在开发上位机软件时,每次需要执行一些耗时操作,如下载数据,此时弹出个进度条提示界面来安抚用户狂躁的内心还是有必要的。为了简化此操作,基于 BackgroundWorker做了个简化的小类库。.NET Framwork 版本 4.5
WPF:
Winform:
使用方法
1.导入类库 Winform(AsyncLoadDialog.DLL AsyncLoadBase.dll) WPF(AsyncLoadDialog.WPF.dll AsyncLoadBase.dll)
2.创建一个继承AsyncLoad的方法,实现关键方法 Woker,在Worker 方法中实现你耗时操作,并在适当的时候报告进度,以便进度条更新。
下面是个示例。
class DemoAsyncLoad : AsyncLoad
public override void Worker(object sender, DoWorkEventArgs e)
BackgroundWorker backgroundWorker = sender as BackgroundWorker;
try
Thread.Sleep(1000);
backgroundWorker.ReportProgress(10, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(1000);
backgroundWorker.ReportProgress(20, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(1000);
backgroundWorker.ReportProgress(30, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(1000);
backgroundWorker.ReportProgress(40, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(1000);
//If User Cancel
if (backgroundWorker.CancellationPending)
backgroundWorker.ReportProgress(80, new ProcessResult() { ProcessState = eProcessState.Cancel });
return;
backgroundWorker.ReportProgress(90, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(1000);
backgroundWorker.ReportProgress(100, new ProcessResult() { ProcessState = eProcessState.Working });
Thread.Sleep(500);
//Work Compelete,Return By Set Content And ProcessState eProcessState.Compelete
backgroundWorker.ReportProgress(100, new ProcessResult() { ProcessState = eProcessState.Compelete, Content = "Loaded Data" });
catch
backgroundWorker.ReportProgress(100, new ProcessResult() { ProcessState = eProcessState.Fail, Content = "Error Msg" });
3. 用2中的Class 生成一个对象,把此对象交给AsyncLoadForm,然后ShowDialog弹窗,等待操作结果,如果正常结束,就取AsyncLoadForm的ReturnObj 作为操作的结果。
DemoAsyncLoad normalDemoAsyncLoad = new DemoAsyncLoad();
AsyncLoadForm asyncLoadForm = new AsyncLoadForm(normalDemoAsyncLoad);
asyncLoadForm.StartPosition = FormStartPosition.CenterScreen;
DialogResult res = asyncLoadForm.ShowDialog();
if (res == DialogResult.OK)
object loadedObj = asyncLoadForm.ReturnObj; //
//TODO
//TODO Load Fail
需要注意的几点:
1 进度需要在Worker 中上报,不然进度条没变化。
2.正常结束或者加载资源出现异常时,必须上报,不然弹窗就在那里死等了。
3.关于Cancel,可以在弹窗上点击Cancel,此时弹窗消失,但是有可能此时Worker里面加载资源的操作还没结束,
优雅的结束方式是在Worker 里面做 backgroundWorker.CancellationPending 检测,在适当时间退出。
4.vs2019 开发的,低版本打不开项目文件,但是项目代码较少,自己依据项目结构重建也可以。
库连接
源代码 https://github.com/semonpic/AsyncLoadDialog
