发表于 2019-9-12 10:33:56
打开makefsdata 脚本,内容如下:
#!/usr/bin/perl
open(OUTPUT, "> fsdata.c");
chdir("fs");
open(FILES, "find . -type f |");
while($file = <FILES>) {
# Do not include files in CVS directories nor backup files.
if($file =~ /(CVS|~)/) {
next;
chop($file);
open(HEADER, "> /tmp/header") || die $!;
if($file =~ /404/) {
print(HEADER "HTTP/1.0 404 File not found\r\n");
} else {
print(HEADER "HTTP/1.0 200 OK\r\n");
print(HEADER "Server: lwIP/pre-0.6 (http://www.sics.se/~adam/lwip/)\r\n");
if($file =~ /\.html$/) {
print(HEADER "Content-type: text/html\r\n");
} elsif($file =~ /\.gif$/) {
print(HEADER "Content-type: image/gif\r\n");
} elsif($file =~ /\.png$/) {
print(HEADER "Content-type: image/png\r\n");
} elsif($file =~ /\.jpg$/) {
print(HEADER "Content-type: image/jpeg\r\n");
} elsif($file =~ /\.class$/) {
print(HEADER "Content-type: application/octet-stream\r\n");
} elsif($file =~ /\.ram$/) {
print(HEADER "Content-type: audio/x-pn-realaudio\r\n");
} else {
print(HEADER "Content-type: text/plain\r\n");
print(HEADER "\r\n");
close(HEADER);
unless($file =~ /\.plain$/ || $file =~ /cgi/) {
system("cat /tmp/header $file > /tmp/file");
} else {
system("cp $file /tmp/file");
open(FILE, "/tmp/file");
unlink("/tmp/file");
unlink("/tmp/header");
$file =~ s/\.//;
$fvar = $file;
$fvar =~ s-/-_-g;
$fvar =~ s-\.-_-g;
print(OUTPUT "static const unsigned char data".$fvar."[] = {\n");
print(OUTPUT "\t/* $file */\n\t");
for($j = 0; $j < length($file); $j++) {
printf(OUTPUT "%#02x, ", unpack("C", substr($file, $j, 1)));
printf(OUTPUT "0,\n");
$i = 0;
while(read(FILE, $data, 1)) {
if($i == 0) {
print(OUTPUT "\t");
printf(OUTPUT "%#02x, ", unpack("C", $data));
$i++;
if($i == 10) {
print(OUTPUT "\n");
$i = 0;
print(OUTPUT "};\n\n");
close(FILE);
push(@fvars, $fvar);
push(@files, $file);
for($i = 0; $i < @fvars; $i++) {
$file = $files[$i];
$fvar = $fvars[$i];
if($i == 0) {
$prevfile = "NULL";
} else {
$prevfile = "file" . $fvars[$i - 1];
print(OUTPUT "const struct fsdata_file file".$fvar."[] = {{$prevfile, data$fvar, ");
print(OUTPUT "data$fvar + ". (length($file) + 1) .", ");
print(OUTPUT "sizeof(data$fvar) - ". (length($file) + 1) ."}};\n\n");
print(OUTPUT "#define FS_ROOT file$fvars[$i - 1]\n\n");
print(OUTPUT "#define FS_NUMFILES $i\n");
