之前用了STM32F103+W5500可以用调试助手实现回环测试,然后把代码移植到STM32F429的SPI4上不行,用示波器调试发现F4的SPI4时钟线没有信号出来,所以怀疑是配置问题,但是看了很多遍没有结果,望大佬们指点一下:
void gpio_for_w5500_config(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI4,ENABLE);
GPIO_PinAFConfig(GPIOE,GPIO_Pin_12,GPIO_AF_SPI4);
GPIO_PinAFConfig(GPIOE,GPIO_Pin_13,GPIO_AF_SPI4);
GPIO_PinAFConfig(GPIOE,GPIO_Pin_14,GPIO_AF_SPI4);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOE, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//cs
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_SetBits(GPIOE,GPIO_Pin_11);
//这里只针对SPI口初始化
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI4,ENABLE);//复位SPI1
RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI4,DISABLE);//停止复位SPI1
/* SPI4 configuration */
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;//SPI_CPOL_Low SPI_CPOL_High
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;//SPI_CPHA_1Edge SPI_CPHA_2Edge
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI4, &SPI_InitStructure);
SPI_Cmd(SPI4, ENABLE);
/*定义RESET引脚*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_SetBits(GPIOE, GPIO_Pin_10);
/*定义INT引脚*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
int main(void)
Config_SystemClock(25, 360, 2, 4);
systick_init(168);
bsp_init();
gpio_for_w5500_config(); //初始化MCU相关引脚
reset_w5500(); //硬复位W5500
set_w5500_mac(); //配置MAC地址
set_w5500_ip(); //配置IP地址
socket_buf_init(txsize, rxsize); //初始化8个Socket的发送接收缓存大小
while (1)
SPI4_ReadWriteByte(0xff);
delay_ms(200);
