最近参考国科微的SDK设计了一个小板子,用的芯片是GK7205RBCFV300;
连接好串口助手,给系统上电后,会打印启动信息,打印完启动信息后,串口就没反应了,重新给系统上电,串口也不打印启动信息了,
这种情况下,拆下SPI FLASH,重新烧写U-BOOT,再重新将SPI FLASH芯片焊接回去,系统上电,又打印日志了,不知道这是怎么回事;
附上我的日志:
- System startup
- Uncompress Ok!
- U-Boot 2016.11 (May 25 2022 - 09:24:30 +0800)gk7205v300
- Relocation Offset is: 07734000
- Relocating to 47f34000, new gd at 47ef3ef0, sp at 47ef3ed0
- SPI Nor: Check Flash Memory Controller v100 ... Found
- SPI Nor ID Table Version 1.0
- SPI Nor(cs 0) ID: 0xa1 0x40 0x18
- Block:64KB Chip:16MB Name:"FM25Q128A-SOB-T-G"
- SPI Nor total size: 16MB
- NAND: 0 MiB
- MMC:
- In: serial
- Out: serial
- Err: serial
- Net: eth0
- Hit any key to stop autoboot: 0
- device 0 offset 0x80000, size 0x280000
- SF: 2621440 bytes @ 0x80000 Read: OK
- ## Booting kernel from Legacy Image at 41000000 ...
- Image Name: Linux-4.9.37
- Image Type: ARM Linux Kernel Image (uncompressed)
- Data Size: 2578789 Bytes = 2.5 MiB
- Load Address: 40008000
- Entry Point: 40008000
- Loading Kernel Image ... OK
- Starting kernel ...
- Booting Linux on physical CPU 0x0
- Linux version 4.9.37 (root@qddytt) (gcc version 6.3.0 (GCC) ) #6 Tue Jun 14 21:14:18 CST 2022
- CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
- CPU: div instructions available: patching division code
- CPU: PIP▒ / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- OF: fdt:Machine model: Goke GK7205V300 DEMO Board
- Memory policy: Data cache writeback
- CPU: All CPU(s) started in SVC mode.
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
- Kernel command line: mem=64M console=ttyAMA0,115200 root=/dev/mtdblock2 rw rootfstype=jffs2 mtdparts=sfc:512K(Uboot),2560K(kernel),13M(rootfs)
- PID hash table entries: 256 (order: -2, 1024 bytes)
- Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
- Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
- Memory: 57944K/65536K available (5019K kernel code, 182K rwdata, 1256K rodata, 176K init, 248K bss, 7592K reserved, 0K cma-reserved)
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
- lowmem : 0xc0000000 - 0xc4000000 ( 64 MB)
- modules : 0xbf000000 - 0xc0000000 ( 16 MB)
- .text : 0xc0008000 - 0xc04ef1f0 (5021 kB)
- .init : 0xc062c000 - 0xc0658000 ( 176 kB)
- .data : 0xc0658000 - 0xc06858a0 ( 183 kB)
- .bss : 0xc0687000 - 0xc06c5388 ( 249 kB)
- SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
- NR_IRQS:16 nr_irqs:16 16
- Gic dist init...
- arm_arch_timer: Architected cp15 timer(s) running at 50.00MHz (phys).
- clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb8812736b, max_idle_ns: 440795202655 ns
- sched_clock: 56 bits at 50MHz, resolution 20ns, wraps every 4398046511100ns
- Switching to timer-based delay loop, resolution 20ns
- clocksource: arm,sp804: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
- Console: colour dummy device 80x30
- Calibrating delay loop (skipped), value calculated using timer frequency.. 100.00 BogoMIPS (lpj=500000)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- CPU: Testing write buffer coherency: ok
- Setting up static identity map for 0x40008200 - 0x40008258
- devtmpfs: initialized
- VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- futex hash table entries: 256 (order: -1, 3072 bytes)
- pinctrl core: initialized pinctrl subsystem
- NET: Registered protocol family 16
- DMA: preallocated 256 KiB pool for atomic coherent allocations
- Serial: AMBA PL011 UART driver
- 12040000.uart: ttyAMA0 at MMIO 0x12040000 (irq = 20, base_baud = 0) is a PL011 rev2
- console [ttyAMA0] enabled
- SCSI subsystem initialized
- ssp-pl022 12070000.spi: ARM PL022 driver, device ID: 0x00041022
- ssp-pl022 12070000.spi: mapped registers from 0x12070000 to c486b000
- ssp-pl022 12071000.spi: ARM PL022 driver, device ID: 0x00041022
- ssp-pl022 12071000.spi: mapped registers from 0x12071000 to c486d000
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- Linux video capture interface: v2.00
- clocksource: Switched to clocksource arch_sys_counter
- NET: Registered protocol family 2
- TCP established hash table entries: 1024 (order: 0, 4096 bytes)
- TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
- TCP: Hash tables configured (established 1024 bind 1024)
- UDP hash table entries: 256 (order: 0, 4096 bytes)
- UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- workingset: timestamp_bits=30 max_order=14 bucket_order=0
- NFS: Registering the id_resolver key type
- Key type id_resolver registered
- Key type id_legacy registered
- jffs2: version 2.2 (NAND) (ZLIB) (RTIME) (c) 2001-2006 Red Hat, Inc.
- Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
- io scheduler noop registered
- io scheduler deadline registered (default)
- io scheduler cfq registered
- pl061_gpio 120b0000.gpio_chip: PL061 GPIO chip @0x120b0000 registered
- pl061_gpio 120b1000.gpio_chip: PL061 GPIO chip @0x120b1000 registered
- pl061_gpio 120b2000.gpio_chip: PL061 GPIO chip @0x120b2000 registered
- pl061_gpio 120b3000.gpio_chip: PL061 GPIO chip @0x120b3000 registered
- pl061_gpio 120b4000.gpio_chip: PL061 GPIO chip @0x120b4000 registered
- pl061_gpio 120b5000.gpio_chip: PL061 GPIO chip @0x120b5000 registered
- pl061_gpio 120b6000.gpio_chip: PL061 GPIO chip @0x120b6000 registered
- pl061_gpio 120b7000.gpio_chip: PL061 GPIO chip @0x120b7000 registered
- pl061_gpio 120b8000.gpio_chip: PL061 GPIO chip @0x120b8000 registered
- pl061_gpio 120b9000.gpio_chip: PL061 GPIO chip @0x120b9000 registered
- brd: module loaded
- bsp-sfc bsp_spi_nor.0: SPI Nor ID Table Version 1.2
- bsp-sfc bsp_spi_nor.0: The ID: 0xa1 isn't in the BP table, Current device can't not protect
- bsp-sfc bsp_spi_nor.0: FM25Q128-SOB-T-G (Chipsize 16 Mbytes, Blocksize 64KiB)
- 3 cmdlinepart partitions found on MTD device sfc
- Creating 3 MTD partitions on "sfc":
- 0x000000000000-0x000000080000 : "Uboot"
- 0x000000080000-0x000000300000 : "kernel"
- 0x000000300000-0x000001000000 : "rootfs"
- SPI Nand ID Table Version 2.7
- Cannot found a valid SPI Nand Device
- bsp_spi_nand_probe(157): Error: driver probe, result: -19
- FEPHY:addr=1, la_am=0x9, ldo_am=0x4, r_tuning=0x26
- libphy: femac_mii_bus: probed
- libphy: Fixed MDIO Bus: probed
- femac 10040000.ethernet: using random MAC address d2:c3:74:4b:93:c2
- Generic PHY 10041100.mdio:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=10041100.mdio:01, irq=-1)
- phy_id=0x20669906, phy_mode=mii
- xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
- xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
- xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe6c hci version 0x110 quirks 0x20010010
- xhci-hcd xhci-hcd.0.auto: irq 132, io mem 0x10030000
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
- usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
- hub 2-0:1.0: USB hub found
- hub 2-0:1.0: hub can't support USB3.0
- usbcore: registered new interface driver usb-storage
- mousedev: PS/2 mouse device common for all mice
- i2c /dev entries driver
- goke-i2c 12060000.i2c: goke-i2c0@100000hz registered
- goke-i2c 12061000.i2c: goke-i2c1@100000hz registered
- goke-i2c 12062000.i2c: goke-i2c2@100000hz registered
- uvcvideo: Unable to create debugfs directory
- usbcore: registered new interface driver uvcvideo
- USB Video Class driver (1.1.1)
- sdhci: Secure Digital Host Controller Interface driver
- sdhci: Copyright(c) Pierre Ossman
- sdhci-pltfm: SDHCI platform and OF driver helper
- mmc0: SDHCI controller on 10010000.sdhci [10010000.sdhci] using ADMA in legacy mode
- mmc1: SDHCI controller on 10020000.sdhci [10020000.sdhci] using ADMA in legacy mode
- usbcore: registered new interface driver usbhid
- usbhid: USB HID core driver
- Initializing XFRM netlink socket
- NET: Registered protocol family 17
- NET: Registered protocol family 15
- Key type dns_resolver registered
- usb 1-1: new high-speed USB device number 2 using xhci-hcd
- VFS: Mounted root (jffs2 filesystem) on device 31:2.
- devtmpfs: mounted
- Freeing unused kernel memory: 176K (c062c000 - c0658000)
- This architecture does not have kernel memory protection.
- random: init: uninitialized urandom read (4 bytes read)
- [RCS]: /etc/init.d/S00devs
- mknod: /dev/console: File exists
- mknod: /dev/ttyAMA0: File exists
- mknod: /dev/null: File exists
- [RCS]: /etc/init.d/S01udev
- udevd[617]: starting eudev-3.2.7
- [RCS]: /etc/init.d/S80network
- Sun Oct 10 12:00:00 UTC 2021
- sh: 64M: bad number
- mmz_start: 0x44000000, mmz_size: 64M
- sysconfig: loading out-of-tree module taints kernel.
- ==== online_flag=0, cmos_yuv_flag=0, sensor=imx335, chip=gk7205v300, board=demo====
- ==== g_quick_start_flag=0 ====
- sysconfig init success!
- Module media: init ok
- Media Memory Zone Manager
- osal 1.0 init success!
- gk7205v200_base: module license 'Proprietary' taints kernel.
- Disabling lock debugging due to kernel taint
- load sys.ko OK!
- load tde.ko...OK!
- load region.ko OK!
- load vgs.ko OK!
- load vi.ko OK !
- ISP Mod init!
- load vpss.ko OK!
- load vo.ko OK!
- load gfbg.ko OK!
- load chnl.ko OK!
- load vedu.ko OK!
- load rc.ko OK!
- load venc.ko OK!
- load h264e.ko OK!
- load h265e.ko OK!
- load jpege.ko OK!
- load ive.ko OK!
- Load sensor_spi.ko OK !
- load piris.ko OK!!
- insert audio
- load mipi_rx driver successful!
- ircut change1
- RTW: module init start
- RTW: rtl8188fu v5.3.0.1_28034.20180525
- RTW: build time: Mar 4 2022 17:25:06
- random: fast init done
- RTW: hal_com_config_channel_plan chplan:0x23
- RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
- wlan0 mac_addr=2c:c3:e6:93:5d:1a
- ------------[ cut here ]------------
- WARNING: CPU: 0 PID: 1005 at fs/proc/generic.c:578 remove_proc_entry+0x13c/0x168
- remove_proc_entry: removing non-empty directory 'net/rtl8188fu', leaking at least 'wlan0'
- Modules linked in: 8188fu(O+) mipi_rx(O) gk7205v200_acodec(PO) gk7205v200_adec(PO) gk7205v200_aenc(PO) gk7205v200_ao(PO) gk7205v200_ai(PO) gk7205v200_aio(PO) isp_piris(O) isp_sensor_spi(O) isp_sensor_i2c(O) isp_pwm(O) gk7205v200_ive(PO) gk7205v200_jpege(PO) gk7205v200_h265e(PO) gk7205v200_h264e(PO) gk7205v200_venc(PO) gk7205v200_rc(PO) gk7205v200_vedu(PO) gk7205v200_chnl(PO) gfbg(O) gk7205v200_vo(PO) gk7205v200_vpss(PO) gk7205v200_isp(PO) gk7205v200_vi(PO) gk7205v200_vgs(PO) gk7205v200_rgn(PO) gk7205v200_tde(PO) gk7205v200_sys(PO) gk7205v200_base(PO) osal(O) sysconfig(O)
- CPU: 0 PID: 1005 Comm: insmod Tainted: P O 4.9.37 #6
- Hardware name: Generic DT based system
- Backtrace:
- [<c0012f6c>] (dump_backtrace) from [<c0013250>] (show_stack+0x18/0x1c)
- r7:00000009 r6:00000000 r5:c05aa7ec r4:c2d11aa4
- [<c0013238>] (show_stack) from [<c025cc7c>] (dump_stack+0x24/0x28)
- [<c025cc58>] (dump_stack) from [<c001caf4>] (__warn+0xe8/0x100)
- [<c001ca0c>] (__warn) from [<c001cb60>] (warn_slowpath_fmt+0x54/0x78)
- r9:c4b9bb64 r8:c4b9c000 r7:c4b99000 r6:c2d132d5 r5:c3823cd5 r4:c2d13280
- [<c001cb10>] (warn_slowpath_fmt) from [<c0112fa8>] (remove_proc_entry+0x13c/0x168)
- r3:c04f5540 r2:c05aa888
- r4:c2d13280
- [<c0112e6c>] (remove_proc_entry) from [<bf427e2c>] (rtw_drv_proc_deinit+0x4c/0x68 [8188fu])
- r6:bf47c774 r5:00000006 r4:bf4b3950
- [<bf427de0>] (rtw_drv_proc_deinit [8188fu]) from [<bf40f340>] (rtw_ndev_init+0xc4/0xe8 [8188fu])
- r7:c4b99000 r6:00000000 r5:c4b9c000 r4:00000000
- [<bf40f27c>] (rtw_ndev_init [8188fu]) from [<c041b960>] (register_netdevice+0x90/0x4b8)
- r5:c0680238 r4:c2e52000
- [<c041b8d0>] (register_netdevice) from [<c041bda4>] (register_netdev+0x1c/0x2c)
- r9:c4b9bb64 r8:c4b9c000 r7:c4b99000 r6:c4b9bbe0 r5:c2e52000 r4:c2e52000
- [<c041bd88>] (register_netdev) from [<bf40f558>] (rtw_os_ndev_register+0x94/0xf8 [8188fu])
- r5:c2e52000 r4:00000001
- [<bf40f4c4>] (rtw_os_ndev_register [8188fu]) from [<bf4101e0>] (rtw_os_ndevs_register+0xa4/0xec [8188fu])
- r9:bf4a25b8 r8:bf48c38d r7:c4b99000 r6:bf4b3530 r5:c381d000 r4:00000000
- [<bf41013c>] (rtw_os_ndevs_register [8188fu]) from [<bf41028c>] (rtw_os_ndevs_init+0x24/0x40 [8188fu])
- r9:c3a5a470 r8:c3972000 r7:c4b99000 r6:bf4b3530 r5:bf4a25b8 r4:c381d000
- [<bf410268>] (rtw_os_ndevs_init [8188fu]) from [<bf41204c>] (rtw_drv_init+0x478/0x568 [8188fu])
- r5:bf4a25b8 r4:c381d000
- [<bf411bd4>] (rtw_drv_init [8188fu]) from [<c0355e74>] (usb_probe_interface+0x164/0x2b0)
- r10:ffffffed r9:00000000 r8:c3a5a400 r7:c3a5a470 r6:c3972020 r5:c3972000
- r4:bf4a280c
- [<c0355d10>] (usb_probe_interface) from [<c02cffd0>] (driver_probe_device+0x20c/0x2b8)
- r10:bf4ae540 r9:c2feb024 r8:0000001f r7:bf4a27bc r6:00000000 r5:c3972020
- r4:c06bdab0
- [<c02cfdc4>] (driver_probe_device) from [<c02d013c>] (__driver_attach+0xc0/0xc4)
- r9:c2feb024 r8:bf4ae540 r7:00000000 r6:c3972054 r5:bf4a27bc r4:c3972020
- [<c02d007c>] (__driver_attach) from [<c02cdf88>] (bus_for_each_dev+0x88/0xd4)
- r7:00000000 r6:c02d007c r5:bf4a27bc r4:00000000
- [<c02cdf00>] (bus_for_each_dev) from [<c02cf808>] (driver_attach+0x24/0x28)
- r6:c0678100 r5:c2d13700 r4:bf4a27bc
- [<c02cf7e4>] (driver_attach) from [<c02cf2e8>] (bus_add_driver+0x110/0x21c)
- [<c02cf1d8>] (bus_add_driver) from [<c02d0944>] (driver_register+0x80/0xfc)
- r7:bf4a27bc r6:bf48cd25 r5:c0678100 r4:bf4a27bc
- [<c02d08c4>] (driver_register) from [<c03548d8>] (usb_register_driver+0x74/0x138)
- r5:c0678100 r4:bf4a278c
- [<c0354864>] (usb_register_driver) from [<bf4df088>] (rtw_drv_entry+0x88/0xe4 [8188fu])
- r9:c2feb024 r8:00000000 r7:00000000 r6:bf4a278c r5:ffffe000 r4:bf4a25b8
- [<bf4df000>] (rtw_drv_entry [8188fu]) from [<c0009720>] (do_one_initcall+0x60/0x1a4)
- r7:c2feb0c0 r6:c2feb000 r5:ffffe000 r4:bf4df000
- [<c00096c0>] (do_one_initcall) from [<c0077c44>] (do_init_module+0x68/0x3ac)
- r8:00000000 r7:c2feb0c0 r6:c2feb000 r5:00000001 r4:bf4ae540
- [<c0077bdc>] (do_init_module) from [<c006a420>] (load_module+0x1ae0/0x1fb8)
- r7:00000001 r6:c2feb000 r5:00000001 r4:c2d11f38
- [<c0068940>] (load_module) from [<c006aa5c>] (SyS_init_module+0x164/0x17c)
- r10:00000000 r9:00000000 r8:00108008 r7:c2d10000 r6:c583ccb0 r5:b6dcbcb8
- r4:0000bcb0
- [<c006a8f8>] (SyS_init_module) from [<c000fc00>] (ret_fast_syscall+0x0/0x34)
- r9:c2d10000 r8:c000fda4 r7:00000080 r6:00107628 r5:be917f7b r4:0016bcb0
- ---[ end trace 08fc24a2b724a75c ]---
复制代码 |
