demo里只有uart0,1,试过是可以正常收发。但修改成2,3都无法收发。什么原因?官方解疑在哪里?
原版:
* uart.c: UART API file for NXP LPC17xx Family Microprocessors
* Copyright(C) 2009, NXP Semiconductor
* All rights reserved.
* History
* 2009.05.27 ver 1.00 Prelimnary version, first Release
#include "lpc17xx.h"
#include "type.h"
#include "uart.h"
volatile uint32_t UART0Status, UART1Status;
volatile uint8_t UART0TxEmpty = 1, UART1TxEmpty = 1;
volatile uint8_t UART0Buffer[BUFSIZE], UART1Buffer[BUFSIZE];
volatile uint32_t UART0Count = 0, UART1Count = 0;
** Function name: UART0_IRQHandler
** Descriptions: UART0 interrupt handler
** parameters: None
** Returned value: None
void UART0_IRQHandler (void)
uint8_t IIRValue, LSRValue;
uint8_t Dummy = Dummy;
IIRValue = LPC_UART0->IIR;
IIRValue >>= 1; /* skip pending bit in IIR */
IIRValue &= 0x07; /* check bit 1~3, interrupt identification */
if ( IIRValue == IIR_RLS ) /* Receive Line Status */
LSRValue = LPC_UART0->LSR;
if ( LSRValue & (LSR_OE|LSR_PE|LSR_FE|LSR_RXFE|LSR_BI) )
/* There are errors or break interrupt */
/* Read LSR will clear the interrupt */
UART0Status = LSRValue;
Dummy = LPC_UART0->RBR; /* Dummy read on RX to clear
interrupt, then bail out */
return;
if ( LSRValue & LSR_RDR ) /* Receive Data Ready */
/* If no error on RLS, normal ready, save into the data buffer. */
/* Note: read RBR will clear the interrupt */
UART0Buffer[UART0Count] = LPC_UART0->RBR;
UART0Count++;
if ( UART0Count == BUFSIZE )
UART0Count = 0; /* buffer overflow */
else if ( IIRValue == IIR_RDA ) /* Receive Data Available */
UART0Count++;
else if ( IIRValue == IIR_CTI ) /* Character timeout indicator */
/* Character Time-out indicator */
UART0Status |= 0x100; /* Bit 9 as the CTI error */
else if ( IIRValue == IIR_THRE ) /* THRE, transmit holding register empty */
/* THRE interrupt */
LSRValue = LPC_UART0->LSR; /* Check status in the LSR to see if
valid data in U0THR or not */
if ( LSRValue & LSR_THRE )
UART0TxEmpty = 1;
UART0TxEmpty = 0;
** Function name: UART1_IRQHandler
** Descriptions: UART1 interrupt handler
** parameters: None
void UART1_IRQHandler (void)
IIRValue = LPC_UART1->IIR;
LSRValue = LPC_UART1->LSR;
UART1Status = LSRValue;
Dummy = LPC_UART1->RBR; /* Dummy read on RX to clear
return;
UART1Buffer[UART1Count] = LPC_UART1->RBR;
UART1Count++;
if ( UART1Count == BUFSIZE )
UART1Count = 0; /* buffer overflow */
UART1Count++;
UART1Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART1->LSR; /* Check status in the LSR to see if
UART1TxEmpty = 1;
UART1TxEmpty = 0;
** Function name: UARTInit
** Descriptions: Initialize UART port, setup pin select,
** clock, parity, stop bits, FIFO, etc.
** parameters: portNum(0 or 1) and UART baudrate
** Returned value: true or false, return false only if the
** interrupt handler can't be installed to the
** VIC table
uint32_t UARTInit( uint32_t PortNum, uint32_t baudrate )
uint32_t Fdiv;
uint32_t pclkdiv, pclk;
if ( PortNum == 0 )
LPC_PINCON->PINSEL0 &= ~0x000000F0;
LPC_PINCON->PINSEL0 |= 0x00000050; /* RxD0 is P0.3 and TxD0 is P0.2 */
/* By default, the PCLKSELx value is zero, thus, the PCLK for
all the peripherals is 1/4 of the SystemFrequency. */
/* Bit 6~7 is for UART0 */
pclkdiv = (LPC_SC->PCLKSEL0 >> 6) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
pclk = SystemFrequency/4;
case 0x01:
pclk = SystemFrequency;
case 0x02:
pclk = SystemFrequency/2;
case 0x03:
pclk = SystemFrequency/8;
LPC_UART0->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
Fdiv = ( pclk / 16 ) / baudrate ; /*baud rate */
LPC_UART0->DLM = Fdiv / 256;
LPC_UART0->DLL = Fdiv % 256;
LPC_UART0->LCR = 0x03; /* DLAB = 0 */
LPC_UART0->FCR = 0x07; /* Enable and reset TX and RX FIFO. */
NVIC_EnableIRQ(UART0_IRQn);
LPC_UART0->IER = IER_RBR | IER_THRE | IER_RLS; /* Enable UART0 interrupt */
return (TRUE);
else if ( PortNum == 1 )
LPC_PINCON->PINSEL4 &= ~0x0000000F;
LPC_PINCON->PINSEL4 |= 0x0000000A; /* Enable RxD1 P2.1, TxD1 P2.0 */
/* Bit 8,9 are for UART1 */
pclkdiv = (LPC_SC->PCLKSEL0 >> 8) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
case 0x01:
case 0x02:
case 0x03:
LPC_UART1->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
LPC_UART1->DLM = Fdiv / 256;
LPC_UART1->DLL = Fdiv % 256;
LPC_UART1->LCR = 0x03; /* DLAB = 0 */
LPC_UART1->FCR = 0x07; /* Enable and reset TX and RX FIFO. */
NVIC_EnableIRQ(UART1_IRQn);
LPC_UART1->IER = IER_RBR | IER_THRE | IER_RLS; /* Enable UART1 interrupt */
return (TRUE);
return( FALSE );
** Function name: UARTSend
** Descriptions: Send a block of data to the UART 0 port based
** on the data length
** parameters: portNum, buffer pointer, and data length
void UARTSend( uint32_t portNum, uint8_t *BufferPtr, uint32_t Length )
if ( portNum == 0 )
while ( Length != 0 )
/* THRE status, contain valid data */
while ( !(UART0TxEmpty & 0x01) );
LPC_UART0->THR = *BufferPtr;
UART0TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
while ( !(UART1TxEmpty & 0x01) );
LPC_UART1->THR = *BufferPtr;
UART1TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
return;
** End Of File
下面是我修改的:
* History
#include "type.h"
#include "uart.h"
volatile uint32_t UART0Status, UART1Status,UART2Status, UART3Status;
volatile uint8_t UART0TxEmpty = 1, UART1TxEmpty = 1,UART2TxEmpty = 1, UART3TxEmpty = 1;
volatile uint8_t UART0Buffer[BUFSIZE], UART1Buffer[BUFSIZE],UART2Buffer[BUFSIZE], UART3Buffer[BUFSIZE];;
volatile uint32_t UART0Count = 0, UART1Count = 0,UART2Count = 0, UART3Count = 0;;
** parameters: None
return;
UART0Count++;
UART0Count++;
UART0TxEmpty = 1;
UART0TxEmpty = 0;
** parameters: None
return;
UART1Count++;
UART1Count++;
UART1TxEmpty = 1;
UART1TxEmpty = 0;
void UART2_IRQHandler (void)
IIRValue = LPC_UART2->IIR;
LSRValue = LPC_UART2->LSR;
UART2Status = LSRValue;
Dummy = LPC_UART2->RBR; /* Dummy read on RX to clear
return;
UART2Buffer[UART2Count] = LPC_UART2->RBR;
UART2Count++;
if ( UART2Count == BUFSIZE )
UART2Count = 0; /* buffer overflow */
UART2Count++;
UART2Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART2->LSR; /* Check status in the LSR to see if
UART2TxEmpty = 1;
UART2TxEmpty = 0;
void UART3_IRQHandler (void)
IIRValue = LPC_UART3->IIR;
LSRValue = LPC_UART3->LSR;
UART3Status = LSRValue;
Dummy = LPC_UART3->RBR; /* Dummy read on RX to clear
return;
UART3Buffer[UART3Count] = LPC_UART3->RBR;
UART3Count++;
if ( UART3Count == BUFSIZE )
UART3Count = 0; /* buffer overflow */
UART3Count++;
UART3Status |= 0x100; /* Bit 9 as the CTI error */
LSRValue = LPC_UART3->LSR; /* Check status in the LSR to see if
UART3TxEmpty = 1;
UART3TxEmpty = 0;
** VIC table
uint32_t Fdiv;
if ( PortNum == 0 )
switch ( pclkdiv )
case 0x00:
default:
case 0x01:
case 0x02:
case 0x03:
return (TRUE);
switch ( pclkdiv )
case 0x00:
default:
case 0x01:
case 0x02:
case 0x03:
return (TRUE);
else if ( PortNum == 2 )
LPC_PINCON->PINSEL4 &= ~0x000f0000;
LPC_PINCON->PINSEL4 |= 0x000a0000; /* Enable RxD1 P2.9, TxD1 P2.8 */
/* Bit 16,17 are for UART2 */
pclkdiv = (LPC_SC->PCLKSEL1 >> 16) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
case 0x01:
case 0x02:
case 0x03:
LPC_UART2->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
LPC_UART2->DLM = Fdiv / 256;
LPC_UART2->DLL = Fdiv % 256;
LPC_UART2->LCR = 0x03; /* DLAB = 0 */
LPC_UART2->FCR = 0x07; /* Enable and reset TX and RX FIFO. */
NVIC_EnableIRQ(UART2_IRQn);
LPC_UART2->IER = IER_RBR | IER_THRE | IER_RLS; /* Enable UART2 interrupt */
return (TRUE);
else if ( PortNum == 3 )
LPC_PINCON->PINSEL9 &= ~0x0f000000;
LPC_PINCON->PINSEL9 |= 0x0f000000; /* Enable RxD1 P4.29, TxD1 P4.28 */
pclkdiv = (LPC_SC->PCLKSEL1 >> 18) & 0x03;
switch ( pclkdiv )
case 0x00:
default:
case 0x01:
case 0x02:
case 0x03:
LPC_UART3->LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
LPC_UART3->DLM = Fdiv / 256;
LPC_UART3->DLL = Fdiv % 256;
LPC_UART3->LCR = 0x03; /* DLAB = 0 */
LPC_UART3->FCR = 0x07; /* Enable and reset TX and RX FIFO. */
NVIC_EnableIRQ(UART3_IRQn);
LPC_UART3->IER = IER_RBR | IER_THRE | IER_RLS; /* Enable UART2 interrupt */
return (TRUE);
return( FALSE );
if ( portNum == 0 )
BufferPtr++;
Length--;
else if ( portNum == 1 )
BufferPtr++;
Length--;
else if ( portNum == 2 )
while ( !(UART2TxEmpty & 0x01) );
LPC_UART2->THR = *BufferPtr;
UART2TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
while ( !(UART3TxEmpty & 0x01) );
LPC_UART3->THR = *BufferPtr;
UART3TxEmpty = 0; /* not empty in the THR until it shifts out */
BufferPtr++;
Length--;
return;
** End Of File
