回复: 8
v4l2虚拟驱动,有朋友写过吗?
发表于 2024-2-19 17:23:54 | 显示全部楼层 |阅读模式
始YUV420  NV12格式的:
gst-launch-1.0 v4l2src device=/dev/my_device   io-mode=4 ! video/x-raw, format=NV12, width=3840, height=2160, framerate=60/1 ! omxh265enc qp-mode=auto gop-mode=basic gop-length=60 b-frames=0 target-bitrate=60000 num-slices=8 control-rate=constant prefetch-buffer=true low-bandwidth=false filler-data=true cpb-size=1000 initial-delay=500 ! queue ! mpegtsmux alignment=7 name=mux ! filesink location="/media/usb/test.ts"
最近做测试,想写一个虚拟的v4l2驱动节点,只支持一种原始格式就行,NV12 ,在ZYNQ平台上,第一次写,写了好几版都不对,有朋友写过吗?可以指导下?
 楼主| 发表于 2024-2-19 17:24:14 | 显示全部楼层
[  199.337371] VIDIOC_TRY_FMT .  need  suport this  cmd.  done.
[  199.343285] start my_ioctl    .
[  199.352327] VIDIOC_TRY_FMT .  need  suport this  cmd.  start.
[  199.352328] VIDIOC_TRY_FMT .  need  suport this  cmd.  done.
[  199.358926] start my_ioctl    .
[  199.367971] VIDIOC_S_FMT driver  start .
[  199.371887] VIDIOC_S_FMT driver done .
[  199.375670] start my_ioctl    .
[  199.378900] VIDIOC_S_FMT driver  start .
[  199.382815] VIDIOC_S_FMT driver done .
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Device '/de[  199.388572] my_release .
v/my_device' does not support interleaved interlacing
Additional debug info:
../../../git/sys/v4l2/gstv4l2object.c(3908): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Device wants interleaved interlacing
Execution ended after 0:00:00.114908122
Setting pipeline to PAUSED ...
出0入1119汤圆
发表于 2024-2-19 17:33:24 | 显示全部楼层
v4l2loopback
 楼主| 发表于 2024-2-19 17:40:21 | 显示全部楼层
多谢,大佬,我去研读下!
 楼主| 发表于 2024-2-19 18:15:08 | 显示全部楼层
大佬,还有简单点的吗?第一次写,看这个有点复杂
发表于 2024-2-19 19:19:32 | 显示全部楼层
gstreamer自带的videotestsrc插件不可以吗
 楼主| 发表于 2024-2-19 22:00:13 | 显示全部楼层
(引用自6楼)
不行呢,写这个驱动是最后要和FPGA对接的,,,用测试插件就没有意义了
出0入1119汤圆
发表于 2024-2-19 23:55:50 | 显示全部楼层
(引用自5楼)
这个还不够简单吗,只需配置都不用开发
modprobe v4l2loopback后 ffmpeg就能直接推给这个虚拟v4l2
 楼主| 发表于 2024-2-20 18:35:41 | 显示全部楼层
Himem 发表于 2024-2-19 23:55
这个还不够简单吗,只需配置都不用开发
modprobe v4l2loopback后 ffmpeg就能直接推给这个虚拟v4l2 ...
(引用自8楼)
可以帮瞅一眼代码吗?我写一个就假数据驱动,就实现必须的命令VIDIOC_REQBUFS VIDIOC_QUERYBUF等,,,NV12格式的,,用v4l2-ctl --device /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=NV12 --stream-mmap --stream-to=./output_1920.yuv --stream-count=1  走到 VIDIOC_QUERYBUF 就不执行了
GMT+8, 2024-8-25 07:24
