回复: 21
请教一阶二阶低通滤波器
发表于 2020-2-19 09:15:25 | 显示全部楼层 |阅读模式
请教一下,这个滤波器的代码在下面,是根据什么公式写出的代码?滤波器是什么类型的滤波器?原理是什么?
typedef struct
        double PrevOut;
        double PrevIn;
        double Frequency;
        double delta;
        double par;
}FIRST_ORDER_FILTER;
typedef struct
        double PreIn1;
        double PreIn2;
        double PreOut1;
        double PreOut2;
        double fWn;
        double fKesai;
        double k, k1, k2, k3, k4, k5, k6;
}SECOND_ORDER_FILTER;
void ResetFirstOrderFilter(FIRST_ORDER_FILTER *pFilter, double Frequency)
        double delta, par;
        delta = 1.0/(2.0*PI*Frequency);
        par = 1.0/(2.0*delta + Ts);
        pFilter->Frequency = Frequency;
        pFilter->delta = delta;
        pFilter->par = par;
        pFilter->PrevIn = 0.0;
        pFilter->PrevOut = 0.0;
void ResetSecondOrderFilter(SECOND_ORDER_FILTER *pFilter, double ffWn, double ffKesai)
        double k;
        pFilter->PreIn1 = 0.0;
        pFilter->PreIn2 = 0.0;
        pFilter->PreOut1 = 0.0;
        pFilter->PreOut2 = 0.0;
        pFilter->fWn = ffWn;
        pFilter->fKesai = ffKesai;
        k = ffWn * ffWn;
        pFilter->k = k;
        pFilter->k1 = 4.0 - 4.0*ffWn*Ts*ffKesai + Ts*Ts*ffWn*ffWn;
        pFilter->k2 = 2.0*Ts*Ts*ffWn*ffWn - 8.0;
        pFilter->k3 = 4.0 + 4.0*ffWn*Ts*ffKesai + Ts*Ts*ffWn*ffWn;
        pFilter->k4 = k*Ts*Ts;
        pFilter->k5 = 2.0*k*Ts*Ts;
        pFilter->k6 = k*Ts*Ts;
double FirstOrderFilterOutput(FIRST_ORDER_FILTER *pFilter, double fIn)
        double fPrevOut, fPrevIn;
        double delt, par;
        double fOut;
        delt = pFilter->delta;
        par = pFilter->par;
        fPrevIn = pFilter->PrevIn;
        fPrevOut = pFilter->PrevOut;
        fOut = par*((2.0*delt - Ts)*fPrevOut + Ts*fPrevIn + Ts*fIn);
        pFilter->PrevIn = fIn;
        pFilter->PrevOut = fOut;
        return fOut;
double SecondOrderFilterOutput(SECOND_ORDER_FILTER *pFilter, double fIn)
        double mfOut;
        mfOut = (pFilter->k4 * pFilter->PreIn2 +
                pFilter->k5 * pFilter->PreIn1 +
                pFilter->k6 * fIn -
                pFilter->k1 * pFilter->PreOut2 -
                pFilter->k2 * pFilter->PreOut1)/pFilter->k3;
        pFilter->PreOut2 = pFilter->PreOut1;
        pFilter->PreOut1 = mfOut;
        pFilter->PreIn2 = pFilter->PreIn1;
        pFilter->PreIn1 = fIn;
        return  mfOut;
出0入10汤圆
发表于 2020-2-19 11:18:50 | 显示全部楼层
我最近在看二阶低通滤波模拟电路,想用FPAG实现。后面又看到FIR滤波器,也可以做低频滤波。
想知道二阶低通滤波和FIR滤波器,哪个好?
发表于 2020-2-19 12:50:06 来自手机 | 显示全部楼层
围观一下,搬凳子
发表于 2020-2-19 13:26:09 | 显示全部楼层
水平不够,关注一下,
 楼主| 发表于 2020-2-23 20:53:03 | 显示全部楼层
没人愿意回答一下吗?
出10入23汤圆
发表于 2020-2-23 21:52:48 | 显示全部楼层
iir滤波器
出105入79汤圆
发表于 2020-2-23 21:53:28 | 显示全部楼层
matlab里面可以直接设计滤波器(低通,高通,带通等), 生成C代码以及代码里面的参数.
出10入23汤圆
发表于 2020-2-23 22:17:09 | 显示全部楼层
出10入23汤圆
发表于 2020-2-23 22:18:58 | 显示全部楼层
楼主位的一阶滤波器就是把模拟的RC一阶滤波器通过双线性变换得到的数字一阶IIR滤波器,转换过程如上图所示
出10入23汤圆
发表于 2020-2-23 22:23:31 | 显示全部楼层
1,先求出滤波器的s域传递函数
2,把s域转换成z域(双线性变换/冲激响应不变法/阶跃响应不变法)
3,把z域方程转换成时域差分方程
4,时域差分方程的本质就是该滤波器的程序代码实现,体现的是out(n)与in(n)  in(n-1) out(n-1)之间的代数关系
出675入8汤圆
发表于 2020-2-24 08:52:24 来自手机 | 显示全部楼层
zouzhichao 发表于 2020-2-23 22:23
1,先求出滤波器的s域传递函数
3,把z域 ...
学习了哦
发表于 2020-2-24 12:30:09 来自手机 | 显示全部楼层
了解一下,不懂。
发表于 2020-2-24 13:23:50 | 显示全部楼层
我X,大神。
最近常感基础不稳……正打算把大学的课程复习一遍。
发表于 2020-2-24 14:03:41 | 显示全部楼层
1,先求出滤波器的s域传递函数
3,把z域 ...
牛!学习了,改天得复习一下了!
 楼主| 发表于 2020-3-6 20:45:53 | 显示全部楼层
谢谢大神回复~
发表于 2020-3-7 14:17:58 | 显示全部楼层
1,先求出滤波器的s域传递函数
3,把z域 ...
讲的很透彻,学习了
出10入23汤圆
发表于 2020-3-7 14:37:37 来自手机 | 显示全部楼层
kms2hh 发表于 2020-3-7 14:17
讲的很透彻,学习了
数字信号处理和计控的基础知识
发表于 2020-3-7 15:35:22 | 显示全部楼层
基础知识,好难的,现在想想主要是老师的问题,我们的教自控的那家伙滔滔不绝,但是从没用过示波器或C代码
推荐几本书
epdf.pub_robert-lacostes-the-darker-side-practical-applicat.pdf
发表于 2020-6-29 11:04:40 | 显示全部楼层
1,先求出滤波器的s域传递函数
3,把z域 ...
这个回复得好详细,学习了,谢谢
出95入100汤圆
发表于 2020-6-29 21:27:18 | 显示全部楼层
用的都是double 这个是matlab自动生成的函数吧。
发表于 2020-6-30 08:28:44 来自手机 | 显示全部楼层
8楼好厉害啊!
出200入657汤圆
发表于 2020-6-30 09:16:43 | 显示全部楼层
第二个也是IIR。
有个疑问:为什么不直接根据截止频率直接计算IIR的系数,设计一个一阶IIR,而要双线性变换,双线性变换有什么好处
GMT+8, 2024-9-28 11:19
