回复: 40
[原创]CVAVR下的ST7920的串行驱动,运行成功,拿出来晒晒,希望能去水分,越晒越好,哈哈
发表于 2006-3-18 17:45:05 | 显示全部楼层 |阅读模式
FileName     : lcd.h
Created by   : ZhengYanbo
Created date : 2006.3.17
Last modified: 2006.3.17
Comments:    : serial drive for st7920
#ifndef __LCD_H__
#define __LCD_H__
#include "type.h"
//LCM122*32 pin define
#define CLK                 PORTC.5     //pc5
#define SID                 PORTC.4     //pc4
#define CS                  PORTB.4     //pb4
#define SET_CLK()           CLK = 1;
#define CLR_CLK()           CLK = 0;
#define SET_SID()           SID = 1;
#define CLR_SID()           SID = 0;
#define LCD_Enable()        CS = 1;
#define LCD_Disable()       CS = 0;
#define SID_PIN_IN()        DDRC.4 = 0;
#define SID_PIN_OUT()       DDRC.4 = 1;
#define CLK_PIN_OUT()       DDRC.5 = 1;
#define CS_PIN_OUT()        DDRB.4 = 1;
#define SID_PIN             PINC.4 //read pinx, not port!
#define LCD_Hi_Z()          DDRC &= 0xCF;
//lcd serial command
//#define LCD_WRITE_COMMAND   0b11111000
//#define LCD_WRITE_DATA      0b11111010
//#define LCD_READ_STATUS     0b11111100
//#define LCD_READ_DATA       0b11111110
#define LCD_WRITE_COMMAND   0xF8
#define LCD_WRITE_DATA      0xFA
#define LCD_READ_STATUS     0xFC
#define LCD_READ_DATA       0xFE
void serial_write_byte(byte data);
byte serial_read_byte(void);
void LCDWriteCmd(byte command);
void LCDWriteData(byte data);
void InitLCD(void);
void LCD_Write_CGRAM(byte nBytes);
void writechar(byte value);
void writestring(byte flash *strn);
void gotoxy(byte line, byte position);
void LCDclrscr(void);
void blink(byte on_off);
void writeNumber(word value);
FileName     : lcd.c
#include "lcd.h"
#include "type.h"
flash byte CGRAM[128] =
//目录循环
0xE3,0x9E,0x91,0x11,0x89,0x11,0x89,0x1E,
0x89,0x14,0x91,0x12,0xE3,0x91,0x00,0x00,
0x00,0x00,0x3F,0xFC,0x40,0x02,0x40,0x42,
0x40,0x82,0x3D,0xFC,0x00,0x80,0x00,0x40,
//文件循环
0xEE,0x8F,0x84,0x88,0x84,0x88,0xE4,0x8E,
0x84,0x88,0x84,0x88,0x8E,0xEF,0x00,0x00,
0x00,0x00,0x3F,0xFC,0x40,0x02,0x40,0x22,
0x40,0x42,0x3E,0xFC,0x00,0x40,0x00,0x20,
//随机模式
0xE1,0x1B,0x92,0x95,0x94,0x55,0xE7,0xD5,
0xA4,0x51,0x94,0x51,0x00,0x00,0x00,0x00,
//磁盘循环
0xCE,0x74,0xA4,0x84,0x94,0x85,0x94,0x66,
0x94,0x14,0xA4,0x16,0xCE,0xE5,0x00,0x00,
//用串行方式写一个字节数据到LCD
    byte i;
    //SID pin output mode
    SID_PIN_OUT();
    CLK_PIN_OUT();
    CS_PIN_OUT();
    for(i=0; i<8; i++)
    if(data & 0x80)
     SET_SID();
     CLR_SID();
    //send clk
    CLR_CLK();
    #asm("nop");
    SET_CLK();
    data<<=1;
//以串行方式从LCD中读一个字节,返回数据
    byte i, temp=0;
    //SID pin input mode
    SID_PIN_IN();
    CLK_PIN_OUT();
    CS_PIN_OUT();
    for(i=0; i<8; i++)
    temp<<=1;
    //send clk
    CLR_CLK();
    #asm("nop");
    SET_CLK();
    //wait pin steady
    #asm("nop");
    temp = (byte)SID_PIN;
    return(temp);
//读LCD的状态,读出BF信号
byte LCD_read_status(void)
    byte temp;
    LCD_Enable();
    //send 0b11111100
    serial_write_byte(LCD_READ_STATUS);
    //read upper 4 bits
    temp = serial_read_byte() & 0xF0;
    //read lower 4 bits
    temp = (serial_read_byte() & 0xF0)>>4 + temp;
    LCD_Disable();
    //return its value
    return(temp);
//忙信号BF检查
//返回: 1->success    0->error(time out)
byte check_busy(void)
    byte time_out;
    time_out=255;
    while(LCD_read_status()&0x80)
    time_out--;
    //check time out
    if(time_out==0) return 0;
    return 1;
//写命令到LCM
    //not check BF state
    delay_us(100);
    LCD_Enable();
    //send 0b11111000
    serial_write_byte(LCD_WRITE_COMMAND);
    //write upper 4 bits
    serial_write_byte(command & 0xF0);
    //write lower 4 bits
    serial_write_byte((command<<4) & 0xF0);
    LCD_Disable();
//写数据到LCM
    delay_us(100);
    LCD_Enable();
    //send 0b11111010
    serial_write_byte(LCD_WRITE_DATA);
    serial_write_byte(data & 0xF0);
    serial_write_byte((data<<4) & 0xF0);
    LCD_Disable();
//Initialize LCD, then print logo
void InitLCD(void)
    delay_ms(50);       //Wait LCD ready
    LCDWriteCmd(0x30);  //function set
    delay_us(100);
    delay_us(100);
    LCDWriteCmd(0x0C);  //display on, cursor off
    delay_us(100);
    LCDWriteCmd(0x01);  //clear lcd
    delay_ms(10);
    LCDWriteCmd(0x06);  //Entry mode set
    //Write LCD CGRAM
    LCD_Write_CGRAM(128);
    //Printing Logo
    //LCDclrscr();
    gotoxy(0,0);
    writestring("ST7920串行驱动");
    gotoxy(1,0);
    writestring("版本:Test v1.0");
    delay_ms(1000);
    //second screen
    LCDclrscr();
    writestring("设计:Datazyb");
    gotoxy(1,0);
    writestring("日期:2006.3.17");
    //Load user's font characters
    byte i;
    //Set CGram addres;
    LCDWriteCmd(0x40);
    //load CGRAM characters
    for(i=0;i<nBytes;i++) LCDWriteData(CGRAM);
    //Write 1 character
    //#asm("cli");
    LCDWriteData(value);
    //Set High status
    LCD_Hi_Z();
//Write a string from flash ROM
    while (*strn!=0) writechar(*strn++);
//Gotoxy function. X=line number, Y=character position
    byte address;
    address=lcdLineStart[line]+position;
    LCDWriteCmd(address);
//Clear LCD
    LCDWriteCmd(0x01);
    delay_ms(5); //Writing cycle time is 4.6ms for LCD128X64.
//Setup curson blink, based on player state
    //if on_off = 1 blink on, if on_off=0 blink off
    LCDWriteCmd(0x0C + (on_off & 1));
//Write a decimal number on LCD
    byte temp[8],i=0;
    do {
    temp[i++]=value%10;
    value=value/10;
    while (value>0);
    //start from back and print the number
    for(;i>0;) writechar(temp[--i]+48);
//end of lcd.c
我使用的是RT12232F型显示器,要特别注意跳线.请看下面的图:
 楼主| 发表于 2006-3-18 17:48:45 | 显示全部楼层
还有个type define:
#ifndef _TYPE_H_
#define _TYPE_H_
typedef unsigned char   byte;
typedef unsigned int    word;
typedef unsigned long   dword;
 楼主| 发表于 2006-3-18 17:55:02 | 显示全部楼层
我没有数码相机,干脆来个资料全集吧:
project files:
点击此处下载armok01108607.rar
说明:包里有整个CVAVR工程文件,直接使用CVAVR就可以直接编译,硬件连接在.h文件里自己看吧~~~~要换接口改变下接口定义.
-----此内容被elefan于2006-03-18,17:57:55编辑过
发表于 2006-3-18 17:56:36 | 显示全部楼层
能做到一行任选几个字反白显示不?
能像LED一样左右移动不?
 楼主| 发表于 2006-3-18 18:00:53 | 显示全部楼层
ST7920自身的指令并不好使用.任意几个字反白我暂时没做.移动还是自己写个函数吧!很简单
发表于 2006-3-18 18:12:07 | 显示全部楼层
是的,我想用自带汉字库,反白只能是一行,不能任意,除非自己做字库以图形RAM来写。
移动?用它本身字库也是麻烦,不能一列快速移动,只能一个字一个字(16×16)移动,快了还不清,请问有什么好方法不?
 楼主| 发表于 2006-3-18 18:15:35 | 显示全部楼层
几个字反白要利用绘图指令吧!具体我也没有做.你说的这种移动估计只有利用绘图才比较理想
发表于 2006-3-18 18:21:30 | 显示全部楼层
GDRAM是可以的,但关键是字库不想自己做了。呵呵
发表于 2006-3-20 08:46:27 | 显示全部楼层
好东西。
发表于 2006-3-25 19:32:46 | 显示全部楼层
楼主可以发个接线图吗
接线方面有没有什么要注意的
我的弄不出来
发表于 2006-3-26 16:43:55 | 显示全部楼层
请问楼主会问绘图模式吗
 楼主| 发表于 2006-3-26 18:49:08 | 显示全部楼层
回question:在.h文件里定义线,另外要特别注意跳线.很简单,就3线.
发表于 2006-4-10 11:22:50 | 显示全部楼层
好帖子,多谢elefan
我刚好有ATmega8515和ST7920(128*32),我用CVAVR1248d试过了程序,硬件可以正常运行
不过,我是刚刚学CVAVR的,所以大部分代码我都看不懂,学习学习
请问elefan,能告诉我你的邮箱吗?谢谢
 楼主| 发表于 2006-4-10 14:23:30 | 显示全部楼层
Email: Datazyb_007@163.com
发表于 2006-11-18 13:21:42 | 显示全部楼层
请教楼主是否试过用下面的子程序读出LCM的RAM数据?
下面子程序中 temp = (byte)SID_PIN;这句看不明白.
    byte i, temp=0;
    SID_PIN_IN();
    CLK_PIN_OUT();
    CS_PIN_OUT();
    for(i=0; i<8; i++)
    temp<<=1;
    //send clk
    CLR_CLK();
    #asm("nop");
    SET_CLK();
    //wait pin steady
    #asm("nop");
    return(temp);
发表于 2006-11-18 19:06:01 | 显示全部楼层
请问我的3v的LCDst7920怎么和5v的avr接呢?
是否可以用74HC245作隔离?
请教了!
谢谢!
 楼主| 发表于 2006-11-19 22:02:48 | 显示全部楼层
to  GandF: 你终于指出了问题所在。
应该是:
temp |= (byte)SID_PIN;
这个问题我后来才发现了,但是我没指出来,想让人指出这个问题。时间长了,后来就忘记了。对大家造成不便,深表歉意。
to okay51: 使用电阻分压最简单了。如下图:
+5V clk -|
        _|_
        | |1.8k
         |____________+3V clk to lcd
        _|_
        | |3.3k
         - gnd
数据线也这样连接。回读数据的时候,因为端口是高阻,所以逻辑依然正确。
发表于 2006-11-20 03:25:27 | 显示全部楼层
我试过,一样读不出数据.是不是串口没法读数据?
发表于 2006-12-7 19:58:28 | 显示全部楼层
多谢 elefan  非常感谢!
我就是担心回读 你说:回读数据的时候,因为端口是高阻,所以逻辑依然正确。
我不大明白啊 请明示?谢谢
 楼主| 发表于 2006-12-9 00:05:46 | 显示全部楼层
to  GandF:
我也没有成功过了,因为LCM是杂牌我也不能确定问题所在。
to  okay51:
当你回读数据的时候,AVR的IO端口为高阻抗,上面那1.8K的电阻不影响输入电平。
发表于 2007-5-21 21:46:09 | 显示全部楼层
谢谢哇,买了个12864只会用并口!
发表于 2007-5-21 23:36:11 | 显示全部楼层
这样行末有分号的宏定义行吗?在引用的时候又加了分号!
发表于 2007-8-6 00:55:27 | 显示全部楼层
我也试了,没成功,程序贴出来,大家帮忙看看(液晶是阿莫这买的黄底黑字,程序是楼主的改的,M8 7.3728MHz)
FileName     : lcd.h
#ifndef __LCD_H__
#define __LCD_H__
#include "type.h"
#define CLK                 PORTC.2     //pc2
#define SID                 PORTC.1     //pc1
#define CS                  PORTC.0     //pC0
#define SET_CLK()           CLK=1
#define CLR_CLK()           CLK=0
#define SET_SID()           SID=1
#define CLR_SID()           SID=0
#define LCD_Enable()        CS=1
#define LCD_Disable()       CS=0
#define SID_PIN_IN()        DDRC.1=0
#define SID_PIN_OUT()       DDRC.1=1
#define CLK_PIN_OUT()       DDRC.2=1
#define CS_PIN_OUT()        DDRC.0=1
#define SID_PIN             PINC.1  //read pinx, not port!
#define LCD_Hi_Z()          PORTC&=~0x07
void InitLCD(void);
FileName     : lcd.c
#include "lcd.h"
#include "type.h"
//用串行方式写一个字节数据到LCD
    byte i;
    SID_PIN_OUT();
    CLK_PIN_OUT();
    CS_PIN_OUT();
    for(i=0; i<8; i++)
    if(data & 0x80)
     SET_SID();
     CLR_SID();
     CLR_CLK();
    //wait pin steady
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    //send clk
    SET_CLK();
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    data<<=1;
    CLR_CLK();
    byte i, temp=0;
    SID_PIN_IN();
    CLK_PIN_OUT();
    CS_PIN_OUT();
    for(i=0; i<8; i++)
    temp<<=1;
    CLR_CLK();
    //wait pin steady
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    //send clk
    SET_CLK();
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    #asm("nop");
    CLR_CLK();
    return(temp);
//读LCD的状态,读出BF信号
    byte temp;
    LCD_Enable();
    //send 0b11111100
    //read upper 4 bits
    //read lower 4 bits
    LCD_Disable();
    //return its value
    return(temp);
//忙信号BF检查
    int time_out;
    time_out=500;
    time_out--;
    //check time out
    return 1;
//写命令到LCM
    //delay_us(500);
    check_busy();
    LCD_Enable();
    //send 0b11111000
    serial_write_byte(command&0xF0);
    serial_write_byte((command<<4)&0xF0);
    LCD_Disable();
//写数据到LCM
    //delay_us(500);
    check_busy();
    LCD_Enable();
    //send 0b11111010
    serial_write_byte(data&0xF0);
    serial_write_byte((data<<4)&0xF0);
    LCD_Disable();
    byte i;
    //Set CGram addres;
    LCDWriteCmd(0x40);
    //Write 1 character
    //#asm("cli");
    //Set High status
    LCD_Hi_Z();
    byte address;
//Clear LCD
    LCDWriteCmd(0x01);
    delay_ms(25); //Writing cycle time is 4.6ms for LCD128X64.
    byte temp[8],i=0;
    do {
    temp[i++]=value%10;
    value=value/10;
    while (value>0);
void InitLCD(void)
    check_busy();
    delay_us(100);
    delay_us(100);
    delay_us(100);
    delay_ms(10);
    //Write LCD CGRAM
    //Printing Logo
    //LCDclrscr();
    gotoxy(0,0);
    gotoxy(1,0);
    delay_ms(1000);
    //second screen
    LCDclrscr();
    gotoxy(1,0);
//end of lcd.c
#ifndef _GLOBAL_H_
#define _GLOBAL_H_
#include "type.h"
byte    key=0;
byte    key_code=0;
byte    intFlag=0;
byte    Menu_Layer=0;
byte    cursorPos=1;
byte    root_index=1;
byte    sub_index=1;
byte    sub_sub_index=1;
flash byte lcdLineStart[4]={0x80,0x90,0x88,0x98};
0x3E,0x38,0x7F,0x38,0xFF,0xB8,0xDD,0xB8,
0x9C,0xB8,0x1C,0x38,0x1C,0x38,0x1C,0x38,
0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1D,0x39,
0x1D,0xBB,0x1D,0xFF,0x1C,0xFE,0x1C,0x7C,
//play char
0x1C,0x00,0x1E,0x00,0x1F,0x00,0x1F,0x80,
0x1F,0xC0,0x1F,0xE0,0x1F,0xF0,0x1F,0xF8,
0x1F,0xF8,0x1F,0xF0,0x1F,0xE0,0x1F,0xC0,
0x1F,0x80,0x1F,0x00,0x1E,0x00,0x1C,0x00,
//stop char
0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xF8,
0x1F,0xF8,0x1F,0xF8,0x1F,0xF8,0x1F,0xF8,
0x1F,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
//pause char
0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x38,
0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,
0x1C,0x38,0x00,0x00,0x00,0x00,0x00,0x00
;CodeVisionAVR C Compiler V1.24.7c Professional
;(C) Copyright 1998-2005 Pavel Haiduc, HP InfoTech s.r.l.
;http://www.hpinfotech.com
;Chip type              : ATmega8L
;Program type           : Application
;Clock frequency        : 16.000000 MHz
;Memory model           : Small
;Optimize for           : Size
CPU : MEGA8
CLK : 12MHz
Test:
Last Access Date: 2006.3.17
#include <mega8.h>
#include "type.h"
#include "global.h"
#include "lcd.h"
#include <delay.h>
void main (void)
unsigned char i;
InitLCD();
delay_ms(1000);
    LCDclrscr();
    gotoxy(2,0);
    writestring("终于看到你了!");
    LCD_Enable();
    delay_ms(2000);
}//main loop
发表于 2007-12-2 16:59:42 | 显示全部楼层
谢谢elefan,程序完全可以使用的,我和m162也可以正常使用,请大家放心使用,不过有谁能写出汉字移动的函数,谢谢拉
发表于 2007-12-11 09:03:55 | 显示全部楼层
谢谢
发表于 2008-3-5 15:22:47 | 显示全部楼层
汉字移动可以上下,不可以左右
发表于 2008-3-5 15:30:12 | 显示全部楼层
还有个问题,我用mega48的硬件SPI驱动ST7920,只写模式,英文字母显示都没有问题,汉字显示有不少不能显示出来,会是什么原因呢?
还有就是datasheet说的cgram的设置和写入,按照st7920的demo程序翻译成C都不行啊。
发表于 2008-3-5 19:30:36 | 显示全部楼层
mark
发表于 2008-3-6 20:20:39 | 显示全部楼层
好贴,顶一下
发表于 2008-5-6 10:09:56 | 显示全部楼层
hao
发表于 2008-6-2 19:31:42 | 显示全部楼层
串行真的能读???
试试先,嘻嘻,谢谢了
发表于 2008-9-15 14:45:04 | 显示全部楼层
MARK
发表于 2009-1-8 16:32:12 | 显示全部楼层
MMAARRKK
发表于 2009-2-24 21:53:55 | 显示全部楼层
我想问一下,到底串行液晶可不可以读取数据呢?
发表于 2010-5-12 15:40:56 | 显示全部楼层
mark
发表于 2010-6-17 09:36:31 | 显示全部楼层
mark
发表于 2010-6-17 11:00:10 | 显示全部楼层
mark
发表于 2010-9-29 19:20:47 | 显示全部楼层
mark
发表于 2011-11-13 13:31:03 | 显示全部楼层
mark!
发表于 2012-2-25 23:38:08 | 显示全部楼层
mark
GMT+8, 2024-9-28 08:20
