RT-Thread 中线程栈溢出检查在 void rt_schedule(void) 函数中,
但是,为什么仅检查了 to_thread,而不是检查 from_thread ?
如果在 from_thread 栈溢出破坏了 to_thread 线程栈,检查 to_thread 栈溢出的时候并不会检查到异常,
但,切换到 to_thread 线程运行的时候,出现了错误,这个时候,定位到的错误在 to_thread,但确实是 from_thread 线程栈溢出导致的,这种情况是不是检查 from_thread 线程栈更加合理?
检查栈溢出的函数如下:
- _rt_scheduler_stack_check(to_thread);
检查线程栈溢出的代码如下:
- if (to_thread != rt_current_thread)
- /* if the destination thread is not the same as current thread */
- rt_current_priority = (rt_uint8_t)highest_ready_priority;
- from_thread = rt_current_thread;
- rt_current_thread = to_thread;
- RT_OBJECT_HOOK_CALL(rt_scheduler_hook, (from_thread, to_thread));
- if (need_insert_from_thread)
- rt_schedule_insert_thread(from_thread);
- rt_schedule_remove_thread(to_thread);
- to_thread->stat = RT_THREAD_RUNNING | (to_thread->stat & ~RT_THREAD_STAT_MASK);
- /* switch to new thread */
- RT_DEBUG_LOG(RT_DEBUG_SCHEDULER,
- ("[%d]switch to priority#%d "
- "thread:%.*s(sp:0x%08x), "
- "from thread:%.*s(sp: 0x%08x)\n",
- rt_interrupt_nest, highest_ready_priority,
- RT_NAME_MAX, to_thread->name, to_thread->sp,
- RT_NAME_MAX, from_thread->name, from_thread->sp));
- #ifdef RT_USING_OVERFLOW_CHECK
- #endif
- if (rt_interrupt_nest == 0)
- extern void rt_thread_handle_sig(rt_bool_t clean_state);
- rt_hw_context_switch((rt_ubase_t)&from_thread->sp,
- (rt_ubase_t)&to_thread->sp);
- /* enable interrupt */
- rt_hw_interrupt_enable(level);
- #ifdef RT_USING_SIGNALS
- /* check signal status */
- rt_thread_handle_sig(RT_TRUE);
- #endif
- goto __exit;
- else
- RT_DEBUG_LOG(RT_DEBUG_SCHEDULER, ("switch in interrupt\n"));
- rt_hw_context_switch_interrupt((rt_ubase_t)&from_thread->sp,
