下面的例子亲测可用。
直接将TIM17配置成38K载波输出,引脚直接驱动IR发射管即可。
只用到了USART4.TX的作为发射,波特率只能2400bps,太高不好,你可以试一下。
* Init USART4 + DMA_CH1 +TIM17
vod IrTxInit(vod)
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
LL_TIM_InitTypeDef TIM_InitStruct = {0};
LL_TIM_OC_InitTypeDef TIM_OC_InitStruct = {0};
// LL_TIM_BDTR_InitTypeDef TIM_BDTRInitStruct = {0};
LL_USART_InitTypeDef USART_InitStruct = {0};
// Enable DMA controller clock
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_DMA1);
// Enable Peripheral clock
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_USART4);
// Enable GPIO Peripheral clock
LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOA | LL_IOP_GRP1_PERIPH_GPIOD);
// Init USART Peripheral
USART_InitStruct.PrescalerValue = LL_USART_PRESCALER_DIV1;
USART_InitStruct.BaudRate = 2400;
USART_InitStruct.DataWidth = LL_USART_DATAWIDTH_8B;
USART_InitStruct.StopBits = LL_USART_STOPBITS_1;
USART_InitStruct.Parity = LL_USART_PARITY_NONE;
USART_InitStruct.TransferDirection = LL_USART_DIRECTION_TX_RX;
USART_InitStruct.HardwareFlowControl = LL_USART_HWCONTROL_NONE;
USART_InitStruct.OverSampling = LL_USART_OVERSAMPLING_16;
LL_USART_Init(USART4, &USART_InitStruct);
LL_USART_SetTXFIFOThreshold(USART4, LL_USART_FIFOTHRESHOLD_1_8);
LL_USART_SetRXFIFOThreshold(USART4, LL_USART_FIFOTHRESHOLD_1_8);
LL_USART_DisableFIFO(USART4);
// LL_USART_ConfigAsyncMode(USART4);
LL_USART_Enable(USART4);
LL_USART_ConfigIrdaMode(USART4);
LL_USART_EnableIrda(USART4);
// Init DMA CH1 for USART4.TX
LL_DMA_SetPeriphRequest(DMA1, LL_DMA_CHANNEL_3, LL_DMAMUX_REQ_USART4_TX);
LL_DMA_SetDataTransferDirection(DMA1, LL_DMA_CHANNEL_3, LL_DMA_DIRECTION_MEMORY_TO_PERIPH);
LL_DMA_SetChannelPriorityLevel(DMA1, LL_DMA_CHANNEL_3, LL_DMA_PRIORITY_HIGH);
LL_DMA_SetMode(DMA1, LL_DMA_CHANNEL_3, LL_DMA_MODE_NORMAL);
LL_DMA_SetPeriphIncMode(DMA1, LL_DMA_CHANNEL_3, LL_DMA_PERIPH_NOINCREMENT);
LL_DMA_SetMemoryIncMode(DMA1, LL_DMA_CHANNEL_3, LL_DMA_MEMORY_INCREMENT);
LL_DMA_SetPeriphSize(DMA1, LL_DMA_CHANNEL_3, LL_DMA_PDATAALIGN_BYTE);
LL_DMA_SetMemorySize(DMA1, LL_DMA_CHANNEL_3, LL_DMA_MDATAALIGN_BYTE);
LL_DMA_ConfigAddresses(DMA1, LL_DMA_CHANNEL_3, (u32)IrTxBuf,
LL_USART_DMA_GetRegAddr(USART4, LL_USART_DMA_REG_DATA_TRANSMIT),
LL_DMA_GetDataTransferDirection(DMA1, LL_DMA_CHANNEL_3));
LL_DMA_SetDataLength(DMA1, LL_DMA_CHANNEL_3, 0);
// Enable DMA transfer complete/error interrupts
// LL_DMA_EnableIT_TC(DMA1, LL_DMA_CHANNEL_3);
// LL_DMA_EnableIT_TE(DMA1, LL_DMA_CHANNEL_3);
// LL_DMA_EnableIT_TC(DMA1, LL_DMA_CHANNEL_4);
// LL_DMA_EnableIT_TE(DMA1, LL_DMA_CHANNEL_4);
// DMA1_Channel1_IRQn interrupt configuration
// NVIC_SetPriority(DMA1_Channel1_IRQn, 0);
// NVIC_EnableIRQ(DMA1_Channel1_IRQn);
// DMA1_Channel2_3_IRQn interrupt configuration
// NVIC_SetPriority(DMA1_Channel2_3_IRQn, 0);
// NVIC_EnableIRQ(DMA1_Channel2_3_IRQn);
// Enable DMA RX Interrupt
// LL_USART_EnableDMAReq_RX(USART2);
// Enable DMA TX Interrupt */
LL_USART_EnableDMAReq_TX(USART4);
// Enable DMA Channel Rx
// LL_DMA_EnableChannel(DMA1, LL_DMA_CHANNEL_4);
// Enable DMA Channel Tx
// LL_DMA_EnableChannel(DMA1, LL_DMA_CHANNEL_3);
// Init Timer17
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM17);
LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOB);
// Init IR_OUT Pin PB9
GPIO_InitStruct.Pin = LL_GPIO_PIN_9;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_HIGH;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
GPIO_InitStruct.Alternate = LL_GPIO_AF_0; // AF2=CH1; AF0=IR_OUT
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
// Init Timer Base
TIM_InitStruct.Prescaler = 0; // 64M
TIM_InitStruct.CounterMode = LL_TIM_COUNTERMODE_UP;
TIM_InitStruct.Autoreload = 1688; //3; // 64M / 38K /2 = 842.10
TIM_InitStruct.ClockDivision = LL_TIM_CLOCKDIVISION_DIV1;
TIM_InitStruct.RepetitionCounter = 0;
LL_TIM_Init(TIM17, &TIM_InitStruct);
LL_TIM_DisableARRPreload(TIM17);
TIM_OC_InitStruct.OCMode = LL_TIM_OCMODE_PWM1;
TIM_OC_InitStruct.OCState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.OCNState = LL_TIM_OCSTATE_DISABLE;
TIM_OC_InitStruct.CompareValue = 1688/2; // 50% Duty
// TIM_OC_InitStruct.OCPolarity = LL_TIM_OCPOLARITY_HIGH;
// TIM_OC_InitStruct.OCNPolarity = LL_TIM_OCPOLARITY_HIGH;
// TIM_OC_InitStruct.OCIdleState = LL_TIM_OCIDLESTATE_LOW;
// TIM_OC_InitStruct.OCNIdleState = LL_TIM_OCIDLESTATE_LOW;
LL_TIM_OC_Init(TIM17, LL_TIM_CHANNEL_CH1, &TIM_OC_InitStruct);
LL_TIM_OC_EnablePreload(TIM17, LL_TIM_CHANNEL_CH1);
LL_TIM_OC_DisableFast(TIM17, LL_TIM_CHANNEL_CH1);
LL_TIM_SetTriggerOutput(TIM17, LL_TIM_TRGO_RESET);
LL_TIM_DisableMasterSlaveMode(TIM17);
TIM_BDTRInitStruct.OSSRState = LL_TIM_OSSR_DISABLE;
TIM_BDTRInitStruct.OSSIState = LL_TIM_OSSI_DISABLE;
TIM_BDTRInitStruct.LockLevel = LL_TIM_LOCKLEVEL_OFF;
TIM_BDTRInitStruct.DeadTime = 0;
TIM_BDTRInitStruct.BreakState = LL_TIM_BREAK_DISABLE;
TIM_BDTRInitStruct.BreakPolarity = LL_TIM_BREAK_POLARITY_HIGH;
TIM_BDTRInitStruct.BreakFilter = LL_TIM_BREAK_FILTER_FDIV1;
TIM_BDTRInitStruct.AutomaticOutput = LL_TIM_AUTOMATICOUTPUT_DISABLE;
LL_TIM_BDTR_Init(TIM17, &TIM_BDTRInitStruct);
LL_TIM_EnableCounter(TIM17);
LL_TIM_EnableAllOutputs(TIM17);
LL_TIM_CC_EnableChannel(TIM17, LL_TIM_CHANNEL_CH1);
// Config IR_TIM
u32 reg;
// Clear IR_MOD & IR_POL
reg = SYSCFG->CFGR1 & (~0x000000E0);
// Set IR_MOD = 10 = USART2
reg |= 0x00000080;
// Set IR_POL = 1
// reg |= 0x00000020;
SYSCFG->CFGR1 = reg;
* @brief: Send A Serial Data by USART with DMA
* @param: dat: [in] Data Address to be send
* @param: length: [in] Data Bytes
* @return: true = success, false = failure
bol IrSend(u8 * dat, u32 length)
u32 i;
MUTEX_LOCK();
// Judge buffer enough
if (length > IR_TX_BUF_SIZE)
MUTEX_UNLOCK();
return false;
IrWaitTxDone();
// Copy Data to DMA TX Buffer
for(i = 0; i < length; i++)
IrTxBuf = dat;
// Set DMA Tx Count
LL_DMA_SetDataLength(DMA1, LL_DMA_CHANNEL_3, length);
// Enable DMA Channel;
MUTEX_UNLOCK();
return true;
