最近搞起了emwin,设计一个类似于苹果ios控制栏上的亮度调节控件,其中用到了圆角矩形。
现在遇到白色部分颜色跟背景色相减变暗了。我想要纯白的,请问程序还需要如何设计?谢谢
- * SEGGER Microcontroller GmbH *
- * Solutions for real time microcontroller applications *
- * C-file generated by: *
- * GUI_Builder for emWin version 5.50 *
- * Compiled Jun 11 2019, 16:51:25 *
- * (c) 2019 Segger Microcontroller GmbH *
- * Internet: www.segger.com Support: support@segger.com *
- // USER START (Optionally insert additional includes)
- #include "my_Anim.h"
- #include "switchWin.h"
- // USER END
- #include "DIALOG.h"
- * Defines
- #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
- // USER START (Optionally insert additional defines)
- // USER END
- * Static data
- // USER START (Optionally insert additional static data)
- // USER END
- * _aDialogCreate
- static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
- { WINDOW_CreateIndirect, "Window_ctrl_", ID_WINDOW_0, 0, 0, 240, 240, 0, 0x0, 0 }
- // USER START (Optionally insert additional widgets)
- // USER END
- * Static code
- // USER START (Optionally insert additional static code)
- extern GUI_CONST_STORAGE GUI_BITMAP bmicon_light;
- // USER END
- #define IMG_BRIGHTNESS_X 11
- #define DRAW_BRIGHTNESS_X 10
- #define DRAW_BRIGHTNESS_Y 187
- #define DRAW_BRIGHTNESS_XSIZE 220+2
- #define DRAW_BRIGHTNESS_YSIZE 40+2
- static int _DrawSkinFlex(const WIDGET_ITEM_DRAW_INFO* pDrawItemInfo) {
- int x;
- int y;
- static int brightnessWidth = 0;
- switch (pDrawItemInfo->Cmd)
- case WIDGET_ITEM_DRAW_THUMB:
- brightnessWidth = pDrawItemInfo->x1;
- return 0;
- case WIDGET_ITEM_DRAW_TICKS:
- return 0;
- case WIDGET_ITEM_DRAW_FOCUS:
- return 0;
- case WIDGET_ITEM_DRAW_SHAFT:
- char str[100];
- snprintf(str, sizeof(str), "x0:%d,y0:%d,x1:%d,y1:%d\r\n", pDrawItemInfo->x0, pDrawItemInfo->y0, pDrawItemInfo->x1, pDrawItemInfo->y1);
- GUI_X_Log(str);
- GUI_SetDrawMode(GUI_DM_NORMAL);
- ////GUI_AA_FillRoundedRect(pDrawItemInfo->x0, pDrawItemInfo->y0, brightnessWidth, pDrawItemInfo->y1, (pDrawItemInfo->y1 - pDrawItemInfo->y0) / 2);
- GUI_FillRect(pDrawItemInfo->x0, pDrawItemInfo->y0, brightnessWidth, pDrawItemInfo->y1);
- GUI_SetDrawMode(GUI_DM_XOR);
- GUI_AA_FillRoundedRect(pDrawItemInfo->x0, pDrawItemInfo->y0, pDrawItemInfo->x1, pDrawItemInfo->y1, (pDrawItemInfo->y1 - pDrawItemInfo->y0) / 2);
- GUI_SetColor(GUI_MAKE_COLOR(0x00343434));
- //GUI_SetColor(GUI_BLACK);
- GUI_AA_FillRoundedRect(pDrawItemInfo->x0, pDrawItemInfo->y0, pDrawItemInfo->x1, pDrawItemInfo->y1, (pDrawItemInfo->y1 - pDrawItemInfo->y0) / 2-2);
- GUI_InvertRect(pDrawItemInfo->x0, pDrawItemInfo->y0, brightnessWidth, pDrawItemInfo->y1);
- //GUI_FillRect(pDrawItemInfo->x0, pDrawItemInfo->y0, brightnessWidth, pDrawItemInfo->y1);
- //GUI_DrawBitmap(&bmicon_light, IMG_BRIGHTNESS_X, pDrawItemInfo->y0);
- return 0;
- default:
- //return SLIDER_DrawSkinFlex(pDrawItemInfo);
- break;
- * _cbDialog
- static void _cbDialog(WM_MESSAGE* pMsg) {
- // USER START (Optionally insert additional variables)
- static WM_HWIN hSlider = NULL;
- int NCode;
- static int Value;
- // USER END
- switch (pMsg->MsgId) {
- case WM_INIT_DIALOG:
- WINDOW_SetBkColor(pMsg->hWin, GUI_BLACK);
- SLIDER_SetDefaultSkin(_DrawSkinFlex);
- hSlider = SLIDER_Create(DRAW_BRIGHTNESS_X, DRAW_BRIGHTNESS_Y, DRAW_BRIGHTNESS_XSIZE, DRAW_BRIGHTNESS_YSIZE, pMsg->hWin, GUI_ID_SLIDER0, WM_CF_SHOW, 0);
- SLIDER_SetWidth(hSlider,0);
- SLIDER_SetRange(hSlider, 0, 100);
- WM_SetFocus(hSlider);
- // USER END
- break;
- case WM_NOTIFY_PARENT:
- NCode = pMsg->Data.v;
- switch (NCode)
- case WM_NOTIFICATION_VALUE_CHANGED:
- Value = SLIDER_GetValue(pMsg->hWinSrc);
- break;
- break;
- // USER START (Optionally insert additional message handling)
- case WM_TOUCH:
- touchSwitchWIn(pMsg, NULL, NULL, CreateWindow_clock_, NULL);
- case WM_PAINT:
- //GUI_SetColor(GUI_MAKE_COLOR(0x00343434));
- //GUI_AA_FillRoundedRect(DRAW_BRIGHTNESS_X, DRAW_BRIGHTNESS_Y, DRAW_BRIGHTNESS_X + DRAW_BRIGHTNESS_XSIZE, DRAW_BRIGHTNESS_Y + DRAW_BRIGHTNESS_YSIZE, DRAW_BRIGHTNESS_YSIZE / 2);
- //GUI_SetColor(GUI_WHITE);
- //GUI_AA_FillRoundedRect(DRAW_BRIGHTNESS_X, DRAW_BRIGHTNESS_Y, DRAW_BRIGHTNESS_X + (DRAW_BRIGHTNESS_XSIZE/100)*Value, DRAW_BRIGHTNESS_Y + DRAW_BRIGHTNESS_YSIZE, DRAW_BRIGHTNESS_YSIZE / 2);
- //GUI_DrawBitmap(&bmicon_light, IMG_BRIGHTNESS_X, IMG_BRIGHTNESS_Y);
- //GUI_SetFont(&GUI_Font13H_ASCII);
- //GUI_GotoXY(0,100);
- //GUI_DispDecMin(Value);
- char str[100];
- snprintf(str, sizeof(str), "Value = %d\r\n", Value);
- GUI_X_Log(str);
- break;
- // USER END
- default:
- WM_DefaultProc(pMsg);
- break;
- * Public code
- * CreateWindow_ctrl_
- WM_HWIN CreateWindow_ctrl_(void);
- WM_HWIN CreateWindow_ctrl_(void) {
- WM_HWIN hWin;
- hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
- WM_DisableWindow(hWin);
- return hWin;
- // USER START (Optionally insert additional public code)
- // USER END
- /*************************** End of file ****************************/
复制代码 |
