发表于 2021-2-20 14:45:46
出问题时的,输出的日志如下:
- ets Jun 8 2016 00:22:57
- rst:0x5 (DEEPSLEEP_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
- configsip: 0, SPIWP:0xee
- clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
- mode:DIO, clock div:1
- load:0x3fff0018,len:4
- load:0x3fff001c,len:1044
- load:0x40078000,len:8896
- load:0x40080400,len:5816
- entry 0x400806ac
- System Start up
- Wakeup caused by timer
- ----------DrawTimeUpdata-----------
- HSPI ReInit OK
- 2021/02/20 08:23:02
- Epd UPDATE_PARTIAL_AREA updat start
- Epd UPDATE_PARTIAL_AREA updat Over
- Epd UPDATE_PARTIAL_AREA delay Over
- Sleep time 60
- Setup ESP32 to wakeup after 60 Seconds
- Going to sleep now
- entry 0x400806ac
- System Start up
- HSPI ReInit OK
- 2021/02/20 08:24:02
- Sleep time 59
- Setup ESP32 to wakeup after 59 Seconds
- entry 0x400806ac
- System Start up
- nowMinute%5=0
- Devsn=xxx WIFI AutoConfig Waiting......6
- WIFI SmartConfig Success
- SSID:xxx, PSW:xxx
- LocalIP:192.168.xxx.xxx ,GateIP:192.168.xxx.xxx
- ------------Http_Get_TodoList()-------------
- HTTP Start post
- HTTP post json string is
- "devsn": "xxx",
- "token": "xxx"
- ------------Http_Post()-------------
- HTTP Start post URL is
- [url]http://screenms.yichiot.com/ScreenMSApp/device/todo/list[/url]
- HTTPclient setUp done!
- HTTPclient StartSend
- HTTPclient Return 200
- {"msg": "success", "code": 0, "result": true, "datas": {"count": 0, "list": []}}
- ---------Http_Post()Return----------
- Json to char...
- 200
- ---------Http_Get_TodoList()Return----------
- ------------Http_Get_LeaveMsg()-------------
- HTTP Start post
- "devsn": "xxx",
- "token": "xxx"
- [url]http://screenms.yichiot.com/ScreenMSApp/device/leavemsg/get[/url]
- {"msg": "success", "code": 0, "result": true, "datas": {"leavemsg": "鐣欒█娴嬭瘯", "msgcode": "xxx"}}
- 鐣欒█娴嬭瘯
- xxx
- 200
- ---------Http_Get_LeaveMsg()Return----------
- ----------DrawFullScreen-----------
- HSPI ReInit OK
- Set RTC Buf
- 2021/02/20 08:25:05
- Set SHT Buf
- init SHT
- init(): success
- Error in readSample()
- BAT VOL IS4.097483:
- ScreenSlect=1
- 04 Epd updat Over
- 2021/02/20 08:25:06
- Sleep time 56
- Setup ESP32 to wakeup after 56 Seconds
- entry 0x400806ac
- System Start up
- HSPI ReInit OK
- 2021/02/20 08:26:02
- Sleep time 53
- Setup ESP32 to wakeup after 53 Seconds
- entry 0x400806ac
- System Start up
- HSPI ReInit OK
- 2021/02/20 08:27:02
- Sleep time 60
- entry 0x400806ac
- System Start up
- HSPI ReInit OK
- 2021/02/20 08:28:02
- Sleep time 59
- entry 0x400806ac
- System Start up
- HSPI ReInit OK
- 2021/02/20 08:29:02
- Sleep time 53
