WIN11, VC2008,多年以来读写串口用一个古董类CSerialPort,不过一直也只是跟原生串口或者USB转串口通信,一直都挺正常的。
改了个上位机要跟STM32的虚拟串口通信,发现不能正常工作,只在打开串口后,才能发送一次数据。要想再次发送,就必须关闭再打开串口。
如果换成USB转的串口,这个上位机是可以正常通信的。
用一些串口调试助手打开这个CDC类虚拟串口,是可以多次发送数据的。
所以问题就是读写这些CDC类虚拟串口,是有什么地方不同,自己没了解到导致的。
- #include "stdafx.h"
- #include "SerialPort.h"
- #include <assert.h>
- // Constructor
- CSerialPort::CSerialPort()
- m_hComm = NULL;
- // initialize overlapped structure members to zero
- m_ov.Offset = 0;
- m_ov.OffsetHigh = 0;
- // create events
- m_ov.hEvent = NULL;
- m_hWriteEvent = NULL;
- m_hShutdownEvent = NULL;
- m_szWriteBuffer = NULL;
- m_nWriteSize = 1;
- m_bThreadAlive = FALSE;
- memset(m_RxRingBuffer.buffer, 0, sizeof(m_RxRingBuffer.buffer));
- m_RxRingBuffer.in = 0;
- m_RxRingBuffer.out = 0;
- // Delete dynamic memory
- CSerialPort::~CSerialPort()
- do
- SetEvent(m_hShutdownEvent);
- while(m_bThreadAlive);
- // if the port is still opened: close it
- if(m_hComm != NULL)
- CloseHandle(m_hComm);
- m_hComm = NULL;
- // Close Handles
- if(m_hShutdownEvent != NULL)
- CloseHandle(m_hShutdownEvent);
- if(m_ov.hEvent != NULL)
- CloseHandle(m_ov.hEvent);
- if(m_hWriteEvent != NULL)
- CloseHandle(m_hWriteEvent);
- TRACE("Thread ended\n");
- delete [] m_szWriteBuffer;
- // Initialize the port. This can be port 1 to 4.
- BOOL CSerialPort::InitPort(CWnd* pPortOwner, // the owner (CWnd) of the port (receives message)
- UINT portnr, // portnumber (1..4)
- UINT baud, // baudrate
- char parity, // parity
- UINT databits, // databits
- UINT stopbits, // stopbits
- DWORD dwCommEvents, // EV_RXCHAR, EV_CTS etc
- UINT writebuffersize) // size to the writebuffer
- assert(portnr > 0 && portnr < 255);
- assert(pPortOwner != NULL);
- // if the thread is alive: Kill
- if(m_bThreadAlive)
- do
- // create events
- ResetEvent(m_ov.hEvent);
- else
- m_ov.hEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
- ResetEvent(m_hWriteEvent);
- else
- m_hWriteEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
- ResetEvent(m_hShutdownEvent);
- else
- m_hShutdownEvent = CreateEvent(NULL, TRUE, FALSE, NULL);
- // initialize the event objects
- m_hEventArray[0] = m_hShutdownEvent; // highest priority
- m_hEventArray[1] = m_ov.hEvent;
- m_hEventArray[2] = m_hWriteEvent;
- // initialize critical section
- InitializeCriticalSection(&m_csCommunicationSync);
- // set buffersize for writing and save the owner
- m_pOwner = pPortOwner;
- if(m_szWriteBuffer != NULL)
- m_szWriteBuffer = new char[writebuffersize];
- m_nPortNr = portnr;
- m_nWriteBufferSize = writebuffersize;
- m_dwCommEvents = dwCommEvents;
- BOOL bResult = FALSE;
- char *szPort = new char[50];
- char *szBaud = new char[50];
- // now it critical!
- EnterCriticalSection(&m_csCommunicationSync);
- // if the port is already opened: close it
- m_hComm = NULL;
- // prepare port strings
- sprintf(szPort, "\\\\.\\COM%d", portnr);
- sprintf(szBaud, "baud=%d parity=%c data=%d stop=%d", baud, parity, databits, stopbits);
- // get a handle to the port
- m_hComm = CreateFile(szPort, // communication port string (COMX)
- GENERIC_READ | GENERIC_WRITE, // read/write types
- 0, // comm devices must be opened with exclusive access
- NULL, // no security attributes
- OPEN_EXISTING, // comm devices must use OPEN_EXISTING
- FILE_FLAG_OVERLAPPED, // Async I/O
- 0); // template must be 0 for comm devices
- if(m_hComm == INVALID_HANDLE_VALUE)
- // port not found
- delete [] szPort;
- delete [] szBaud;
- return FALSE;
- // set the timeout values
- m_CommTimeouts.ReadIntervalTimeout = 1000;
- m_CommTimeouts.ReadTotalTimeoutMultiplier = 1000;
- m_CommTimeouts.ReadTotalTimeoutConstant = 1000;
- m_CommTimeouts.WriteTotalTimeoutMultiplier = 1000;
- m_CommTimeouts.WriteTotalTimeoutConstant = 1000;
- // configure
- if(SetCommTimeouts(m_hComm, &m_CommTimeouts))
- if(SetCommMask(m_hComm, dwCommEvents))
- if(GetCommState(m_hComm, &m_dcb))
- m_dcb.EvtChar = 'q';
- m_dcb.fRtsControl = RTS_CONTROL_ENABLE; // set RTS bit high!
- if(BuildCommDCB(szBaud, &m_dcb))
- if(SetCommState(m_hComm, &m_dcb))
- ; // normal operation... continue
- else
- ProcessErrorMessage("SetCommState()");
- else
- ProcessErrorMessage("BuildCommDCB()");
- else
- ProcessErrorMessage("GetCommState()");
- else
- ProcessErrorMessage("SetCommMask()");
- else
- ProcessErrorMessage("SetCommTimeouts()");
- ////设置超大接收缓冲区
- //SetupComm(m_hComm, 200000, 1024);
- delete [] szPort;
- delete [] szBaud;
- // flush the port
- PurgeComm(m_hComm, PURGE_RXCLEAR | PURGE_TXCLEAR | PURGE_RXABORT | PURGE_TXABORT);
- // release critical section
- LeaveCriticalSection(&m_csCommunicationSync);
- TRACE("Initialisation for communicationport %d completed.\nUse Startmonitor to communicate.\n", portnr);
- return TRUE;
- // The CommThread Function.
- UINT CSerialPort::CommThread(LPVOID pParam)
- // Cast the void pointer passed to the thread back to
- // a pointer of CSerialPort class
- CSerialPort *port = (CSerialPort*)pParam;
- // Set the status variable in the dialog class to
- // TRUE to indicate the thread is running.
- port->m_bThreadAlive = TRUE;
- // Misc. variables
- DWORD BytesTransfered = 0;
- DWORD Event = 0;
- DWORD CommEvent = 0;
- DWORD dwError = 0;
- COMSTAT comstat;
- BOOL bResult = TRUE;
- // Clear comm buffers at startup
- if(port->m_hComm) // check if the port is opened
- PurgeComm(port->m_hComm, PURGE_RXCLEAR | PURGE_TXCLEAR | PURGE_RXABORT | PURGE_TXABORT);
- // Initialize comstat
- ClearCommError(port->m_hComm, &dwError, &comstat);
- // begin forever loop. This loop will run as long as the thread is alive.
- for(;;)
- // Make a call to WaitCommEvent(). This call will return immediatly
- // because our port was created as an async port (FILE_FLAG_OVERLAPPED
- // and an m_OverlappedStructerlapped structure specified). This call will cause the
- // m_OverlappedStructerlapped element m_OverlappedStruct.hEvent, which is part of the m_hEventArray to
- // be placed in a non-signeled state if there are no bytes available to be read,
- // or to a signeled state if there are bytes available. If this event handle
- // is set to the non-signeled state, it will be set to signeled when a
- // character arrives at the port.
- // we do this for each port!
- bResult = WaitCommEvent(port->m_hComm, &Event, &port->m_ov);
- if(!bResult)
- // If WaitCommEvent() returns FALSE, process the last error to determin
- // the reason..
- switch(dwError = GetLastError())
- case ERROR_IO_PENDING:
- // This is a normal return value if there are no bytes
- // to read at the port.
- // Do nothing and continue
- break;
- case 87:
- // Under Windows NT, this value is returned for some reason.
- // I have not investigated why, but it is also a valid reply
- // Also do nothing and continue.
- break;
- default:
- // All other error codes indicate a serious error has
- // occured. Process this error.
- port->ProcessErrorMessage("WaitCommEvent()");
- break;
- else
- // If WaitCommEvent() returns TRUE, check to be sure there are
- // actually bytes in the buffer to read.
- // If you are reading more than one byte at a time from the buffer
- // (which this program does not do) you will have the situation occur
- // where the first byte to arrive will cause the WaitForMultipleObjects()
- // function to stop waiting. The WaitForMultipleObjects() function
- // resets the event handle in m_OverlappedStruct.hEvent to the non-signelead state
- // as it returns.
- // If in the time between the reset of this event and the call to
- // ReadFile() more bytes arrive, the m_OverlappedStruct.hEvent handle will be set again
- // to the signeled state. When the call to ReadFile() occurs, it will
- // read all of the bytes from the buffer, and the program will
- // loop back around to WaitCommEvent().
- // At this point you will be in the situation where m_OverlappedStruct.hEvent is set,
- // but there are no bytes available to read. If you proceed and call
- // ReadFile(), it will return immediatly due to the async port setup, but
- // GetOverlappedResults() will not return until the next character arrives.
- // It is not desirable for the GetOverlappedResults() function to be in
- // this state. The thread shutdown event (event 0) and the WriteFile()
- // event (Event2) will not work if the thread is blocked by GetOverlappedResults().
- // The solution to this is to check the buffer with a call to ClearCommError().
- // This call will reset the event handle, and if there are no bytes to read
- // we can loop back through WaitCommEvent() again, then proceed.
- // If there are really bytes to read, do nothing and proceed.
- bResult = ClearCommError(port->m_hComm, &dwError, &comstat);
- if(comstat.cbInQue == 0)
- continue;
- } // end if bResult
- // Main wait function. This function will normally block the thread
- // until one of nine events occur that require action.
- Event = WaitForMultipleObjects(3, port->m_hEventArray, FALSE, INFINITE);
- switch(Event)
- case 0:
- // Shutdown event. This is event zero so it will be
- // the higest priority and be serviced first.
- CloseHandle(port->m_hComm);
- port->m_hComm = NULL;
- port->m_bThreadAlive = FALSE;
- // Kill this thread. break is not needed, but makes me feel better.
- AfxEndThread(100);
- break;
- case 1: // read event
- GetCommMask(port->m_hComm, &CommEvent);
- if(CommEvent & EV_RXCHAR)
- // Receive character event from port.
- ReceiveChar(port, comstat);
- if(CommEvent & EV_CTS)
- ::SendMessage(port->m_pOwner->m_hWnd, WM_COMM_CTS_DETECTED, (WPARAM) 0, (LPARAM) port->m_nPortNr);
- if(CommEvent & EV_BREAK)
- ::SendMessage(port->m_pOwner->m_hWnd, WM_COMM_BREAK_DETECTED, (WPARAM) 0, (LPARAM) port->m_nPortNr);
- if(CommEvent & EV_ERR)
- ::SendMessage(port->m_pOwner->m_hWnd, WM_COMM_ERR_DETECTED, (WPARAM) 0, (LPARAM) port->m_nPortNr);
- if(CommEvent & EV_RING)
- ::SendMessage(port->m_pOwner->m_hWnd, WM_COMM_RING_DETECTED, (WPARAM) 0, (LPARAM) port->m_nPortNr);
- if(CommEvent & EV_RXFLAG)
- ::SendMessage(port->m_pOwner->m_hWnd, WM_COMM_RXFLAG_DETECTED, (WPARAM) 0, (LPARAM) port->m_nPortNr);
- break;
- case 2: // write event
- // Write character event from port
- WriteChar(port);
- break;
- } // end switch
- } // close forever loop
- return 0;
- // start comm watching
- BOOL CSerialPort::StartMonitoring()
- if(!(m_Thread = AfxBeginThread(CommThread, this)))
- return FALSE;
- TRACE("Thread started\n");
- return TRUE;
- // Restart the comm thread
- BOOL CSerialPort::RestartMonitoring()
- TRACE("Thread resumed\n");
- m_Thread->ResumeThread();
- return TRUE;
- // Suspend the comm thread
- BOOL CSerialPort::StopMonitoring()
- TRACE("Thread suspended\n");
- m_Thread->SuspendThread();
- return TRUE;
- // If there is a error, give the right message
- void CSerialPort::ProcessErrorMessage(char* ErrorText)
- char *Temp = new char[200];
- LPVOID lpMsgBuf;
- FormatMessage(
- FORMAT_MESSAGE_ALLOCATE_BUFFER | FORMAT_MESSAGE_FROM_SYSTEM,
- NULL,
- GetLastError(),
- MAKELANGID(LANG_NEUTRAL, SUBLANG_DEFAULT), // Default language
- (LPTSTR) &lpMsgBuf,
- 0,
- NULL
- sprintf(Temp, "WARNING: %s Failed with the following error: \n%s\nPort: %d\n", (char*)ErrorText, lpMsgBuf, m_nPortNr);
- MessageBox(NULL, Temp, "Application Error", MB_ICONSTOP);
- LocalFree(lpMsgBuf);
- delete [] Temp;
- // Write a character.
- void CSerialPort::WriteChar(CSerialPort* port)
- BOOL bWrite = TRUE;
- DWORD BytesSent = 0;
- ResetEvent(port->m_hWriteEvent);
- // Gain ownership of the critical section
- EnterCriticalSection(&port->m_csCommunicationSync);
- if(bWrite)
- // Initailize variables
- port->m_ov.Offset = 0;
- port->m_ov.OffsetHigh = 0;
- // Clear buffer
- bResult = WriteFile(port->m_hComm, // Handle to COMM Port
- port->m_szWriteBuffer, // Pointer to message buffer in calling finction
- // strlen((char*)port->m_szWriteBuffer), // Length of message to send
- port->m_nWriteSize, // Length of message to send
- &BytesSent, // Where to store the number of bytes sent
- &port->m_ov); // Overlapped structure
- // deal with any error codes
- if(!bResult)
- DWORD dwError = GetLastError();
- switch(dwError)
- // continue to GetOverlappedResults()
- BytesSent = 0;
- bWrite = FALSE;
- break;
- default:
- // all other error codes
- port->ProcessErrorMessage("WriteFile()");
- else
- LeaveCriticalSection(&port->m_csCommunicationSync);
- } // end if(bWrite)
- if(!bWrite)
- bWrite = TRUE;
- bResult = GetOverlappedResult(port->m_hComm, // Handle to COMM port
- &port->m_ov, // Overlapped structure
- &BytesSent, // Stores number of bytes sent
- TRUE); // Wait flag
- // deal with the error code
- // if (!bResult)
- // port->ProcessErrorMessage("GetOverlappedResults() in WriteFile()");
- } // end if (!bWrite)
- //Verify that the data size send equals what we tried to send
- if(BytesSent != port->m_nWriteSize) // Length of message to send)
- TRACE("WARNING: WriteFile() error.. Bytes Sent: %d; Message Length: %d\n", BytesSent, strlen((char*)port->m_szWriteBuffer));
- // ::SendMessage((port->m_pOwner)->m_hWnd, WM_COMM_TXEMPTY_DETECTED, (WPARAM) RXBuff, (LPARAM) port->m_nPortNr);
- // ::SendMessage((port->m_pOwner)->m_hWnd, WM_COMM_TXEMPTY_DETECTED,0,(LPARAM) port->m_nPortNr);
- // Character received. Inform the owner
- void CSerialPort::ReceiveChar(CSerialPort * port, COMSTAT comstat)
- BOOL bRead = TRUE;
- DWORD BytesRead = 0;
- const int bufferSize = 1024; // 定义缓冲区大小
- unsigned char RXBuff[bufferSize]; // 定义缓冲区
- for(;;)
- break;
- if(bRead)
- bResult = ReadFile(port->m_hComm, // Handle to COMM port
- RXBuff, // RX Buffer Pointer
- bufferSize, // Read bufferSize bytes
- &BytesRead, // Stores number of bytes read
- &port->m_ov); // pointer to the m_ov structure
- if(!bResult)
- bRead = FALSE;
- break;
- default:
- port->ProcessErrorMessage("ReadFile()");
- break;
- else
- bRead = TRUE;
- if(!bRead)
- bRead = TRUE;
- if(!bResult)
- port->ProcessErrorMessage("GetOverlappedResults() in ReadFile()");
- for(DWORD i = 0; i < BytesRead; ++i)
- port->m_RxRingBuffer.buffer[port->m_RxRingBuffer.in++] = RXBuff[i];
- if(port->m_RxRingBuffer.in >= MAX_RING_LEN)
- port->m_RxRingBuffer.in = 0;
- } // end forever loop
- ::PostMessage((port->m_pOwner)->m_hWnd, WM_COMM_RXCHAR, 1, (LPARAM) port->m_nPortNr);
- // Write a string to the port
- void CSerialPort::WriteToPort(char * string)
- assert(m_hComm != 0);
- memset(m_szWriteBuffer, 0, sizeof(m_szWriteBuffer));
- strcpy(m_szWriteBuffer, string);
- m_nWriteSize = strlen(string);
- // set event for write
- SetEvent(m_hWriteEvent);
- void CSerialPort::WriteToPort(char * string, int n)
- // memset(m_szWriteBuffer, 0, n);
- // strncpy(m_szWriteBuffer, string, n);
- memcpy(m_szWriteBuffer, string, n);
- m_nWriteSize = n;
- void CSerialPort::WriteToPort(LPCTSTR string)
- void CSerialPort::WriteToPort(LPCTSTR string, int n)
- m_nWriteSize = n;
- // Return the device control block
- DCB CSerialPort::GetDCB()
- return m_dcb;
- // Return the communication event masks
- DWORD CSerialPort::GetCommEvents()
- return m_dwCommEvents;
- // Return the output buffer size
- DWORD CSerialPort::GetWriteBufferSize()
- return m_nWriteBufferSize;
- void CSerialPort::ClosePort()
- void CSerialPort::ProcessData(void)
- do
- } while (m_bThreadAlive);
- if (m_hComm != NULL)
- m_hComm = NULL;
- // Close Handles
- if(m_hShutdownEvent!=NULL)
- CloseHandle( m_hShutdownEvent);
- if(m_ov.hEvent!=NULL)
- CloseHandle( m_ov.hEvent );
- if(m_hWriteEvent!=NULL)
- CloseHandle( m_hWriteEvent );
复制代码 |
