回复: 1
Rockwell PackML 3.0-based Programming.pdf
出16390入6832汤圆
发表于 2023-1-7 15:52:47 来自手机 | 显示全部楼层 |阅读模式
(VIP++福利贴:本资源由坛友 microEC   提出申请,由阿莫网上搜集与上传,版权归原作者。)
手册是 Rockwell 关于PackML应用指导,前面介绍了运动控制的设计,接线,编程等必要信息,附录具体介绍了PackML编程应用。 State model programming provides a way to execute processing procedures based on machine conditions, but independent of the direct equipment control logic. This is an essential component to modular programming. The PackML 3.0 state model, a recognized standard in the packaging segment, is implemented in this example using an Add-On Instruction (AOI) that manages from 1…32 modes, each having its associated instance of the state model. The states may be enabled and disabled as required depending on the needs of the mode.
头像被屏蔽
出16390入6832汤圆
 楼主| 发表于 2023-1-7 15:52:54 来自手机 | 显示全部楼层
提示: 该帖被管理员或版主屏蔽
GMT+8, 2024-8-15 22:15
