发表于 2023-1-26 11:24:42
我在eevblog论坛上问了,有一个Super Contributor回复我了。
他说
Different historical series by different manufacturers that over time, due to cloning, mergers, spinoffs, etc. show up as similar but not identical parts.
又说
The MMBZ52 series is an old Fairchild line, which is now part of onsemi. Motorola had both the MMBZ52 and BZX84 lines since at least 1994. Either is probably fine in your application. It seems the BZX84 series is more completely defined. You may need to test both in your application to determine the best performance.
我感觉他说的言之凿凿,就决定信他了。加上某商城本来就是BZX84系列销量大,所以我就打算选用BZX84系列了。 |
