如题:当接收的时候,串口会连续多次发送已经固定好的数据。
#define _GNU_SOURCE //在源文件开头定义_GNU_SOURCE宏
#include <stdio.h>
#include <stdlib.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <errno.h>
#include <string.h>
#include <signal.h>
#include <termios.h>
typedef struct uart_hardware_cfg {
unsigned int baudrate; /* 波特率 */
unsigned char dbit; /* 数据位 */
char parity; /* 奇偶校验 */
unsigned char sbit; /* 停止位 */
} uart_cfg_t;
static struct termios old_cfg; //用于保存终端的配置参数
static int fd; //串口终端对应的文件描述符
** 串口初始化操作
** 参数device表示串口终端的设备节点
static int uart_init(const char *device)
/* 打开串口终端 */
fd = open(device, O_RDWR | O_NOCTTY);
if (0 > fd) {
fprintf(stderr, "open error: %s: %s\n", device, strerror(errno));
return -1;
/* 获取串口当前的配置参数 */
if (0 > tcgetattr(fd, &old_cfg)) {
fprintf(stderr, "tcgetattr error: %s\n", strerror(errno));
close(fd);
return -1;
return 0;
** 串口配置
** 参数cfg指向一个uart_cfg_t结构体对象
static int uart_cfg(const uart_cfg_t *cfg)
struct termios new_cfg = {0}; //将new_cfg对象清零
speed_t speed;
/* 设置为原始模式 */
cfmakeraw(&new_cfg);
/* 使能接收 */
new_cfg.c_cflag |= CREAD;
/* 设置波特率 */
switch (cfg->baudrate) {
case 1200: speed = B1200;
case 1800: speed = B1800;
case 2400: speed = B2400;
case 4800: speed = B4800;
case 9600: speed = B9600;
case 19200: speed = B19200;
case 38400: speed = B38400;
case 57600: speed = B57600;
case 115200: speed = B115200;
case 230400: speed = B230400;
case 460800: speed = B460800;
case 500000: speed = B500000;
default: //默认配置为115200
speed = B9600;
printf("default baud rate: 9600\n");
if (0 > cfsetspeed(&new_cfg, speed)) {
fprintf(stderr, "cfsetspeed error: %s\n", strerror(errno));
return -1;
/* 设置数据位大小 */
new_cfg.c_cflag &= ~CSIZE; //将数据位相关的比特位清零
switch (cfg->dbit) {
case 5:
new_cfg.c_cflag |= CS5;
case 6:
new_cfg.c_cflag |= CS6;
case 7:
new_cfg.c_cflag |= CS7;
case 8:
new_cfg.c_cflag |= CS8;
default: //默认数据位大小为8
printf("default data bit size: 8\n");
/* 设置奇偶校验 */
switch (cfg->parity) {
case 'N': //无校验
new_cfg.c_cflag &= ~PARENB;
new_cfg.c_iflag &= ~INPCK;
case 'O': //奇校验
new_cfg.c_cflag |= (PARODD | PARENB);
new_cfg.c_iflag |= INPCK;
case 'E': //偶校验
new_cfg.c_cflag |= PARENB;
new_cfg.c_cflag &= ~PARODD; /* 清除PARODD标志,配置为偶校验 */
default: //默认配置为无校验
printf("default parity: N\n");
/* 设置停止位 */
switch (cfg->sbit) {
case 1: //1个停止位
new_cfg.c_cflag &= ~CSTOPB;
case 2: //2个停止位
new_cfg.c_cflag |= CSTOPB;
default: //默认配置为1个停止位
printf("default stop bit size: 1\n");
/* 将MIN和TIME设置为0 */
new_cfg.c_cc[VTIME] = 0;
new_cfg.c_cc[VMIN] = 0;
/* 清空缓冲区 */
if (0 > tcflush(fd, TCIOFLUSH)) {
fprintf(stderr, "tcflush error: %s\n", strerror(errno));
return -1;
/* 写入配置、使配置生效 */
if (0 > tcsetattr(fd, TCSANOW, &new_cfg)) {
fprintf(stderr, "tcsetattr error: %s\n", strerror(errno));
return -1;
/* 配置OK 退出 */
return 0;
--dev=/dev/ttymxc2
--brate=115200
--dbit=8
--parity=N
--sbit=1
--type=read
** 打印帮助信息
static void show_help(const char *app)
printf("Usage: %s [选项]\n"
"\n必选选项:\n"
" --dev=DEVICE 指定串口终端设备名称, 譬如--dev=/dev/ttymxc2\n"
" --type=TYPE 指定操作类型, 读串口还是写串口, 譬如--type=read(read表示读、write表示写、其它值无效)\n"
"\n可选选项:\n"
" --brate=SPEED 指定串口波特率, 譬如--brate=115200\n"
" --dbit=SIZE 指定串口数据位个数, 譬如--dbit=8(可取值为: 5/6/7/8)\n"
" --parity=PARITY 指定串口奇偶校验方式, 譬如--parity=N(N表示无校验、O表示奇校验、E表示偶校验)\n"
" --sbit=SIZE 指定串口停止位个数, 譬如--sbit=1(可取值为: 1/2)\n"
" --help 查看本程序使用帮助信息\n\n", app);
** 信号处理函数,当串口有数据可读时,会跳转到该函数执行
static void io_handler(int sig, siginfo_t *info, void *context)
unsigned char buf[50] = {0};
int ret;
int n;
if(SIGRTMIN != sig)
return;
/* 判断串口是否有数据可读 */
if (POLL_IN == info->si_code) {
ret = read(fd, buf, 20); //一次最多读8个字节数据
printf("[ ");
for (n = 0; n < ret; n++)
printf("0x%hhx ", buf[n]);
printf("]\n");
** 异步I/O初始化函数
static void async_io_init(void)
struct sigaction sigatn;
int flag;
/* 使能异步I/O */
flag = fcntl(fd, F_GETFL); //使能串口的异步I/O功能
flag |= O_ASYNC;
fcntl(fd, F_SETFL, flag);
/* 设置异步I/O的所有者 */
fcntl(fd, F_SETOWN, getpid());
/* 指定实时信号SIGRTMIN作为异步I/O通知信号 */
fcntl(fd, F_SETSIG, SIGRTMIN);
/* 为实时信号SIGRTMIN注册信号处理函数 */
sigatn.sa_sigaction = io_handler; //当串口有数据可读时,会跳转到io_handler函数
sigatn.sa_flags = SA_SIGINFO;
sigemptyset(&sigatn.sa_mask);
sigaction(SIGRTMIN, &sigatn, NULL);
int main(int argc, char *argv[])
uart_cfg_t cfg = {0};
char *device = NULL;
int rw_flag = -1;
unsigned char w_buf[10] = {0x00, 0x04, 0x00, 0x01,
0x00, 0x05, 0x60, 0x18}; //通过串口发送出去的数据 00 04 00 01 00 05 60 18
int n;
/* 串口初始化 */
//if (uart_init("/dev/ttyUSB0"))
if (uart_init("/dev/ttyS1"))
exit(EXIT_FAILURE);
/* 串口配置 */
if (uart_cfg(&cfg)) {
tcsetattr(fd, TCSANOW, &old_cfg); //恢复到之前的配置
close(fd);
exit(EXIT_FAILURE);
for ( ; ; )
w_buf[0] = 0x00;
w_buf[1] = 0x04;
w_buf[2] = 0x00;
w_buf[3] = 0x01;
w_buf[4] = 0x00;
w_buf[5] = 0x05;
w_buf[6] = 0x60;
w_buf[7] = 0x18;
write(fd, w_buf, 8); //一次向串口写入8个字节+
sleep(1); //进入休眠、等待有数据可读,有数据可读之后就会跳转到io_handler()函数
async_io_init(); //我们使用异步I/O方式读取串口的数据,调用该函数去初始化串口的异步I/O
/* 退出 */
close(fd);
exit(EXIT_SUCCESS);
