在使用MKV30的时候遇到问题,现在需要使用MKV30的ADC的差分输入功能,到使用DMA来获取数据。在一番折腾之后有问题,
结合SDK以及论坛的帖子写了一个MKV30的ADC的DMA差分输入,debug时候发现可以采集到电压,但是DMA的接收缓存数组g_adc16SampleDataArray[16]只有第一个有数据,后面都是空的。我在主函数循环void DifferentialSample_DC(void)这个函数,ADC_Value是有值的。
可有偿
#include "ADC.h"
* BOARD_InitPeripherals functional group
#define ADC16_RESULT_REG_ADDR 0x4003b010U
#define DEMO_ADC16_SAMPLE_COUNT 16U /* The ADC16 sample count. */
volatile bool g_Transfer_Done = false; /* DMA transfer completion flag. */
edma_transfer_config_t g_transferConfig;
uint32_t g_adc16SampleDataArray[DEMO_ADC16_SAMPLE_COUNT];
* DMA initialization code
static void Edma_Callback(edma_handle_t *handle, void *userData, bool transferDone, uint32_t tcds)
/* Clear Edma interrupt flag. */
EDMA_ClearChannelStatusFlags(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_InterruptFlag);
/* Setup transfer */
EDMA_PrepareTransfer(&g_transferConfig, (void *)ADC16_RESULT_REG_ADDR, sizeof(uint32_t),
(void *)g_adc16SampleDataArray, sizeof(uint32_t), sizeof(uint32_t),
sizeof(g_adc16SampleDataArray), kEDMA_PeripheralToMemory);
EDMA_SetTransferConfig(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, &g_transferConfig, NULL);
/* Enable transfer. */
EDMA_StartTransfer(&DMA_CH1_Handle);
g_Transfer_Done = true;
const edma_config_t DMA_config = {
.enableContinuousLinkMode = false,
.enableHaltOnError = false,
.enableRoundRobinArbitration = false,
.enableDebugMode = false
edma_handle_t DMA_CH1_Handle;
edma_handle_t DMA_CH2_Handle;
void ADC_DMA_init(void) {
/* Channel CH1 initialization */
DMAMUX_Init(DMAMUX);
/* Set the source kDmaRequestMux0ADC0 request in the DMAMUX */
DMAMUX_SetSource(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL, 40);
/* Enable the channel 1 in the DMAMUX */
DMAMUX_EnableChannel(DMA_DMAMUX_BASEADDR, DMA_CH1_DMA_CHANNEL);
/* Create the eDMA DMA_CH1_Handle handle */
EDMA_CreateHandle(&DMA_CH1_Handle, DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL);
void EDMA_Configuration(void)
edma_config_t userConfig;
EDMA_GetDefaultConfig(&userConfig);
EDMA_Init(DMA_DMA_BASEADDR, &userConfig);
EDMA_SetCallback(&DMA_CH1_Handle, Edma_Callback, NULL);
EDMA_SubmitTransfer(&DMA_CH1_Handle, &g_transferConfig);
/* Enable interrupt when transfer is done. */
EDMA_EnableChannelInterrupts(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, kEDMA_MajorInterruptEnable);
#if defined(FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT) && FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT
/* Enable async DMA request. */
EDMA_EnableAsyncRequest(DMA_DMA_BASEADDR, DMA_CH1_DMA_CHANNEL, true);
#endif /* FSL_FEATURE_EDMA_ASYNCHRO_REQUEST_CHANNEL_COUNT */
* ADC0 initialization code
adc16_channel_config_t ADC0_channelsConfig[1] = {
.channelNumber = 1U,
.enableDifferentialConversion = true,
.enableInterruptOnConversionCompleted = true,
const adc16_config_t ADC0_config = {
.referenceVoltageSource = kADC16_ReferenceVoltageSourceVref,
.clock Source = kADC16_Clock SourceAsynchronousClock,
.enableAsynchronousClock = true,
.clockDivider = kADC16_ClockDivider8,
.resolution = kADC16_ResolutionSE16Bit,
.longSampleMode = kADC16_LongSampleDisabled,
.enableHighSpeed = true,
.enableLowPower = false,
.enableContinuousConversion = true
const adc16_channel_mux_mode_t ADC0_muxMode = kADC16_ChannelMuxA;
const adc16_hardware_average_mode_t ADC0_hardwareAverageMode = kADC16_HardwareAverageCount8;
void ADC0_init(void) {
/* Initialize ADC16 converter */
ADC16_Init(ADC0_PERIPHERAL, &ADC0_config);
/* Make sure, that software trigger is used */
ADC16_EnableHardwareTrigger(ADC0_PERIPHERAL, false);
/* Configure hardware average mode */
ADC16_SetHardwareAverage(ADC0_PERIPHERAL, ADC0_hardwareAverageMode);
/* Configure channel multiplexing mode */
ADC16_SetChannelMuxMode(ADC0_PERIPHERAL, ADC0_muxMode);
/* Initialize channel */
ADC16_SetChannelConfig(ADC0_PERIPHERAL, 0U, &ADC0_channelsConfig[0]);
/* Enable DMA. */
ADC16_EnableDMA(ADC0_PERIPHERAL, true);
void ADC_Differential_DC_Channel_Config(void)
ADC0_channelsConfig[0].channelNumber = 0;
ADC0_channelsConfig[0].enableDifferentialConversion =true;
ADC0_channelsConfig[0].enableInterruptOnConversionCompleted = true;
uint32_t ADC_Value = 0;
ADC_Differential_DC_Channel_Config();
// while (0U == (kADC16_ChannelConversionDoneFlag & ADC16_GetChannelStatusFlags(ADC0, 0)))
ADC_Value = ADC16_GetChannelConversionValue(ADC0, 0);
ADC_Value = ADC_Value*3000/4095;
* Initialization functions
void ADC_InitPeripherals(void)
ADC_DMA_init();
EDMA_Configuration();
ADC0_init();
* BOARD_InitBootPeripherals function
void ADC_InitBootPeripherals(void)
ADC_InitPeripherals();
