回复: 10
怎样使用protues的source code debug
发表于 2006-3-3 16:19:05 | 显示全部楼层 |阅读模式
怎么才能从debug选项中调出这个窗口呢?
贴补上图呀?
发表于 2006-3-3 17:33:45 | 显示全部楼层
要调出source code debug窗口,要求你的单片机AVR的源文件使用cof文件,并且这个cof文件有版本限制。ICC6.31a Pro,你应该改一下编译器选项,AVR Studio Version选Studio 3.x 。Gcc中也要修改Debug Format,改为AVR-COFF.
我的教程里提到了,里面有很多图
http://www.ouravr.com/bbs/bbs_content.jsp?bbs_sn=555615&bbs_page_no=1&bbs_id=1037
Gcc设置参考
http://www.ouravr.com/bbs/bbs_content.jsp?bbs_sn=591552&bbs_page_no=2&bbs_id=1000
 楼主| 发表于 2006-3-3 21:05:19 | 显示全部楼层
谢谢 archeng504 阿成
你说的那个编译器应该需要另外下载吧,AVR系列我不太熟悉,我用的51单片机,在安装目录下的例子里并没有.cof格式的文加呀,在source code 的窗口下有个.SDI格式的文件,用记事本打开内容如下:
,,,; EEPROM - Read Write the EEPROM.
,,,; Specify Device.
,,,.device AT90S8515
,,,; I/O Register Definitions
,,,.equ    SREG    =$3F
,,,.equ    SP      =$3D
,,,.equ    TIMSK   =$39
,,,.equ    TIFR    =$38
,,,.equ    MCUCR   =$35
,,,.equ    TCCR1A  =$2F
,,,.equ    TCCR1B  =$2E
,,,.equ    OCR1AH  =$2B
,,,.equ    OCR1AL  =$2A
,,,.equ    ICR1H   =$25
,,,.equ    ICR1L   =$24
,,,.equ    EECR  =$1C
,,,.equ    EEDR    =$1D
,,,.equ    EEAR    =$1E
,,,.equ  PORTB   =$18
,,,.equ  DDRB    =$17
,,,.equ    PINB    =$16
,,,.equ    PORTC   =$15
,,,.equ    DDRC    =$14
,,,.equ  PINC    =$13
,,,.equ  PORTD   =$12
,,,.equ  DDRD    =$11
,,,.equ    SPDR    =$0F
,,,.equ    SPSR    =$0E
,,,.equ    SPCR    =$0D
,,,.equ    UDR     =$0C
,,,.equ    USR     =$0B
,,,.equ    UCR     =$0A
,,,.equ    UBRR    =$09
,,,.equ    ACSR    =$08
,,,.equ    ADMUX   =$07
,,,.equ    ADCSR   =$06
,,,.equ    ADCH    =$05
,,,.equ    ADCL    =$04
,,,; Variable Declarations
,,,.def temp     = r16
,,,.def isrsreg  = r17
,,,.def isrtemp1 = r18
,,,.def isrtemp2 = r19
,,,.def isrflag  = r20
,,,.def X        = r26
,,,.def Y        = r28
,,,.def Z        = r30
,,,.cseg                                 ; CODE segment.
,,,.org 0
000000,C000,,       rjmp init                       ; origin.
,,,;Main Routine
000002,ED0F,init,init:   ldi r16,$DF                    ; Initialize the stack.
000004,BF0D,,       out SP,r16
,,,; Write some data to the external memory at 0x0400
000006,EA00,loop,loop:   ldi r16,$A0                    ; Enable Sleep and SRAM - 0 ws
000008,BF05,,       out MCUCR,r16
00000A,E505,,       ldi r16,$55
00000C,9300,,        sts $0400,r16
000010,9300,,        sts $0401,r16
000014,9000,,        lds r0,$0400
000018,9000,,        lds r0,$0401
00001C,EE00,,       ldi r16,$E0                     ; Enable Sleep and SRAM - 1 ws
00001E,BF05,,       out MCUCR,r16
000020,EA0A,,        ldi r16,$AA
000022,9300,,        sts $0400,r16
000026,9300,,        sts $0401,r16
00002A,9000,,        lds r0,$0400
00002E,9000,,        lds r0,$0401
000032,9588,,       sleep
也许这是他的文加格式,是不是有这中格式的文件就可以打开source code了?另外,有.BAS的文件也可以打开,但这些文件是怎么生成的呢?
发表于 2006-3-3 23:39:26 | 显示全部楼层
51用汇编的话,利用Proteus中Code Generation Tool可以生成SDI格式的文件,有这个文件就可以在Proteus中进行调试了(打开source code)。
   Proteus仿真文件(DSN文件)和51的asm文件放到同一个的文件夹里,
   到菜单“Source”->"Add/Remove Source files",会出现一个对话框
照图设置好有关内容,ok退出。
执行菜单“Source”->“Build All”之后会有Build log窗口,如果编译成功的话,你就可以调试了。菜单“Debug”->"Start/Restart Debugging"就会出现源代码窗口!!!
上面说Proteus仿真文件(DSN文件)是指你用PROTEUS画的那个原理图啊,其后缀为DSN
-----此内容被archeng504于2006-03-03,23:48:48编辑过
 楼主| 发表于 2006-3-4 09:49:52 | 显示全部楼层
archeng504 阿成
你说的这一步我之前也试过了,问题是我找遍了keil\c51\bin和Proteus 6.7\Tools\ASEM51下的两个目录没有发现ASEM51这个代码产生工具,在Proteus 6.7\Tools\ASEM51倒是有一个ASEM.exe,我用“Source”->"Add/Remove Code Generation Tools"添加,然后回到“Source”->"Add/Remove Source files这一步选择ASEM作为代码产生工具,build all后没有SDI文件呀,后来我重启了proteus还是打开那个例子,选用默认的ASEM51,竟然无法build all,提示如下:
Processing EXTMEM.ASM...
NOT built - requires ASEM51
N.B. 3rd party assemblers such as MPASM, ASEM51, ASM11 and AVRASM can be installed using the Proteus SETUP program.
Build FAILED with 1 error(s).
我真是晕呀,还有,我怎么贴补上图呀,为什么手工添加完ASEM后,在Source”->"Add/Remove Source files对话框中就找不到原来的ASEM51了。
 楼主| 发表于 2006-3-4 10:31:15 | 显示全部楼层
这两个图标是怎么画出来的,总画不出来那个圈和总线的那个箭头:)
-----此内容被11uu于2006-03-04,10:37:39编辑过
发表于 2006-3-4 15:55:09 | 显示全部楼层
发表于 2006-3-4 16:05:59 | 显示全部楼层
我这里用ASEM51没问题啊!!!我使用SAMPLES里面的8051 LCD Driver测试过,给你看一下
ASEM51的配置
如还不行,就重装Proteus
-----此内容被archeng504于2006-03-04,16:08:50编辑过
发表于 2006-3-5 19:49:03 | 显示全部楼层
不用管ASEM51,只要照偶像的做就可以了!
Proteus仿真文件(DSN文件)和51的asm文件放到同一个的文件夹里,然后ADD源文件就可以了!我的编译环境都乱了,被我从仿真选项里删除了也照样仿真。
 楼主| 发表于 2006-3-6 10:09:07 | 显示全部楼层
谢谢archeng504 阿成,我知道了,我下载proteus是从另外一个网站下载的面安装版的,直接点击快捷方式就可以用,code generation里面的设置被该了,我从这个下载了一个安装后才发现在code generation已经设置好了。就可以用了。
用c语言怎么产生source code 窗口呀?在Samples\Basic Stamp 1\路径下的好像是用basic编的程序,那个basic stamp是什么意思?另一种单片机吗?BAS文件呀,我把code generation tool改用C51,但没有source code选项。
-----此内容被11uu于2006-03-06,10:24:00编辑过
发表于 2006-4-10 20:19:40 | 显示全部楼层
用Keil C51编的程序能不能进行源码仿真?
GMT+8, 2024-8-25 13:26
