- : serial
- Out: serial
- Err: serial
- Found PFUZE100! deviceid=10,revid=21
- Net: got MAC address from IIM: 00:00:00:00:00:00
- FEC0 [PRIME]
- WatchDog is disabled
- Hit Space key to stop autoboot: 0
- kernel @ 10808000 (4768856)
- ramdisk @ 11800000 (500211)
- kernel cmdline:
- use uboot command line:
- console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 ldb=sin0 audio_codec=wm8960-24M fb0base=0x27b00000 fbmem=28M,28M fec_mac=7A:8D:B8:CE:BB:6C androidboot.hardware=freescale
- Starting kernel ...
- Uncompressing Linux... done, booting the kernel.
- [ 0.000000] Initializing cgroup subsys cpu
- [ 0.000000] Linux version 3.0.35 (root@ubuntu) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #121 SMP PREEMPT Tue Nov 8 20:59:46 CST 2022
- [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
- [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
- [ 0.000000] Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
- [ 0.000000] Ignoring unrecognised tag 0x54410008
- [ 0.000000] Memory policy: ECC disabled, Data cache writealloc
- [ 0.000000] CPU identified as i.MX6Q, unknown revision
- [ 0.000000] On node 0 totalpages: 198400
- [ 0.000000] free_area_init_node: node 0, pgdat c0970280, node_mem_map c0b29000
- [ 0.000000] Normal zone: 800 pages used for memmap
- [ 0.000000] Normal zone: 0 pages reserved
- [ 0.000000] Normal zone: 96224 pages, LIFO batch:31
- [ 0.000000] HighMem zone: 1248 pages used for memmap
- [ 0.000000] HighMem zone: 100128 pages, LIFO batch:31
- [ 0.000000] PERCPU: Embedded 7 pages/cpu @c1332000 s6528 r8192 d13952 u32768
- [ 0.000000] pcpu-alloc: s6528 r8192 d13952 u32768 alloc=8*4096
- [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
- [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 196352
- [ 0.000000] Kernel command line: console=ttymxc0,115200 androidboot.console=ttymxc0 vmalloc=400M init=/init video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB24,bpp=32 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 ldb=sin0 audio_codec=wm8960-24M fb0base=0x27b00000 fbmem=28M,28M fec_mac=7A:8D:B8:CE:BB:6C androidboot.hardware=freescale
- [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
- [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
- [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
- [ 0.000000] Memory: 379MB 360MB 36MB = 775MB total
- [ 0.000000] Memory: 772928k/772928k available, 275648k reserved, 405504K highmem
- [ 0.000000] Virtual kernel memory layout:
- [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
- [ 0.000000] DMA : 0xfbe00000 - 0xffe00000 ( 64 MB)
- [ 0.000000] vmalloc : 0xd9800000 - 0xf2000000 ( 392 MB)
- [ 0.000000] lowmem : 0xc0000000 - 0xd9000000 ( 400 MB)
- [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
- [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
- [ 0.000000] .init : 0xc0008000 - 0xc0047000 ( 252 kB)
- [ 0.000000] .text : 0xc0047000 - 0xc08ee4d4 (8862 kB)
- [ 0.000000] .data : 0xc08f0000 - 0xc0985a78 ( 599 kB)
- [ 0.000000] .bss : 0xc0985a9c - 0xc0b283e8 (1675 kB)
- [ 0.000000] Preemptible hierarchical RCU implementation.
- [ 0.000000] NR_IRQS:624
- [ 0.000000] MXC GPIO hardware
- [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
- [ 0.000000] arm_max_freq=1GHz
- [ 0.000000] MXC_Early serial console at MMIO 0x2020000 (options '115200')
- [ 0.000000] bootconsole [ttymxc0] enabled
- [ 0.275818] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
- [ 0.368555] pid_max: default: 32768 minimum: 301
- [ 0.373400] Mount-cache hash table entries: 512
- [ 0.378629] Initializing cgroup subsys debug
- [ 0.382921] Initializing cgroup subsys cpuacct
- [ 0.387419] Initializing cgroup subsys freezer
- [ 0.391942] CPU: Testing write buffer coherency: ok
- [ 0.397106] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
- [ 0.517725] CPU1: Booted secondary processor
- [ 0.617723] CPU2: Booted secondary processor
- [ 0.717717] CPU3: Booted secondary processor
- [ 0.777101] Brought up 4 CPUs
- [ 0.792927] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
- [ 0.822427] print_constraints: dummy:
- [ 0.826427] NET: Registered protocol family 16
- [ 0.835793] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
- [ 0.843318] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
- [ 0.851116] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
- [ 0.858799] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
- [ 0.866546] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
- [ 0.874250] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
- [ 0.883208] mx6_sabresd_board_init...
- [ 0.888272] ram_console: got buffer at 3ff00000, size 100000
- [ 0.894103] ram_console: uncorrectable error in header
- [ 0.899286] ram_console: no valid data in buffer (sig = 0x00424040)
- [ 0.912922] console [ram-1] enabled
- [ 1.074890] register fpga...
- [ 1.077892] plat: add device fpga
- [ 1.081668] register gpio...
- [ 1.084640] plat: add device gpio
- [ 1.088353] register oled...
- [ 1.091389] plat: add device oled
- [ 1.095070] register epcs...
- [ 1.098068] plat: add device epcs
- [ 1.101772] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
- [ 1.108747] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
- [ 1.116231] hw-breakpoint: maximum watchpoint size is 4 bytes.
- [ 1.122209] L310 cache controller enabled
- [ 1.126316] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1048576 B
- [ 1.168934] bio: create slab <bio-0> at 0
- [ 1.176718] mxs-dma mxs-dma-apbh: initialized
- [ 1.181571] print_constraints: vmmc: 3300 mV
- [ 1.186811] vgaarb: loaded
- [ 1.190806] SCSI subsystem initialized
- [ 1.195086] libata version 3.00 loaded.
- [ 1.199855] usbcore: registered new interface driver usbfs
- [ 1.205639] usbcore: registered new interface driver hub
- [ 1.211249] usbcore: registered new device driver usb
- [ 1.216461] Freescale USB OTG Driver loaded, $Revision: 1.55 $
- [ 1.223306] i2c-gpio i2c-gpio.3: using pins 35 (SDA) and 169 (SCL)
- [ 1.232077] mc_pfuze 1-0008: ID: 0,Full lay: 2 ,Metal lay: 1
- [ 1.238371] mc_pfuze 1-0008: FAB: 0 ,FIN: 0
- [ 1.255032] print_constraints: PFUZE100_SW1A: 300 <--> 1875 mV at 1300 mV
- [ 1.262772] print_constraints: PFUZE100_SW1B: 300 <--> 1875 mV at 300 mV
- [ 1.271365] print_constraints: PFUZE100_SW1C: 300 <--> 1875 mV at 1300 mV
- [ 1.279108] print_constraints: PFUZE100_SW2: 800 <--> 3950 mV at 3300 mV
- [ 1.286793] print_constraints: PFUZE100_SW3A: 400 <--> 1975 mV at 1500 mV
- [ 1.294568] print_constraints: PFUZE100_SW3B: 400 <--> 1975 mV at 1500 mV
- [ 1.302293] print_constraints: PFUZE100_SW4: 800 <--> 3950 mV at 3150 mV
- [ 1.309992] print_constraints: PFUZE100_SWBST: 5000 <--> 5150 mV at 5000 mV
- [ 1.317890] print_constraints: PFUZE100_VSNVS: 1200 <--> 3000 mV at 1800 mV
- [ 1.326209] print_constraints: PFUZE100_VREFDDR: at 750 mV
- [ 1.332681] print_constraints: PFUZE100_VGEN1: 800 <--> 1550 mV at 1500 mV
- [ 1.340489] print_constraints: PFUZE100_VGEN2: 800 <--> 1550 mV at 1500 mV
- [ 1.348351] print_constraints: PFUZE100_VGEN3: 1800 <--> 3300 mV at 2800 mV
- [ 1.357145] print_constraints: PFUZE100_VGEN4: 1800 <--> 3300 mV at 1800 mV
- [ 1.365996] print_constraints: PFUZE100_VGEN5: 1800 <--> 3300 mV at 3000 mV
- [ 1.373952] print_constraints: PFUZE100_VGEN6: 1800 <--> 3300 mV at 3300 mV
- [ 1.397183] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
- [ 1.405088] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
- [ 1.411706] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
- [ 1.419526] MIPI CSI2 driver module loaded
- [ 1.424019] Advanced Linux Sound Architecture Driver Version 1.0.24.
- [ 1.431400] Bluetooth: Core ver 2.16
- [ 1.435194] NET: Registered protocol family 31
- [ 1.439805] Bluetooth: HCI device and connection manager initialized
- [ 1.446261] Bluetooth: HCI socket layer initialized
- [ 1.451301] Bluetooth: L2CAP socket layer initialized
- [ 1.456465] Bluetooth: SCO socket layer initialized
- [ 1.461921] i2c-core: driver [max17135] using legacy suspend method
- [ 1.468299] i2c-core: driver [max17135] using legacy resume method
- [ 1.474666] Switching to clocksource mxc_timer1
- [ 1.489614] NET: Registered protocol family 2
- [ 1.494299] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
- [ 1.501905] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
- [ 1.510300] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
- [ 1.518091] TCP: Hash tables configured (established 65536 bind 65536)
- [ 1.524794] TCP reno registered
- [ 1.528023] UDP hash table entries: 256 (order: 1, 8192 bytes)
- [ 1.534045] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
- [ 1.540788] NET: Registered protocol family 1
- [ 1.545670] RPC: Registered named UNIX socket transport module.
- [ 1.551712] RPC: Registered udp transport module.
- [ 1.556567] RPC: Registered tcp transport module.
- [ 1.561383] RPC: Registered tcp NFSv4.1 backchannel transport module.
- [ 1.567982] PCI: CLS 0 bytes, default 32
- [ 1.572141] Unpacking initramfs...
- [ 1.606521] Freeing initrd memory: 488K
- [ 1.611463] PMU: registered new PMU device of type 0
- [ 1.616647] Static Power Management for Freescale i.MX6
- [ 1.622056] wait mode is enabled for i.MX6
- [ 1.626438] cpaddr = d9880000 suspend_iram_base=d9928000
- [ 1.631950] PM driver module loaded
- [ 1.635642] iMX6 PCIe PCIe RC mode imx_pcie_pltfm_probe entering.
- [ 1.749368] PCIE: imx_pcie_pltfm_probe start link up.
- [ 2.360075] link up failed, DB_R0:0x00cec900, DB_R1:0x08200000!
- [ 2.366088] IMX PCIe port: link down with power supply 1!
- [ 2.372088] IMX usb wakeup probe
- [ 2.375483] the wakeup pdata is 0xd46ecea0
- [ 2.380096] add wake up source irq 75
- [ 2.390547] IMX usb wakeup probe
- [ 2.393941] the wakeup pdata is 0xd46ecc20
- [ 2.398669] cpu regulator mode:ldo_bypass
- [ 2.404896] _regulator_get: get() with no identifier
- [ 2.409975] mx6_cpu_regulator_init: failed to get pu regulator
- [ 2.418100] i.MXC CPU frequency driver
- [ 2.432697] highmem bounce pool size: 64 pages
- [ 2.437464] ashmem: initialized
- [ 2.441846] NTFS driver 2.1.30 [Flags: R/O].
- [ 2.446281] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- [ 2.452602] fuse init (API version 7.16)
- [ 2.456865] msgmni has been set to 718
- [ 2.461889] NET: Registered protocol family 38
- [ 2.466551] cryptodev: driver loaded.
- [ 2.470320] io scheduler noop registered
- [ 2.474313] io scheduler deadline registered
- [ 2.478762] io scheduler cfq registered (default)
- [ 2.485048] mxc_mipi_dsi mxc_mipi_dsi: i.MX MIPI DSI driver probed
- [ 2.491464] MIPI DSI driver module loaded
- [ 2.495735] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
- [ 2.502205] _regulator_get: get() with no identifier
- [ 2.507302] mxc_ldb mxc_ldb: change IPU DI1 to IPU DI0 for LDB channel0.
- [ 2.514665] Unable to handle kernel NULL pointer dereference at virtual address 00000000
- [ 2.522890] pgd = c0004000
- [ 2.525662] [00000000] *pgd=00000000
- [ 2.529433] Internal error: Oops: 5 [#1] PREEMPT SMP
- [ 2.534469] Modules linked in:
- [ 2.537663] CPU: 0 Not tainted (3.0.35 #121)
- [ 2.542413] PC is at __wake_up_common+0x28/0x90
- [ 2.547017] LR is at complete+0x48/0x5c
- [ 2.550976] pc : [<c00776bc>] lr : [<c00791b4>] psr: a0000193
- [ 2.550980] sp : d402fc60 ip : 00000000 fp : d402fc8c
- [ 2.562666] r10: 00000003 r9 : 00000000 r8 : 00000000
- [ 2.567965] r7 : d42d0b14 r6 : d42d0b08 r5 : 20000193 r4 : d42d0b0c
- [ 2.574621] r3 : 00000000 r2 : 00000001 r1 : 00000003 r0 : d42d0b0c
- [ 2.581225] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
- [ 2.588753] Control: 10c53c7d Table: 1000404a DAC: 00000015
- [ 2.594571]
- [ 2.594574] PC: 0xc007763c:
- [ 2.599035] 763c e14b22d4 e18060da e0944002 e0a55003 e1b030a9 e1a02068 e14b82d4 e0566004
- [ 2.607934] 765c e0c77005 e18040fc e1580006 e0d99007 e18020f1 bafffff0 e24bd01c e8bd0ff0
- [ 2.616910] 767c e12fff1e e1a01831 eaffffc6 c08f2080 c067a2c8 c0905aa0 e92d4ff0 e28db020
- [ 2.625871] 769c e24dd00c e1a07000 e1a0a001 e50b2028 e1a08003 e5b7c008 e59b9004 e157000c
- [ 2.634823] 76bc e41c400c 0a000015 e244400c e59c5008 e1a0000c e1a03009 e1a0100a e1a02008
- [ 2.643730] 76dc e59c6000 e12fff35 e1a03004 e1a0c004 e3500000 0a000005 e3160001 0a000003
- [ 2.652704] 76fc e51b2028 e2522001 e50b2028 0a000003 e5b3400c e1570003 e244400c 1affffea
- [ 2.661660] 771c e24bd020 e8bd8ff0 e92d4800 e3a0c000 e28db004 e24dd008 e3a02001 e1a0300c
- [ 2.670619]
- [ 2.670622] LR: 0xc0079134:
- [ 2.675033] 9134 e3a01003 e1a0200c e2433106 e5863000 e1a0300c e58dc000 e1a05000 e1a00004
- [ 2.683988] 9154 ebfff94e e1a00004 e1a01005 e24bd010 e8bd4870 ea17fae0 e92d4870 e2804004
- [ 2.692890] 9174 e28db010 e24dd00c e1a06000 e1a00004 eb17fc28 e5963000 e3a0c000 e3a01003
- [ 2.701840] 9194 e2833001 e3a02001 e5863000 e1a0300c e58dc000 e1a05000 e1a00004 ebfff937
- [ 2.710801] 91b4 e1a00004 e1a01005 e24bd010 e8bd4870 ea17fac9 e92d49f0 e2504000 e28db018
- [ 2.719761] 91d4 e24dd00c e1a07001 e1a08002 e1a05003 0a00000d eb17fc0f e2983000 e1a01007
- [ 2.728657] 91f4 e1a02008 13a03001 e58d5000 e1a06000 e1a00004 ebfff921 e1a00004 e1a01006
- [ 2.737614] 9214 e24bd018 e8bd49f0 ea17fab3 e24bd018 e8bd89f0 e52db004 e3a03000 e28db000
- [ 2.746566]
- [ 2.746568] SP: 0xd402fbe0:
- [ 2.750973] fbe0 d402e000 00000101 c0998960 c009c780 c133281c c0927460 60000113 c1332714
- [ 2.759925] fc00 c0927520 0000040f 00000005 d42d0b08 d42d0b14 c004d2d0 d42d0b0c 00000003
- [ 2.768877] fc20 00000001 00000000 d42d0b0c 20000193 d42d0b08 d42d0b14 00000000 00000000
- [ 2.777779] fc40 00000003 d402fc8c 00000000 d402fc60 c00791b4 c00776bc a0000193 ffffffff
- [ 2.786742] fc60 c09067d0 00000001 00000000 d42d0b0c 20000193 d42d0b08 ff7fffff 00000000
- [ 2.795701] fc80 00800000 d402fcc4 d402fcac c00791b4 00000000 c09702d8 00000000 c09f87ac
- [ 2.804592] fca0 00000000 c09f89ec 00001dc8 c02e6214 c02e6204 c047b038 00000001 c09fa684
- [ 2.813534] fcc0 00000001 00000002 00000003 00000004 0000000b 0000000c 0000000d 0000000e
- [ 2.822494]
- [ 2.822496] FP: 0xd402fc0c:
- [ 2.826908] fc0c d42d0b08 d42d0b14 c004d2d0 d42d0b0c 00000003 00000001 00000000 d42d0b0c
- [ 2.835864] fc2c 20000193 d42d0b08 d42d0b14 00000000 00000000 00000003 d402fc8c 00000000
- [ 2.844827] fc4c d402fc60 c00791b4 c00776bc a0000193 ffffffff c09067d0 00000001 00000000
- [ 2.853727] fc6c d42d0b0c 20000193 d42d0b08 ff7fffff 00000000 00800000 d402fcc4 d402fcac
- [ 2.862684] fc8c c00791b4 00000000 c09702d8 00000000 c09f87ac 00000000 c09f89ec 00001dc8
- [ 2.871636] fcac c02e6214 c02e6204 c047b038 00000001 c09fa684 00000001 00000002 00000003
- [ 2.880591] fccc 00000004 0000000b 0000000c 0000000d 0000000e 0000000f 00000000 00000000
- [ 2.889488] fcec d449e1e0 c08f344c 00000026 00000026 00000000 d402e000 d402e000 00000000
- [ 2.898405]
- [ 2.898407] R0: 0xd42d0a8c:
- [ 2.902819] 0a8c 33424752 01000001 00000001 00000000 00000000 00000000 00000000 00000000
- [ 2.911771] 0aac 00000017 00000057 000001ce 00000033 00000000 00000000 00000000 00000000
- [ 2.920728] 0acc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 2.929678] 0aec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000001
- [ 2.938581] 0b0c 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 2.947476] 0b2c 00000000 00000000 00000000 00000000 00000000 00000000 c09f87ac 00000000
- [ 2.956434] 0b4c d442aa80 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 2.965391] 0b6c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 2.974305]
- [ 2.974307] R4: 0xd42d0a8c:
- [ 2.978774] 0a8c 33424752 01000001 00000001 00000000 00000000 00000000 00000000 00000000
- [ 2.987667] 0aac 00000017 00000057 000001ce 00000033 00000000 00000000 00000000 00000000
- [ 2.996560] 0acc 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.005513] 0aec 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000001
- [ 3.014470] 0b0c 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.023369] 0b2c 00000000 00000000 00000000 00000000 00000000 00000000 c09f87ac 00000000
- [ 3.032323] 0b4c d442aa80 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.041277] 0b6c 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.050183]
- [ 3.050185] R6: 0xd42d0a88:
- [ 3.054646] 0a88 00000000 33424752 01000001 00000001 00000000 00000000 00000000 00000000
- [ 3.063600] 0aa8 00000000 00000017 00000057 000001ce 00000033 00000000 00000000 00000000
- [ 3.072502] 0ac8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.081448] 0ae8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.090395] 0b08 00000001 00000001 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.099299] 0b28 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c09f87ac
- [ 3.108245] 0b48 00000000 d442aa80 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.117200] 0b68 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.126156]
- [ 3.126158] R7: 0xd42d0a94:
- [ 3.130572] 0a94 00000001 00000000 00000000 00000000 00000000 00000000 00000017 00000057
- [ 3.139532] 0ab4 000001ce 00000033 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.148425] 0ad4 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.157389] 0af4 00000000 00000000 00000000 00000000 00000000 00000001 00000001 00000000
- [ 3.166349] 0b14 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.175305] 0b34 00000000 00000000 00000000 00000000 c09f87ac 00000000 d442aa80 00000000
- [ 3.184198] 0b54 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.193145] 0b74 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
- [ 3.202045] Process swapper (pid: 1, stack limit = 0xd402e2f0)
- [ 3.207951] Stack: (0xd402fc60 to 0xd4030000)
- [ 3.212435] fc60: c09067d0 00000001 00000000 d42d0b0c 20000193 d42d0b08 ff7fffff 00000000
- [ 3.220695] fc80: 00800000 d402fcc4 d402fcac c00791b4 00000000 c09702d8 00000000 c09f87ac
- [ 3.229011] fca0: 00000000 c09f89ec 00001dc8 c02e6214 c02e6204 c047b038 00000001 c09fa684
- [ 3.237324] fcc0: 00000001 00000002 00000003 00000004 0000000b 0000000c 0000000d 0000000e
- [ 3.245639] fce0: 0000000f 00000000 00000000 d449e1e0 c08f344c 00000026 00000026 00000000
- [ 3.253899] fd00: d402e000 d402e000 00000000 c00d3058 00000001 c0049414 00000000 c08f3400
- [ 3.262211] fd20: 00000003 c08f3400 c08f344c d449e1e0 00000026 00000000 d402e000 00000080
- [ 3.270523] fd40: 33424752 c00d32e0 c08f3400 c08f344c 00000001 c00d56bc c09067d0 c0045dc4
- [ 3.278784] fd60: d402e000 c00d29a4 00000270 c004e1b0 ffffffff f2a00100 00000026 00000001
- [ 3.287043] fd80: 00000000 c004d34c c0911380 60000013 00000000 00000000 c09f87ac 00800000
- [ 3.295356] fda0: c09fa684 60000013 00000000 0000000f 00000080 33424752 00000001 d402fdd0
- [ 3.303673] fdc0: c0481044 c00715e4 60000013 ffffffff d42d0800 d42d0a68 d42d083c c07ee8e8
- [ 3.311933] fde0: d42d0a2c ffffffff d42d0a68 c02e67f4 c07ee8e8 d42d0800 00029500 442a76ec
- [ 3.320248] fe00: 33505349 00474220 50534944 47462033 53494400 42203350 202d2047 00314944
- [ 3.328563] fe20: 00000000 0000003b 00000500 00000320 000036f0 00000046 00000050 00000008
- [ 3.336875] fe40: 0000000d 0000000a 00000002 00000000 00000000 00000020 d417c000 d42d0800
- [ 3.345135] fe60: d42d0a68 c09e10b8 00000000 c02e9830 00000000 c012ceec 000000d0 d417c008
- [ 3.353451] fe80: c132f240 33524742 00000008 00000000 d42d0800 33424752 00000020 c132f240
- [ 3.361764] fea0: 00000000 00000000 d435ef38 d46ee260 d435ef38 c0182608 d40249c0 d435ef38
- [ 3.370027] fec0: d435ef38 00000000 0062646c c0003062 d4020ea8 c018270c d4020ea8 00000000
- [ 3.378340] fee0: d417e278 00000000 d417c008 d417c008 c09f1ad8 c0976cb8 c0932680 00000000
- [ 3.386658] ff00: 00000000 00000000 00000000 c0313fe4 c0313fcc c0312c2c 00000000 00000000
- [ 3.394971] ff20: d417c008 c0932680 d417c03c 00000000 00000000 c0312e98 c0932680 00000000
- [ 3.403236] ff40: c0312e0c c0311c80 d407b4e0 d41465f8 c0932680 c0934940 d46ee260 c0312518
- [ 3.411549] ff60: c07ee8e8 c0932680 c0985aa0 c0932680 c0985aa0 c004e408 c00236a8 00000000
- [ 3.419867] ff80: 00000000 c0313368 d402e000 c0985aa0 c004e408 c00236a8 00000000 c0047640
- [ 3.428179] ffa0: 000001df c00d6748 000001df 00000000 00000000 373494bc 00000039 00000000
- [ 3.436442] ffc0: c0927268 c003a45c c003a914 c004e408 00000013 00000000 00000000 00000000
- [ 3.444757] ffe0: 00000000 c00089a8 00000000 00000000 c000890c c004e408 37ddef7f d9e1fedb
- [ 3.453081] [<c00776bc>] (__wake_up_common+0x28/0x90) from [<c00791b4>] (complete+0x48/0x5c)
- [ 3.461671] [<c00791b4>] (complete+0x48/0x5c) from [<c02e6214>] (mxcfb_irq_handler+0x10/0x18)
- [ 3.470291] [<c02e6214>] (mxcfb_irq_handler+0x10/0x18) from [<c047b038>] (ipu_sync_irq_handler+0x120/0x19c)
- [ 3.480185] [<c047b038>] (ipu_sync_irq_handler+0x120/0x19c) from [<c00d3058>] (handle_irq_event_percpu+0x6c/0x2b8)
- [ 3.490680] [<c00d3058>] (handle_irq_event_percpu+0x6c/0x2b8) from [<c00d32e0>] (handle_irq_event+0x3c/0x5c)
- [ 3.500653] [<c00d32e0>] (handle_irq_event+0x3c/0x5c) from [<c00d56bc>] (handle_fasteoi_irq+0xbc/0x164)
- [ 3.510190] [<c00d56bc>] (handle_fasteoi_irq+0xbc/0x164) from [<c00d29a4>] (generic_handle_irq+0x28/0x3c)
- [ 3.519902] [<c00d29a4>] (generic_handle_irq+0x28/0x3c) from [<c004e1b0>] (handle_IRQ+0x4c/0xac)
- [ 3.528783] [<c004e1b0>] (handle_IRQ+0x4c/0xac) from [<c004d34c>] (__irq_svc+0x4c/0xe8)
- [ 3.536933] [<c004d34c>] (__irq_svc+0x4c/0xe8) from [<c00715e4>] (clk_disable+0x0/0x8c)
- [ 3.545082] [<c00715e4>] (clk_disable+0x0/0x8c) from [<c07ee8e8>] (rfkill_ids+0xdbbf0/0x15f92c)
- [ 3.553919] Code: e1a08003 e5b7c008 e59b9004 e157000c (e41c400c)
- [ 3.560101] ---[ end trace 199f8b1c5287134b ]---
- [ 3.564848] Kernel panic - not syncing: Fatal exception in interrupt
- [ 3.571297] [<c0054fe4>] (unwind_backtrace+0x0/0x138) from [<c067116c>] (panic+0x74/0x194)
- [ 3.579706] [<c067116c>] (panic+0x74/0x194) from [<c0051478>] (die+0x220/0x284)
- [ 3.587104] [<c0051478>] (die+0x220/0x284) from [<c06705e8>] (__do_kernel_fault.part.3+0x54/0x74)
- [ 3.596119] [<c06705e8>] (__do_kernel_fault.part.3+0x54/0x74) from [<c0058d90>] (do_page_fault+0x2cc/0x334)
- [ 3.606007] [<c0058d90>] (do_page_fault+0x2cc/0x334) from [<c0047410>] (do_DataAbort+0x34/0x9c)
- [ 3.614848] [<c0047410>] (do_DataAbort+0x34/0x9c) from [<c004d2d0>] (__dabt_svc+0x70/0xa0)
- [ 3.623249] Exception stack(0xd402fc18 to 0xd402fc60)
- [ 3.628374] fc00: d42d0b0c 00000003
- [ 3.636686] fc20: 00000001 00000000 d42d0b0c 20000193 d42d0b08 d42d0b14 00000000 00000000
- [ 3.645003] fc40: 00000003 d402fc8c 00000000 d402fc60 c00791b4 c00776bc a0000193 ffffffff
- [ 3.653268] [<c004d2d0>] (__dabt_svc+0x70/0xa0) from [<c00776bc>] (__wake_up_common+0x28/0x90)
- [ 3.662019] [<c00776bc>] (__wake_up_common+0x28/0x90) from [<c00791b4>] (complete+0x48/0x5c)
- [ 3.670599] [<c00791b4>] (complete+0x48/0x5c) from [<c02e6214>] (mxcfb_irq_handler+0x10/0x18)
- [ 3.679264] [<c02e6214>] (mxcfb_irq_handler+0x10/0x18) from [<c047b038>] (ipu_sync_irq_handler+0x120/0x19c)
- [ 3.689100] [<c047b038>] (ipu_sync_irq_handler+0x120/0x19c) from [<c00d3058>] (handle_irq_event_percpu+0x6c/0x2b8)
- [ 3.699592] [<c00d3058>] (handle_irq_event_percpu+0x6c/0x2b8) from [<c00d32e0>] (handle_irq_event+0x3c/0x5c)
- [ 3.709563] [<c00d32e0>] (handle_irq_event+0x3c/0x5c) from [<c00d56bc>] (handle_fasteoi_irq+0xbc/0x164)
- [ 3.719099] [<c00d56bc>] (handle_fasteoi_irq+0xbc/0x164) from [<c00d29a4>] (generic_handle_irq+0x28/0x3c)
- [ 3.728808] [<c00d29a4>] (generic_handle_irq+0x28/0x3c) from [<c004e1b0>] (handle_IRQ+0x4c/0xac)
- [ 3.737740] [<c004e1b0>] (handle_IRQ+0x4c/0xac) from [<c004d34c>] (__irq_svc+0x4c/0xe8)
- [ 3.745834] [<c004d34c>] (__irq_svc+0x4c/0xe8) from [<c00715e4>] (clk_disable+0x0/0x8c)
- [ 3.753980] [<c00715e4>] (clk_disable+0x0/0x8c) from [<c07ee8e8>] (rfkill_ids+0xdbbf0/0x15f92c)
- [ 3.762820] CPU1: stopping
- [ 3.765610] [<c0054fe4>] (unwind_backtrace+0x0/0x138) from [<c00473a8>] (do_IPI+0x1d4/0x208)
- [ 3.774189] [<c00473a8>] (do_IPI+0x1d4/0x208) from [<c004d34c>] (__irq_svc+0x4c/0xe8)
- [ 3.782151] Exception stack(0xd4065f90 to 0xd4065fd8)
- [ 3.787276] 5f80: c099a0a8 80000093 00000001 00000000
- [ 3.795591] 5fa0: d4064000 c0985b44 c0905a70 c067ad64 c090e2c4 412fc09a 00000000 00000000
- [ 3.803851] 5fc0: 00000000 d4065fd8 c005d284 c004e468 40000013 ffffffff
- [ 3.810605] [<c004d34c>] (__irq_svc+0x4c/0xe8) from [<c004e468>] (default_idle+0x24/0x28)
- [ 3.818922] [<c004e468>] (default_idle+0x24/0x28) from [<c004e790>] (cpu_idle+0xe0/0x124)
- [ 3.827188] [<c004e790>] (cpu_idle+0xe0/0x124) from [<1066cb94>] (0x1066cb94)
- [ 3.834456] CPU2: stopping
- [ 3.837244] [<c0054fe4>] (unwind_backtrace+0x0/0x138) from [<c00473a8>] (do_IPI+0x1d4/0x208)
- [ 3.845824] [<c00473a8>] (do_IPI+0x1d4/0x208) from [<c004d34c>] (__irq_svc+0x4c/0xe8)
- [ 3.853787] Exception stack(0xd4071f90 to 0xd4071fd8)
- [ 3.858914] 1f80: c099a0a8 60000093 00000001 00000000
- [ 3.867229] 1fa0: d4070000 c0985b44 c0905a70 c067ad64 c090e2c4 412fc09a 00000000 00000000
- [ 3.875541] 1fc0: 00000000 d4071fd8 c005d284 c004e468 40000013 ffffffff
- [ 3.882237] [<c004d34c>] (__irq_svc+0x4c/0xe8) from [<c004e468>] (default_idle+0x24/0x28)
- [ 3.890553] [<c004e468>] (default_idle+0x24/0x28) from [<c004e790>] (cpu_idle+0xe0/0x124)
- [ 3.898869] [<c004e790>] (cpu_idle+0xe0/0x124) from [<1066cb94>] (0x1066cb94)
- [ 3.906083] CPU3: stopping
- [ 3.908923] [<c0054fe4>] (unwind_backtrace+0x0/0x138) from [<c00473a8>] (do_IPI+0x1d4/0x208)
- [ 3.917451] [<c00473a8>] (do_IPI+0x1d4/0x208) from [<c004d34c>] (__irq_svc+0x4c/0xe8)
- [ 3.925414] Exception stack(0xd409bf90 to 0xd409bfd8)
- [ 3.930539] bf80: c099a0a8 60000093 00000001 00000000
- [ 3.938799] bfa0: d409a000 c0985b44 c0905a70 c067ad64 c090e2c4 412fc09a 00000000 00000000
- [ 3.947111] bfc0: 00000000 d409bfd8 c005d284 c004e468 40000013 ffffffff
- [ 3.953862] [<c004d34c>] (__irq_svc+0x4c/0xe8) from [<c004e468>] (default_idle+0x24/0x28)
- [ 3.962125] [<c004e468>] (default_idle+0x24/0x28) from [<c004e790>] (cpu_idle+0xe0/0x124)
- [ 3.970444] [<c004e790>] (cpu_idle+0xe0/0x124) from [<1066cb94>] (0x1066cb94)
复制代码 |
