根据《编译器设计之路》中的neopascal实现,书中是用c++实现的。我计划改为go语言版,以下是用go实现的词法分析部分。https://github.com/kekemuyu/neopascal
- package main
- import (
- "fmt"
- "io/ioutil"
- "strconv"
- log "github.com/donnie4w/go-logger/logger"
- "strings"
- type CToken struct {
- m_iKind int
- m_szContent string
- m_iRow int
- var (
- m_szLexTbl [50][130]int
- m_szSource string
- m_szFileName string
- m_KeywordTbl map[string]int
- m_szBuffer string
- m_iRow int
- m_iPos int
- m_iNonterminal int
- m_pTokenList []CToken
- func init() {
- LexInit()
- func LexInit() {
- m_pTokenList = make([]CToken, 0)
- m_KeywordTbl = make(map[string]int)
- SetLexTbl(FileToString("lex.txt"))
- SetKeywords(FileToString("KEYWORDS.txt"))
- // for i := 0; i < 50; i++ {
- // fmt.Println(m_szLexTbl[i])
- // fmt.Println(m_KeywordTbl)
- func main() {
- GetToken(FileToString("test.p"))
- log.Debug(m_pTokenList)
- func FileToString(filename string) string {
- bs, err := ioutil.ReadFile(filename)
- if err != nil {
- fmt.Println(err)
- return ""
- return string(bs)
- func SetLexTbl(szStr string) {
- iTmp := 0
- // szs := strings.TrimSpace(szStr)
- szs := strings.Replace(szStr, "\r\n", "", -1)
- for iRow := 0; iRow <= 36; iRow++ {
- for iCol := 0; iCol <= 128; iCol++ {
- t, _ := strconv.Atoi(szs[iTmp:(iTmp + 3)])
- // fmt.Println(iTmp, iTmp+3, szs[iTmp:(iTmp+3)])
- m_szLexTbl[iRow][iCol] = t
- iTmp = iTmp + 3
- func SetKeywords(szSource string) {
- var szTmp string
- cnt := 0
- for i := 0; i < len(szSource); i++ {
- if szSource[i] != '\n' {
- szTmp += string(szSource[i])
- } else {
- if szTmp != "" {
- m_KeywordTbl[szTmp] = cnt
- szTmp = ""
- cnt++
- if szTmp != "" {
- func GetToken(zsStr string) bool {
- bTag := true
- m_iPos = 0
- zss := zsStr + ""
- m_iRow = 1
- TmpPos := 0
- for (m_iPos < len(zss)) && (bTag) {
- if string(zss[m_iPos]) == "\n" && TmpPos != m_iPos {
- m_iRow++
- TmpPos = m_iRow
- m_szBuffer += string(zss[m_iPos])
- col := zss[m_iPos]
- if zss[m_iPos] >= 128 {
- col = 128
- bTag = Process(m_szLexTbl[m_iNonterminal][col])
- if !bTag {
- fmt.Println(m_iRow, ":", "词法分析错误,请检查单词")
- return false
- m_iPos++
- return bTag
- func Process(iTag int) bool {
- iTmp := 0
- if iTag == -99 {
- return false
- if iTag < 0 {
- // log.Debug(m_szBuffer)
- m_szBuffer = m_szBuffer[:len(m_szBuffer)-1]
- m_iPos--
- m_szBuffer = strings.TrimSpace(m_szBuffer)
- if iTag == -1 {
- m_szBuffer = strings.ToUpper(m_szBuffer)
- if SearchKeyword(m_szBuffer) {
- EmitToken(iTmp+40, "", m_iRow)
- } else {
- if m_szBuffer == "TRUE" || m_szBuffer == "FALSE" {
- EmitToken(3, m_szBuffer, m_iRow)
- } else {
- EmitToken(1, m_szBuffer, m_iRow)
- if iTag >= -6 && iTag <= -2 {
- EmitToken(-iTag, m_szBuffer, m_iRow)
- if iTag >= -15 && iTag <= -7 {
- if iTag >= -28 && iTag <= -16 {
- if iTag == -42 {
- m_szBuffer := m_szBuffer[:len(m_szBuffer)-1]
- m_iPos--
- m_szBuffer = ""
- m_iNonterminal = 0
- } else {
- m_iNonterminal = iTag
- return true
- func SearchKeyword(szKey string) bool {
- if _, ok := m_KeywordTbl[szKey]; ok != true {
- return false
- } else {
- return true
- func EmitToken(iKind int, iContent string, iRow int) {
- ct := CToken{
- m_iKind: iKind,
- m_szContent: iContent,
- m_iRow: iRow,
- m_pTokenList = append(m_pTokenList, ct)
复制代码 |
