NUC980 LINUX 4.4 系统下串口最大的波特率是多少? 有坛友知道吗 ? 目前我测试只能支持921600 看规格书上是可以支持3M 的 我想问如何在LINUX 系统上使用 2M工3M 这种特殊波特率呢 查看内核中的tty_ioctl.c 文件中 可以看到是可以更高的
* Routine which returns the baud rate of the tty
* Note that the baud_table needs to be kept in sync with the
* include/asm/termbits.h file.
static const speed_t baud_table[] = {
0, 50, 75, 110, 134, 150, 200, 300, 600, 1200, 1800, 2400, 4800,
9600, 19200, 38400, 57600, 115200, 230400, 460800,
#ifdef __sparc__
76800, 153600, 307200, 614400, 921600
#else
500000, 576000, 921600, 1000000, 1152000, 1500000, 2000000,
2500000, 3000000, 3500000, 4000000
#ifndef __sparc__
static const tcflag_t baud_bits[] = {
B0, B50, B75, B110, B134, B150, B200, B300, B600,
B1200, B1800, B2400, B4800, B9600, B19200, B38400,
B57600, B115200, B230400, B460800, B500000, B576000,
B921600, B1000000, B1152000, B1500000, B2000000, B2500000,
B3000000, B3500000, B4000000
#else
B57600, B115200, B230400, B460800, B76800, B153600,
B307200, B614400, B921600
static int n_baud_table = ARRAY_SIZE(baud_table);
* tty_termios_baud_rate
* @termios: termios structure
* Convert termios baud rate data into a speed. This should be called
* with the termios lock held if this termios is a terminal termios
* structure. May change the termios data. Device drivers can call this
* function but should use ->c_[io]speed directly as they are updated.
* Locking: none
