参考正点原子imx6ull移植了QT5.12和tslib,屏幕触摸屏用8寸电阻屏,跑QT的APP点击按钮有时会连续触发两次,可能是哪里的问题呢请教各位大神。
设备树配置如下
- tsc2046 {
- compatible = "ti,tsc2046";
- reg = <0>;
- spi-max-frequency = <1000000>;
- pinctrl-names ="default";
- pinctrl-0 = <&pinctrl_tsc2046_pendown>;
- interrupt-parent = <&gpio1>;
- interrupts = <9 0>;
- pendown-gpio = <&gpio1 9 0>;
- ti,x-min = /bits/ 16 <0>;
- ti,x-max = /bits/ 16 <0>;
- ti,y-min = /bits/ 16 <0>;
- ti,y-max = /bits/ 16 <0>;
- ti,pressure-max = /bits/ 16 <0>;
- ti,x-plat-ohms = /bits/ 16 <0>;
- ti,debounce-max = /bits/ 16 <50>; /*消抖采样次数最大值,采样消抖超过该值,忽略本次 */
- ti,debounce-tol = /bits/ 16 <50>; /*正负误差范围 */
- ti,debounce-rep = /bits/ 16 <0>;
- /*ti,pendown-gpio-debounce = /bits/ 32 <10>;*/
- /*ti,swap-xy;*/
- linux,wakeup;
ts.conf配置如下
- # Access plugins
- # Uncomment if you wish to use the linux input layer event interface
- module_raw input
- # For other driver modules, see the ts.conf man page
- # Filter plugins
- # Uncomment if first or last samples are unreliable
- module skip nhead=0 ntail=2
- # Uncomment if needed for devices that measure pressure
- #module pthres pmin=1
- module debounce drop_threshold=2
- # Uncomment if needed to filter spikes
- #module median depth=3
- # Uncomment to enable smoothing of fraction N/D
- # module iir N=6 D=10
- module lowpass factor=0.4 threshold=1
- # Uncomment if needed to filter noise samples
- module dejitter delta=100
- # Uncomment to define threshold in number of events from device
- #module evthres N=5
- # Uncomment and adjust if you need to invert an axis or both
- # module invert x0=800 y0=480
- # Uncomment to use ts_calibrate's settings
- module linear
