发表于 2020-10-10 08:38:50
目前深圳IPV4/IPV6 可以同时支持。
但是电脑Win10,尝试设置IPV6,一直失败。 手机可以
貌似是这个原因, 试下:
https://docs.microsoft.com/en-us ... ure-ipv6-in-windows
By default, the 6to4 tunneling protocol is enabled in Windows Vista, Windows Server 2008, or later versions when an interface is assigned a public IPv4 address (that is, an IPv4 address that is not in the ranges 10.0.0.0/8, 172.16.0.0/12, or 192.168.0.0/16). 6to4 automatically assigns an IPv6 address to the 6to4 tunneling interface for each such address that is assigned, and 6to4 dynamically registers these IPv6 addresses on the assigned DNS server. If this behavior is not desired, we recommend that you disable IPv6 tunnel interfaces on the affected hosts.
You can also follow these steps to modify the registry key:
Open an administrative Command Prompt window.
Run the following command:
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters" /v DisabledComponents /t REG_DWORD /d <value> /f
1. 登陆管理者账号
2. 同时按【win键+R】,输入regedit,打开【注册表】
3. 前往【HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip6\Parameters】
4. 找到和双击打开【DisabledComponents】数项,把数值改为0,确认
5. 重启电脑 |
