char)(sendPacketLength));
rtl8019Write(TBCR1, (unsigned char)((sendPacketLength)>>8));
//do remote write operation
rtl8019Write(CR,0x12);
void rtl8019SendPacketData(unsigned char * localBuffer, unsigned int length)
unsigned int i;
for(i=0;i<length;i++)
rtl8019Write(RDMAPORT, localBuffer);
void rtl8019EndPacketSend(void)
//send the contents of the transmit buffer onto the network
rtl8019Write(CR,0x24);
// clear the remote DMA interrupt
rtl8019Write(ISR, (1<<ISR_RDC));
// pointers to locations in the RTL8019 receive buffer
static unsigned char nextPage;
static unsigned int currentRetreiveAddress;
// location of items in the RTL8019's page header
#define enetpacketstatus 0x00
#define nextblock_ptr 0x01
#define enetpacketLenL 0x02
#define enetpacketLenH 0x03
unsigned int rtl8019BeginPacketRetreive(void)
unsigned char i;
unsigned char bnry;
unsigned char pageheader[4];
unsigned int rxlen;
// check for and handle an overflow
rtl8019ProcessInterrupt();
// read CURR from page 1
rtl8019Write(CR,0x62);
i = rtl8019Read(CURR);
// return to page 0
// read the boundary register - pointing to the beginning of the packet
bnry = rtl8019Read(BNRY) ;
// return if there is no packet in the buffer
if( bnry == i )
return 0;
// clear the packet received interrupt flag
rtl8019Write(ISR, (1<<ISR_PRX));
// the boundary pointer is invalid, reset the contents of the buffer and exit
if( (bnry >= RXSTOP_INIT) || (bnry < RXSTART_INIT) )
rtl8019Write(BNRY, RXSTART_INIT);
rtl8019Write(CR, 0x62);
rtl8019Write(CURR, RXSTART_INIT);
rtl8019Write(CR, 0x22);
return 0;
// initiate DMA to transfer the RTL8019 packet header
rtl8019Write(RBCR0, 4);
rtl8019Write(RBCR1, 0);
rtl8019Write(RSAR0, 0);
rtl8019Write(RSAR1, bnry);
rtl8019Write(CR, 0x0A);
for(i=0;i<4;i++)
pageheader = rtl8019Read(RDMAPORT);
// end the DMA operation
for(i = 0; i <= 20; i++)
if(rtl8019Read(ISR) & 1<<6)
rtl8019Write(ISR, 1<<6);
rxlen = (pageheader[enetpacketLenH]<<8) + pageheader[enetpacketLenL];
nextPage = pageheader[nextblock_ptr] ;
currentRetreiveAddress = (bnry<<8) + 4;
// if the nextPage pointer is invalid, the packet is not ready yet - exit
if( (nextPage >= RXSTOP_INIT) || (nextPage < RXSTART_INIT) )
return 0;
return rxlen-4;
void rtl8019RetreivePacketData(unsigned char * localBuffer, unsigned int length)
unsigned int i;
// initiate DMA to transfer the data
rtl8019Write(RBCR0, (unsigned char)length);
rtl8019Write(RBCR1, (unsigned char)(length>>8));
rtl8019Write(RSAR0, (unsigned char)currentRetreiveAddress);
rtl8019Write(RSAR1, (unsigned char)(currentRetreiveAddress>>8));
localBuffer = rtl8019Read(RDMAPORT);
currentRetreiveAddress += length;
if( currentRetreiveAddress >= 0x6000 )
currentRetreiveAddress = currentRetreiveAddress - (0x6000-0x4600) ;
void rtl8019EndPacketRetreive(void)
unsigned char i;
// set the boundary register to point to the start of the next packet
rtl8019Write(BNRY, nextPage);
unsigned char data_L, resend;
data_L = rtl8019Read(CR);
rtl8019Write(CR, 0x21);
delay_ms(2);
rtl8019Write(RBCR0, 0x00);
rtl8019Write(RBCR1, 0x00);
if(!(data_L & 0x04))
resend = 0;
else if(data_L & 0x04)
data_L = rtl8019Read(ISR);
if((data_L & 0x02) || (data_L & 0x08))
resend = 0;
resend = 1;
rtl8019Write(TCR, 0x02);
rtl8019Write(ISR, 0x10);
rtl8019Write(TCR, TCR_INIT);
if(resend)
rtl8019Write(CR, 0x26);
rtl8019Write(ISR, 0xFF);
void rtl8019Init(void)
rtl8019SetupPorts();
HARD_RESET_RTL8019();
// do soft reset
rtl8019Write( ISR, rtl8019Read(ISR) ) ;
delay_ms(50);
rtl8019Write(CR,0x21); // stop the NIC, abort DMA, page 0
delay_ms(2); // make sure nothing is coming in or going out
rtl8019Write(DCR, DCR_INIT); // 0x58
rtl8019Write(RBCR0,0x00);
rtl8019Write(RBCR1,0x00);
rtl8019Write(RCR,0x04);
rtl8019Write(TPSR, TXSTART_INIT);
rtl8019Write(TCR,0x02);
rtl8019Write(PSTART, RXSTART_INIT);
rtl8019Write(PSTOP, RXSTOP_INIT);
rtl8019Write(CR, 0x61);
delay_ms(2);
rtl8019Write(PAR0+0, MYMAC_0);
rtl8019Write(PAR0+1, MYMAC_1);
rtl8019Write(PAR0+2, MYMAC_2);
rtl8019Write(PAR0+3, MYMAC_3);
rtl8019Write(PAR0+4, MYMAC_4);
rtl8019Write(PAR0+5, MYMAC_5);
rtl8019Write(ISR,0xFF);
rtl8019Write(IMR, IMR_INIT);
rtl8019Write(CR, 0x22); // start the NIC
void rtl8019ProcessInterrupt(void)
unsigned char byte = rtl8019Read(ISR);
if( byte & (1<<ISR_OVW) )
rtl8019Overrun();
