2楼
发表于 2022-12-26 17:41:14
只看该作者
git上找到一个
#include <Arduino.h>
#include <FastLED.h>
#include "Hsv2rgbw16.h"
HSV16 HSV8toHSV16(CHSV inVal) {
HSV16 retVal;
retVal.h = (uint16_t) (inVal.h) << 8;
if (inVal.s == 0xFF)
retVal.s = 0xFFFF;
retVal.s = (uint16_t) (inVal.s) << 8;
if (inVal.v == 0xFF)
retVal.v = 0xFFFF;
retVal.v = (uint16_t) (inVal.v) << 8;
return retVal;
CHSV HSV16toHSV8(HSV16 inVal) {
CHSV retVal;
retVal.h = (uint8_t) (inVal.h >> 8);
retVal.s = (uint8_t) (inVal.s >> 8);
retVal.v = (uint8_t) (inVal.v >> 8);
return retVal;
void HSV16toRGBW16(HSV16 cHSV16, RGBW16 *cRGBW16) {
// Yellow has a higher inherent brightness than
// any other color; 'pure' yellow is perceived to
// be 93% as bright as white. In order to make
// yellow appear the correct relative brightness,
// it has to be rendered brighter than all other
// colors.
// Level Y1 is a moderate boost, the default.
// Level Y2 is a strong boost.
const uint8_t Y1 = 1;
const uint8_t Y2 = 0;
// G2: Whether to divide all greens by two.
// Depends GREATLY on your particular LEDs
const uint8_t G2 = 0;
// Gscale: what to scale green down by.
const uint16_t Gscale = 0;
uint16_t hue = cHSV16.h;
uint16_t sat = cHSV16.s;
uint16_t val = cHSV16.v;
uint16_t offset = hue & (0x1FFF); // 0..31
//Serial.print("Offset = ");
//Serial.print(offset);
// offset8 = offset * 8
uint16_t offset8 = (offset << 3);
//Serial.print(" Offset8 = ");
//Serial.print(offset8);
uint16_t third = scale16( offset8, (65536 / 3)); // max = 85
//Serial.print(" Third = ");
//Serial.print(third);
uint16_t r, g, b, w;
w = 0;
if( ! (hue & 0x8000) ) {
// 0XX
if( ! (hue & 0x4000) ) {
// 00X
//section 0-1
if( ! (hue & 0x2000) ) {
// 000
//case 0: // R -> O
r = (65535) - third;
g = third;
b = 0;
} else {
// 001
//case 1: // O -> Y
if( Y1 ) {
r = (171 << 8);
g = (85 << 8) + third ;
b = 0;
if( Y2 ) {
r = (170 << 8) + third;
uint16_t twothirds = (third << 1);
//old: uint8_t twothirds = scale8( offset8, ((256 * 2) / 3)); // max=170
g = (85 << 8) + twothirds;
b = 0;
} else {
//01X
// section 2-3
// 010
//case 2: // Y -> G
if( Y1 ) {
// old: uint8_t twothirds = scale8( offset8, ((256 * 2) / 3)); // max=170
r = (171 << 8) - twothirds;
g = (170 << 8) + third;
b = 0;
if( Y2 ) {
r = 65535 - offset8;
g = 65535;
b = 0;
} else {
// 011
// case 3: // G -> A
r = 0;
g = 65535 - third;
b = third;
} else {
// section 4-7
// 1XX
// 10X
if( ! ( hue & 0x2000) ) {
// 100
//case 4: // A -> B
r = 0;
g = (171 << 8) - twothirds; //K170?
b = (85 << 8) + twothirds;
} else {
// 101
//case 5: // B -> P
r = third;
g = 0;
b = 65535 - third;
} else {
// 110
//case 6: // P -- K
r = (85 << 8) + third;
g = 0;
b = (171 << 8) - third;
} else {
// 111
//case 7: // K -> R
g = 0;
b = (85 << 8) - third;
// This is one of the good places to scale the green down,
// although the client can scale green down as well.
if( G2 ) g = g >> 1;
// old: if( Gscale ) g = scale8_video_LEAVING_R1_DIRTY( g, Gscale);
if ( Gscale ) g = scale16(g, Gscale); // Note this is not a "video" scale
// Scale down colors if we're desaturated at all
// and add the brightness_floor to r, g, and b.
if( sat != 65535 ) {
if( sat == 0) {
r = 0; b = 0; g = 0; w = 65535;
else {
w = 0;
if( r ) r = scale16( r, sat);
if( g ) g = scale16( g, sat);
if( b ) b = scale16( b, sat);
//Serial.print(" SScaled R = ");
//Serial.print(r);
uint16_t desat = 65535 - sat;
//Serial.print(" Desat = ");
//Serial.print(desat);
desat = scale16( desat, desat);
uint16_t brightness_floor = desat;
//Serial.print(" Floor = ");
//Serial.print(brightness_floor);
r += brightness_floor;
g += brightness_floor;
b += brightness_floor;
//Serial.print(" Floored R = ");
//Serial.print(r);
// Now scale everything down if we're at value < 255.
if( val != 65535 ) {
val = scale16( val, val);
//Serial.print(" Scaled Val = ");
//Serial.print(val);
if( val == 0 ) {
r=0; g=0; b=0; w = 0;
else {
// nscale8x3_video( r, g, b, val);
if( r ) r = scale16( r, val);
if( g ) g = scale16( g, val);
if( b ) b = scale16( b, val);
if( w ) w = scale16( w, val);
//Serial.print(" VScaled R = ");
//Serial.println(r);
(*cRGBW16).r = r;
(*cRGBW16).g = g;
(*cRGBW16).b = b;
(*cRGBW16).w = w;
