KiCad EDA 自豪地宣布 KiCad 5 系列最新稳定版发布。5.1.4 稳定版修复了来自 5.1.2 和 5.1.3 版本的关键错误修复和其他一些小改进。它还包括改进的封装库、符号和3D模型库,以及翻译和文档。可以在 KiCad 5.1.3 和 KiCad 5.1.4 里程碑页面上找到自5.1.2和5.1.3 版本以来所有已修复错误的列表 。此版本包含几个关键错误修复,因此请尽快考虑升级。
如果您想知道为什么没有“官方” 5.1.3版本,那么在5.1.3被标记后有一个严重的问题,并且一些用户从KiCad构建服务器下载了未发布的5.1.3版本。防止安装冲突,唯一办法就是创建新的 5.1.4 标签。KiCad项目对此可能造成的任何不便表示歉意。
版本5.1.4是从 lp:kicad / 5.1 分支创建的,其中包含一些来自开发分支的更改。
适用于 Windows,MacOS 和 Linux 的软件包稍后即可使用。有关指导,请参阅 KiCad下载页面。
感谢所有开发人员,打包人员,封装库编写人员,文档编写人员,翻译人员以及帮助实现此版本的所有人。
KiCad EDA 5.1.4 国内下载地址: https://mirrors.tuna.tsinghua.edu.cn/kicad/windows/stable/
开源 KiCad EDA 中文资料收集整理: https://www.cnblogs.com/F4NNIU/p/KiCad.html
原文
KiCad 5.1.4 Release
2019-08-13
The KiCad project is proud to announce the latest series 5 stable release of KiCad. The 5.1.4 stable version contains critical bug fixes and other minor improvements since the 5.1.2 and 5.1.3 releases. It also includes improved footprint, symbol, and 3D model libraries, translations, and documentation. A list of all of the fixed bugs since the 5.1.2 and 5.1.3 releases can be found on the KiCad 5.1.3 milestone page and the KiCad 5.1.4 milestone page. This release contains several critical bug fixes so please consider upgrading as soon as possible.
If you are wondering why there was no "official" 5.1.3 release, there was a serious issue after 5.1.3 was tagged and some users had downloaded the unreleased 5.1.3 builds from the KiCad build server. The only way to prevent install conflicts was to create a new 5.1.4 tag with the bug fix and spin new builds. The KiCad project would like to apologize for any inconvenience this may have caused.
Version 5.1.4 is made from the lp:kicad/5.1 branch with some cherry picked changes from the development branch.
Packages for Windows, MacOS, and Linux are available or will be in the very near future. See the KiCad download page for guidance.
Thank you to all developers, packagers, librarians, document writers, translators, and everyone else who helped make this release possible. |
